Exam JN0-481 Consultant & Reliable JN0-481 Test Sample
Posted at 2/7/2026 12:11:45
View134
Replies1
They are not forced to buy one format or the other to prepare for the Data Center, Specialist (JNCIS-DC) JN0-481 exam. Exams-boost designed Juniper JN0-481 exam preparation material in Data Center, Specialist (JNCIS-DC) JN0-481 PDF and practice test. If you prefer PDF Dumps notes or practicing on the Data Center, Specialist (JNCIS-DC) JN0-481 practice test software, use either.
Since our JN0-481 study guide have veried versions which contain the PDF, Softwate and APP online, you can study whenever you are or even offline state according to their different merits. In addition, Our JN0-481 training quiz will be very useful for you to improve your learning efficiency, because you can make full use of your all spare time to do test. It will bring a lot of benefits for you beyond your imagination if you buy our JN0-481 Study Materials.
100% Pass Quiz Juniper - High Pass-Rate JN0-481 - Exam Data Center, Specialist (JNCIS-DC) ConsultantDuring review, you can contact with our after-sales if there are any problems with our JN0-481 exam torrent. They will help you 24/7 all the time. These services assure you avoid any loss. Besides, our passing rate of JN0-481 practice materials has reached up to 98 to 100 percent up to now, so you cannot miss this opportunity. Besides, free updates of JN0-481 Exam Torrent will be sent to your mailbox freely for one year, hope you can have a great experience during usage of our practice materials.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q61-Q66):NEW QUESTION # 61
When editing a device configuration to install some manual changes, which procedure should be followed?
- A. Delete the device from the Juniper Apstra system, change the configuration, then re-import the device.
- B. Add a persistent change to a device configuration with a configlet.
- C. Edit the configuration on the device directly by the CLI; the changes will automatically be adjusted in the Juniper Apstra configuration
- D. Edit the pristine configuration of the device.
A configlet is a small piece of configuration that can be applied to a device or a group of devices to make persistent changes that are not overwritten by Apstra. Configlets can be used to install manual changes that are not part of the Apstra rendered configuration, such as custom commands, scripts, or features. Configlets can be created, edited, and deleted from the Apstra GUI or CLI.
NEW QUESTION # 62
You are working with a three-stage IP fabric using EBGP for peering. In this scenario, which two actions are required to implement ECMP? (Choose two.)
- A. Use a load balancing policy applied to BGP as an export policy.
- B. Use a load balancing policy applied to the forwarding table as an export policy.
- C. Use the multipath multiple-as BGP parameter.
- D. Use a load balancing policy applied lo BGP as an import policy.
To implement ECMP in IP fabric using EBGP, you need to enable BGP to install multiple equal- cost paths in the routing table and to advertise them to the peers.
NEW QUESTION # 63
The 10.100.0.0/16 route is being advertised into your BGP IP fabric. ECMP load balancing has been properly enabled on all devices.
In this scenario, how many routes will the leaf device in AS 65000 receive for the 10.100.0.0/16 prefix?
The leaf device in AS 65000 will receive three routes for the 10.100.0.0/16 prefix, one from each spine device in AS 65001, AS 65002, and AS 65003. Since ECMP load balancing is enabled, the leaf device will install all three routes in its routing table and distribute the traffic among them.
NEW QUESTION # 64
Which three statements describe intent-based analytics? (Choose three.)
- A. It collects information from vendor websites.
- B. It indicates when device operating versions require updating.
- C. It alerts the network operator when network performance moves away from the baseline.
- D. It is used to establish network performance baselines.
- E. It is a real-time information processing pipeline.
Answer: C,D,E
Intent-based analytics (IBA) is a feature of Juniper Apstra that allows you to combine intent from the network design with current and historic data from devices to reason about the network at- large.
IBA has the following characteristics:
It is a real-time information processing pipeline. This means that IBA can ingest, process, and analyze large amounts of data from devices in real time, using agents and probes.
Agents are software components that collect data from devices and send them to the Apstra server.
Probes are user-defined queries that aggregate data across devices and generate advanced data that can be more easily reasoned about.
It is used to establish network performance baselines. This means that IBA can use the advanced data to measure and monitor the network performance against the expected outcomes and service levels.
IBA can also use the historic data to create baselines that represent the normal behavior and state of the network.
It alerts the network operator when network performance moves away from the baseline. This means that IBA can detect and report any anomalies or deviations from the baseline or the intent in the network.
IBA can also provide insights and recommendations for troubleshooting and resolving the issues.
NEW QUESTION # 65
Which two statements ate correct about the graph query output shown in the exhibit? (Choose two.)
- A. The interface has tags assigned to it.
- B. The interface has an IP address assigned to it.
- C. The output shows a LAG connection.
- D. The switch in the output is a Juniper device.
The graph query output shown in the exhibit is a JSON representation of an interface node and its properties in the Apstra graph database. Based on the output, we can infer the following statements:
The output shows a LAG connection. This is true because the interface node has a property called lag_mode which is set to lacp_active, indicating that the interface is part of a link aggregation group (LAG) that uses the Link Aggregation Control Protocol (LACP) to negotiate the link state and parameters.
