[Hardware] Quiz 2026 Amazon Data-Engineer-Associate Useful Exam Book
96
【Hardware】 Quiz 2026 Amazon Data-Engineer-Associate Useful Exam Book
Posted at 2/7/2026 08:19:40      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon Data-Engineer-Associate dumps are available on Google Drive shared by Test4Sure: https://drive.google.com/open?id=1UtN97Fwuun7OASzG7un2WYZOUXGbqjNC
Test4Sure provide a good after-sales service for all customers. If you choose to purchase Test4Sure products, Test4Sure will provide you with online service for 24 hours a day and one year free update service, which timely inform you the latest exam information to let you have a fully preparation. We can let you spend a small amount of time and money and pass the IT certification exam at the same time. Selecting the products of Test4Sure to help you pass your first time Amazon Certification Data-Engineer-Associate Exam is very cost-effective.
Success in the Amazon Data-Engineer-Associate exam paves the way toward high-paying jobs, promotions, and skills verification. Hundreds of Amazon Data-Engineer-Associate test takers do not get success because of using Amazon Data-Engineer-Associate outdated dumps. Due to failure, they lose money, time, and confidence. All these losses can be prevented by using updated and real Data-Engineer-Associate exam.
Composite Test Amazon Data-Engineer-Associate Price, Data-Engineer-Associate Reliable TorrentUp to 1 year of free updates of Amazon Data-Engineer-Associate exam questions are also available at Test4Sure. To test the features of our product before buying, you may also try a free demo. It is not difficult to clear the Data-Engineer-Associate certification exam if you have actual exam questions of at your disposal. Why then wait? Visit and download Amazon Data-Engineer-Associate updated exam questions right away to start the process of cracking your test in one go.
Amazon AWS Certified Data Engineer - Associate (DEA-C01) Sample Questions (Q29-Q34):NEW QUESTION # 29
A company needs to implement a new inventory management system that provides near real-time updates and visibility across all AWS Regions. The new solution must provide centralized access control over data access and permissions. The company has a separate inventory management team assigned to each Region. Each inventory management team needs to update inventory levels.
A data engineer must implement Amazon Redshift data sharing with write capabilities. The solution must follow the principle of least privilege.
Which solution will meet these requirements with the LEAST operational overhead?
  • A. Configure three Regional Redshift datashares that provide full write access. Allow full self-managed access controls.
  • B. Configure a single Redshift datashare from the company's headquarters that has selective write permissions for inventory. Set up Regional namespace controls.
  • C. Configure separate Redshift datashares for multiple table types that provide full write access. Distribute the datashares across all Regional clusters. Allow self-managed Regional schema permissions.
  • D. Configure a single Redshift datashare from the company's headquarters that provides read-only access for all Regions. Configure a separate AWS Glue ETL job to update data for each Region.
Amazon Redshift data sharing now supports bi-directional and selective write access through datashare namespaces.
This allows centralized management of permissions from headquarters while giving Regional clusters controlled write access to specific datasets - adhering to least privilege and minimizing admin overhead.
"Use Redshift datashares with write permissions and namespaces to enable controlled cross-Region data collaboration while maintaining centralized governance."
- Ace the AWS Certified Data Engineer - Associate Certification - version 2 - apple.pdf This configuration ensures near real-time inventory updates, centralized access management, and compliance with AWS security best practices.
NEW QUESTION # 30
A company currently stores all of its data in Amazon S3 by using the S3 Standard storage class.
A data engineer examined data access patterns to identify trends. During the first 6 months, most data files are accessed several times each day. Between 6 months and 2 years, most data files are accessed once or twice each month. After 2 years, data files are accessed only once or twice each year.
The data engineer needs to use an S3 Lifecycle policy to develop new data storage rules. The new storage solution must continue to provide high availability.
Which solution will meet these requirements in the MOST cost-effective way?
