Exam Questions For Google Professional-Cloud-DevOps-Engineer With 1 year Of Upda
Posted at 2/7/2026 06:30:40
What's more, part of that Dumpleader Professional-Cloud-DevOps-Engineer dumps now are free: https://drive.google.com/open?id=1T1GSB6_ccIZWlFiSK7j_4gYiZS90i0pr
In this way, the Google Professional-Cloud-DevOps-Engineer certified professionals can not only validate their skills and knowledge level but also put their careers on the right track. By doing this you can achieve your career objectives. To avail of all these benefits you need to pass the Google Cloud Certified - Professional Cloud DevOps Engineer Exam (Professional-Cloud-DevOps-Engineer) exam which is a difficult exam that demands firm commitment and complete Google Professional-Cloud-DevOps-Engineer exam questions preparation.
The Google Professional-Cloud-DevOps-Engineer exam is designed to test the candidate's proficiency in using GCP services to deploy, manage and monitor applications, as well as their ability to implement best practices for application development, testing and deployment. Google Cloud Certified - Professional Cloud DevOps Engineer Exam certification exam requires a strong understanding of DevOps principles and tools, including containerization, automation, and infrastructure as code. Candidates must also have experience in using Google Cloud's tools and services, such as Cloud Storage, Cloud Functions, Cloud Pub/Sub, and Cloud Logging, to deploy and manage applications. The Professional-Cloud-DevOps-Engineer Certification can help IT professionals advance their careers and demonstrate their expertise in cloud computing and DevOps practices.
The Professional Cloud DevOps Engineer Exam is intended for professionals who have experience in cloud architecture and operations, as well as expertise in developing and deploying applications using Google Cloud Platform. Google Cloud Certified - Professional Cloud DevOps Engineer Exam certification exam is perfect for individuals who want to demonstrate their expertise in DevOps engineering and cloud computing and want to enhance their career opportunities in the field of cloud-based operations.
Professional-Cloud-DevOps-Engineer Valid Exam Dumps - Latest Professional-Cloud-DevOps-Engineer Test ReportFor some candidates who want to pass an exam, some practice for it is quite necessary. Our Professional-Cloud-DevOps-Engineer learning materials will help you to pass the exam successfully with the high-quality of the Professional-Cloud-DevOps-Engineer exam dumps. We have the experienced experts to compile Professional-Cloud-DevOps-Engineer Exam Dumps, and they are quite familiar with the exam centre, therefore the Professional-Cloud-DevOps-Engineer learning materials can help you pass the exam successfully. Besides, we also pass guarantee and money back guarantee if you fail to pass the exam exam.
The Google Professional-Cloud-DevOps-Engineer Exam is designed to test a candidate's knowledge and skills across a range of topics, including cloud architecture, application development, automation, compliance, and security. Professional-Cloud-DevOps-Engineer exam also covers best practices for managing and monitoring cloud-based DevOps processes, as well as strategies for implementing continuous integration and delivery. Candidates who pass the exam will be able to demonstrate their ability to design and manage complex cloud-based DevOps environments.
Google Cloud Certified - Professional Cloud DevOps Engineer Exam Sample Questions (Q125-Q130):NEW QUESTION # 125
Your team uses Cloud Build for all CI/CO pipelines. You want to use the kubectl builder for Cloud Build to deploy new images to Google Kubernetes Engine (GKE). You need to authenticate to GKE while minimizing development effort. What should you do?
- A. Create a new service account with the Container Developer role and use it to run Cloud Build.
- B. Assign the Container Developer role to the Cloud Build service account.
- C. Create a separate step in Cloud Build to retrieve service account credentials and pass these to kubectl.
- D. Specify the Container Developer role for Cloud Build in the cloudbuild.yaml file.
NEW QUESTION # 126
You have a set of applications running on a Google Kubernetes Engine (GKE) cluster, and you are using Stackdriver Kubernetes Engine Monitoring. You are bringing a new containerized application required by your company into production. This application is written by a third party and cannot be modified or reconfigured. The application writes its log information to /var/log/app_messages.log, and you want to send these log entries to Stackdriver Logging. What should you do?
