Pass-Sure PT-AM-CPE Reliable Study Plan - Easy and Guaranteed PT-AM-CPE Exam Suc
Posted at 2/7/2026 16:39:31
View129
Replies0
Despite the complex technical concepts, our PT-AM-CPE exam questions have been simplified to the level of average candidates, posing no hurdles in understanding the various ideas. It is also the reason that our PT-AM-CPE study guide is famous all over the world. We also have tens of thousands of our loyal customers who support us on the PT-AM-CPE Learning Materials. Just look at the feedbacks on our website, they all praised our PT-AM-CPE practice engine.
The authority and validity of Ping Identity PT-AM-CPE pdf practice are the 100% pass guarantee for all the IT candidates. We ensure you one year free update after purchase, so you can obtain the latest information about PT-AM-CPE test cram review without costing extra money. Besides, you can download the PrepAwayExam PT-AM-CPE Torrent dumps and install it on your electronic device, thus you can review at anytime and anywhere available. The fast study and PT-AM-CPE valid practice will facilitate your coming test.
Perfect Ping Identity - PT-AM-CPE - Certified Professional - PingAM Exam Reliable Study PlanAs long as you choose our PT-AM-CPE exam questions, we are the family. From the time you purchase, use, and pass the exam, we will be with you all the time. You can seek our help on our PT-AM-CPE practice questions anytime, anywhere. As long as you are convenient, you can contact us by email. If you have experienced a very urgent problem while using PT-AM-CPE Exam simulating, you can immediately contact online customer service. And we will solve the problem for you right away.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q89-Q94):NEW QUESTION # 89
What authentication tree nodes are provided for device registration in PingAM?
- A. MFA Registration Options node, Push Registration node, WebAuthn Registration node
- B. OATH Registration node, Push Registration node, WebAuthn Registration node
- C. MFA Registration Options node, OATH Registration node, WebAuthn Registration node
- D. MFA Registration Options node, OATH Registration node, Push Registration node
In PingAM 8.0.2, the Intelligent Access designer provides specialized nodes to handle the onboarding and registration of Multi-Factor Authentication (MFA) devices.3 These nodes are essential for building "Self-Service" registration trees where users can enroll their smartphones or security keys.
According to the "Authentication Node Reference," the three primary nodes dedicated specifically to the act of registering a device are:
OATH Registration Node: This node generates a secret and a QR code (or manual entry code) that the user scans with an OATH-compliant app (like ForgeRock Authenticator).4 It then verifies the first code generated by the app to finalize the registration in the user's profile.
Push Registration Node: This node is used to register a device for Push notifications.5 It coordinates with the Push service to link the user's specific installation of the ForgeRock Authenticator app to their AM identity store entry.
WebAuthn Registration Node: This node handles the FIDO2/WebAuthn ceremony. It prompts the browser to interact with the user's local authenticator (like TouchID or a YubiKey) and saves the resulting public key and credential ID to the user's profile.
Why other options are incorrect: The MFA Registration Options node (found in Options A, B, and C) is a "decision" or "UI" node that allows a user to choose which MFA method they want to register (e.g., "Would you like to register Push or OATH?").6 However, it does not perform the actual technical registration logic itself. The question asks for the nodes provided for device registration, which refers to the functional nodes that execute the registration protocols. Therefore, the set of OATH, Push, and WebAuthn Registration nodes (Option D) is the correct answer.
NEW QUESTION # 90
A PingAM administrator wants to deny access to an area of a protected application if the end user has been logged in for more than 10 minutes. How can this be achieved?
- A. Use a policy with a Current session properties environment condition
- B. Use a policy with a Scripted environment condition
- C. Use a policy with a Time environment condition
- D. Use a policy with an Active session time environment condition
To enforce complex authorization logic based on session duration, PingAM 8.0.2 administrators must move beyond the static "Out-of-the-Box" conditions.
Analysis of the options based on the " olicy Conditions" documentation:
Time Condition (Option A): This condition is used to restrict access based on the clock time of day or day of the week (e.g., "Allow access only between 9 AM and 5 PM"). It does not track the elapsed time of a specific user session.
