1Z0-1042-25最新考題 & 1Z0-1042-25最新題庫資源
Posted at 2/7/2026 03:03:33
順便提一下,可以從雲存儲中下載VCESoft 1Z0-1042-25考試題庫的完整版:https://drive.google.com/open?id=1BOYSs-Fr-A5m0K5fFGxr_NteP9bl56UP
1Z0-1042-25 考題寶典由 VCESoft 在世界各地的資深IT工程師組成的專業團隊製作完成,Oracle 的 1Z0-1042-25 考題寶典內包含最新的 1Z0-1042-25 考試試題,並附有全部正確答案,保證一次輕鬆通過 1Z0-1042-25 考試,完全無需購買其他額外的1Z0-1042-25 複習資料。並且購買 1Z0-1042-25 考題後,享有一年的免費更新服務。
Oracle 1Z0-1042-25 考試大綱:| 主題 | 簡介 | | 主題 1 | - Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
| | 主題 2 | - Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
| | 主題 3 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
| | 主題 4 | - Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
| | 主題 5 | - Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
最好的的1Z0-1042-25最新考題,全面覆蓋1Z0-1042-25考試知識點既然通過Oracle 1Z0-1042-25 認證考試是不容易的,那麼選擇好的培訓工具就是成功的保證。VCESoft會第一時間為你提供考試資料及考試練習題和答案,讓你為Oracle 1Z0-1042-25 認證考試做好充分的準備,以確保能100%通過Oracle 1Z0-1042-25 認證考試。VCESoft不僅能讓你首次參加Oracle 1Z0-1042-25 認證考試就成功通過,還能幫你節約寶貴的時間。
最新的 Oracle Cloud Infrastructure 1Z0-1042-25 免費考試真題 (Q23-Q28):問題 #23
You need to create an OIC integration that will process many records individually contained within a large file. You have been advised to use an implementation approach that includes using the Download File operation of an FTP adapter in conjunction with the Stage File action's Read File in Segments operation to mitigate issues with memory consumption.
When using this approach, which is a valid consideration regarding the use of the Read File in Segments operation?
- A. The Read File in Segments operation allows you to process the segments sequentially or in parallel.
- B. You will need to explicitly configure a Scope action for this operation if you want to add additional actions during the processing of each segment.
- C. Segment sizes will default to 50 records but can be configured to any other segment size.
- D. You must provide the actual filename because file references cannot be processed by the Read File in Segments operation.
答案:A
解題說明:
The Read File in Segments operation allows you to process file segments sequentially or in parallel, making it an effective method to handle large files without consuming excessive memory.
問題 #24
Your organization maintains two SOA cloud service instances used separately for testing and production. What is the best practice for defining the property values and endpoint addresses unique to each environment when deploying the same SOA composite application archive to both instances?
- A. Manually update any required values for unique properties or endpoint addresses in Fusion Middleware Control following deployment.
- B. Edit each application's deployment descriptor to dynamically retrieve values for properties and endpoint addresses from the environment upon deployment.
- C. You cannot deploy the same archive to two different environments. Define the specific properties and endpoint addresses statically within two separate SOA archives.
- D. Create two separate configuration plans that contain the environment-specific values and then associate the appropriate plan with the SOA archive deployment.
答案:D
解題說明:
Creating two separate configuration plans for each environment is the best practice. This keeps environment-specific details separate from the SOA archive and promotes reusability and maintainability. Other methods are error-prone or inefficient.
問題 #25
Which of the following best exemplifies the concept of HATEOAS (Hypermedia as the Engine of Application State) in RESTful web services?
- A. A client application receives resource representations that include hyperlinks to related resources, enabling dynamic navigation based on the server's responses.
- B. A client application hardcodes all URIs for resource endpoints, allowing it to navigate the API without relying on server responses.
- C. A client application receives a base URI from the server and constructs all subsequent resource URIs by concatenating strings.
- D. A client application pre-fetches all possible resource states and transitions to minimize server interactions.
答案:A
解題說明:
HATEOAS:
B:True-dynamic navigation via hyperlinks.
問題 #26
Which statement is NOT true about Schedule Parameters in Oracle Integration Cloud (OIC) integration flows?
- A. Updates to Schedule Parameter values can be made manually when starting a schedule.
- B. Updates to Schedule Parameter values can be made manually before submitting an ad hoc request.
- C. Schedule Parameters are always visible as an additional data source in the Sources section of the mappers and expression editors within the integration.
- D. Updates to Schedule Parameter values made dynamically in an Assign action will not persist on to the next instance run of the integration.
答案:C
解題說明:
Schedule parameters are not directly visible as data sources in the mapper or expression editors. They are used for dynamic configuration during execution.
問題 #27
In Oracle Integration Cloud (OIC), you are working on an integration that uses a REST trigger, which will require authentication. You need to ensure that only authorized clients can access the integration.
Which configuration should you apply?
- A. Enable Cross-Origin Resource Sharing (CORS) and set an API key in the REST Adapter configuration.