- A. Use the default Stackdriver Kubernetes Engine Monitoring agent configuration.
- B. Write a script to tail the log file within the pod and write entries to standard output. Run the script as a sidecar container with the application's pod. Configure a shared volume between the containers to allow the script to have read access to /var/log in the application container.
- C. Install Kubernetes on Google Compute Engine (GCE> and redeploy your applications. Then customize the built-in Stackdriver Logging configuration to tail the log file in the application's pods and write to Stackdriver Logging.
- D. Deploy a Fluentd daemonset to GKE. Then create a customized input and output configuration to tail the log file in the application's pods and write to Slackdriver Logging.
NEW QUESTION # 127
You are building and running client applications in Cloud Run and Cloud Functions Your client requires that all logs must be available for one year so that the client can import the logs into their logging service You must minimize required code changes What should you do?
- A. Update all images in Cloud Run and all functions in Cloud Functions to send logs to both Cloud Logging andthe client's logging service Ensure that all the ports required to send logs are open in the VPC firewall
- B. Create a logs bucket and logging sink. Set the retention on the logs bucket to 365 days Configure thelogging sink to send logs to the bucket Give your client access to the bucket to retrieve the logs
- C. Create a storage bucket and appropriate VPC firewall rules Update all images in Cloud Run and allfunctions in Cloud Functions to send logs to a file within the storage bucket
- D. Create a Pub/Sub topic subscription and logging sink Configure the logging sink to send all logs into thetopic Give your client access to the topic to retrieve the logs
NEW QUESTION # 128
Your uses Jenkins running on Google Cloud VM instances for CI/CD. You need to extend the functionality to use infrastructure as code automation by using Terraform. You must ensure that the Terraform Jenkins instance is authorized to create Google Cloud resources. You want to follow Google-recommended practices- What should you do?
- A. use the Terraform module so that Secret Manager can retrieve credentials.
- B. Add the auth application-default command as a step in Jenkins before running the Terraform commands.
- C. Confirm that the Jenkins VM instance has an attached service account with the appropriate Identity and Access Management (IAM) permissions.
- D. Create a dedicated service account for the Terraform instance. Download and copy the secret key value to the GOOGLE environment variable on the Jenkins server.
The correct answer is C)
Confirming that the Jenkins VM instance has an attached service account with the appropriate Identity and Access Management (IAM) permissions is the best way to ensure that the Terraform Jenkins instance is authorized to create Google Cloud resources. This follows the Google-recommended practice of using service accounts to authenticate and authorize applications running on Google Cloud1. Service accounts are associated with private keys that can be used to generate access tokens for Google Cloud APIs2. By attaching a service account to the Jenkins VM instance, Terraform can use the Application Default Credentials (ADC) strategy to automatically find and use the service account credentials3.
Answer A is incorrect because the auth application-default command is used to obtain user credentials, not service account credentials. User credentials are not recommended for applications running on Google Cloud, as they are less secure and less scalable than service account credentials1.
Answer B is incorrect because it involves downloading and copying the secret key value of the service account, which is not a secure or reliable way of managing credentials. The secret key value should be kept private and not exposed to any other system or user2. Moreover, setting the GOOGLE environment variable on the Jenkins server is not a valid way of providing credentials to Terraform. Terraform expects the credentials to be either in a file pointed by the GOOGLE_APPLICATION_CREDENTIALS environment variable, or in a provider block with the credentials argument3.
Answer D is incorrect because it involves using the Terraform module for Secret Manager, which is a service that stores and manages sensitive data such as API keys, passwords, and certificates. While Secret Manager can be used to store and retrieve credentials, it is not necessary or sufficient for authorizing the Terraform Jenkins instance. The Terraform Jenkins instance still needs a service account with the appropriate IAM permissions to access Secret Manager and other Google Cloud resources.
NEW QUESTION # 129
You are designing a system with three different environments: development, quality assurance (QA), and production.
Each environment will be deployed with Terraform and has a Google Kubemetes Engine (GKE) cluster created so that application teams can deploy their applications. Anthos Config Management will be used and templated to deploy infrastructure level resources in each GKE cluster. All users (for example, infrastructure operators and application owners) will use GitOps. How should you structure your source control repositories for both Infrastructure as Code (laC) and application code?
