[General] Updated Juniper - JN0-481 Latest Test Braindumps
84
General Updated Juniper - JN0-481 Latest Test Braindumps
Posted at 2/7/2026 08:29:29      View157 | Replies3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Braindumpsqa JN0-481 dumps from Cloud Storage: https://drive.google.com/open?id=1cnq3Rc1mXLYYIWUrbSA3S8hw27_w2wT4
Getting the test JN0-481 certification maybe they need to achieve the goal of the learning process, have been working for the workers, have more qualifications can they provide wider space for development. The JN0-481 actual exam guide can provide them with efficient and convenient learning platform so that they can get the certification as soon as possible in the shortest possible time. A high degree may be a sign of competence, getting the test JN0-481 Certification is also a good choice. When we get the JN0-481 certificates, we have more options to create a better future.
When you decide to pass JN0-481 exam, you must want to find a good study materials to help you prepare for your exam. It is evident to all that the JN0-481 test torrent from our company has a high quality all the time. A lot of people who have bought our products can agree that our JN0-481 Test Questions are very useful for them to get the certification. There have been 99 percent people used our JN0-481 exam prep that have passed their exam and get the certification, more importantly, there are signs that this number is increasing slightly.
Braindumpsqa Study Guide Helps You Master All the Topics on the JN0-481 ExamIt is browser-based; therefore no need to install it, and you can start practicing for the Data Center, Specialist (JNCIS-DC) (JN0-481) exam by creating the Data Center, Specialist (JNCIS-DC) (JN0-481) practice test. Our Data Center, Specialist (JNCIS-DC) (JN0-481) exam dumps give help to give you an idea about the actual Juniper JN0-481 Exam. You can attempt multiple Data Center, Specialist (JNCIS-DC) (JN0-481) exam questions on the software to improve your performance.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q18-Q23):NEW QUESTION # 18
You want to keep virtual networks isolated from each other within the Juniper Apstra system. In this scenario, what are three ways to accomplish this task? (Choose three.)
  • A. Disable IPv4 connectivity when creating the virtual network within the same Routing Zone.
  • B. Disable Route Target exports when creating the Routing Zones.
  • C. Use Connectivity Templates to block access within the same Routing Zone.
  • D. Enable Security Policy for virtual networks in the same Routing Zone.
  • E. Put each network in different Routing Zones.
Answer: C,D,E
To keep virtual networks isolated from each other within the Juniper Apstra system, you can use one or more of the following methods:
Enable Security Policy for virtual networks in the same Routing Zone. This allows you to define rules that control the traffic flow between different virtual networks within the same routing zone.
You can specify the source and destination virtual networks, the protocol, the port, and the action (allow or deny) for each rule. The security policy is applied on the ingress interface of the leaf devices.
Use Connectivity Templates to block access within the same Routing Zone. This allows you to customize the connectivity between different racks within the same routing zone. You can create templates that define the link type, the routing protocol, and the access control list (ACL) for each rack pair. The ACL can be used to filter the traffic based on the source and destination IP addresses, the protocol, and the port.
Put each network in different Routing Zones. This allows you to create logical boundaries between different virtual networks based on the route target (RT) values. A routing zone is a collection of virtual networks that share the same RT for importing and exporting routes. Virtual networks in different routing zones do not exchange routes with each other, unless you configure remote EVPN gateways to connect them.
NEW QUESTION # 19
Which statement is correct about making changes to a predefined device profile in Juniper Apstra?
  • A. Changing the predefined device profile will also affect deployed devices that use the same profile.
  • B. The processor load on the Apstra server will be negatively impacted when changes are made to a predefined device profile.
  • C. The changes you make to a predefined device profile will be discarded and overwritten when upgrading the Apstra server version.
  • D. You must reboot the Apstra server after changes are made to a predefined device profile before they will become active.
A predefined device profile is a configuration template that is shipped with Apstra software and supports most qualified Juniper devices. A predefined device profile cannot be changed, since any changes would be discarded and overwritten when you upgrade the Apstra server version. If you want to customize a predefined device profile, you can clone and edit it instead.
NEW QUESTION # 20
Which attribute enables Juniper Apstra to scale and manage thousands of devices with a single server instance?
  • A. Apstra is available as an OVA.
  • B. Apstra is based on NGINX.
  • C. Apstra is a distributed state system.
  • D. Apstra is installed as a cloud resource.
The attribute that enables Juniper Apstra to scale and manage thousands of devices with a single server instance is that Apstra is a distributed state system. This means that Apstra uses a graph database to store the network topology and configuration data in a distributed and replicated manner across multiple server nodes. This allows Apstra to handle large-scale networks with high performance, reliability, and availability. Apstra also uses a stateful orchestration engine that ensures the network state is always consistent with the intent of the blueprint, which is the logical representation of the network design and behavior. Apstra can automatically detect and resolve any discrepancies between the desired and actual network state, as well as handle any changes or failures in the network.
