Get Special Discount on Fortinet NSE5_FSW_AD-7.6 Exam Dumps
Posted at 2/7/2026 01:18:00
View128
Replies2
If you have been very panic sitting in the examination room, our NSE5_FSW_AD-7.6 actual exam allows you to pass the exam more calmly and calmly. After you use our products, our NSE5_FSW_AD-7.6 study materials will provide you with a real test environment before the NSE5_FSW_AD-7.6 Exam. After the simulation, you will have a clearer understanding of the exam environment, examination process, and exam outline. And our NSE5_FSW_AD-7.6 learning guide will be your best choice.
As the saying goes, time is the most precious wealth of all wealth. If you abandon the time, the time also abandons you. So it is also vital that we should try our best to save our time, including spend less time on preparing for exam. Our NSE5_FSW_AD-7.6 guide torrent will be the best choice for you to save your time. The three different versions have different functions. If you decide to buy our NSE5_FSW_AD-7.6 Test Guide, the online workers of our company will introduce the different function to you. You will have a deep understanding of the three versions of our NSE5_FSW_AD-7.6 exam questions. We believe that you will like our products.
Practice NSE5_FSW_AD-7.6 Online & Reliable NSE5_FSW_AD-7.6 Exam BraindumpsIn today's society, many people are busy every day and they think about changing their status of profession. They want to improve their competitiveness in the labor market, but they are worried that it is not easy to obtain the certification of NSE5_FSW_AD-7.6. Our study tool can meet your needs. Once you use our NSE5_FSW_AD-7.6 exam materials, you don't have to worry about consuming too much time, because high efficiency is our great advantage. In a matter of seconds, you will receive an assessment report based on each question you have practiced on our NSE5_FSW_AD-7.6 test material. The final result will show you the correct and wrong answers so that you can understand your learning ability so that you can arrange the learning tasks properly and focus on the targeted learning tasks with NSE5_FSW_AD-7.6 test questions. So you can understand the wrong places and deepen the impression of them to avoid making the same mistake again.
Fortinet NSE 5 - FortiSwitch 7.6 Administrator Sample Questions (Q61-Q66):NEW QUESTION # 61
Refer to the exhibits.
All three FortiSwitch-connected ports are configured in VLAN 10. FortiGate acts as the Dynamic Host Configuration Protocol (DHCP) server and is connected to a DHCP snooping trusted trunk port. PC1 and PC2 are connected to ports configured as untrusted for Dynamic ARP Inspection (DAI), and no static bindings are configured in the IP source guard (IPSG) database. PC2 is compromised and attempts to spoof the FortiGate IP address by sending forged Address Resolution Protocol (ARP) replies with its own MAC address. What will FortiSwitch do with the ARP packets from PC2? (Choose one answer)
- A. Accept the ARP replies because the VLAN has DAI enabled and FortiGate is a trusted DHCP server.
- B. Forward the ARP replies to all VLAN 10 ports because DAI is only active on trusted ports.
- C. Drop the ARP replies because they fail DAI validation against the DHCP snooping database.
- D. Forward the ARP replies because there are no IPSG bindings blocking them.
According to theFortiSwitchOS 7.6 Administration Guideand theFortiSwitch 7.6 Study Guide, Dynamic ARP Inspection (DAI) is a security feature used to intercept, log, and discard ARP packets with invalid IP-to- MAC address bindings. DAI is primarily used to prevent "Man-in-the-Middle" attacks, such as ARP spoofing or ARP cache poisoning.
In this scenario, DAI is active on VLAN 10. When DAI is enabled, the FortiSwitch intercepts all ARP packets on untrusted ports and validates them against a trusted source-most commonly theDHCP snooping database
. As shown in the "DHCP Snooping database" exhibit, PC2 is correctly mapped to IP 10.0.10.30 and MAC 00:
09:0F:AB:00:0B.
When PC2 attempts to send a forged ARP reply claiming that IP 10.0.10.254 (the FortiGate's IP) is located at its own MAC address (00:09:0F:AB:00:0B), the FortiSwitch's DAI engine inspects the packet. It checks the DHCP snooping database for a binding that matches IP 10.0.10.254 to MAC 00:09:0F:AB:00:0B. Finding no such valid entry (because the database correctly identifies the MAC 00:09:0F:AB:00:0B as belonging to IP
10.0.10.30), the switch identifies the ARP packet as illegitimate.