  • A. Transition objects to S3 Standard-Infrequent Access (S3 Standard-IA) after 6 months. Transfer objects to S3 Glacier Flexible Retrieval after 2 years.
  • B. Transition objects to S3 Standard-Infrequent Access (S3 Standard-IA) after 6 months. Transfer objects to S3 Glacier Deep Archive after 2 years.
  • C. Transition objects to S3 One Zone-Infrequent Access (S3 One Zone-IA) after 6 months. Transfer objects to S3 Glacier Flexible Retrieval after 2 years.
  • D. Transition objects to S3 One Zone-Infrequent Access (S3 One Zone-IA) after 6 months. Transfer objects to S3 Glacier Deep Archive after 2 years.
To achieve the most cost-effective storage solution, the data engineer needs to use an S3 Lifecycle policy that transitions objects to lower-cost storage classes based on their access patterns, and deletes them when they are no longer needed. The storage classes should also provide high availability, which means they should be resilient to the loss of data in a single Availability Zone1. Therefore, the solution must include the following steps:
Transition objects to S3 Standard-Infrequent Access (S3 Standard-IA) after 6 months. S3 Standard-IA is designed for data that is accessed less frequently, but requires rapid access when needed. It offers the same high durability, throughput, and low latency as S3 Standard, but with a lower storage cost and a retrieval fee2.
Therefore, it is suitable for data files that are accessed once or twice each month. S3 Standard-IA also provides high availability, as it stores data redundantly across multiple Availability Zones1.
Transfer objects to S3 Glacier Deep Archive after 2 years. S3 Glacier Deep Archive is the lowest-cost storage class that offers secure and durable storage for data that is rarely accessed and can tolerate a 12-hour retrieval time. It is ideal for long-term archiving and digital preservation3. Therefore, it is suitable for data files that are accessed only once or twice each year. S3 Glacier Deep Archive also provides high availability, as it stores data across at least three geographically dispersed Availability Zones1.
Delete objects when they are no longer needed. The data engineer can specify an expiration action in the S3 Lifecycle policy to delete objects after a certain period of time. This will reduce the storage cost and comply with any data retention policies.
Option C is the only solution that includes all these steps. Therefore, option C is the correct answer.
Option A is incorrect because it transitions objects to S3 One Zone-Infrequent Access (S3 One Zone-IA) after
6 months. S3 One Zone-IA is similar to S3 Standard-IA, but it stores data in a single Availability Zone. This means it has a lower availability and durability than S3 Standard-IA, and it is not resilient to the loss of data in a single Availability Zone1. Therefore, it does not provide high availability as required.
Option B is incorrect because it transfers objects to S3 Glacier Flexible Retrieval after 2 years. S3 Glacier Flexible Retrieval is a storage class that offers secure and durable storage for data that is accessed infrequently and can tolerate a retrieval time of minutes to hours. It is more expensive than S3 Glacier Deep Archive, and it is not suitable for data that is accessed only once or twice each year3. Therefore, it is not the most cost-effective option.
Option D is incorrect because it combines the errors of option A and B. It transitions objects to S3 One Zone- IA after 6 months, which does not provide high availability, and it transfers objects to S3 Glacier Flexible Retrieval after 2 years, which is not the most cost-effective option.
1: Amazon S3 storage classes - Amazon Simple Storage Service
2: Amazon S3 Standard-Infrequent Access (S3 Standard-IA) - Amazon Simple Storage Service
3: Amazon S3 Glacier and S3 Glacier Deep Archive - Amazon Simple Storage Service
[4]: Expiring objects - Amazon Simple Storage Service
[5]: Managing your storage lifecycle - Amazon Simple Storage Service
[6]: Examples of S3 Lifecycle configuration - Amazon Simple Storage Service
[7]: Amazon S3 Lifecycle further optimizes storage cost savings with new features - What's New with AWS
NEW QUESTION # 31
A company uses an Amazon Redshift provisioned cluster as its database. The Redshift cluster has five reserved ra3.4xlarge nodes and uses key distribution.
