[Hardware] Valid Salesforce Salesforce-Certified-Administrator Exam Tips - Exam Salesforce-
96
【Hardware】 Valid Salesforce Salesforce-Certified-Administrator Exam Tips - Exam Salesforce-
Posted at 2/7/2026 02:41:49      View:122 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce Salesforce-Certified-Administrator dumps are available on Google Drive shared by Itcertking: https://drive.google.com/open?id=1mc-3unpCqzFNB1XZsiG3pKj5Y_oQHnwG
Therefore, you have the option to use Salesforce Salesforce-Certified-Administrator PDF questions anywhere and anytime. Itcertking Salesforce Certified Administrator (Salesforce-Certified-Administrator) dumps are designed according to the Salesforce Certified Administrator (Salesforce-Certified-Administrator) certification exam standard and have hundreds of questions similar to the actual Salesforce-Certified-Administrator Exam. Itcertking Salesforce web-based practice exam software also works without installation.
You can use this format of Salesforce Certified Administrator (Salesforce-Certified-Administrator) actual questions on your smart devices. In addition to the Salesforce Certified Administrator (Salesforce-Certified-Administrator) PDF dumps, we also offer Salesforce Certified Administrator (Salesforce-Certified-Administrator) practice exam software. You will find the same ambiance and atmosphere when you attempt the real Salesforce Salesforce-Certified-Administrator exam.
2026 The Best Salesforce-Certified-Administrator – 100% Free Valid Exam Tips | Exam Salesforce Certified Administrator OverviewsAfter you have used our Salesforce-Certified-Administrator learning prep, you will make a more informed judgment. We strongly believe that our Salesforce-Certified-Administrator practice quiz will conquer you. After that, you can choose the version you like. We also provide you with three trial versions of our Salesforce-Certified-Administrator Exam Questions. You can choose one or more versions according to your situation, and everything depends on your own preferences. And you will definitely love our Salesforce-Certified-Administrator training materials.
Salesforce Certified Administrator Sample Questions (Q67-Q72):NEW QUESTION # 67
Users at Universal Containers would like to visually see the sales stages on an Opportunity page. The administrator is configuring path for Opportunities.
Which is an important consideration for path configuration?
  • A. Path can include guidance and key fields for each stage.
  • B. Kanban views for Path must be configured manually.
  • C. The Owner field can be edited in the key fields Panel.
  • D. Celebrations are unable to be added to a path.
Path is a feature that can be used to visually see the sales stages on an opportunity page. Path can include guidance and key fields for each stage to help users move opportunities along the sales process. Guidance can provide tips, policy information, or best practices for each stage. Key fields can display important fields that users need to fill in or update for each stage. References:
https://help.salesforce.com/s/ar ... view.htm&type=5
NEW QUESTION # 68
AW Computing has added a new custom text field called Market Segment on the Lead object. When a Lead is converted, the new field is not getting copied to the Account record.
What should the administrator do to ensure the Market Segment field from a Lead is copied to the converted Account record in routine?
  • A. Write a Validation Rule to ensure the Account has a value in that field.
  • B. Ensure the Market Segment field on the Lead is mapped to right field on Account.
  • C. Write a record-triggered flow to copy the custom field from Lead to Account.
  • D. Ensure Account has a field that has the exact same name as the new Lead field.
To ensure Market Segment field from Lead is copied to converted Account record in routine manner without manual intervention , an administrator should ensure Market Segment field on Lead is mapped to right field on Account using Lead Field Mapping tool under Lead Settings. This tool allows mapping custom fields from Lead object to custom fields on Account , Contact , or Opportunity objects so that data is transferred when leads are converted . For example , an administrator can map Market Segment field on Lead to Market Segment field on Account using this tool . Ensuring Account has a field that has same name as new Lead field
, writing validation rule , or writing record-triggered flow are not necessary for copying custom fields from Lead to Account . References : https :// help . salesforce . com / s / articleView ? id = sf .
leads_custom_field_mapping . htm & type = 5
NEW QUESTION # 69
Clod Kicks has a screen flow with two questions on the same screen, but only one is necessary at a time. The administrator has been asked to show only the questions that is needed.
How should an administrator complete this?