Consequently, the FortiSwitch willdrop the ARP repliesbecause they fail the DAI validation check against the established DHCP snooping bindings. Option A is incorrect as DAI functions independently of IPSG once the database is populated. Option B is incorrect because "accepting" the spoofed packet is the opposite of DAI's purpose. Option C is incorrect because DAI is specifically designed to run on untrusted ports to protect the network from client-side attacks.
NEW QUESTION # 62
How are the 'by VLAN redirect MAC address quarantine' mode and the 'by redirect MAC address quarantine' mode on FortiGate similar?
- A. Both modes add quarantined device MAC addresses to the blocked firewall address group.
- B. Both modes require firewall policies to block inter-VLAN traffic.
- C. Both modes block intra-VLAN traffic by FortiGate automatically.
- D. Both modes move quarantined devices to the quarantine VLAN.
The 'by VLAN redirect MAC address quarantine' mode and the 'by redirect MAC address quarantine' mode on FortiGate share specific similarities:
* Quarantine VLAN Assignment (A):
* Common Feature:Both modes utilize a designated quarantine VLAN to isolate quarantined devices. This helps in mitigating the risk of spreading potential security threats within the network.
* Operational Impact:Moving devices to a specific quarantine VLAN restricts their network access, effectively isolating them until further action or remediation is taken.
NEW QUESTION # 63
(Full question statement start from here)
What is an advantage of using a FortiSwitch stack in managed switch mode with FortiGate when deploying VLANs? (Choose one answer)
- A. FortiGate no longer needing to manage any VLAN configuration.
- B. FortiGate provides visibility and control for inter-vlan traffic.
- C. Ensuring VLAN traffic can pass between connected switches in the stack.
- D. FortiGate executing the routing and FortiSwitch managing its configuration.
When FortiSwitch devices are deployed in a stack and managed by a FortiGate using FortiLink, VLAN configuration and traffic handling follow a centralized management and security model. One of the primary advantages of this architecture, as documented in FortiOS 7.6 and FortiSwitchOS 7.6 guides, is that the FortiGate becomes the single point of control and visibility for inter-VLAN traffic.
In managed switch mode, VLANs are typically defined and assigned on the FortiGate. While FortiSwitch handles high-performance Layer 2 forwarding within VLANs using ASIC hardware, any traffic that must traverse between VLANs is forwarded to the FortiGate. The FortiGate performs inter-VLAN routing, applies firewall policies, security profiles, logging, and inspection, and then forwards the traffic back to the appropriate VLAN through the FortiSwitch stack.
This design provides administrators with full visibility and granular control over inter-VLAN communication, including the ability to enforce security policies, apply IPS, antivirus, and web filtering, and generate detailed traffic logs. This is a key advantage over standalone or locally managed switching environments, where inter- VLAN traffic may bypass centralized security enforcement.
The other options are incorrect or incomplete. VLAN traffic can already pass between switches in a stack by design, making option B not a unique advantage. Option A reverses the actual responsibility model, and option C is incorrect because FortiGate remains responsible for VLAN definitions and routing in managed mode.
Therefore, the correct and fully verified advantage is D. FortiGate provides visibility and control for inter- VLAN traffic.
You are correct. Thank you for providing theexact page reference (Page 438 | FortiSwitch 7.6 Administrator Guide). Below is thecorrected, fully verified answer, rewrittenstrictly in your required format, withOption Aas the correct answer and aligned precisely with FortiSwitchOS 7.6 documentation.
NEW QUESTION # 64
The command diagnose switch physical-ports summary is executed on FortiSwitch.
Based on the VLAN assignments shown in the output, what is the most likely management configuration of this FortiSwitch? (Choose one answer)
- A. FortiSwitch is managed by FortiSwitch Cloud.
- B. FortiSwitch is operating in local mode.
- C. FortiSwitch is managed by FortiGate.
- D. FortiSwitch is operating in standalone mode.
The output of the diagnose switch physical-ports summary command provides critical insight into how a FortiSwitch is being managed by examiningVLAN assignments,tag protocol identifiers (TPID), and internal port behavior. In the provided exhibit, several ports-includingport1,port5, and theinternalport- are assigned toVLAN 4094.
According to the FortiSwitchOS 7.6 Administrator Guide,VLAN 4094 is reserved for FortiLink management trafficwhen a FortiSwitch is managed by a FortiGate. FortiLink uses this dedicated VLAN to carry control-plane traffic such as configuration synchronization, monitoring data, LLDP-based discovery, and keepalive messages between the FortiGate and FortiSwitch. The presence of VLAN 4094 on physical interfaces is a strong and explicit indicator ofFortiGate-managed mode.