The switch in the output is a Juniper device. This is true because the interface node has a property called if_name which is set to ae, indicating that the interface name follows the Juniper naming convention for aggregated Ethernet interfaces.
The interface has an IP address assigned to it. This is false because the interface node has properties called ipv4_addr and ipv6_addr which are both set to null, indicating that the interface does not have any IPv4 or IPv6 address configured.
The interface has tags assigned to it. This is false because the interface node has a property called tags which is set to null, indicating that the interface does not have any tags associated with it.
NEW QUESTION # 66
It is of great importance to consolidate all key knowledge points of the JN0-481 exam. It is difficult for you to summarize by yourself. It is a complicated and boring process. We will collect all relevant reference books of the JN0-481 exam written by famous authors from the official website. And it is not easy and will cost a lot of time and efforts. At the same time, it is difficult to follow and trace the changes of the JN0-481 Exam, but our professional experts are good at this for you. Just buy our JN0-481 study materials, you will succeed easily!
Reliable JN0-481 Test Sample: https://www.exams-boost.com/JN0-481-valid-materials.html
With our JN0-481 free practice exams, you will minimize your cost on the exam preparation and be ready to pass your JN0-481 actual test on your first try, The JN0-481 exam questions have simplified the sophisticated notions, With our JN0-481 free demo files, you will not waste precious studying hours filling your head with useless information, Users can start using Juniper JN0-481 instantly after purchasing it.
Here you'll set your hardware white point by JN0-481 clicking on the Measure button and selecting from the gray boxes I mentioned earlier, There are a variety of reasons, including Exam JN0-481 Consultant the following: A stunt may be too dangerous for an actor to perform on location.
Juniper JN0-481 Dumps-Ensure your Brilliant Success In ExamWith our JN0-481 Free Practice Exams, you will minimize your cost on the exam preparation and be ready to pass your JN0-481 actual test on your first try, The JN0-481 exam questions have simplified the sophisticated notions.
You know, the time is very tight now.
- JN0-481 Latest Braindumps Ebook 🎭 JN0-481 Premium Files 🎳 Reliable JN0-481 Test Duration 🤜 Search for ✔ JN0-481 ️✔️ and download it for free immediately on ➽ [url]www.testkingpass.com 🢪 ℹReliable JN0-481 Test Experience[/url]
- Juniper JN0-481 PDF Questions - Pass Your Exam With Ease ➰ Go to website [url]www.pdfvce.com open and search for JN0-481 to download for free 🕠JN0-481 Premium Files[/url]
- Dump JN0-481 Check 🚋 JN0-481 Reliable Test Labs 🏍 JN0-481 Reliable Test Guide 🦔 ⮆ [url]www.examdiscuss.com ⮄ is best website to obtain [ JN0-481 ] for free download 🍲JN0-481 Dumps Cost[/url]
- Get Ready for JN0-481 with Juniper's Realistic Exam Questions and Accurate Answers 🤺 Simply search for ▷ JN0-481 ◁ for free download on [url]www.pdfvce.com ℹReliable JN0-481 Test Experience[/url]
- JN0-481 Latest Braindumps Ebook 🔥 JN0-481 Dumps Cost 🧶 JN0-481 Dumps Torrent 🚶 Open [url]www.examcollectionpass.com and search for ➠ JN0-481 🠰 to download exam materials for free 🤸Original JN0-481 Questions[/url]
- Visual JN0-481 Cert Exam 🦛 Examcollection JN0-481 Questions Answers 🍱 Download JN0-481 Fee ⛲ Download { JN0-481 } for free by simply entering [url]www.pdfvce.com website 📁JN0-481 Dumps Cost[/url]
- Get Ready for JN0-481 with Juniper's Realistic Exam Questions and Accurate Answers 🐃 Easily obtain [ JN0-481 ] for free download through [ [url]www.vceengine.com ] 🔺Reliable JN0-481 Test Duration[/url]
- Get Ready for JN0-481 with Juniper's Realistic Exam Questions and Accurate Answers 🍐 Download ⏩ JN0-481 ⏪ for free by simply searching on ➤ [url]www.pdfvce.com ⮘ 🦨Examcollection JN0-481 Questions Answers[/url]
- JN0-481 Online Exam 🧟 Dump JN0-481 Check 🔕 Updated JN0-481 CBT 🟠 Open [url]www.troytecdumps.com enter JN0-481 and obtain a free download 🤦New Study JN0-481 Questions[/url]
- JN0-481 Reliable Test Guide 🏛 Dump JN0-481 Check ⛺ JN0-481 Reliable Test Labs I Open ☀ [url]www.pdfvce.com ️☀️ and search for JN0-481 to download exam materials for free 🏸JN0-481 Online Exam[/url]
- JN0-481 Online Exam ⭐ JN0-481 Dumps Torrent 🧉 JN0-481 Reliable Test Labs ⛅ Download ➤ JN0-481 ⮘ for free by simply entering ▷ [url]www.vceengine.com ◁ website 🥩Original JN0-481 Questions[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, chillimath.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