- A. Cloud Infrastructure (Terraform) repositories are separated: different branches are different environmentsGKE Infrastructure (Anthos Config Management Kustomize manifests) repositories are separated:different overlay directories are different environmentsApplication (app source code) repositories are separated: different branches are different features
- B. Cloud Infrastructure (Terraform) repository is shared: different directories are different environmentsGKE Infrastructure (Anthos Config Management Kustomize manifests) repositories are separated:different branches are different environmentsApplication (app source code) repositories are separated: different branches are different features
- C. Cloud Infrastructure (Terraform) repository is shared: different branches are different environmentsGKE Infrastructure (Anthos Config Management Kustomize manifests) repository is shared: differentoverlay directories are different environmentsApplication (app source code) repository is shared: different directories are different features
- D. Cloud Infrastructure (Terraform) repository is shared: different directories are different environmentsGKE Infrastructure (Anthos Config Management Kustomize manifests) repository is shared: differentoverlay directories are different environmentsApplication (app source code) repositories are separated: different branches are different features
The correct answer is B. Cloud Infrastructure (Terraform) repository is shared: different directories are different environments. GKE Infrastructure (Anthos Config Management Kustomize manifests) repositories are separated: different branches are different environments. Application (app source code) repositories are separated: different branches are different features.
This answer follows the best practices for using Terraform and Anthos Config Management with GitOps, as described in the following sources:
For Terraform, it is recommended to use a single repository for all environments, and use directories to separate them. This way, you can reuse the same Terraform modules and configurations across environments, and avoid code duplication and drift.You can also use Terraform workspaces to isolate the state files for each environment12.
For Anthos Config Management, it is recommended to use separate repositories for each environment, and use branches to separate the clusters within each environment. This way, you can enforce different policies and configurations for each environment, and use pull requests to promote changes across environments.You can also use Kustomize to create overlays for each cluster that apply specific patches or customizations34.
For application code, it is recommended to use separate repositories for each application, and use branches to separate the features or bug fixes for each application. This way, you can isolate the development and testing of each application, and use pull requests to merge changes into the main branch.You can also use tags or labels to trigger deployments to different environments5.
1:Best practices for using Terraform | Google Cloud
2: Terraform Recommended Practices - Part 1 | Terraform - HashiCorp Learn
3 eploy Anthos on GKE with Terraform part 1: GitOps with Config Sync | Google Cloud Blog
4: Using Kustomize with Anthos Config Management | Anthos Config Management Documentation | Google Cloud
5: Deploy Anthos on GKE with Terraform part 3: Continuous Delivery with Cloud Build | Google Cloud Blog
6: GitOps-style continuous delivery with Cloud Build | Cloud Build Documentation | Google Cloud
NEW QUESTION # 130
Professional-Cloud-DevOps-Engineer Valid Exam Dumps: https://www.dumpleader.com/Professional-Cloud-DevOps-Engineer_exam.html
