[Hardware] AZ-120 Latest Test Discount, Free AZ-120 Download Pdf
94
Hardware AZ-120 Latest Test Discount, Free AZ-120 Download Pdf
Posted at 2/7/2026 03:07:09      View108 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that PassSureExam AZ-120 dumps now are free: https://drive.google.com/open?id=1Ac_N3Ok9ngoaYQHD2zABzNdh69jr8Kko
All the real AZ-120 questions are included in the Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) PDF Dumps files. This file is compatible with smart devices. The Microsoft PDF Dumps files are portable and printable, allowing candidates to study and prepare for the AZ-120 exam from anywhere, even on smartphones, laptops, and tablets. Moreover, PassSureExam regularly updates its Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) PDF questions format to keep up with the changes in the Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) exam content, ensuring that its Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) exam questions are up-to-date and relevant.
Microsoft AZ-120 Certification Exam is designed to test your proficiency in planning and administering Microsoft Azure for SAP Workloads. AZ-120 exam is intended for IT professionals who have experience in SAP workloads and Azure administration. Planning and Administering Microsoft Azure for SAP Workloads certification will demonstrate your expertise in deploying, managing, and monitoring SAP workloads on Azure.
Benefits of Preparing with the AZ-120This Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) software has a simple-to-use interface. By using the AZ-120 practice exam software, you can evaluate your mistakes at the end of every take and overcome them. Our software helps you to get familiar with the format of the original AZ-120 test. Software lets you customize your Microsoft AZ-120 Practice Exam's duration and question numbers as per your practice needs. You just need an active internet connection to confirm the license of your product. All Windows-based computers support this AZ-120 practice exam software.
The Microsoft AZ-120 Exam is divided into several sections, including planning and configuring Azure infrastructure for SAP workloads, deploying and managing SAP HANA on Azure, and optimizing Azure infrastructure for SAP applications. Candidates will need to demonstrate their ability to configure Azure Virtual Machines, design Azure storage solutions, and manage Azure networking. They will also need to show their knowledge of SAP HANA deployment scenarios, performance optimization techniques, and disaster recovery strategies.
Planning and Administering Microsoft Azure for SAP Workloads Exam Certification Details:
Sample QuestionsPlanning and Administering Microsoft Azure for SAP Workloads Sample Questions
Books / TrainingCourse AZ-120T00-A: Planning and Administering Microsoft Azure for SAP Workloads
Number of Questions40-60
Exam Price$165 (USD)
Exam NameMicrosoft Certified - Azure for SAP Workloads Specialty
Exam CodeAZ-120
Passing Score700 / 1000
Schedule ExamPearson VUE
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q182-Q187):NEW QUESTION # 182
You have an existing on-premises SAP landscape that is hosted on VMware VSphere.
You plan to migrate the landscape to Azure.
You configure the Azure Site Recovery replication policy shown in the following exhibit.
Answer selected as in image below.
NEW QUESTION # 183
You have an on-premises deployment of SAP Business Suite on HANA that includes a CPU-intensive application tier and a 20-TB database tier.
You plan to migrate to SAP HANA on Azure.
You need to recommend a compute option to host the application and database tiers. The solution must minimize cost.
What should you recommend for each tier? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
Text Description automatically generated
Box 1: Ev3 series M Azure virtual machines
The Ev3 series pricing is starting from $58.40 /per month.
The E-series Azure VMs are optimized for heavy in-memory applications such as SAP HANA. These VMs are configured with high memory-to-core ratios, which makes them well-suited for memory-intensive enterprise applications, large relational database servers, in-memory analytics workloads etc.
The Ev3-series VMs range from 2 to 64 vCPUs and 16-432 GiB of RAM, respectively.
Example workloads include SAP HANA (e.g., E64s v3, E20ds v4, E32ds v4, E48ds v4, E64ds v4), SAP S/4 HANA application layer, SAP NetWeaver application layer, and more broadly memory-intensive enterprise applications, large relational database servers, data warehousing workloads, business intelligence applications, in-memory analytics workloads, and additional business-critical applications, including systems that process financial transactions of various nature...
Note: The M-series family of Azure virtual machines are memory optimized and are ideal for heavy in-memory workloads such as SAP HANA. The M-Series offer up to 4 TB of RAM on a single VM. In addition, these VMs offer a virtual CPU count of up to 128 vCPUs on a single VM to enable high performance parallel processing.
Example workloads include SAP HANA, SAP S/4 HANA, SQL Hekaton and other large in-memory business critical workloads requiring massive parallel compute power.
Box 2: Hana on Azure (Large Instances)
The storage used in HANA Large Instances has a file size limitation. The size limitation is 16 TB per file.
https://docs.microsoft.com/en-us ... torage-architecture
https://azure.microsoft.com/en-u ... al-machines/series/
NEW QUESTION # 184
You need to provide the Azure administrator with the values to complete the Azure Resource Manager template.
Which values should you provide for diskCount, StorageAccountType, and domainName? To answer, select the appropriate options in the answer area.
Box 1: 4
Scenario: the Azure Resource Manager template that will be used to provision the production application servers.
Ensure that each production application server has four 1-TB data disks.
Box 2: Standard_LRS
Scenario: Minimize costs whenever possible.
Box 3: contoso.onmicrosoft.com
The network contains an on-premises Active Directory domain named ad.contoso.com.
The Initial domain: The default domain (onmicrosoft.com) in the Azure AD Tenant. For example, contoso.
onmicrosoft.com.
https://docs.microsoft.com/en-us ... t-userprincipalname
NEW QUESTION # 185
You plan to deploy SAP HANA to an Azure virtual machine that has a constrained vCPU size.
You need to validate that the virtual machine complies with SAP-defined resource requirements by using the SAP HANA Hardware and Cloud Measurement Tools (HCMT).
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
Table Description automatically generated with low confidence
NEW QUESTION # 186
You have an SAP environment on Azure.
You use Azure Recovery Services to back up an SAP application server.
You need to test the restoration process of a file on the server.
1 - From Azure Recover Vault, select File Recovery
2 - Download and run the mount disk executable
3 - recover the file and unmount the disk
NEW QUESTION # 187
Free AZ-120 Download Pdf: https://www.passsureexam.com/AZ-120-pass4sure-exam-dumps.html
BONUS!!! Download part of PassSureExam AZ-120 dumps for free: https://drive.google.com/open?id=1Ac_N3Ok9ngoaYQHD2zABzNdh69jr8Kko
