[General] 71301T Test Questions Fee - 71301T Latest Material
101
【General】 71301T Test Questions Fee - 71301T Latest Material
Posted at 2/7/2026 00:46:03      View:94 | Replies:1        Print      Only Author   [Copy Link] 1#
Preparing for the exam may be not an easy thing for some candidates, if you choose us, we will do the things for you, what you need to do is practicing. We offer you free demo for 71301T training materials, you can have a try before buying. And you will receive the downloading link and password within ten minutes after purchasing the 71301T Exam Dumps. In addition, we have after-service stuff to resolve the confusions you have. If you fail to pass the exam, we are money back guaranteed, or if you have other exam to attend, we can also replace other 2 valid exam dumps for you.
Our 71301T Study Materials are recognized as the standard and authorized study materials and are widely commended at home and abroad. Our 71301T study materials boost superior advantages and the service of our products is perfect. We choose the most useful and typical questions and answers which contain the key points of the test and we try our best to use the least amount of questions and answers to showcase the most significant information.
71301T Latest Material & New 71301T Test ExperienceOur 71301T study materials are famous for instant download, and if you want to start practicing as quickly as possible, you can have a try. After purchasing 71301T exam dumps , you will receive the downloading link and password within ten minutes, and if you don’t receive, just contact us. In addition, 71301T Exam Dumps are high-quality, and they can ensure you pass the exam just one time. We also pass guarantee and money back guarantee if you fail to pass the exam, and money will be returned to your payment account.
Avaya Aura Communication Applications Implement Sample Questions (Q69-Q74):NEW QUESTION # 69
When Avaya Aura Presence Services is implemented, which statement is true about Port Management?
  • A. It collects statistics about Port-Usage from each Presence-compatible endpoint across the network.
  • B. It allows multi-media services over a standard Web-Browser.
  • C. Port 5222 is used for one-X Endpoints, while Port 5269 is open for connecting with other XMPP
    3rd-Party Servers.
  • D. It allows independent management capabilities to filter out undesired message to every Avaya Aura Presence Services user.
Port 5222: XMPP connection configuration
The Connection Manager runs by default when you install the XCP server. It is configured with a JSM Command Processor and two XMPP directors. The XMPP directors handle communication with IM clients. One of the directors is configured to use port 5222 and the other is configured to use port 5223 for secure communications.
Port 5269:Example Obtaining the Server-to-Server Port from an Openfire server Procedure
1. Log in to the Openfire Web console.
2. Click Server > Server Settings > Server to Server.
3. In the Service Enabled section, the Enabled check box should be checked, and the port value is contained in the box to the right of Remote servers can exchange packets with this server on port. By default the value is 5269, and it is recommended that this default value be maintained.
NEW QUESTION # 70
When looking at Avaya Aura System Manager - Hom>t; Service>t; Replication, what is the name of the replica group representing the EDP / Avaya BreezeTM instances?
  • A. Avaya BreezeTM_7.0
  • B. CollaborationEnvironment_3.1
  • C. Engagement Development Platform EDP_7.0
  • D. CollaborationEnvironment_7.0
Confirming that Avaya Breeze successfully replicates with System Manager Procedure
1. On the System Manager web console, navigate to Services > Replication.
2. In Replica Group column, click CollaborationEnvironment_3.1.
3. In Replica Node Host Name column, locate your newly-deployed Avaya Breeze.
4. After 2 - 15 minutes, verify that the status of the Synchronization Status field is green/ Synchronized. If not, see Repairing replication between Avaya BreezeTM and System Manager
NEW QUESTION # 71
What identifies that the Avaya BreezeTM server is using Identity Certificates that have been signed by Avaya Aura System Manager (SMGR)?