A data engineer notices that one of the nodes frequently has a CPU load over 90%. SQL Queries that run on the node are queued. The other four nodes usually have a CPU load under 15% during daily operations.
The data engineer wants to maintain the current number of compute nodes. The data engineer also wants to balance the load more evenly across all five compute nodes.
Which solution will meet these requirements?
  • A. Change the distribution key to the table column that has the largest dimension.
  • B. Change the sort key to be the data column that is most often used in a WHERE clause of the SQL SELECT statement.
  • C. Change the primary key to be the data column that is most often used in a WHERE clause of the SQL SELECT statement.
  • D. Upgrade the reserved node from ra3.4xlarqe to ra3.16xlarqe.
Changing the distribution key to the table column that has the largest dimension will help to balance the load more evenly across all five compute nodes. The distribution key determines how the rows of a table are distributed among the slices of the cluster. If the distribution key is not chosen wisely, it can cause data skew, meaning some slices will have more data than others, resulting in uneven CPU load and query performance.
By choosing the table column that has the largest dimension, meaning the column that has the most distinct values, as the distribution key, the data engineer can ensure that the rows are distributed more uniformly across the slices, reducing data skew and improving query performance.
The other options are not solutions that will meet the requirements. Option A, changing the sort key to be the data column that is most often used in a WHERE clause of the SQL SELECT statement, will not affect the data distribution or the CPU load. The sort key determines the order in which the rows of a table are stored on disk, which can improve the performance of range-restricted queries, but not the load balancing. Option C, upgrading the reserved node from ra3.4xlarge to ra3.16xlarge, will not maintain the current number of compute nodes, as it will increase the cost and the capacity of the cluster. Option D, changing the primary key to be the data column that is most often used in a WHERE clause of the SQL SELECT statement, will not affect the data distribution or the CPU load either. The primary key is a constraint that enforces the uniqueness of the rows in a table, but it does not influence the data layout or the query optimization.
* Choosing a data distribution style
* Choosing a data sort key
* Working with primary keys
NEW QUESTION # 32
A company needs to build a data lake in AWS. The company must provide row-level data access and column-level data access to specific teams. The teams will access the data by using Amazon Athena, Amazon Redshift Spectrum, and Apache Hive from Amazon EMR.
  • A. Use Amazon Redshift for data lake storage. Use Redshift security policies to restrict data access byrows and columns. Provide data accessby usingApache Spark and Amazon Athena federated queries.
  • B. UseAmazon S3 for data lake storage. Use AWS Lake Formation to restrict data access by rows and columns. Provide data access through AWS Lake Formation.
  • C. Use Amazon S3 for data lake storage. Use Apache Ranger through Amazon EMR to restrict data access byrows and columns. Providedata access by using Apache Pig.
  • D. Use Amazon S3 for data lake storage. Use S3 access policies to restrict data access by rows and columns. Provide data access throughAmazon S3.
Option D is the best solution to meet the requirements with the least operational overhead because AWS Lake Formation is a fully managed service that simplifies the process of building, securing, and managing data lakes. AWS Lake Formation allows you to define granular data access policies at the row and column level for different users and groups. AWS Lake Formation also integrates with Amazon Athena, Amazon Redshift Spectrum, and Apache Hive on Amazon EMR, enabling these services to access the data in the data lake through AWS Lake Formation.
Option A is not a good solution because S3 access policies cannot restrict data access by rows and columns.
S3 access policies are based on the identity and permissions of the requester, the bucket and object ownership, and the object prefix and tags. S3 access policies cannot enforce fine-grained data access control at the row and column level.
Option B is not a good solution because it involves using Apache Ranger and Apache Pig, which are not fully managed services and require additional configuration and maintenance. Apache Ranger is a framework that provides centralized security administration for data stored in Hadoop clusters, such as Amazon EMR. Apache Ranger can enforce row-level and column-level access policies for Apache Hive tables. However, Apache Ranger is not a native AWS service and requires manual installation and configuration on Amazon EMR clusters. Apache Pig is a platform that allows you to analyze large data sets using a high-level scripting language called Pig Latin. Apache Pig can access data stored in Amazon S3 and process it using Apache Hive.
