Trustworthy Professional-Cloud-Network-Engineer Source, Test Professional-Cloud-
Posted at 2/7/2026 12:37:01
P.S. Free 2026 Google Professional-Cloud-Network-Engineer dumps are available on Google Drive shared by iPassleader: https://drive.google.com/open?id=1IJne887Bft_kl6_CbiQl7gXUVvrdoFSF
all of our Google Professional-Cloud-Network-Engineer exam questions follow the latest exam pattern. We have included only relevant and to-the-point Google Professional-Cloud-Network-Engineer exam questions for the Google Cloud Certified - Professional Cloud Network Engineer exam preparation. You do not need to waste time preparing for the exam with extra or irrelevant outdated Google Professional-Cloud-Network-Engineer exam questions. Employers in multinational companies do not want people who have passed the Professional-Cloud-Network-Engineer Exam but do not understand the Google Professional-Cloud-Network-Engineer exam topics in depth. Our Google Certified Professionals make sure that Professional-Cloud-Network-Engineer exam questions cover all core exam topics, allowing you to better understand the important exam topics.
Google Professional Cloud Network Engineer Certified Professional salaryThe average salary of a Google Professional Cloud Network Engineer Certified Expert in
- India - 27,42,327 INR
- England - 135,632 POUND
- Europe - 145,347 EURO
- United State - 181,247 USD
Test Professional-Cloud-Network-Engineer Question & Latest Professional-Cloud-Network-Engineer Exam RegistrationHowever, iPassleader saves your money by offering Professional-Cloud-Network-Engineer real questions at an affordable price. In addition, we offer up to 12 months of free Professional-Cloud-Network-Engineer exam questions. This way you can save money even if Professional-Cloud-Network-Engineer introduces fresh Google Cloud Certified - Professional Cloud Network Engineer Professional-Cloud-Network-Engineer exam updates. Purchase the Google Professional-Cloud-Network-Engineer preparation material to get certified on the first attempt.
Google Cloud Certified - Professional Cloud Network Engineer Sample Questions (Q67-Q72):NEW QUESTION # 67
You are designing a hybrid cloud environment for your organization. Your Google Cloud environment is interconnected with your on-premises network using Cloud HA VPN and Cloud Router. The Cloud Router is configured with the default settings. Your on-premises DNS server is located at 192.168.20.88 and is protected by a firewall, and your Compute Engine resources are located at 10.204.0.0/24. Your Compute Engine resources need to resolve on-premises private hostnames using the domain corp.altostrat.com while still resolving Google Cloud hostnames. You want to follow Google-recommended practices. What should you do?
- A. Create a private forwarding zone in Cloud DNS for 'corp.altostrat.com' called corp-altostrat-com that points to 192.168.20.88.
Configure your on-premises firewall to accept traffic from 10.204.0.0/24.
Set a custom route advertisement on the Cloud Router for 10.204.0.0/24 - B. Create a private forwarding zone in Cloud DNS for 'corp.altostrat.com' called corp-altostrat-com that points to 192.168 20.88.
Configure your on-premises firewall to accept traffic from 35.199.192.0/19 Set a custom route advertisement on the Cloud Router for 35.199.192.0/19. - C. Create a private zone in Cloud DNS for 'corp altostrat.com' called corp-altostrat-com.
Configure DNS Server Policies and create a policy with Alternate DNS servers to 192.168.20.88.
Configure your on-premises firewall to accept traffic from 35.199.192.0/19.
Set a custom route advertisement on the Cloud Router for 35.199.192.0/19. - D. Create a private forwarding zone in Cloud DNS for 'corp .altostrat.com' called corp-altostrat-com that points to 192.168.20.88.
Modify the /etc/resolv conf file on your Compute Engine instances to point to 192.168.20 88
NEW QUESTION # 68
Your company is planning a migration to Google Kubernetes Engine. Your application team informed you that they require a minimum of 60 Pods per node and a maximum of 100 Pods per node Which Pod per node CIDR range should you use?
The correct answer is B. /25.
This answer is based on the following facts:
The Pod per node CIDR range determines the size of the IP address range that is assigned to each node for Pods1. The Pods that run on a node are allocated IP addresses from the node's assigned CIDR range1.
