[General] Pass Guaranteed CAS-004 - CompTIA Advanced Security Practitioner (CASP+) Exam Ne
97
【General】 Pass Guaranteed CAS-004 - CompTIA Advanced Security Practitioner (CASP+) Exam Ne
Posted at 2/7/2026 15:05:45      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that ITExamDownload CAS-004 dumps now are free: https://drive.google.com/open?id=1o8JX_9486d1aBIQhEl7OrbIzN205FDBL
We understand your itching desire of the exam. Do not be bemused about the exam. We will satisfy your aspiring goals. Our CAS-004 real questions are high efficient which can help you pass the exam during a week. We just contain all-important points of knowledge into our CAS-004 latest material. And we keep ameliorate our CAS-004 latest material according to requirements of CAS-004 exam. Besides, we arranged our CAS-004 Exam Prep with clear parts of knowledge. You may wonder whether our CAS-004 real questions are suitable for your current level of knowledge about computer, as a matter of fact, our CAS-004 exam prep applies to exam candidates of different degree. By practicing and remember the points in them, your review preparation will be highly effective and successful.
Achieving the CASP+ certification demonstrates that an individual has the skills and knowledge necessary to effectively manage and respond to security threats and incidents. It is a valuable certification for professionals who are involved in cybersecurity operations, including security analysts, engineers, architects, and managers. The CASP+ certification is also recognized by the U.S. Department of Defense (DoD) and is included in the DoD 8570.01-M directive.
To be eligible for the CASP+ certification exam, candidates must have a minimum of ten years of experience in IT administration, including a minimum of five years of hands-on technical security experience. CompTIA Advanced Security Practitioner (CASP+) Exam certification exam is intended to validate the candidate's knowledge and skills in advanced-level cybersecurity concepts and practices. CompTIA Advanced Security Practitioner (CASP+) Exam certification will demonstrate to employers that the candidate has the expertise and experience to design, implement, and manage cybersecurity solutions at the enterprise level.
CAS-004 Latest Dumps Pdf | CAS-004 Exam SuccessWhen people take the subway staring blankly, you can use Pad or cell phone to see the PDF version of the CAS-004 study materials. While others are playing games online, you can do online CAS-004 exam questions. We are sure that as you hard as you are, you can Pass CAS-004 Exam easily in a very short time. While others are surprised at your achievement, you might have found a better job.
For more information about the CompTIA CAS-004 Exam visit the following reference link:CompTIACAS-004 Exam's Reference link
CompTIA Advanced Security Practitioner (CASP+) Exam Sample Questions (Q325-Q330):NEW QUESTION # 325
A pharmaceutical company was recently compromised by ransomware. Given the following EDR output from the process investigation:
On which of the following devices and processes did the ransomware originate?
  • A. cpt-ws018, powershell.exe
  • B. cpt-ws002, NO-AV.exe
  • C. cpt-ws026, DearCry.exe
  • D. cpt-ws026, NO-AV.exe
  • E. cpt-ws002, DearCry.exe
The EDR output shows the process tree of the ransomware infection. The root node is NO-AV.exe, which is a malicious executable that disables antivirus software and downloads the DearCry ransomware. The NO-AV.exe process was launched on cpt-ws026 by a user named John. The DearCry.exe process was then launched on cpt-ws026 by NO-AV.exe and propagated to other devices via SMB. Therefore, the ransomware originated from cpt-ws026 and NO-AV.exe. Verified References:
* https://www.microsoft.com/securi ... -first-attack-to-ex
* https://www.crowdstrike.com/blog/dearcry-ransomware-analysis/
NEW QUESTION # 326
An application security engineer is performing a vulnerability assessment against a new web application that uses SAML. The engineer wants to identify potential authentication issues within the application. Which of the following methods would be most appropriate for the engineer to perform?
