[General] SAP C-TS422-2023 dumps VCE file - Testking C-TS422-2023 real dumps
89
General SAP C-TS422-2023 dumps VCE file - Testking C-TS422-2023 real dumps
Posted at 2/7/2026 14:39:15      View165 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Actual4Dumps C-TS422-2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1nG6rh2bpLOjBm09bBtEV4ujZPly1acU-
Provided you get the certificate this time with our C-TS422-2023 practice materials, you may have striving and excellent friends and promising colleagues just like you. It is also as obvious magnifications of your major ability of profession, so C-TS422-2023 practice materials may bring underlying influences with positive effects. The promotion or acceptance will be easy. So it is quite rewarding investment. Propulsion occurs when using our C-TS422-2023 practice materials. They can even broaden amplitude of your horizon in this line. Of course, knowledge will accrue to you from our C-TS422-2023 practice materials.
SAP C-TS422-2023 Exam Syllabus Topics:
  • Capacity Planning in SAP S
  • 4HANA: This section covers a discussion of SAP S
  • 4HANA best practices, SAP HANA database concept, SAP Fiori user experience, and embedded analytics capabilities.
  • Introduction to SAP S
  • 4HANA Supply Chain Planning: This part covers the background and motivation for SAP S
  • 4HANA, its main components, business applications, and user experience strategy.
  • 4HANA Production Planning: This section covers an overview of production planning components, functions, and planning approaches. Exploration of emerging trends.
  • Material Requirements Planning in SAP S
  • 4HANA: This part of the exam covers an examination of planning strategies, tools, and long-term planning concepts. Overview of MRP fundamentals and lot size procedures.
Topic 5
  • Advanced Planning in SAP S
  • 4HANA: This section includes an overview of advanced planning fundamentals and master data. Explanation of key tools and processes. Discussion of planning evaluation concepts.
Topic 6
  • Production Orders in SAP S
  • 4HANA: This section covers BOM item categorization, order status management, availability checks, routing selection, order type setup, and material handling processes.
Role of SAP C-TS422-2023 Exam Questions in Getting the Highest-Paid JobChoosing our C-TS422-2023 exam quiz will be a wise decision that you make, because this decision may have a great impact in your future development. Having the C-TS422-2023 certificate may be something you have always dreamed of, because it can prove that you have certain strength. Our C-TS422-2023 Exam Questions can provide you with services with pretty quality and help you obtain a certificate. The quality of our C-TS422-2023 learning materials can withstand the test of practice.
SAP S/4HANA Cloud Private Edition - Production Planning and Manufacturing Sample Questions (Q35-Q40):NEW QUESTION # 35
Which time elements does MRP consider in backward scheduling to determine the order dates for components from dependent requirements?
Note: There are 2 correct answers to this question
  • A. Planned delivery time
  • B. In-house production time
  • C. Total replenishment lead time
  • D. Operation duration
Backward scheduling is a method of determining the order dates for components from dependent requirements by starting from the requirement date of the finished product and working backwards through the production structure. Backward scheduling considers the following time elements:
Operation duration: This is the time required to perform an operation on a resource, such as a work center or a machine. Operation duration is influenced by various factors, such as the quantity, the lot size, the setup time, the processing time, the teardown time, and the operation scrap. Operation duration is subtracted from the requirement date of the finished product to determine the start date of the operation.
In-house production time: This is the time required to produce a material in-house, from the start of the first operation to the end of the last operation. In-house production time is influenced by various factors, such as the routing, the work center, the production version, and the scheduling margin key. In-house production time is subtracted from the start date of the first operation to determine the order start date of the material.
Backward scheduling does not consider the following time elements:
Total replenishment lead time: This is the time required to procure a material externally, from the creation of the purchase requisition to the receipt of the goods. Total replenishment lead time is influenced by various factors, such as the planned delivery time, the goods receipt processing time, the release time, and the scheduling margin key. Total replenishment lead time is used in forward scheduling, not backward scheduling, to determine the order dates for externally procured materials.
Planned delivery time: This is the time required to deliver a material from the vendor to the receiving plant. Planned delivery time is maintained in the purchasing info record or the material master record. Planned delivery time is a component of the total replenishment lead time, which is used in forward scheduling, not backward scheduling, to determine the order dates for externally procured materials. Reference: Backward Scheduling | SAP Help Portal, Scheduling | SAP Help Portal, SAP S/4HANA Production Planning and Manufacturing Certification Guide, page 77-78.
NEW QUESTION # 36
You want to use capacity availability checks for production orders. Which settings have to be made for this?
  • A. A checking rule must be assigned to the work centers.
  • B. The scope of check must be defined in Customizing.
  • C. The Relevant for Finite Scheduling indicator must be set.
  • D. An overall profile must be assigned in the checking control.
NEW QUESTION # 37
How can a material availability check be triggered automatically for a production order? Note: There are 2 correct answers to this question.
  • A. By order release
  • B. By capacity planning
  • C. By mass processing
  • D. By order confirmation
In SAP S/4HANA, a material availability check ensures components are available before production proceeds. This check can be triggered automatically:
* By order release(C): When a production order is released (transaction CO02 or mass release via CO05N), the system can perform an availability check based on settings in the order type-dependent parameters (Customizing: Production > Shop Floor Control > Define Order Types). The "Availability Check" field (e.g., "2 - Check at Release") triggers this automatically, ensuring materials are reserved or shortages are flagged.
* By mass processing(D): Using transaction COHV (Mass Processing of Production Orders), planners can execute availability checks for multiple orders simultaneously. The function "Check Material Availability" can be scheduled or run manually, automating the process across orders.
By capacity planning(A) focuses on work center capacity, not material availability.By order confirmation(B) may trigger a check for remaining quantities, but it's not a standard automatic trigger point-it's more relevant for backflushing or goods issue. This is outlined in SAP's production order management documentation.
NEW QUESTION # 38
Under what circumstances can you change the material type for a material if stocks reservations or purchasing documents exist? Note: There are 2 correct answers to this question.
  • A. The quantity value updates are the same.
  • B. The same account category is used.
  • C. The same base unit of measure is used.
  • D. The same batch management level is used.
NEW QUESTION # 39
Under what circumstances can you change the material type for a material if stocks, reservations, or purchasing documents exist? Note: There are 2 correct answers to this question.
  • A. The quantity and value updates are the same
  • B. The same base unit of measure is used.
  • C. The same account category is used
You can change the material type for a material if stocks, reservations, or purchasing documents exist only if the following conditions are met:
The same base unit of measure is used. This ensures that the material quantity is consistent across different material types.
The quantity and value updates are the same. This ensures that the material valuation is consistent across different material types.
The material is not subject to split valuation. This ensures that the material has only one valuation class and price control. Reference: [SAP Help Portal] - Change Material Type
NEW QUESTION # 40
In the course of your study, the test engine of C-TS422-2023 actual exam will be convenient to strengthen the weaknesses in the learning process. This can be used as an alternative to the process of sorting out the wrong questions of C-TS422-2023 learning guide in peacetime learning, which not only help you save time, but also makes you more focused in the follow-up learning process with our C-TS422-2023 learning materials.
Pass C-TS422-2023 Guarantee: https://www.actual4dumps.com/C-TS422-2023-study-material.html
Posted at 2/24/2026 11:26:10        Only Author  2#
Im deeply appreciative of your article, it was truly enlightening. Good luck to me as I prepare for the 350-701 latest exam dumps.zip exam!
