[Hardware] CheckPoint 156-587 New Dumps Questions & New 156-587 Braindumps Questions
128
【Hardware】 CheckPoint 156-587 New Dumps Questions & New 156-587 Braindumps Questions
Posted at 2/7/2026 12:50:19      View:79 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ValidBraindumps 156-587 dumps for free: https://drive.google.com/open?id=12GpEEn4B_XthhVSrwIQjLVJGgeD58xBH
Desktop and web-based 156-587 practice exams are available at ValidBraindumps for thorough preparation. Going through these CheckPoint 156-587 mock exams boosts your learning and reduces mistakes in the CheckPoint 156-587 Test Preparation. Customization features of CheckPoint 156-587 practice tests allow you to change the settings of the 156-587 test sessions.
CheckPoint 156-587 Exam Syllabus Topics:
  • Advanced Troubleshooting with Logs and Events: This section of the exam measures the skills of  Check Point Security Administrators and covers the analysis of logs and events for troubleshooting. Candidates will learn how to interpret log data to identify issues and security threats effectively.
  • Advanced Firewall Kernel Debugging: This section of the exam measures the skills of Check Point Network Security Administrators and focuses on kernel-level debugging for firewalls. Candidates will learn how to analyze kernel logs and troubleshoot firewall-related issues at a deeper level.
  • Advanced Access Control Troubleshooting: This section of the exam measures the skills of Check Point System Administrators in demonstrating expertise in troubleshooting access control mechanisms. It involves understanding user permissions and resolving authentication issues.
  • Advanced Site-to-Site VPN Troubleshooting: This section of the exam measures the skills of Check Point System Administrators and covers troubleshooting site-to-site VPN connections.
Topic 5
  • Advanced Client-to-Site VPN Troubleshooting: This section of the exam measures the skills of CheckPoint System Administrators and focuses on troubleshooting client-to-site VPN issues.
Topic 6
  • Advanced Identity Awareness Troubleshooting: This section of the exam measures the skills of heck Point Security Consultants and focuses on troubleshooting identity awareness systems.
Topic 7
  • Introduction to Advanced Troubleshooting: This section of the exam measures the skills of Check Point Network Security Engineers and covers the foundational concepts of advanced troubleshooting techniques. It introduces candidates to various methodologies and approaches used to identify and resolve complex issues in network environments.
New 156-587 Braindumps Questions & 156-587 Test DumpOne more thing to give you an idea about the top features of Check Point Certified Troubleshooting Expert - R81.20 (156-587) exam questions before purchasing, the ValidBraindumps are offering free ValidBraindumps 156-587 Exam Questions demo download facility. This facility is being offered in all three ValidBraindumps 156-587 exam practice question formats.
CheckPoint Check Point Certified Troubleshooting Expert - R81.20 Sample Questions (Q43-Q48):NEW QUESTION # 43
Troubleshooting issues with Mobile Access requires the following:
  • A. Standard VPN debugs, packet captures and debugs of cvpnd1 process on Security Gateway
  • B. Standard VPN debugs and packet captures on Security Gateway, debugs of 'cvpnd' process on Security Management
  • C. Debug logs of FWD captured with the command - 'fw debug fwd on
    TDERROR_MOBILE_ACCESS=5'
  • D. 'ma_vpnd' process on Security Gateway
NEW QUESTION # 44
User defined URLS and HTTPS inspection User defined URLs on the Security Gateway are stored in which database file?
  • A. urtf_https.bin
  • B. https_db.bin
  • C. https_urif.bin
  • D. urlf db.bin
NEW QUESTION # 45
When viewing data for CPMI objects in the Postgres database, what table column should be selected to query for the object instance?
  • A. fwset
  • B. CpmiHostCkp
  • C. GuiDBedit
  • D. CPM Global M
NEW QUESTION # 46
PostgreSQL is a powerful, open source relational database management system. Check Point offers a command for viewing the database to interact with Postgres interactive shell. Which command do you need to enter the PostgreSQL interactive shell?
  • A. mysql_client cpm postgres
  • B. psql_client postgres cpm
  • C. mysql -u root
  • D. psql_client cpm postgres
The correct command to enter the PostgreSQL interactive shell is psql_client cpm postgres. This command allows the administrator to view and manipulate the database of the Check Point Management (CPM) module, which stores the configuration and policy data. The psql_client command is a Check Point wrapper for the psql command, which is the native PostgreSQL interactive shell. The psql_client command takes two arguments: the first one is the name of the database module, and the second one is the name of the database user. In this case, the database module is cpm and the database user is postgres.
The other commands are incorrect because:
A . mysql_client cpm postgres is not a valid command. The mysql_client command is used to access the MySQL database, which is not used by Check Point. The Check Point database is based on PostgreSQL, not MySQL.
B . mysql -u root is not a valid command. The mysql command is used to access the MySQL database, which is not used by Check Point. The Check Point database is based on PostgreSQL, not MySQL. Moreover, the -u option specifies the MySQL user name, which is not relevant for Check Point.
D . psql_client postgres cpm is not a valid command. The psql_client command takes the database module name as the first argument, and the database user name as the second argument. In this case, the database module name is cpm and the database user name is postgres. The order of the arguments is reversed in this command.
How to use PostgreSQL interactive shell (psql) with Check Point database Check Point Database Tool (GuiDBedit) - Check Point Software (CCTE) - Check Point Software
NEW QUESTION # 47
You were asked by security team to debug Mobile Access VPN. What processes will you debug?
  • A. IKED
  • B. SNX daemon
  • C. VPND and IKED
  • D. HTTPD and CPVND
NEW QUESTION # 48
With the development of society, CheckPoint industry has been tremendously popular. And more and more people join CheckPoint 156-587 certification exam and want to get CheckPoint certificate that make them go further in their career. This time you should be thought of ValidBraindumps website that is good helper of your exam. ValidBraindumps powerful exam dumps is experiences and results summarized by 156-587 experts in the past years, standing upon the shoulder of predecessors, it will let you further access to success.
New 156-587 Braindumps Questions: https://www.validbraindumps.com/156-587-exam-prep.html
DOWNLOAD the newest ValidBraindumps 156-587 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=12GpEEn4B_XthhVSrwIQjLVJGgeD58xBH