Current Session Properties (Option B): This condition checks for the presence of specific key-value pairs in a session. While a session contains a startTime property, this condition is designed for matching static values (like department=HR), not for performing mathematical time calculations.
Active Session Time (Option D): This is not a standard default condition name in the PingAM 8.0.2 policy engine.
The Correct Approach (Option C): A Scripted Policy Condition is required for this use case. Within a Policy Condition script, the administrator has access to the session object. The script can retrieve the startTime (or creationTime) of the session and compare it against the current system time (currentTime).
Example logic in the script:
var sessionStartTime = session.getProperty("startTime");
var maxDuration = 10 * 60 * 1000; // 10 minutes in milliseconds
if ((currentTime - sessionStartTime) > maxDuration) { authorized = false; } By using a script, PingAM can dynamically calculate the age of the session at the moment of the access request and return a "Deny" decision if the 10-minute threshold has been exceeded. This provides the granular control needed for high-security environments where "session freshness" is a requirement for specific sensitive resources.
NEW QUESTION # 91
OpenID Connect acr_values map to what component within PingAM?
- A. Authentication levels
- B. Authentication trees
- C. Authorization policies
- D. SAML Circles of Trust
The Authentication Context Class Reference (acr) is a standard parameter in OpenID Connect (OIDC) used by a client (Relying Party) to request a specific level or method of authentication from the OpenID Provider (PingAM 8.0.2).
According to the "OpenID Connect 1.0" and "OAuth2 Provider Service" documentation in PingAM, there is a specific configuration mapping for ACR to Authentication Tree. In the AM console, under the OAuth2 Provider > OpenID Connect tab, administrators define a list of mappings. Each entry consists of an ACR string (e.g., urn:mace:incommon:iap:silver or simply MFA) and its corresponding Authentication Tree name.
When an OIDC client sends a request to the /authorize endpoint containing the acr_values parameter, PingAM performs a lookup:
It checks the incoming acr_values against the configured map.
If a match is found, PingAM ignores the default realm authentication configuration and initiates the Authentication Tree mapped to that specific ACR value.
Upon successful completion, the resulting ID Token will contain the acr claim with the requested value, confirming to the client that the specific journey was completed.
This mechanism allows developers to programmatically request "Step-up" or "Social Login" or "MFA" specifically from their application code by leveraging OIDC standard parameters. While ACR values are often related to Authentication Levels (Option D) conceptually, in PingAM's internal architecture, they are directly used to select and trigger a specific Authentication Tree (Option A).
NEW QUESTION # 92
Which statements are correct about push notification authentication implemented with PingAM?
A . The user must have a device with a camera and install the Authenticator app.
B . The registration and authentication steps must be part of the same authentication tree.
C . To register a device the user scans a barcode with the Authenticator installed on their device.1 D . During subsequent authentication processes, PingAM instructs the push server to send a notification to the registered device, and waits for the user to use the Authenticator app to approve the request.2 Options:
- A. B, C, and D only
- B. A and B only
- C. A, B, and C only
- D. A and D only
Push authentication in PingAM 8.0.2 utilizes the ForgeRock/Ping Authenticator app to provide a seamless, out-of-band multi-factor authentication (MFA) experience.3 To understand the correct statements, we must look at the technical requirements and the authentication lifecycle defined in the "MFA: Push Authentication" documentation.
Statement A is correct: For the initial setup, a device with a camera is required because the registration process involves scanning a QR code generated by PingAM. Additionally, the user must install the specific Authenticator app (available for iOS and Android) to handle the cryptographic exchange and receive push notifications.4 Statement D is correct: This accurately describes the runtime flow of a push journey. When a user reaches a Push Sender node, PingAM communicates with the Push Notification Service (Apple APNs or Google FCM).5 The user's device receives the notification, and PingAM enters a "waiting" state (via the Push Result Verifier node) until the user either approves or denies the request within the app.6 Why other statements are incorrect:
Statement B is incorrect because registration and authentication are typically handled by separate trees. Best practice dictates a "Device Registration" tree for the initial onboarding and a "Login/MFA" tree for day-to-day access. Forcing them into the same tree would be inefficient and create a poor user experience.