  • A. if the Issuer Name states "O=AVAYA, OU=MGMT, CN= System Manager CA" for the Security Module SIP Identity Certificate
  • B. if a successfully installed WebRTC snap-in is used
  • C. if the replication status is showing `Synchronized' with a green background color
  • D. if the Entity Link between Avaya Aura Session Manager (SM) and Avaya BreezeTM server is up
NEW QUESTION # 72
Which four kinds of services does the TSAPI standard provide for third-party call control over Avaya Aura Communication Manager (CM)? (Choose four.)
  • A. completing the routing of incoming calls
  • B. receiving notifications of events
  • C. adding new feature buttons to agent sets
  • D. invoking CM features
  • E. performing a remote reboot to the CM server
  • F. controlling specific calls or stations
Answer: A,B,D,F
A: The services in the Event Report group provide a client application with the reports of events that cause a change in the state of a call, a connection, or a device.
B: The services in the call control group enable a telephony client application to control a call or connection on Communication Manager. Typical uses of these services are: placing calls from a device controlling a connection for a single call.
C: The services in the query group allow a client to query device features and static attributes of a Communication Manager device.
E: The services in the routing group allow Communication Manager to request and receive routing instructions for a call from a client application.
NEW QUESTION # 73
An Avaya Aura Messaging (AAM) server intended to store Voice Messages in Avaya Message Store Mode, and you are configuring that server for integration with an Avaya Aura Core. In Messaging Administration > Server Settings > Server Role/AxC Address, which Server Role must be chosen at the "Roles for this server" field?
  • A. Storage Only
  • B. AMSM
  • C. Application Only
  • D. Storage & Application
NEW QUESTION # 74
All customer information to purchase our 71301T guide torrent is confidential to outsides. You needn’t worry about your privacy information leaked by our company. People who can contact with your name, e-mail, telephone number are all members of the internal corporate. The privacy information provided by you only can be used in online support services and providing professional staff remote assistance. Our experts check whether there is an update on the Avaya Aura Communication Applications Implement exam questions every day, if an update system is sent to the customer automatically. If you have any question about our 71301T Test Guide, you can email or contact us online.
71301T Latest Material: https://www.lead2passexam.com/AVAYA/valid-71301T-exam-dumps.html
We have the professional experts to verify the 71301T exam dumps at times, therefore the correctness can be guaranteed, If you believe that your property appears on this site in a manner that constitutes infringement of your copyright, please do contact us via support@Lead2PassExam 71301T Latest Material.com, Our 71301T Testing Engine will Save your 71301T Exam Score so you can Review it later to improve your results.Saving Your Exam NotesQuestion Selection in Test engine.
Traditional small businesses are also moving 71301T to coworking spaces and over  of all U.S, Join a Project learning community,We have the professional experts to verify the 71301T exam dumps at times, therefore the correctness can be guaranteed.
Fantastic 71301T Test Questions Fee | Easy To Study and Pass Exam at first attempt & The Best Avaya Avaya Aura Communication Applications ImplementIf you believe that your property appears on this site New 71301T Exam Format in a manner that constitutes infringement of your copyright, please do contact us via support@Lead2PassExam.com.
If you choose our 71301T study questions as your study tool, we can promise that we will try our best to enhance the safety guarantees and keep your information from revealing, and your privacy will be protected well.
Every version has their advantages so you 71301T Test Questions Fee can choose the most suitable method of Avaya Aura Communication Applications Implement test guide to prepare the exam.
Posted at 2/14/2026 11:54:43        Only Author  2#
PrüfungFrage wird nicht nur Ihren Wunsch erfüllen, sondern Ihnen einen einjährigen kostenlosen Update-Service und Kundendienst bieten. Die Prüfungsfragen von PrüfungFrage sind alle richtig, die Ihnen beim Bestehen der Salesforce JS-Dev-101 Zertifizierungsprüfung helfen. Im PrüfungFrage können Sie kostenlos einen Teil der Fragen und Antworten zur Salesforce JS-Dev-101 Zertifizierungsprüfung als Probe herunterladen.