- Professional-Cloud-DevOps-Engineer Trustworthy Practice - 100% Pass Professional-Cloud-DevOps-Engineer: Google Cloud Certified - Professional Cloud DevOps Engineer Exam First-grade Valid Exam Dumps 🏤 Search for ▷ Professional-Cloud-DevOps-Engineer ◁ and download it for free immediately on ▶ [url]www.dumpsquestion.com ◀ 💇Exam Topics Professional-Cloud-DevOps-Engineer Pdf[/url]
- 100% Pass Quiz Google - Professional-Cloud-DevOps-Engineer - Google Cloud Certified - Professional Cloud DevOps Engineer Exam –Valid Trustworthy Practice 🔔 The page for free download of ➥ Professional-Cloud-DevOps-Engineer 🡄 on { [url]www.pdfvce.com } will open immediately 🧐Sample Professional-Cloud-DevOps-Engineer Questions Pdf[/url]
- Test Professional-Cloud-DevOps-Engineer Sample Questions 💾 Professional-Cloud-DevOps-Engineer Free Dump Download ✈ New Professional-Cloud-DevOps-Engineer Exam Camp 😙 Open ➽ [url]www.prepawayete.com 🢪 and search for ⏩ Professional-Cloud-DevOps-Engineer ⏪ to download exam materials for free 🖊New Professional-Cloud-DevOps-Engineer Exam Camp[/url]
- 2026 Professional-Cloud-DevOps-Engineer Trustworthy Practice | High-quality 100% Free Google Cloud Certified - Professional Cloud DevOps Engineer Exam Valid Exam Dumps 👦 Search for ➠ Professional-Cloud-DevOps-Engineer 🠰 and download it for free immediately on ➠ [url]www.pdfvce.com 🠰 ⛅Valid Professional-Cloud-DevOps-Engineer Mock Test[/url]
- Test Professional-Cloud-DevOps-Engineer Sample Questions ⭕ Professional-Cloud-DevOps-Engineer Free Dump Download 🏥 Professional-Cloud-DevOps-Engineer Free Dump Download ⚫ Open ➥ [url]www.easy4engine.com 🡄 and search for ▶ Professional-Cloud-DevOps-Engineer ◀ to download exam materials for free 🐍
rofessional-Cloud-DevOps-Engineer Guaranteed Questions Answers[/url] - Test Professional-Cloud-DevOps-Engineer Sample Questions 🈵 Professional-Cloud-DevOps-Engineer Guaranteed Questions Answers ⏺ Professional-Cloud-DevOps-Engineer New Study Guide ⬛ Simply search for “ Professional-Cloud-DevOps-Engineer ” for free download on ⮆ [url]www.pdfvce.com ⮄ 🔒
rofessional-Cloud-DevOps-Engineer Valid Exam Duration[/url] - 100% Pass Quiz Google - Professional-Cloud-DevOps-Engineer - Google Cloud Certified - Professional Cloud DevOps Engineer Exam –Valid Trustworthy Practice 🎯 Search for ✔ Professional-Cloud-DevOps-Engineer ️✔️ and download exam materials for free through ☀ [url]www.vce4dumps.com ️☀️ 🎱Exam Topics Professional-Cloud-DevOps-Engineer Pdf[/url]
- Professional-Cloud-DevOps-Engineer New Exam Braindumps 🏨 New Professional-Cloud-DevOps-Engineer Test Voucher 🍩 Professional-Cloud-DevOps-Engineer New Study Guide 🏳 Easily obtain free download of ▶ Professional-Cloud-DevOps-Engineer ◀ by searching on ➠ [url]www.pdfvce.com 🠰 📲
rofessional-Cloud-DevOps-Engineer New Exam Braindumps[/url] - HOT Professional-Cloud-DevOps-Engineer Trustworthy Practice 100% Pass | Trustable Google Google Cloud Certified - Professional Cloud DevOps Engineer Exam Valid Exam Dumps Pass for sure 🥢 Easily obtain ➡ Professional-Cloud-DevOps-Engineer ️⬅️ for free download through ▛ [url]www.vce4dumps.com ▟ 🔉
rofessional-Cloud-DevOps-Engineer Reliable Exam Pattern[/url] - Pass Guaranteed Quiz Pass-Sure Google - Professional-Cloud-DevOps-Engineer Trustworthy Practice 👴 Download ➤ Professional-Cloud-DevOps-Engineer ⮘ for free by simply searching on { [url]www.pdfvce.com } 🍼Exam Topics Professional-Cloud-DevOps-Engineer Pdf[/url]
- Professional-Cloud-DevOps-Engineer New Study Guide 😩 Cert Professional-Cloud-DevOps-Engineer Exam ☮ Latest Professional-Cloud-DevOps-Engineer Exam Objectives 😿 Easily obtain 【 Professional-Cloud-DevOps-Engineer 】 for free download through 「 [url]www.dumpsquestion.com 」 🛴
rofessional-Cloud-DevOps-Engineer Exam Quick Prep[/url] - paidforarticles.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest Dumpleader Professional-Cloud-DevOps-Engineer PDF Dumps and Professional-Cloud-DevOps-Engineer Exam Engine Free Share: https://drive.google.com/open?id=1T1GSB6_ccIZWlFiSK7j_4gYiZS90i0pr