  • A. Use branching in the flowscreen to show the proper scenario
  • B. Use a new version of the flow for each scenario.
  • C. Use a decision element and a new screen to show the proper question
  • D. Use a conditional visibility to hide the unnecessary question
Conditional visibility is a feature that allows administrators to show or hide screen components in a flow based on certain conditions or criteria. For example, conditional visibility can show only one questionon a screen depending on the value of another field or variable. Conditional visibility consists of one or more rules that define when to show or hide a component based on an expression that evaluates to true or false. In this case, the administrator can use conditional visibility to hide the unnecessary question on the screen flow based on the scenario.
References:https://help.salesforce.com/s/ar ... ncmp.htm&type=5
NEW QUESTION # 70
An administrator at Northern Trail Outfitters is creating a validation rule.
Which two functions should the administrator use when creating a validation rule?
Choose 2 answers
  • A. Rule active date
  • B. Error message location
  • C. Formula return type
  • D. Error condition formula
Two functions that an administrator should use when creating a validation rule are:
Error condition formula, which defines when an error should occur based on record fields and values Error message location, which specifies where on the page layout an error message should appear when triggered by an error condition formula Formula return type and rule active date are not functions used for validation rules. References:
NEW QUESTION # 71
Users at Cloud Kicks want to be able to create a task that will repeat every two weeks.
What should an administrator do to meet the requirement?
  • A. Turn on Recurring Activities.
  • B. Enable Creation of Recurring Tasks.
  • C. Workflow rule to create recurring tasks.
  • D. Flow to create recurring tasks.
Recurring tasks are tasks that repeat at regular intervals, such as daily, weekly, monthly, etc. They can be created by users who have the permission to create recurring tasks, which can be enabled by administrators in the user profile settings. Flow, workflow rule, and recurring activities are not valid options for creating recurring tasks in Salesforce. References:
https://help.salesforce.com/s/ar ... ring.htm&type=5
NEW QUESTION # 72
Are there many friends around you have passed Salesforce Salesforce-Certified-Administrator Certification test? How could they have done this? Let Itcertking.com tell you. Itcertking Salesforce Salesforce-Certified-Administrator exam dumps provide you with the most comprehensive information and quality service, which is your unique choice. Don't hesitate. Come on and visit Itcertking.com to know more information. Let us help you pass the exam.
Exam Salesforce-Certified-Administrator Overviews: https://www.itcertking.com/Salesforce-Certified-Administrator_exam.html
thank you very much, Itcertking Exam Salesforce-Certified-Administrator Overviews, With experienced experts to compile and verify Salesforce-Certified-Administrator training materials, the quality can be guaranteed, They sincerely hope that all people who use the Salesforce-Certified-Administrator study materials from our company can pass the exam and get the related certification successfully, Our Salesforce Certified Administrator (Salesforce-Certified-Administrator) exam questions are excellent and ensure that users succeed in one go.
Setting Device Fonts Versus Embedded Fonts, A built-in subwoofer New Salesforce-Certified-Administrator Dumps Ebook eliminates the need for a separate subwoofer elsewhere in your room, and thus results in a cleaner setup.
thank you very much, Itcertking, With experienced experts to compile and verify Salesforce-Certified-Administrator Training Materials, the quality can be guaranteed, They sincerely hope that all people who use the Salesforce-Certified-Administrator study materials from our company can pass the exam and get the related certification successfully.
Authoritative Valid Salesforce-Certified-Administrator Exam Tips, Ensure to pass the Salesforce-Certified-Administrator ExamOur Salesforce Certified Administrator (Salesforce-Certified-Administrator) exam questions are excellent and ensure that users succeed in one go, The software of our Salesforce-Certified-Administrator test torrent provides the statistics Salesforce-Certified-Administrator report function and help the students find the weak links and deal with them.
BTW, DOWNLOAD part of Itcertking Salesforce-Certified-Administrator dumps from Cloud Storage: https://drive.google.com/open?id=1mc-3unpCqzFNB1XZsiG3pKj5Y_oQHnwG
Posted at 2/14/2026 11:52:40        Only Author  2#
Can’t resist liking this great content. Elevate your IT skills and download free Reliable visual C-CPE-2409 cert exam. Wishing you all the best!
