[General] NCLEX-RN Mock Test & NCLEX-RN Latest Test Simulations
99
【General】 NCLEX-RN Mock Test & NCLEX-RN Latest Test Simulations
Posted at 2/6/2026 23:24:48      View:194 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 NCLEX NCLEX-RN dumps are available on Google Drive shared by TestInsides: https://drive.google.com/open?id=195WFVd2v97UXuez5XWrmrzDLZKpak5VY
The name of these formats are NCLEX NCLEX-RN PDF dumps file, desktop practice test software, and web-based practice test software. All these three NCLEX Cloud NCLEX-RN practice test formats are easy to use and perfectly work with all devices, operating systems, and web browsers. The NCLEX-RN Pdf Dumps file is a simple collection of Real and Updated National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) exam questions in PDF format and it is easy to install and use.
Free demo for NCLEX-RN exam bootcamp is available, and you can have a try before buying, so that you can have a deeper understanding of what you are going to buy. In addition, NCLEX-RN exam materials are high-quality and accuracy, and therefore you can use the exam materials with ease. In order to build up your confidence for NCLEX-RN Exam Dumps, we are pass guarantee and money back guarantee, and if you fail to pass the exam, we will give you full refund. We have online and offline service for NCLEX-RN exam brainudmps, and if you have any questions, you can consult us, and we will give you reply as quickly as we can.
NCLEX-RN Latest Test Simulations | Test NCLEX-RN PrepA NCLEX NCLEX-RN practice questions is a helpful, proven strategy to crack the NCLEX NCLEX-RN exam successfully. It helps candidates to know their weaknesses and overall performance. TestInsides software has hundreds of NCLEX exam dumps that are useful to practice in real time. The National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) practice questions have a close resemblance with the actual NCLEX-RN exam.
NCLEX National Council Licensure Examination(NCLEX-RN) Sample Questions (Q383-Q388):NEW QUESTION # 383
Medication is administered to a client who has been placed in restraints after a sudden violent episode, and his EPSs subside. Restraints can be removed when:
  • A. The nurse deems that removal of restraints is necessary
  • B. The violent behavior subsides, and the client agrees to behave
  • C. The physician orders it
  • D. A therapeutic alliance has been established, and violent behavior subsides
(A) The physicianmayorder release of restraints, but prior to that, the client must meet criteria for release. (B) While the client is still restrained, but after violent behavior has subsided, a therapeutic bridge is built. This alliance encourages dialogue between nurse and client, allowing the client to determine causative factors, feelings prior to loss of control, and adaptive alternatives to violence. (C) If the client only "agrees to behave" after violent behavior subsides, he has developed no insight into cause and effect of violence or his response to stress. (D)Removal of restraints occurs only when the client meets the criteria for release, not just because the nurse says it is necessary.
NEW QUESTION # 384
A cardinal symptom of the schizophrenic client is hallucinations. A nurse identifies this as a problem in the category of:
  • A. Impaired communication
  • B. Altered thought processes
  • C. Sensory-perceptual alterations
  • D. Impaired social interaction
(A) Impaired communication refers to decreased ability or inability to use or understand language in an interaction. (B) In sensory-perceptual alterations an individual has distorted, impaired, or exaggerated responses to incoming stimuli (i.e., a hallucination, which is a false sensory perception that is not associated with real external stimuli). (C) An altered thought processes problem statement is used when an individual experiences a disruption in cognitive operations and activities (i.e., delusions, loose associations, ideas of reference). (D) In impaired social interaction, the individual participates too little or too much in social interactions.
NEW QUESTION # 385
The most frequent cause of early postpartum hemorrhage is:
  • A. Hematoma
  • B. Coagulation disorders
  • C. Uterine atony
  • D. Retained placental fragments
Explanation/Reference:
(A) Hematomas, which are the result of damage to a vessel wall without laceration of the tissue, are a cause, though not the most frequent cause. (B) Coagulation disorders are among the causes of postpartal hemorrhage, but they are less common. (C) The most frequent causes of hemorrhage in the postpartal period are related to an interference with involution of the uterus. Uterine atony is the most frequent cause, occurring in the first 24 hours after delivery. (D) Retained placental fragments are also a cause, although these bleeds usually occur 7-14 days after delivery.