Statement C is a common point of confusion; while the user scans a code, the documentation refers to it as a QR code, not a standard barcode. In technical certification contexts, this distinction is often strictly enforced.
Therefore, only statements A and D represent the verified facts of the Push implementation in version 8.0.2, making Option C the correct answer.
NEW QUESTION # 93
Which is the correct simplified TLS handshake sequence needed to authenticate clients using a mutual TLS exchange?
- A. 1. Client sends a request to a server to establish a secure connection
2. The server presents its certificate in a response to the client
3. The client sends its certificate to the server
4. The mutually secure connection is established and the client is authenticated - B. 1. Client sends a certificate in the request to a server to establish a secure connection
2. The client sends its session key to the server
3. The server presents its certificate in a response to the client
4. The mutually secure connection is established and the client is authenticated - C. 1. Client sends a request to a server to establish a secure connection
2. The server requests the client certificate
3. The client sends its certificate and the session key to the server
4. The server sends its certificate to the client if the client certificate and key are valid
5. The mutually secure connection is established and the client is authenticated - D. 1. Client sends a request to a server to establish a secure connection
2. The client sends its certificate to the server
4. The client sends its session key to the server
Mutual TLS (mTLS) is a security enhancement where both the client and the server provide X.509 certificates to prove their identities.9 In PingAM 8.0.2, mTLS is frequently used for secure "Machine-to-Machine" (M2M) communication, such as between an OAuth2 client and the token endpoint, or between AM and a Directory Server (PingDS).
According to the PingAM documentation on "Secure Network Communication" and "mTLS for OAuth2," the handshake sequence for mTLS follows these logical steps:
Client Hello: The client initiates the request to the server.10
Server Hello & Certificate: The server responds by presenting its own certificate (verifying the server's identity to the client).11 In an mTLS scenario, the server also includes a CertificateRequest message.12 Client Certificate & Key Exchange: The client validates the server's certificate. If valid, the client then sends its own Client Certificate to the server, along with the encrypted pre-master secret or key exchange data.
Verification and Establishment: The server validates the client's certificate against its truststore. If the certificate is trusted and the cryptographic signatures match, the mutually secure connection is established.
Option D represents the most accurate "simplified" sequence. Option A is incorrect because the server presents its certificate before the client sends its own certificate. Option B and C are incorrect because the server always responds to the initial "Client Hello" with its own identity (Server Certificate) before the client proceeds with identity submission. This "handshake" ensures that no data is transmitted until both parties have cryptographically verified each other.
NEW QUESTION # 94
The Certified Professional - PingAM Exam (PT-AM-CPE) Exam Questions offered by PrepAwayExam provide you with a good idea of what you can expect in the PT-AM-CPE exam from Ping Identity. All the PT-AM-CPE exam topics and objectives are well covered by our product. Thus, PrepAwayExam Ping Identity PT-AM-CPE Practice Questions are considered a very good resource that will help you in your practicing by focusing on your weak points and strengthening them to easily pass the PT-AM-CPE exam.
Test PT-AM-CPE King: https://www.prepawayexam.com/Ping-Identity/braindumps.PT-AM-CPE.ete.file.html
Ping Identity PT-AM-CPE Reliable Study Plan They are perfect, unique and the simplest for all exam candidates form varying academic backgrounds, Ping Identity PT-AM-CPE Reliable Study Plan The competition in the IT industry is very fierce, In order to ensure the quality of our PT-AM-CPE actual exam, we have made a lot of efforts, If you feel that it is worthy for you to buy our PT-AM-CPE test torrent you can choose a version which you favor, fill in our mail and choose the most appropriate purchase method and finally pay for our PT-AM-CPE study tool after you enter in the pay pages on the website.
A legitimate search engine agency probably won't make those kinds of guarantees, PT-AM-CPE Dumps Reviews This led to him working on Microsoft's freelance toolkit, a set of software tools that help corporations hire, work with and manage freelancers.