However,Apache Pig is not a native AWS service and requires manual installation and configuration on Amazon EMR clusters.
Option C is not a good solution because Amazon Redshift is not a suitable service for data lake storage.
Amazon Redshift is a fully managed data warehouse service that allows you to run complex analytical queries using standard SQL. Amazon Redshift can enforce row-level and column-level access policies for different users and groups. However, Amazon Redshift is not designed to store and process large volumes of unstructured or semi-structured data, which are typical characteristics of data lakes. Amazon Redshift is also more expensive and less scalable than Amazon S3 for data lake storage.
AWS Certified Data Engineer - Associate DEA-C01 Complete Study Guide
What Is AWS Lake Formation? - AWS Lake Formation
Using AWS Lake Formation with Amazon Athena - AWS Lake Formation
Using AWS Lake Formation with Amazon Redshift Spectrum - AWS Lake Formation Using AWS Lake Formation with Apache Hive on Amazon EMR - AWS Lake Formation Using Bucket Policies and User Policies - Amazon Simple Storage Service Apache Ranger Apache Pig What Is Amazon Redshift? - Amazon Redshift
NEW QUESTION # 33
A retail company is expanding its operations globally. The company needs to use Amazon QuickSight to accurately calculate currency exchange rates for financial reports. The company has an existing dashboard that includes a visual that is based on an analysis of a dataset that contains global currency values and exchange rates.
A data engineer needs to ensure that exchange rates are calculated with a precision of four decimal places.
The calculations must be precomputed. The data engineer must materialize results in QuickSight super-fast, parallel, in-memory calculation engine (SPICE).
  • A. Define and create the calculated field in the visual.
  • B. Define and create the calculated field in the analysis.
  • C. Define and create the calculated field in the dataset.
  • D. Define and create the calculated field in the dashboard.
NEW QUESTION # 34
Do you want to get the valid and latest study material for Data-Engineer-Associate actual test? Please stop hunting with aimless, Test4Sure will offer you the updated and high quality Amazon study material for you. The Data-Engineer-Associate training dumps are specially designed for the candidates like you by our professional expert team. Data-Engineer-Associate Questions and answers are valuable and validity, which will give you some reference for the actual test. Please prepare well for the actual test with our Data-Engineer-Associate practice torrent, 100% pass will be an easy thing.
Composite Test Data-Engineer-Associate Price: https://www.test4sure.com/Data-Engineer-Associate-pass4sure-vce.html
Test4Sure Composite Test Data-Engineer-Associate Price's concentration is to provide you with the state of the art products at affordable prices, We take client's advice on Data-Engineer-Associate learning materials seriously, Amazon Data-Engineer-Associate Exam Book In the such a brilliant era of IT industry in the 21st century competition is very fierce, Amazon Data-Engineer-Associate Exam Book What is the shortcut for your exam?
Consider all drawn elements in response to Data-Engineer-Associate Reliable Torrent the format's edges, here in sunny CA) people might not be able to, or might be told not to, come to the office, Test4Sure's concentration Data-Engineer-Associate is to provide you with the state of the art products at affordable prices.
Reliable Data-Engineer-Associate Exam Book to Obtain Amazon CertificationWe take client's advice on Data-Engineer-Associate learning materials seriously, In the such a brilliant era of IT industry in the 21st century competition is very fierce, What is the shortcut for your exam?
So we provide numerous benefits along with our AWS Certified Data Engineer - Associate (DEA-C01) exam study material.
BONUS!!! Download part of Test4Sure Data-Engineer-Associate dumps for free: https://drive.google.com/open?id=1UtN97Fwuun7OASzG7un2WYZOUXGbqjNC