NEW QUESTION # 386
A newborn girl's father expresses concern that the newborn does not have good control of her hands and arms. It is important for the father to realize certain neurological patterns that characterize the newborn:
  • A. Purposeless, uncoordinated movements of the arms are indicative of neurological dysfunction.
  • B. Asymmetrical movement of the extremities is not unusual and will disappear with maturation of the central nervous system.
  • C. Function progresses in a head-to-toe, proximal-distal fashion.
  • D. Mild hypotonia is expected in the upper extremities.
(A) Term neonates are predominantly in a flexed position with strong active muscle tone that increases.
Newborns are slightly hypertonic. (B) Neonatal movements may be jerky and uncoordinated as the neonate works against gravity in contrast to the buoyancy of the amniotic fluid. Jerky movements must be differentiated from the tremors of hypoglycemia, hypocalcemia, and neurological dysfunction. (C) Growth of the newborn progresses in a cephalocaudal, proximal-distal fashion. Knowledge regarding infant development may facilitate parental involvement and infant stimulation. (D) Asymmetrical movements of the extremities are indicative of neurological dysfunction.
NEW QUESTION # 387
A client delivered a stillborn male at term. An appropriate action of the nurse would be to:
  • A. State, "You have an angel in heaven."
  • B. Provide an opportunity for the parents to see and hold the baby for an undetermined amount of time.
  • C. Reassure the parents that they can have other children.
  • D. Discourage the parents from seeing the baby.
(A) This is not a supportive statement. There are also no data to indicate the family's religious beliefs. (B) Seeing their baby assists the parents in the grieving process. This gives them the opportunity to say "good-bye." (C) Parents need time to get to know their baby. (D) This is not a comforting statement when a baby has died. There are also no guarantees that the couple will be able to have another child.
NEW QUESTION # 388
Dreaming to be a certified professional in this line? Our NCLEX-RN study materials are befitting choices. We made real test materials in three accessible formats for your inclinations. (PDF, APP, software). Our website is an excellent platform, which provides the questions of these versions of our NCLEX-RN Exam Questions compiled by experts. By browsing this website, all there versions of our NCLEX-RN pratice engine can be chosen according to your taste or preference.
NCLEX-RN Latest Test Simulations: https://www.testinsides.top/NCLEX-RN-dumps-review.html
You can learn from your National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) practice test mistakes and overcome them before the actual National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) exam, We can claim that if you prapare with our NCLEX-RN exam braindumps for 20 to 30 hours, then you will be confident to pass the exam, Choosing our NCLEX-RN exam quiz will be a wise decision that you make, because this decision may have a great impact in your future development, The latest updated NCLEX-RN Latest Test Simulations - National Council Licensure Examination(NCLEX-RN) latest training material for you is aim the purpose to you can pass the exam 100%.
Then you can better distinguish between the addresses for Test NCLEX-RN Vce Free the APs/servers and the end users, In the perspective of service we stick to "Customer First, Service Foremost".
You can learn from your National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) practice test mistakes and overcome them before the actual National Council Licensure Examination(NCLEX-RN) (NCLEX-RN) exam, We can claim that if you prapare with our NCLEX-RN exam braindumps for 20 to 30 hours, then you will be confident to pass the exam.
Well-known NCLEX-RN Practice Engine Sends You the Best Training Dumps - TestInsidesChoosing our NCLEX-RN exam quiz will be a wise decision that you make, because this decision may have a great impact in your future development, The latest updated National Council Licensure Examination(NCLEX-RN) NCLEX-RN latest training material for you is aim the purpose to you can pass the exam 100%.
High quality with high pass rate.
What's more, part of that TestInsides NCLEX-RN dumps now are free: https://drive.google.com/open?id=195WFVd2v97UXuez5XWrmrzDLZKpak5VY
Posted at 2/8/2026 01:46:17        Only Author  2#
Reading this article has helped me plan for my future work. The 220-1201 mock test questions are shared for free—best of luck in your exams!
Posted at 4/20/2026 04:34:56        Only Author  3#
After reading this article, I have a more in-depth understanding of the related topics. The CMMC-CCP test objectives exam is almost here. Please send me good vibes!
