[General] Valid Exam Integration-Architect Blueprint | New Integration-Architect Real Test
【General】 Valid Exam Integration-Architect Blueprint | New Integration-Architect Real Test
Posted at 2/7/2026 03:25:09      View:79 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest TestPassKing Integration-Architect PDF Dumps and Integration-Architect Exam Engine Free Share: https://drive.google.com/open?id=1q94jkdg_dQiNypZSpIkYhsf3RQ-AxAfF
Sharp tools make good work. Valid Integration-Architect test questions and answers will make your exam easily. If you still feel difficult in passing exam, our products are suitable for you. Integration-Architect test questions and answers are worked out by TestPassKing professional experts who have more than 8 years in this field. With so many years' development, we can keep stable high passing rate for Salesforce Integration-Architect Exam. You will only spend dozens of money and 20-30 hours' preparation on our Integration-Architect test questions, passing exam is easy for you.
TestPassKing is constantly updated in accordance with the changing requirements of the Salesforce certification. We arrange the experts to check the update every day, if there is any update about the Integration-Architect pdf vce, the latest information will be added into the Integration-Architect exam dumps, and the useless questions will be remove of it to relief the stress for preparation. Al the effort our experts have done is to ensure the high quality of the Integration-Architect Study Material. You will get your Integration-Architect certification with little time and energy by the help of out dumps.
New Salesforce Integration-Architect Real Test & Valid Integration-Architect Exam LabsIf you want to get certified, you should use the most recent Salesforce Integration-Architect practice test. These Real Integration-Architect Questions might assist you in passing this difficult test quickly because of how busy life routine is. Stop wasting more time. With real Salesforce Integration-Architect Dumps PDF, desktop practice test software, and a web-based practice test, TestPassKing is here to help.
Salesforce Certified Integration Architect Sample Questions (Q117-Q122):NEW QUESTION # 117
Northern Trail Outfitters is planning to perform nightly batch loads into Salesforce from an external system with a custom Java application using the Bulk API. The CIO is curious about monitoring recommendations for the jobs from the technical architect. Which recommendation should help meet the requirements?
  • A. Set the Salesforce debug logs level to "finest", and add the user ID running the job to monitor in the
    "Debug Logs" in the setup menu.
  • B. Use the getBatchInfo method in the Java application to monitor the status of the jobs from the Java application.
  • C. Write the error response from the Bulk API status to a custom error logging object in Salesforce using an Apex trigger, and create reports on the object.
For high-volume data loads using the Bulk API, monitoring should be performed programmatically by the orchestrating client-in this case, the custom Java application. The Bulk API is asynchronous, meaning that when you submit a job, Salesforce acknowledges the request and processes it in the background.
The Java application must actively track the state of its own jobs. Using the `getBatchInfo` (or `getJobInfo` in Bulk API 2.0) method allows the application to retrieve the real-time status of each batch. The application can check for statuses such as `Queued`, `InProgress`, `Completed`, or `Failed`. Once a batch is marked as
`Completed`, the application can then call `getBatchResult` to retrieve a list of successes and failures for individual records.
Option B is architecturally unsound because Bulk API operations are designed to bypass most synchronous Apex logic to ensure performance; furthermore, creating custom records for every error in a "nightly batch load" would likely hit other platform limits (like storage or CPU) and defeat the purpose of using the Bulk API. Option C is ineffective for Bulk API monitoring, as debug logs do not capture the background processing of bulk batches and would quickly hit the log size limits.
By recommending Option A, the architect ensures that the Java application maintains full control over the integration lifecycle. The application can log errors locally, implement automated retries for transient failures, and provide the CIO with accurate, high-level reporting on the success rate of the nightly loads without placing unnecessary overhead on the Salesforce platform.
NEW QUESTION # 118
Which three considerations should an Integration Architect consider when recommending Platform Event as a Integration solution?
Choose 3 answers
  • A. Inability to query event messages using SOQL
  • B. Inability to create a Lightning record page for platform events.
  • C. You can use Event Monitoring to track user activity, such as logins and running reports.
  • D. When you delete an event definition, it's permanently removed and can't be restored.
  • E. Subscribe to an AssetToken Event stream to monitor OAuth 2.0 authentication activity. C
Answer: A,B,D
NEW QUESTION # 119
A call center manager uses a custom dashboard to track Case related metrics. The manager wants a component to display the number of closed Cases in real time.
What type of event should be used to meet this requirement?
