[Hardware] 100% Pass 4A0-113 Nokia OSPF Routing Protocol Exam Marvelous New Test Dumps
82
【Hardware】 100% Pass 4A0-113 Nokia OSPF Routing Protocol Exam Marvelous New Test Dumps
Posted at 2/7/2026 15:05:58      View:96 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that VCE4Dumps 4A0-113 dumps now are free: https://drive.google.com/open?id=1YqvzHEtlGkzn2KIHio1xavrIcvzl2kJT
This updated 4A0-113 exam study material consists of 4A0-113 PDF dumps, desktop practice exam software, and a web-based practice test. Experts have prepared the 4A0-113 desktop-based exam simulation software. There are 4A0-113 Actual Questions in the practice test to give you an exact impression of the Nokia 4A0-113 original test.
Nokia 4A0-113 certification exam is designed to test a candidate's knowledge and skills in implementing and troubleshooting the Open Shortest Path First (OSPF) routing protocol using Nokia equipment. OSPF is a widely used routing protocol in enterprise and service provider networks, and mastering this technology is essential for professionals working with Nokia routers and switches.
Nokia 4A0-113 certification exam is designed for network professionals who are interested in demonstrating their expertise in OSPF routing protocol. Nokia is a globally recognized technology leader that offers high-quality solutions in the telecommunications industry. The Nokia 4A0-113 Certification Exam is one of the most sought-after certifications in the industry, as it validates the candidates' knowledge and skills in working with Nokia's OSPF routing protocol.
Free PDF Quiz 2026 Nokia Pass-Sure 4A0-113: New Nokia OSPF Routing Protocol Exam Test DumpsIf you are determined to enter into Nokia company or some companies who are the product agents of Nokia, a good certification will help you obtain more jobs and high positions. VCE4Dumps release high passing-rate 4A0-113 exam simulations to help you obtain certification in a short time. If you obtain a certification you will get a higher job or satisfying benefits with our 4A0-113 Exam Simulations. Every day there is someone choosing our exam materials. If this is what you want, why are you still hesitating?
Nokia OSPF Routing Protocol Exam Sample Questions (Q59-Q64):NEW QUESTION # 59
Which of the following statements regarding OSPF routing updates on a multi-access network segment is true?
  • A. In multi-access networks, a DR and BDR are elected. The DR sends link-state advertisements describing the network.
  • B. In multi-access networks, a DR and BDR are elected only if there are more than two routers connected to the network segment.
  • C. In multi-access networks, a DR and BDR are elected. To ensure resiliency, both the DR and BDR send link-state advertisements describing the network.
  • D. In multi-access networks, a DR and BDR are elected only if the subnet masks on the router interfaces are less than /30.
From Nokia 7750 SR OS Routing Protocols Guide (OSPF DR/BDR Election and LSA Generation):
DR is responsible for generating Type 2 LSAs to describe the broadcast network.
BDR is only a standby and does not send LSAs unless promoted to DR.
DR/BDR election occurs regardless of the number of routers if the network type is broadcast.
Thus, correct answer: D.
NEW QUESTION # 60
Click the exhibit button.
Two neighboring OSPF routers have exchanged the packets shown. What state is the adjacency in?
  • A. Full; both routers are exchanging Helios to maintain the adjacency.
  • B. The adjacency is in the exchange state.
  • C. The adjacency is down.
  • D. The adjacency is in exstart state.
Analysis of the Exhibit:
The two routers are exchanging OSPF Hello packets.
Both Hello packets contain:
Same Hello and Dead Intervals.
Same Options field.
Same Router Priority.
Same subnet mask.
Authentication: Null.
BUT - The key issue is:
The Area ID is different:
Left router: Area ID 0.0.0.0
Right router: Area ID 0.0.1.1
OSPF Neighbor Formation Rule:
From Nokia 7750 SR OS Routing Protocols Guide (OSPF Neighbor Adjacency Criteria):
"OSPF neighbors must have matching Area IDs, Hello Intervals, Dead Intervals, Stub Flag, Authentication, and Interface Subnet." Since the Area IDs are mismatched, adjacency will not form.
B). The adjacency is down.
OSPF adjacency formation fails when Area IDs do not match. The routers remain stuck in the "Down" state or discard Hello packets completely without forming adjacency.
Fully verified and aligned with Nokia 7750 SR OS documentation.
NEW QUESTION # 61
When redistributing OSPF into RIP V2 what must be taken into consideration for the redistribution to take place?
  • A. The metric must be set accordingly for RIP
  • B. The subnet mask must be removed from the OSPF route
  • C. You must divide the cost of the OSPF route by three
  • D. The router must be configured as an ASBR
From Nokia 7750 SR OS Routing Protocols Guide (RIP Redistribution):
RIP uses hop count as a metric, while OSPF uses cost.
When redistributing OSPF routes into RIP, you must assign a valid RIP metric (hop count) through policies or default metric settings.
If no metric is assigned, redistribution will fail or install unreachable routes (default RIP maximum is 16 hops).
Thus, correct answer: A.
NEW QUESTION # 62
What are the default Hello and Dead timer intervals for OSPF on the Nokia 7750 SR?
  • A. 10 and 40 seconds
  • B. 10 and 30 seconds
  • C. 5 and 15 seconds
  • D. 5 and 20 seconds
FromNokia 7750 SR OS OSPF Guide - OSPF Timers Section:
"The default OSPF Hello interval is 10 seconds, and the default Dead interval is four times the Hello interval (40 seconds)." Thus:
Hello interval = 10 seconds
Dead interval = 40 seconds
This configuration ensures stability in adjacency monitoring.
NEW QUESTION # 63
What is the protocol number for OSPF in the IP header?
  • A. OSPF uses UDP, so the protocol number is 17.
  • B. OSPF does not use IP.
  • C. OSPF has its own protocol number of 89.
  • D. OSPF uses TCP, so the protocol number is 6.
NEW QUESTION # 64
Our 4A0-113 training materials are famous for high-quality, and we have a professional team to collect the first hand information for the exam. 4A0-113 learning materials of us also have high accurate, since we have the professionals check the exam dumps at times. We are strict with the answers and quality, we can ensure you that the 4A0-113 Learning Materials you get are the latest one we have. Moreover, we offer you free update for one year and the update version for the 4A0-113 exam dumps will be sent to your email automatically.
Latest 4A0-113 Test Online: https://www.vce4dumps.com/4A0-113-valid-torrent.html
BTW, DOWNLOAD part of VCE4Dumps 4A0-113 dumps from Cloud Storage: https://drive.google.com/open?id=1YqvzHEtlGkzn2KIHio1xavrIcvzl2kJT