  • A. Dynamic analysis
  • B. Fuzz testing
  • C. Side-channel analysis
  • D. Static analysis
In this case, the security engineer is assessing a web application that uses SAML, and dynamic analysis (also known as DAST - Dynamic Application Security Testing) is the most appropriate method to identify potential authentication issues. Dynamic analysis tests the application in a runtime environment, allowing the engineer to identify vulnerabilities that arise during actual application execution, such as SAML misconfigurations or other authentication weaknesses. This is more effective for finding authentication issues compared to static analysis, which only reviews code without execution.
NEW QUESTION # 327
A company is outsourcing to an MSSP that performs managed detection and response services. The MSSP requires a server to be placed inside the network as a log aggregate and allows remote access to MSSP analyst.
Critical devices send logs to the log aggregator, where data is stored for 12 months locally before being archived to a multitenant cloud. The data is then sent from the log aggregate to a public IP address in the MSSP datacenter for analysis.
A security engineer is concerned about the security of the solution and notes the following.
* The critical devise send cleartext logs to the aggregator.
* The log aggregator utilize full disk encryption.
* The log aggregator sends to the analysis server via port 80.
* MSSP analysis utilize an SSL VPN with MFA to access the log aggregator remotely.
* The data is compressed and encrypted prior to being achieved in the cloud.
Which of the following should be the engineer's GREATEST concern?
  • A. Hardware vulnerabilities introduced by the log aggregate server
  • B. Multinancy and data remnants in the cloud
  • C. Network bridging from a remote access VPN
  • D. Encryption of data in transit
Encryption of data in transit should be the engineer's greatest concern regarding the security of the solution.
Data in transit refers to data that is being transferred over a network or between devices. If data in transit is not encrypted, it can be intercepted, modified, or stolen by attackers who can exploit vulnerabilities in the network protocols or devices. The solution in the question sends logs from the critical devices to the aggregator in cleartext and from the aggregator to the analysis server via port 80, which are both insecure methods that expose the data to potential attacks. Verified References:
https://www.comptia.org/training/books/casp-cas-004-study-guide ,https://us-cert.cisa.gov/ncas/tips/ST04-019
NEW QUESTION # 328
A security administrator sees several hundred entries in a web server security log that are similar to the following:
The network source varies, but the URL, status, and user agent are the same. Which of the following would BEST protect the web server without blocking legitimate traffic?
  • A. Replace the file xmlrpc.php with a honeypot form to collect further IOCs.
  • B. Script the daily collection of the WHOIS ranges to add to the WAF as a denied ACL.
  • C. Automate the addition of bot IP addresses into a deny list for the web host.
  • D. Block every subnet that is identified as having a bot that is a source of the traffic.
NEW QUESTION # 329
A security analyst is investigating a series of suspicious emails by employees to the security team. The email appear to come from a current business partner and do not contain images or URLs. No images or URLs were stripped from the message by the security tools the company uses instead, the emails only include the following in plain text.
Which of the following should the security analyst perform?
  • A. Block the IP address for the business partner at the perimeter firewall.
  • B. Contact the security department at the business partner and alert them to the email event.
  • C. Configure the email gateway to automatically quarantine all messages originating from the business partner.
  • D. Pull the devices of the affected employees from the network in case they are infected with a zero-day virus.
The best option for the security analyst to perform is to contact the security department at the business partner and alert them to the email event. The email appears to be a phishing attempt that tries to trick the employees into revealing their login credentials by impersonating a legitimate sender. The security department at the business partner should be notified so they can investigate the source and scope of the attack and take appropriate actions to protect their systems and users. Verified References: https://www.comptia.org/training
/books/casp-cas-004-study-guide , https://us-cert.cisa.gov/ncas/tips/ST04-014
NEW QUESTION # 330
CAS-004 Latest Dumps Pdf: https://www.itexamdownload.com/CAS-004-valid-questions.html
P.S. Free 2026 CompTIA CAS-004 dumps are available on Google Drive shared by ITExamDownload: https://drive.google.com/open?id=1o8JX_9486d1aBIQhEl7OrbIzN205FDBL
