[General] Get 100% Pass Rate FCP_FGT_AD-7.6 Reliable Exam Sims and Pass Exam in First Atte
98
【General】 Get 100% Pass Rate FCP_FGT_AD-7.6 Reliable Exam Sims and Pass Exam in First Atte
Posted at 2/7/2026 01:11:52      View:132 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New FCP_FGT_AD-7.6 dumps are available on Google Drive shared by PassSureExam: https://drive.google.com/open?id=1kX_wdVPKAcsIUTA4OCxSNSt3R73Y96ne
So rest assured that with the PassSureExam FCP_FGT_AD-7.6 exam questions you will get everything that is necessary for FCP_FGT_AD-7.6 exam preparation and success. Take a decision right now and just get registered in the Fortinet FCP_FGT_AD-7.6 certification exam and start preparation with PassSureExam FCP_FGT_AD-7.6 Exam Questions.You do not need to get worried about it choose the right PassSureExam FCP - FortiGate 7.6 Administrator exam questions formats and start this journey without wasting further time.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Topic 5
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
2026 FCP_FGT_AD-7.6 Reliable Exam Sims | Useful 100% Free Latest FCP - FortiGate 7.6 Administrator Test AnswersPassing the FCP_FGT_AD-7.6 exam is your best career opportunity. The rich experience with relevant certificates is important for enterprises to open up a series of professional vacancies for your choices. Our website's FCP_FGT_AD-7.6 learning quiz bank and learning materials look up the Latest FCP_FGT_AD-7.6 Questions and answers based on the topics you choose. This choice will serve as a breakthrough of your entire career, so prepared to be amazed by high quality and accuracy rate of our FCP_FGT_AD-7.6 study guide.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q128-Q133):NEW QUESTION # 128
Which statement about this firewall policy list is true?
  • A. The Implicit group can include more than one deny firewall policy.
  • B. The firewall policies are listed by ID sequence view.
  • C. LAN to WAN, WAN to LAN, and Implicit are sequence grouping view lists.
  • D. The firewall policies are listed by ingress and egress interfaces pairing view.
The firewall policy list shown is displayed in the sequence grouping view, where policies are grouped based on their traffic direction - such as LAN to WAN, WAN to LAN, and Implicit. This view helps administrators quickly identify and manage policies according to their interface pairings and logical traffic flow, rather than by numerical ID order.
NEW QUESTION # 129
A network administrator enabled antivirus and selected an SSL inspection profile on a firewall policy. When downloading an EICAR test file through HTTP, FortiGate detects the virus and blocks the file. When downloading the same file through HTTPS, FortiGate does not detect the virus and does not block the file, allowing it to be downloaded.
The administrator confirms that the traffic matches the configured firewall policy. What are two reasons for the failed virus detection by FortiGate? (Choose two.)
  • A. The browser does not trust the FortiGate self-signed CA certificate.
  • B. The selected SSL inspection profile has certificate inspection enabled.
  • C. The website is exempted from SSL inspection.
  • D. The El CAR test file exceeds the protocol options oversize limit.
NEW QUESTION # 130
An administrator has configured a dialup IPsec VPN on FortiGate with add-route enabled.
However, the static route is not showing in the routing table.
Which two statements about this scenario are correct? (Choose two.)
  • A. The administrator must define the remote network correctly in the phase 2 selectors.
  • B. The administrator must ensure phase 2 is successfully established.
  • C. The administrator must enable a dynamic routing protocol on the dialup interface.
  • D. The administrator must use a policy route instead of a static route for add-route to work properly.
The administrator must ensure phase 2 is successfully established → The static route for the dialup VPN is only added after Phase 2 negotiation completes successfully.
The administrator must define the remote network correctly in the phase 2 selectors → The add- route feature installs a route based on the Phase 2 selectors; if they are incorrect, no route will appear in the routing table.
NEW QUESTION # 131
You are analyzing connectivity problems caused by intermediate devices blocking traffic in SSL VPN environment.
In which two ways can you effectively resolve the problem? (Choose two.)
  • A. You can use SSL VPN tunnel mode to prevent problems with blocked ESP and UDP ports (500 or 4500).
  • B. You should use IPsec to solve issues with fragment drops and large certificate exchanges.
  • C. You can turn off IKE fragmentation to fix large certificate negotiation problems.
  • D. You can configure a hub-and-spoke topology with SSL VPN tunnels to bypass blocked UDP ports.
The training is basically trying to point out the advantage of FortiGate's SSL VPN over IPSec VPN in situation where issues are caused by an intermediate device.
IPsec uses ESP and UDP 500 and 4500, so where these are blocked, SSL VPN tunnel mode shines because it uses HTTPS (443) and TLS by default (both TCP).
Again where UDP ports are blocked, SSL VPN shines (Tunnel mode Hub and Spoke) because it does not use UDP.
NEW QUESTION # 132
You have configured the below commands on a FortiGate.
What would be the impact of this configuration on FortiGate?
  • A. FortiGate will enable strict RPF on all its interfaces and port1 will be exempted from RPF checks.
  • B. Port1 will be enabled with flexible RPF, and all other interfaces will be enabled for strict RPF
  • C. The global configuration will take precedence and FortiGate will enable strict RPF on all interfaces.
  • D. FortiGate will enable strict RPF on ail its interfaces and port1 will be enable for asymmetric routing.
The global setting enables strict source checking (RPF) on all interfaces by default. The per- interface setting disables the source check on port1, exempting it from strict RPF enforcement.
NEW QUESTION # 133
Do you want to pass your exam by using the least time? FCP_FGT_AD-7.6 exam braindumps of us can do that for you. With skilled professionals to compile and verify, FCP_FGT_AD-7.6 exam dumps of us is high quality and accuracy. You just need to spend 48 to 72 hours on practicing, and you can pass your exam. We are pass guaranteed and money back guaranteed. If you fail to pass the exam, we will give you full refund. Besides, we offer you free demo to have a try before buying FCP_FGT_AD-7.6 Exam Dumps. We also have free update for one year after purchasing.
Latest FCP_FGT_AD-7.6 Test Answers: https://www.passsureexam.com/FCP_FGT_AD-7.6-pass4sure-exam-dumps.html
2026 Latest PassSureExam FCP_FGT_AD-7.6 PDF Dumps and FCP_FGT_AD-7.6 Exam Engine Free Share: https://drive.google.com/open?id=1kX_wdVPKAcsIUTA4OCxSNSt3R73Y96ne
