[General] Free PDF Quiz Perfect Cisco - 300-410 - Valid Implementing Cisco Enterprise Adva
102
【General】 Free PDF Quiz Perfect Cisco - 300-410 - Valid Implementing Cisco Enterprise Adva
Posted at 2/7/2026 12:04:40      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsMaterials 300-410 dumps from Cloud Storage: https://drive.google.com/open?id=1gfWxH1s430_UfOnwBjGn3CQ-Z1Io8aqN
If you want a relevant and precise content that imparts you the most updated, relevant and practical knowledge on all the key topics of the Cisco Certification exam, no other study material meets these demands so perfectly as does DumpsMaterials’s study guides. The 300-410 questions and answers in these guides have been prepared by the best professionals who have deep exposure of the certification exams and the exam takers needs. The result is that 300-410 Study Guides are liked by so many ambitious professionals who give them first priority for their exams. The astonishing success rate of 300-410clients is enough to prove the quality and benefit of the study questions of 300-410.
Cisco 300-410 (Implementing Cisco Enterprise Advanced Routing and Services) Certification Exam is a professional-level certification offered by Cisco Systems. Implementing Cisco Enterprise Advanced Routing and Services certification is designed for the network engineers and professionals who possess advanced knowledge and skills in implementing and managing enterprise-level routing and services. It is an ideal certification for those who want to enhance their proficiency in enterprise-level routing technologies and services, such as Layer 3 VPN, MPLS, BGP, and more.
300-410 Online Training, Dumps 300-410 PDFWindows, Mac, iOS, Android, and Linux support this 300-410 practice exam. The desktop Implementing Cisco Enterprise Advanced Routing and Services (300-410) practice test software is similar to the web-based 300-410 format as far as its features are concerned. But it works offline only on the Windows operating system. The offline 300-410 Practice Exam can be taken easily just by just installing the software on your Windows laptop or computer. All three Implementing Cisco Enterprise Advanced Routing and Services (300-410) formats of DumpsMaterials are according to the latest content of the Cisco 300-410 examination.
Cisco Implementing Cisco Enterprise Advanced Routing and Services Sample Questions (Q164-Q169):NEW QUESTION # 164
Refer to Exhibit.
The network administrator configured the branch router for IPv6 on the E0/0 interface. The neighboring router is fully configured to meet requirements, but the neighbor relationship is not coming up. Which action fixes the problem on the branch router to bring the IPv6 neighbors up?
  • A. Disable OSPF for IPv4 using the no ospfv3 4 area 0 ipv4 command under the E0/0 interface
  • B. Enable the IPv4 address family under the E0/0 interface by using the address-family ipv4 unicast command
  • C. Enable the IPv4 address family under the router ospfv3 4 process by using the address-family ipv4 unicast command
  • D. Disable IPv6 on the E0/0 interface using the no ipv6 enable command
Once again, Cisco changed the IOS configuration commands required for OSPFv3 configuration. The new OSPFv3 configuration uses the "ospfv3" keyword instead of the earlier "ipv6 router ospf" routing process command and "ipv6 ospf" interface commands.
The Open Shortest Path First version 3 (OSPFv3) address families feature enables both IPv4 and IPv6 unicast traffic to be supported. With this feature, users may have two processes per interface, but only one process per address family (AF).
NEW QUESTION # 165
Refer to Exhibit.
A network administrator has successfully configured DMVPN topology between a hub and two spoke routers.
Which two configuration commands should establish direct communications between spoke 1 and spoke 2 without going through the hub? (Choose two).
  • A. At the hub router, configure ip nhrp redirect the command
  • B. At the hub router, configure the ip nhrp shortcut command.
  • C. At the spoke routers, configure the ip nhrp spoke-tunnel command.
  • D. At the hub router, configure tne Ip nhrp spoke-tunnel command
  • E. At the spoke routers, configure the ip nhrp shortcut command.
Answer: A,E
To configure Spoke to Spoke communication we can configure DMVPN Phase II or Phase III. But in Phase II, the first few packets would go through Hub. In order tototally ignore the hub, we have to use DMVPN Phase III:
DMVPN Phase III is same as Phase 2 but removes some restrictions and complexities of Phase 2. Also allows greater variety of DMVPN network designs we use:+ ip nhrp redirect in hub: tells the initiator spoke to look for a better path to the destination spoke than through the Hub. Upon receiving the NHRP redirect message thespokes communicate with each other over the hub and they have their NHRP replies for the NHRP Resolution Requests that they sent out.+ ip nhrp shortcut in spokes: overwrite the CEF table on the spoke. It basically overrides the next-hop value for a remote spoke network from the default initial hubtunnel IP address to the NHRP resolved remote spoke tunnel IP address)
NEW QUESTION # 166
To provide reachability to network 10.1.1.0 /24 from R5, the network administrator redistributes EIGRP into OSPF on R3 but notices that R4 is now taking a ........... path through R5 to reach 10.1.1.0/24 network. Which action fixes the issue while keeping the reachability from R5 to 10.1.1.0/24 network?
  • A. Apply the outbound distribution list on R5 toward R4 in OSPF.
  • B. Change the administrative distance of OSPF to 200 on R5.
  • C. Change the administrative distance of the external EIGRP to 90.
  • D. Redistribute OSPF into EIGRP on R4.
NEW QUESTION # 167
Which subnet is redistributed from EIGRP to OSPF routing protocols?
  • A. 10.1.4.0/26
  • B. 10.2.2.0/24
  • C. 10.2.3.0/26
  • D. 10.1.2.0/24
NEW QUESTION # 168
Refer to the exhibit. The services at branch B are down. An engineer notices mal rouler A and router B are not exchanging any routes Which configuration resolves the issue on router B?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 169
It is certain that the pass rate among our customers is the most essential criteria to check out whether our 300-410 training materials are effective or not. The good news is that according to statistics, under the help of our training materials, the pass rate among our customers has reached as high as 98% to 100%. And you can prepare for your 300-410 Exam with under the guidance of our training materials anywhere at any time. Just take action to purchase we would be pleased to make you the next beneficiary of our 300-410 exam practice.
300-410 Online Training: https://www.dumpsmaterials.com/300-410-real-torrent.html
