[General] JN0-637 Exam Sample Online - JN0-637 Online Training
80
General JN0-637 Exam Sample Online - JN0-637 Online Training
Posted at 2/7/2026 09:39:42      View142 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsQuestion JN0-637 PDF Dumps and JN0-637 Exam Engine Free Share: https://drive.google.com/open?id=15AtVh1U-gEFGRgp1njXRrNN-3K53tW_u
The DumpsQuestion is a trusted and reliable platform that has been helping the Security, Professional (JNCIP-SEC) (JN0-637) certification exam candidates for many years. Over this long time period, the JN0-637 Exam Practice questions have helped the JN0-637 exam candidates in their preparation and enabled them to pass the challenging exam on the first attempt.
Juniper JN0-637 Exam Syllabus Topics:
  • Logical Systems and Tenant Systems: This topic of the exam explores the concepts and functionalities of logical systems and tenant systems.
  • Layer 2 Security: It covers Layer 2 Security concepts and requires candidates to configure or monitor related scenarios.
  • Automated Threat Mitigation: This topic covers Automated Threat Mitigation concepts and emphasizes implementing and managing threat mitigation strategies.
  • Troubleshooting Security Policies and Security Zones: This topic assesses the skills of networking professionals in troubleshooting and monitoring security policies and zones using tools like logging and tracing.
Topic 5
  • Multinode High Availability (HA): In this topic, aspiring networking professionals get knowledge about multinode HA concepts. To pass the exam,  candidates must learn to configure or monitor HA systems.
Topic 6
  • Advanced IPsec VPNs: Focusing on networking professionals, this part covers advanced IPsec VPN concepts and requires candidates to demonstrate their skills in real-world applications.
Topic 7
  • Advanced Policy-Based Routing (APBR): This topic emphasizes on advanced policy-based routing concepts and practical configuration or monitoring tasks.
JN0-637 Online Training & Reliable JN0-637 Test GuideOur website focus on helping candidates pass Juniper certification exams with our Valid JN0-637 Practice Questions and detailed test answers. The most reliable JN0-637 dumps pdf are written by our professional IT experts who have rich experience in actual test. And you will be enjoyed one-year free updating after you make payment.
Juniper Security, Professional (JNCIP-SEC) Sample Questions (Q54-Q59):NEW QUESTION # 54
Click the Exhibit button.
Referring to the exhibit. SRX-1 and SRX-3 have to be connected using EBGP. The BGP configuration on SRX-1 and SRX-3 is verified and correct.
Which configuration on SRX-2 would establish an EBGP connection successfully between SRX-1 and SRX-3?
  • A. The host-inbound-traffic statements do not allow EBGP traffic to traverse SRX-2.
  • B. The security policy to allow SRX-1 and SRX-3 to communicate on TCP port 79 should be configured.
  • C. The security policy to allow SRX-1 and SRX-3 to communicate on TCP port 169 should be configured.
  • D. The security policy to allow SRX-1 and SRX-3 to communicate on TCP port 179 should be configured.
NEW QUESTION # 55
You are configuring an interconnect logical system that is configured as a VPLS switch to allow two logical systems to communicate.
Which two parameters are required when configuring the logical tunnel interfaces? (Choose two.)
  • A. Encapsulation ethernet must be used.
  • B. The logical tunnel interfaces should be configured with two logical unit pairs per logical system interconnect.
  • C. Encapsulation ethernet-vpls must be used.
  • D. The virtual tunnel interfaces should only be configured with two logical unit pairs per logical system interconnect.
NEW QUESTION # 56
You are enabling advanced policy-based routing. You have configured a static route that has a next hop from the inet.0 routing table. Unfortunately, this static route is not active in your routing instance.
In this scenario, which solution is needed to use this next hop?
  • A. Use filter-based forwarding.
  • B. Use RIB groups.
  • C. Use transparent mode.
  • D. Use policies.
To enable advanced policy-based routing in Junos OS and activate a static route with a next-hop address in the inet.0 table within your routing instance, you should utilize RIB groups. RIB groups allow you to import routes from one routing table to another. In this scenario, the static route within the routing instance needs access to the inet.0 routes, which is facilitated by configuring a RIB group. Juniper's documentation outlines RIB groups as a necessary component for handling instances where routes need to be shared across routing tables, thereby ensuring seamless traffic flow through specified routes. For more details, refer to the Juniper Networks Documentation on RIB Groups.
In Junos OS for SRX Series devices, when enabling advanced policy-based routing and configuring a static route with a next-hop from the inet.0 routing table, the issue arises because the static route is not being used in the routing instance. This is a common scenario when the next-hop belongs to a different routing table or instance, and the routing instance is not aware of that next-hop.