The size of the CIDR range corresponds to the maximum number of Pods per node. For example, a /24 CIDR range allows up to 256 IP addresses, but the default maximum number of Pods per node for Standard clusters is 1102. A /25 CIDR range allows up to 128 IP addresses, which is enough for 100 Pods per node.
The other options are not correct because:
Option A is too large. A /24 CIDR range allows more IP addresses than needed for 100 Pods per node. This could result in inefficient use of the IP address space and limit the number of nodes that can be created in the cluster.
Option C is too small. A /26 CIDR range allows only 64 IP addresses, which is not enough for 60 Pods per node. This could result in insufficient capacity to schedule Pods on the nodes.
Option D is also too small. A /28 CIDR range allows only 16 IP addresses, which is far below the minimum requirement of 60 Pods per node. This could result in Pod scheduling failures and poor performance.
NEW QUESTION # 69
Your company is working with a partner to provide a solution for a customer. Both your company and the partner organization are using GCP. There are applications in the partner's network that need access to some resources in your company's VPC. There is no CIDR overlap between the VPCs.
Which two solutions can you implement to achieve the desired results without compromising the security? (Choose two.)
- A. Shared VPC
- B. VPC peering
- C. Cloud VPN
- D. Cloud NAT
- E. Dedicated Interconnect
Google Cloud VPC Network Peering allows internal IP address connectivity across two Virtual Private Cloud (VPC) networks regardless of whether they belong to the same project or the same organization.
NEW QUESTION # 70
After a network change window one of your company's applications stops working. The application uses an on-premises database server that no longer receives any traffic from the application. The database server IP address is 10.2.1.25. You examine the change request, and the only change is that 3 additional VPC subnets were created. The new VPC subnets created are 10.1.0.0/16, 10.2.0.0/16, and 10.3.1.0/24/ The on-premises router is advertising 10.0.0.0/8.
What is the most likely cause of this problem?
- A. The less specific VPC subnet route is taking priority.
- B. The more specific VPC subnet route is taking priority.
- C. A cloud firewall rule that blocks traffic to the on-premises database server was created during the change.
- D. The on-premises router is not advertising a route for the database server.
NEW QUESTION # 71
You have a Cloud Storage bucket in Google Cloud project XYZ. The bucket contains sensitive dat a. You need to design a solution to ensure that only instances belonging to VPCs under project XYZ can access the data stored in this Cloud Storage bucket. What should you do?
- A. Configure Private Service Connect to privately access Cloud Storage from all VPCs under project XYZ.
- B. Configure a VPC Service Controls perimeter around project XYZ, and include storage.googleapis.com as a restricted service in the service perimeter.
- C. Configure Private Google Access to privately access the Cloud Storage service using private IP addresses.
- D. Configure Cloud Storage with projectPrivate Access Control List (ACL) that gives permission to the project team based on their roles.
NEW QUESTION # 72
Laziness will ruin your life one day. It is time to have a change now. Although we all love cozy life, we must work hard to create our own value. Then our Professional-Cloud-Network-Engineer training materials will help you overcome your laziness. Study is the best way to enrich your life. On one hand, you may learn the newest technologies in the field with our Professional-Cloud-Network-Engineer Study Guide to help you better adapt to your work, and on the other hand, you will pass the Professional-Cloud-Network-Engineer exam and achieve the certification which is the symbol of competence.