- B. Encrypt the payload using a custom encryption algorithm and provide the decryption key to authorized clients.
- C. Configure the REST Adapter with a Basic Authentication or OAuth 2.0 security policy and provide the required credentials.
- D. Set up an IP whitelist in the OIC instance, allowing only specific IP addresses to access the integration.
答案:C
解題說明:
Configuring Basic Authentication or OAuth 2.0 is the most appropriate and secure method to authenticate clients accessing your OIC integration via a REST trigger.
問題 #28
我受不了現在的生活和工作了,想做別的工作。你現在有這樣的想法嗎?但是,怎樣才能做更好的工作呢?你喜歡IT嗎?想通過IT來證明自己的實力嗎?如果你想從事IT方面的工作,那麼參加IT認定考試,取得認證資格是非常有必要的。你現在要做的就是參加被普遍認可的、有價值的IT資格考試。從而打開你職業生涯的新的大門。關於Oracle的1Z0-1042-25考試,你一定不陌生吧。取得這個資格可以讓你在找工作的時候得到一份助力。什麼?沒有信心參加這個考試嗎?沒關係,你可以使用VCESoft的1Z0-1042-25考試資料。
1Z0-1042-25最新題庫資源: https://www.vcesoft.com/1Z0-1042-25-pdf.html
- 1Z0-1042-25考古題介紹 👞 1Z0-1042-25最新試題 🧹 1Z0-1042-25考古題更新 🦗 來自網站【 tw.fast2test.com 】打開並搜索➥ 1Z0-1042-25 🡄免費下載1Z0-1042-25最新考證
- 1Z0-1042-25考古題更新 ❎ 免費下載1Z0-1042-25考題 🌾 1Z0-1042-25考古題更新 🦳 立即到【 [url]www.newdumpspdf.com 】上搜索➥ 1Z0-1042-25 🡄以獲取免費下載1Z0-1042-25熱門認證[/url]
- 1Z0-1042-25最新考題:最新的Oracle認證1Z0-1042-25考試題庫 🐰 ⇛ [url]www.kaoguti.com ⇚提供免費➽ 1Z0-1042-25 🢪問題收集1Z0-1042-25考題套裝[/url]
- 快速下載的Oracle 1Z0-1042-25:Oracle Cloud Infrastructure 2025 Application Integration Professional最新考題 - 高質量的Newdumpspdf 1Z0-1042-25最新題庫資源 🔮 到⮆ [url]www.newdumpspdf.com ⮄搜尋➤ 1Z0-1042-25 ⮘以獲取免費下載考試資料最新1Z0-1042-25考證[/url]
- 1Z0-1042-25最新考證 🦦 最新1Z0-1042-25考證 🚹 1Z0-1042-25證照指南 🤞 打開「 [url]www.pdfexamdumps.com 」搜尋⮆ 1Z0-1042-25 ⮄以免費下載考試資料1Z0-1042-25考題資源[/url]
- 1Z0-1042-25最新考證 🐡 1Z0-1042-25題庫資訊 🕒 1Z0-1042-25資料 🐸 來自網站⮆ [url]www.newdumpspdf.com ⮄打開並搜索⇛ 1Z0-1042-25 ⇚免費下載1Z0-1042-25熱門認證[/url]
- Oracle 1Z0-1042-25最新考題:Oracle Cloud Infrastructure 2025 Application Integration Professional和資格考試的領導者 🏹 ⮆ [url]www.newdumpspdf.com ⮄是獲取{ 1Z0-1042-25 }免費下載的最佳網站1Z0-1042-25指南[/url]
- 100%專業的1Z0-1042-25最新考題,最好的考試資料幫助妳快速通過1Z0-1042-25考試 ➕ 來自網站➽ [url]www.newdumpspdf.com 🢪打開並搜索⏩ 1Z0-1042-25 ⏪免費下載1Z0-1042-25資料[/url]
- Oracle 1Z0-1042-25最新考題:Oracle Cloud Infrastructure 2025 Application Integration Professional和資格考試的領導者 🩸 在{ tw.fast2test.com }上搜索“ 1Z0-1042-25 ”並獲取免費下載最新1Z0-1042-25考證
- 1Z0-1042-25題庫最新資訊 💔 1Z0-1042-25題庫最新資訊 🥠 免費下載1Z0-1042-25考題 📒 立即打開▛ [url]www.newdumpspdf.com ▟並搜索➽ 1Z0-1042-25 🢪以獲取免費下載1Z0-1042-25資料[/url]
- 免費下載1Z0-1042-25考題 🍽 1Z0-1042-25資料 🧼 最新1Z0-1042-25題庫資源 🔅 進入「 [url]www.newdumpspdf.com 」搜尋☀ 1Z0-1042-25 ️☀️免費下載1Z0-1042-25真題材料[/url]
- www.stes.tyc.edu.tw, www.intensedebate.com, www.fanart-central.net, www.stes.tyc.edu.tw, gifyu.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