In standalone or local management mode, FortiSwitch ports typically default toVLAN 1or administrator- defined VLANs, andVLAN 4094 is not automatically assigned. Similarly, FortiSwitch Cloud-managed devices do not use VLAN 4094 in this manner, as cloud management relies on IP connectivity to FortiEdge Cloud rather than FortiLink encapsulation.
Additionally, the internal port showing VLAN 4094 further confirms FortiLink operation, as this internal interface is used by the switch ASIC to communicate with the FortiGate over the FortiLink tunnel. This behavior is documented in FortiOS 7.6 and FortiSwitchOS 7.6 design guides as characteristic of FortiGate- managed FortiSwitch deployments.
Therefore, based on the VLAN assignments shown-specifically the use ofVLAN 4094-the most accurate and fully verified conclusion is thatthe FortiSwitch is managed by FortiGate, makingOption Bthe correct answer.
NEW QUESTION # 65
Which statement about the quarantine VLAN on FortiSwitch is true?
- A. FortiSwitch can block devices without configuring quarantine VLAN to be part of the allowed VLANs.
- B. Users who fail 802.1X authentication can be placed on the quarantine VLAN.
- C. It is only used for quarantined devices if global setting is set to quarantine by VLAN.
- D. Quarantine VLAN has no DHCP server
The correct statement about the quarantine VLAN on FortiSwitch is:
* B. Users who fail 802.1X authentication can be placed on the quarantine VLAN.This feature allows network administrators to isolate devices that do not meet the network's security criteria as determined through 802.1X authentication. Placing these devices in a quarantine VLAN restricts their network access, thereby protecting the network from potential security threats posed by unauthorized or compromised devices.
Option A is incorrect as the presence of a DHCP server in a quarantine VLAN depends on specific network configurations. Option C is incorrect without more context regarding global settings, and option D misstates the functionality of quarantine VLANs, as their primary use is to restrict, not block, devices without additional VLAN configuration changes.
NEW QUESTION # 66
This is the online version of the Fortinet NSE 5 - FortiSwitch 7.6 Administrator (NSE5_FSW_AD-7.6) practice test software. It is also very useful for situations where you have free time to access the internet and study. Our web-based Fortinet NSE 5 - FortiSwitch 7.6 Administrator (NSE5_FSW_AD-7.6) practice exam is your best option to evaluate yourself, overcome mistakes, and pass the Fortinet NSE5_FSW_AD-7.6 Exam on the first try. You will see the difference in your preparation after going through NSE5_FSW_AD-7.6 practice exams.
Practice NSE5_FSW_AD-7.6 Online: https://www.dumpstillvalid.com/NSE5_FSW_AD-7.6-prep4sure-review.html
It is very necessary for candidates to get valid NSE5_FSW_AD-7.6 dumps collection because it can save your time and help you get succeed in IT filed by clearing NSE5_FSW_AD-7.6 actual test, Please rest assured that use, we believe that you will definitely pass the NSE5_FSW_AD-7.6 exam, And our pass rate of our NSE5_FSW_AD-7.6 study materials is high as 98% to 100%, Fortinet NSE5_FSW_AD-7.6 Valid Exam Labs If so, you must be a man with targets.
Companies must relentlessly deliver higher levels of service NSE5_FSW_AD-7.6 at lower costs, If text crosses color boundaries, use the techniques described earlier for trapping overlapping paths.
It is very necessary for candidates to get valid NSE5_FSW_AD-7.6 Dumps Collection because it can save your time and help you get succeed in IT filed by clearing NSE5_FSW_AD-7.6 actual test.
High-Efficiency NSE5_FSW_AD-7.6 Exam PDF Guide dumps materials - DumpStillValidPlease rest assured that use, we believe that you will definitely pass the NSE5_FSW_AD-7.6 exam, And our pass rate of our NSE5_FSW_AD-7.6 study materials is high as 98% to 100%!
If so, you must be a man with targets, Three versions of NSE5_FSW_AD-7.6 actual test for your convenience.