PT-AM-CPE Reliable Study Plan - Effective Test PT-AM-CPE King and Valid Certified Professional - PingAM Exam Valid Exam QuestionThey are perfect, unique and the simplest PT-AM-CPE for all exam candidates form varying academic backgrounds, The competition in the IT industry is very fierce, In order to ensure the quality of our PT-AM-CPE actual exam, we have made a lot of efforts.
Therefore, through our unremitting efforts, our PT-AM-CPE real questions have a pass rate of 98% to 100%.
- New PT-AM-CPE Exam Guide 🙈 PT-AM-CPE Latest Exam Papers 👳 Exam PT-AM-CPE Tutorial 🥠 Download PT-AM-CPE for free by simply entering ➥ [url]www.practicevce.com 🡄 website 🏊
T-AM-CPE Training Material[/url] - Efficient PT-AM-CPE Reliable Study Plan Covers the Entire Syllabus of PT-AM-CPE 🏣 Go to website ➥ [url]www.pdfvce.com 🡄 open and search for ▶ PT-AM-CPE ◀ to download for free 🐓
T-AM-CPE Exam Discount[/url] - High-quality PT-AM-CPE Reliable Study Plan Spend Your Little Time and Energy to Pass PT-AM-CPE: Certified Professional - PingAM Exam exam 🏰 Search for PT-AM-CPE and download exam materials for free through ⇛ [url]www.practicevce.com ⇚ 🐻New PT-AM-CPE Test Voucher[/url]
- PT-AM-CPE Latest Exam Papers ⏮ PT-AM-CPE Unlimited Exam Practice 🧉 Preparation PT-AM-CPE Store 🔉 Search for { PT-AM-CPE } and download it for free immediately on ➠ [url]www.pdfvce.com 🠰 🔜
T-AM-CPE Latest Exam Papers[/url] - PT-AM-CPE Trustworthy Dumps 🌑 PT-AM-CPE Exam Topics Pdf 🏅 PT-AM-CPE Detail Explanation 🔻 Download ➽ PT-AM-CPE 🢪 for free by simply entering ➽ [url]www.pass4test.com 🢪 website 🚓
reparation PT-AM-CPE Store[/url] - Free PDF PT-AM-CPE - Latest Certified Professional - PingAM Exam Reliable Study Plan 👽 Search for ✔ PT-AM-CPE ️✔️ and download it for free immediately on ⏩ [url]www.pdfvce.com ⏪ 🥂
T-AM-CPE Training Material[/url] - 2026 Ping Identity Efficient PT-AM-CPE: Certified Professional - PingAM Exam Reliable Study Plan 🟫 Search for PT-AM-CPE and download it for free on ➽ [url]www.torrentvce.com 🢪 website 👙
T-AM-CPE Exam Materials[/url] - PT-AM-CPE Real Exam 🍘 PT-AM-CPE Training Material 👸 Training PT-AM-CPE Materials 🐸 The page for free download of PT-AM-CPE on ⮆ [url]www.pdfvce.com ⮄ will open immediately 🚙Latest PT-AM-CPE Test Dumps[/url]
- PT-AM-CPE Reliable Study Plan - Free PDF Quiz First-grade Ping Identity Test PT-AM-CPE King 📳 Search for PT-AM-CPE and download exam materials for free through ▛ [url]www.troytecdumps.com ▟ 📲Braindump PT-AM-CPE Free[/url]
- Braindump PT-AM-CPE Free 📌 PT-AM-CPE New Dumps Files 🆗 PT-AM-CPE Unlimited Exam Practice 🧔 Search for { PT-AM-CPE } and download it for free immediately on ▷ [url]www.pdfvce.com ◁ 🌄New PT-AM-CPE Exam Guide[/url]
- High-quality PT-AM-CPE Reliable Study Plan Spend Your Little Time and Energy to Pass PT-AM-CPE: Certified Professional - PingAM Exam exam 📔 Go to website ▛ [url]www.pdfdumps.com ▟ open and search for ⇛ PT-AM-CPE ⇚ to download for free 🙁
T-AM-CPE Exam Materials[/url] - www.stes.tyc.edu.tw, estar.jp, app.parler.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, yu856.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