Test Professional-Cloud-Network-Engineer Question: https://www.ipassleader.com/Google/Professional-Cloud-Network-Engineer-practice-exam-dumps.html
- Professional-Cloud-Network-Engineer Authentic Exam Questions 🍵 Professional-Cloud-Network-Engineer Test Dumps Demo 🕞 Reliable Professional-Cloud-Network-Engineer Dumps Free ↩ Open ☀ [url]www.practicevce.com ️☀️ and search for ➡ Professional-Cloud-Network-Engineer ️⬅️ to download exam materials for free 📅
rofessional-Cloud-Network-Engineer Free Pdf Guide[/url] - Professional-Cloud-Network-Engineer Certificate Exam 🐌 Dump Professional-Cloud-Network-Engineer Torrent 🥶 Reliable Professional-Cloud-Network-Engineer Test Duration 🥖 Easily obtain ▛ Professional-Cloud-Network-Engineer ▟ for free download through ⇛ [url]www.pdfvce.com ⇚ 🐪New Professional-Cloud-Network-Engineer Test Price[/url]
- Google Professional-Cloud-Network-Engineer Practice Test In Desktop Format 🎓 Search for ➠ Professional-Cloud-Network-Engineer 🠰 and download it for free immediately on ➠ [url]www.examdiscuss.com 🠰 🗳
rofessional-Cloud-Network-Engineer Valid Exam Braindumps[/url] - New Professional-Cloud-Network-Engineer Test Price 🚐 Professional-Cloud-Network-Engineer Detailed Study Dumps ☁ Professional-Cloud-Network-Engineer Valid Exam Braindumps 📹 Open ☀ [url]www.pdfvce.com ️☀️ enter ▷ Professional-Cloud-Network-Engineer ◁ and obtain a free download 🍬
remium Professional-Cloud-Network-Engineer Exam[/url] - Professional-Cloud-Network-Engineer Detailed Study Dumps 🐍 Professional-Cloud-Network-Engineer Free Pdf Guide 🛃 Reliable Professional-Cloud-Network-Engineer Dumps Free 🦁 Go to website 「 [url]www.testkingpass.com 」 open and search for ⏩ Professional-Cloud-Network-Engineer ⏪ to download for free 📙Latest Professional-Cloud-Network-Engineer Test Cram[/url]
- Best Google Trustworthy Professional-Cloud-Network-Engineer Source Professionally Researched by Google Certified Trainers 🚓 Search for 「 Professional-Cloud-Network-Engineer 」 and download it for free immediately on ➥ [url]www.pdfvce.com 🡄 💓
rofessional-Cloud-Network-Engineer Free Pdf Guide[/url] - 100% Pass Quiz 2026 Google Professional-Cloud-Network-Engineer: Google Cloud Certified - Professional Cloud Network Engineer – Valid Trustworthy Source 🥻 Search for ➥ Professional-Cloud-Network-Engineer 🡄 on ▛ [url]www.vceengine.com ▟ immediately to obtain a free download 🟤
rofessional-Cloud-Network-Engineer Real Brain Dumps[/url] - Professional-Cloud-Network-Engineer Free Pdf Guide 🐬 Latest Professional-Cloud-Network-Engineer Test Cram ⭕ New Professional-Cloud-Network-Engineer Exam Notes 🐀 Search for 【 Professional-Cloud-Network-Engineer 】 on ▶ [url]www.pdfvce.com ◀ immediately to obtain a free download 🦋Study Professional-Cloud-Network-Engineer Tool[/url]
- Google Professional-Cloud-Network-Engineer Practice Test - Right Preparation Method [[url]www.practicevce.com] 🌰 Search for ➽ Professional-Cloud-Network-Engineer 🢪 and download it for free on ⏩ www.practicevce.com ⏪ website 🕢Reliable Professional-Cloud-Network-Engineer Test Duration[/url]
- [url=https://acts3.org/?s=Google%20Professional-Cloud-Network-Engineer%20Practice%20Test%20-%20Right%20Preparation%20Method%20[Pdfvce]%20%f0%9f%98%85%20Download%20{%20Professional-Cloud-Network-Engineer%20}%20for%20free%20by%20simply%20searching%20on%20{%20www.pdfvce.com%20}%20%f0%9f%a5%bbProfessional-Cloud-Network-Engineer%20Lead2pass]Google Professional-Cloud-Network-Engineer Practice Test - Right Preparation Method [Pdfvce] 😅 Download { Professional-Cloud-Network-Engineer } for free by simply searching on { www.pdfvce.com } 🥻
rofessional-Cloud-Network-Engineer Lead2pass[/url] - Dumps Professional-Cloud-Network-Engineer PDF 👔 Reliable Professional-Cloud-Network-Engineer Dumps Free 🐘 Reliable Professional-Cloud-Network-Engineer Test Duration 📿 Simply search for ⮆ Professional-Cloud-Network-Engineer ⮄ for free download on 《 [url]www.troytecdumps.com 》 💃Reliable Professional-Cloud-Network-Engineer Dumps Free[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.mixcloud.com, www.stes.tyc.edu.tw, Disposable vapes