To resolve this, RIB (Routing Information Base) groups are used. RIB groups allow routes from one routing table (RIB) to be shared or imported into another routing table. This means that the routing instance can import the necessary routes from inet.0 and make them available for the routing instance where the policy- based routing is applied.
Detailed Steps:
* Configure the Static Route: First, configure the static route pointing to the next-hop in inet.0. Here's an example:
bash
set routing-options static route 10.1.1.0/24 next-hop 192.168.1.1
This static route will be placed in the inet.0 routing table by default.
* Create and Apply a RIB Group: To import routes from inet.0 into the routing instance, create a RIB group configuration. This will allow the static route from inet.0 to be visible within the routing instance.
Example configuration for the RIB group:
bash
set routing-options rib-groups RIB-GROUP import-rib inet.0
set routing-options rib-groups RIB-GROUP import-rib <routing-instance-name>.inet.0 This configuration ensures that routes from inet.0 are imported into the specified routing instance.
* Apply the RIB Group to the Routing Instance: Once the RIB group is configured, apply it to the appropriate routing instance:
bash
set routing-instances <routing-instance-name> routing-options rib-group RIB-GROUP
* Verify Configuration: Use the following command to verify that the static route has been imported into the routing instance:
bash
show route table <routing-instance-name>.inet.0
The output should now display the static route imported from inet.0.
Juniper Security Reference:
* RIB Groups Overview: Juniper's documentation provides detailed information on how RIB groups function and how to use them to share routes between different routing tables. This is essential for scenarios involving policy-based routing where routes from one instance (like inet.0) need to be available in another instance. Reference: Juniper Networks Documentation on RIB Groups.
By using RIB groups, you ensure that the static route from inet.0 is available in the appropriate routing instance for policy-based routing to function correctly. This avoids the need for other methods like filter- based forwarding or transparent mode, which do not address the specific issue of static route visibility across routing instances.
NEW QUESTION # 57
You have configured the backup signal route IP for your multinode HA deployment, and the ICL link fails.
Which two statements are correct in this scenario? (Choose two.)
  • A. The current active node retains the active role.
  • B. The active node removes the active signal route.
  • C. The active node keeps the active signal route.
  • D. The backup node changes the routing preference to the other node at its medium priority.
NEW QUESTION # 58
Which two security intelligence feed types are supported?
  • A. infected host feed
  • B. custom feeds
  • C. malicious URL feed
  • D. Command and Control feed
The two security intelligence feed types that are supported are:
A) Infected host feed. An infected host feed is a security intelligence feed that contains the IP addresses of hosts that are infected by malware or compromised by attackers. The SRX Series device can download the infected host feed from the Juniper ATP Cloud or generate its own infected host feed based on the detection events from IDP. The SRX Series device can use the infected host feed to block or quarantine the traffic to or from the infected hosts based on the security policies1.
B) Command and Control feed. A command and control feed is a security intelligence feed that contains the IP addresses of servers that are used by malware or attackers to communicate with infected hosts.
The SRX Series device can download the command and control feed from the Juniper ATP Cloud or generate its own command and control feed based on the detection events from IDP. The SRX Series device can use the command and control feed to block or log the traffic to or from the command and control servers based on the security policies2.
The other options are incorrect because:
C) Custom feeds. Custom feeds are not a security intelligence feed type, but a feature that allows you to create your own security intelligence feeds based on your own criteria and sources. You can configure custom feeds by using the Junos Space Security Director or the CLI. Custom feeds are not supported by the Juniper ATP Cloud or the IDP3.
D) Malicious URL feed. Malicious URL feed is not a security intelligence feed type, but a feature that allows you to block or log the traffic to or from malicious URLs based on the security policies. The SRX Series device can download the malicious URL feed from the Juniper ATP Cloud or the Juniper Threat Labs. Malicious URL feed is not supported by the IDP4.
Reference: Infected Host Feed Overview Command and Control Feed Overview Custom Feed Overview Malicious URL Feed Overview
NEW QUESTION # 59
The successful selection, development and JN0-637 training of personnel are critical to our company's ability to provide a high standard of service to our customers and to respond their needs. That's the reason why we can produce the best JN0-637 exam prep and can get so much praise in the international market. And we always believe first-class quality comes with the first-class service. Yowill find we are proffessional on the answering the questions on our JN0-637 Study Materials.
JN0-637 Online Training: https://www.dumpsquestion.com/JN0-637-exam-dumps-collection.html
What's more, part of that DumpsQuestion JN0-637 dumps now are free: https://drive.google.com/open?id=15AtVh1U-gEFGRgp1njXRrNN-3K53tW_u