NEW QUESTION # 21
What does EVPN use lo identity which remote leaf device advertised the EVPN route?
  • A. a VRF target value
  • B. a community tag
  • C. a route target value
  • D. a route distinguisher value
EVPN uses a route distinguisher (RD) value to identify which remote leaf device advertised the EVPN route. An RD is a 64-bit value that is prepended to the EVPN NLRI to create a unique VPNv4 or VPNv6 prefix. The RD value is usually derived from the IP address of the PE that originates the EVPN route. By comparing the RD values of different EVPN routes, a PE can determine which remote PE advertised the route and which VRF the route belongs to.
NEW QUESTION # 22
In the case of IP Clos data center five-stage fabric design, what are two rotes of the super spines? (Choose two.)
  • A. Super spines are always connected to an external data center gateway.
  • B. Super spines are used to connect leaf nodes within a data center pod.
  • C. Super spines are used to interconnect two different data center pods.
  • D. Super spines connect to all spine devices within the five-stage architecture.
In the case of IP Clos data center five-stage fabric design, the super spines are the devices that provide the highest level of aggregation in the network. They have two main roles:
Super spines are used to interconnect two different data center pods. A pod is a cluster of leaf and spine devices that form a 3-stage Clos topology. A 5-stage Clos topology consists of multiple pods that are connected by the super spines. This allows for scaling the network to support more devices and bandwidth.
Super spines connect to all spine devices within the five-stage architecture. The spine devices are the devices that provide the second level of aggregation in the network. They connect to the leaf devices, which are the devices that provide access to the end hosts. The super spines connect to all the spine devices in the network, regardless of which pod they belong to. This provides any-to-any connectivity between the pods and enables optimal routing and load balancing.
NEW QUESTION # 23
Prior to your decision on which JN0-481 exam questions to buy, please inform us of your email address on the JN0-481 study guide so that we can make sure that you can have a try on the free demos of our JN0-481 practice materials. We hope that the JN0-481 learning braindumps you purchased are the best for you. And you can free download all of the three versions to have a fully understanding and feeling.
Reliable JN0-481 Test Online: https://www.braindumpsqa.com/JN0-481_braindumps.html
In addition, JN0-481 exam braindumps are high-quality and accuracy, because we have professionals to verify the answers to ensure the accuracy, JN0-481 exam dump also provide customer service, in case you have any inquiry or question, our professional Customer Support will be available for you 24/7, Juniper JN0-481 Latest Test Braindumps If you want to achieve that you must boost an authorized and extremely useful certificate to prove that you boost good abilities and plenty of knowledge in some area.
If you are ready for a JN0-481 certification you may know us Braindumpsqa, Kurt Bittner is chief technical officer for the Americas at Ivar Jacobson Consulting.
In addition, JN0-481 Exam Braindumps are high-quality and accuracy, because we have professionals to verify the answers to ensure the accuracy, JN0-481 exam dump also provide customer service, in case JN0-481 Latest Test Braindumps you have any inquiry or question, our professional Customer Support will be available for you 24/7.
Free PDF Quiz 2026 Juniper JN0-481: Data Center, Specialist (JNCIS-DC) C High Pass-Rate Latest Test BraindumpsIf you want to achieve that you must boost an authorized JN0-481 and extremely useful certificate to prove that you boost good abilities and plenty of knowledge in some area.
Our three versions of Juniper JN0-481 valid questions can make all buyers satisfying, Dear, are you tired of the study preparation for JN0-481 exam test?
P.S. Free 2026 Juniper JN0-481 dumps are available on Google Drive shared by Braindumpsqa: https://drive.google.com/open?id=1cnq3Rc1mXLYYIWUrbSA3S8hw27_w2wT4
Posted at 2/8/2026 19:32:27        Only Author  2#
Im really thankful for your article, it left a strong impression. Free access to Massachusetts-Real-Estate-Salesperson exam questions pdfs content is provided, hoping it will benefit your studies.
Posted at 2/16/2026 19:52:30        Only Author  3#
Instant like for this brilliant content. Sharing free Dumps Professional-Cloud-DevOps-Engineer guide resourceswishing you all the best!
Posted at 3/6/2026 10:52:30        Only Author  4#
Your article is really impressive, thank you for sharing! Im offering the Latest Workday-Pro-HCM-Reporting exam fee exam that helped me land my promotion and pay raise. Its free todaygood luck achieving your career goals!