  • A. Change Data Capture Event
  • B. Platform Event
  • C. Push Topic Event
  • D. Generic Event
https://developer.salesforce.com ... ic_events_intro.htm
NEW QUESTION # 120
Northern Trail Outfitters (NTO) is looking to integrate three external systems that run nightly data enrichment processes in Salesforce. NTO has both of the following security and strict auditing requirements:
1. The external systems must follow the principle of least privilege, and
2. The activities of the eternal systems must be available for audit.
What should an Integration Architect recommend as a solution for these integrations?
  • A. A shared integration user for the three external system integrations.
  • B. A shared Connected App for the three external system integrations.
  • C. A Connected App for each external system integration.
  • D. A unique integration user for each external system integration.
Using a Connected App for each external system integration is a good solution because it can provide security, auditing, and monitoring features for each integration. A Connected App is an application that can connect to Salesforce using APIs and OAuth as an authentication protocol. A Connected App can also enforce policies such as IP restrictions, login hours, and session timeout for each integration. Using a shared integration user for the three external system integrations is not a good solution because it violates the principle of least privilege, as well as makes it difficult to audit the activities of each system. Using a shared Connected App for the three external system integrations is also not a good solution because it does not allow for granular control and visibility of each integration. Using a unique integration user for each external system integration is not enough to meet the security and auditing requirements, as it does not provide any mechanism for authentication, authorization, or encryption. Reference: Salesforce Integration Architecture Designer Resource Guide, page 20-21
NEW QUESTION # 121
Northern Trail Outfitters submits orders to the manufacturing system web-service. Recently, the system has experienced outages that keeping service unavailable for several days.
What solution should an architect recommend to handle errors during these types of service outages?
  • A. Use @future jobld and custom scheduled apex process to retry failed service calls.
  • B. Use Outbound Messaging to automatically retry failed service calls.
  • C. Use middleware queuing and buffering to insulate Salesforce from system outages.
  • D. A Use Platform Event replayldand custom scheduled Apex process to retrieve missed events.
Using middleware queuing and buffering is a solution that can handle errors during service outages by storing the messages in a queue until the service is available again. This way, Salesforce does not lose any data or encounter any failures when the service is down. Using @future jobld and custom scheduled apex process to retry failed service calls is not a good solution because it can consume a lot of governor limits and create a lot of duplicate records. Using Outbound Messaging to automatically retry failed service calls is also not a good solution because it has a limited number of retries and a fixed retry interval, which may not be sufficient for long service outages. Using Platform Event replayld and custom scheduled Apex process to retrieve missed events is not applicable for this scenario because Platform Events are used for event-driven integration, not for web-service integration. Reference: Salesforce Integration Architecture Designer Resource Guide, page 29-30
NEW QUESTION # 122
Our Integration-Architect test prep embrace latest information, up-to-date knowledge and fresh ideas, encouraging the practice of thinking out of box rather than treading the same old path following a beaten track. As the industry has been developing more rapidly, our Integration-Architect exam dumps have to be updated at irregular intervals in case of keeping pace with changes. To give you a better using environment, our experts have specialized in the technology with the system upgraded to offer you the latest Integration-Architect Exam practices. What’s more, we won’t charge you in one-year cooperation; if you are pleased with it, we may have further cooperation. We will inform you of the latest preferential activities about our Integration-Architect test braindumps to express our gratitude towards your trust.
New Integration-Architect Real Test: https://www.testpassking.com/Integration-Architect-exam-testking-pass.html
As you know the Salesforce Integration-Architect exam syllabus is being updated on a regular basis, Passing Integration-Architect is not simple, Salesforce Valid Exam Integration-Architect Blueprint Isn't there an easy way to help all candidates pass their exam successfully, Our Integration-Architect certification material get to the exam questions can help users in the first place, and what they care about the test information, can put more time in learning a new hot spot content, Salesforce Valid Exam Integration-Architect Blueprint We do not share the information of our clients with any irrelevant party so, be relax while making your purchase.
Granting Permissions to Classes, Just how clever are the invaders, As you know the Salesforce Integration-Architect Exam Syllabus is being updated on a regular basis, Passing Integration-Architect is not simple.
Isn't there an easy way to help all candidates pass their exam successfully, Our Integration-Architect certification material get to the exam questions can help users in the first place, and what Integration-Architect they care about the test information, can put more time in learning a new hot spot content.
100% Pass Salesforce - High Pass-Rate Valid Exam Integration-Architect BlueprintWe do not share the information of our Valid Integration-Architect Exam Labs clients with any irrelevant party so, be relax while making your purchase.
What's more, part of that TestPassKing Integration-Architect dumps now are free: https://drive.google.com/open?id=1q94jkdg_dQiNypZSpIkYhsf3RQ-AxAfF