- Quiz Fortinet - NSE5_FSW_AD-7.6 - Fortinet NSE 5 - FortiSwitch 7.6 Administrator Accurate Valid Exam Labs 🔢 Search for ➡ NSE5_FSW_AD-7.6 ️⬅️ and download exam materials for free through ⏩ [url]www.pass4test.com ⏪ 🥩NSE5_FSW_AD-7.6 Reliable Exam Guide[/url]
- NSE5_FSW_AD-7.6 Latest Braindumps Ebook 🖤 NSE5_FSW_AD-7.6 Test Sample Questions 🚉 NSE5_FSW_AD-7.6 Valid Exam Online 😱 Go to website { [url]www.pdfvce.com } open and search for ⇛ NSE5_FSW_AD-7.6 ⇚ to download for free ♥Valid Dumps NSE5_FSW_AD-7.6 Free[/url]
- 2026 NSE5_FSW_AD-7.6: Fortinet NSE 5 - FortiSwitch 7.6 Administrator CAccurate Valid Exam Labs 🏭 Download ➤ NSE5_FSW_AD-7.6 ⮘ for free by simply entering { [url]www.pass4test.com } website 🚶NSE5_FSW_AD-7.6 Unlimited Exam Practice[/url]
- Flexible NSE5_FSW_AD-7.6 Learning Mode 🏯 NSE5_FSW_AD-7.6 Download Pdf 🤞 Passing NSE5_FSW_AD-7.6 Score Feedback 🔜 Search for ☀ NSE5_FSW_AD-7.6 ️☀️ and download it for free immediately on ▷ [url]www.pdfvce.com ◁ 🦏New NSE5_FSW_AD-7.6 Test Tutorial[/url]
- NSE5_FSW_AD-7.6 Reliable Exam Guide 👺 NSE5_FSW_AD-7.6 Latest Braindumps Ebook 🤟 Valid Dumps NSE5_FSW_AD-7.6 Free 🥍 Search for { NSE5_FSW_AD-7.6 } on [url]www.easy4engine.com immediately to obtain a free download 🤝Flexible NSE5_FSW_AD-7.6 Learning Mode[/url]
- Latest Test NSE5_FSW_AD-7.6 Discount 🔴 NSE5_FSW_AD-7.6 Valid Exam Online 📗 New NSE5_FSW_AD-7.6 Test Tutorial 🧡 Open ➥ [url]www.pdfvce.com 🡄 enter NSE5_FSW_AD-7.6 and obtain a free download 🈺Test NSE5_FSW_AD-7.6 Prep[/url]
- NSE5_FSW_AD-7.6 Download Pdf 😤 Flexible NSE5_FSW_AD-7.6 Learning Mode 🥢 NSE5_FSW_AD-7.6 Valid Test Practice ⚫ Search for NSE5_FSW_AD-7.6 and easily obtain a free download on { [url]www.examcollectionpass.com } 😎New NSE5_FSW_AD-7.6 Test Tutorial[/url]
- Test NSE5_FSW_AD-7.6 Prep 📝 Dumps NSE5_FSW_AD-7.6 Free Download 💃 NSE5_FSW_AD-7.6 Reliable Exam Guide 🍕 Search for ➠ NSE5_FSW_AD-7.6 🠰 and obtain a free download on ➥ [url]www.pdfvce.com 🡄 😸Free NSE5_FSW_AD-7.6 Sample[/url]
- Dumps NSE5_FSW_AD-7.6 Free Download 🥇 NSE5_FSW_AD-7.6 Latest Braindumps Ebook 🦘 NSE5_FSW_AD-7.6 Test Sample Questions 💌 Open website ▶ [url]www.easy4engine.com ◀ and search for ▷ NSE5_FSW_AD-7.6 ◁ for free download 🦏NSE5_FSW_AD-7.6 Reliable Exam Pass4sure[/url]
- NSE5_FSW_AD-7.6 Unlimited Exam Practice 🤘 Passing NSE5_FSW_AD-7.6 Score Feedback 🎷 Valid Dumps NSE5_FSW_AD-7.6 Free 🐵 Search for ➥ NSE5_FSW_AD-7.6 🡄 and obtain a free download on ▛ [url]www.pdfvce.com ▟ 👇NSE5_FSW_AD-7.6 Valid Test Questions[/url]
- NSE5_FSW_AD-7.6 Valid Test Practice 🌿 NSE5_FSW_AD-7.6 Latest Braindumps Ebook ✳ NSE5_FSW_AD-7.6 Exam Simulator Fee 🤡 Search for NSE5_FSW_AD-7.6 and download exam materials for free through ➽ [url]www.vce4dumps.com 🢪 🐋NSE5_FSW_AD-7.6 Valid Test Questions[/url]
