[General] Reliable ISTQB CT-AI Exam Simulations, Latest CT-AI Test Cram
98
【General】 Reliable ISTQB CT-AI Exam Simulations, Latest CT-AI Test Cram
Posted at 2/7/2026 17:35:36      View:106 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TorrentExam CT-AI dumps from Cloud Storage: https://drive.google.com/open?id=1aiBDRfeiLkwlnkelhsJb1ODRx9LMKYMm
TorrentExam's ISTQB CT-AI exam questions pdf is formed in a proper way that gives candidates the necessary asthenic unformatted data required to pass the ISTQB exam. The study materials highlight a few basic and important questions that are repeatedly seen in past ISTQB exam paper sheets. The ISTQB CT-AI Practice Questions are easy to access and can be downloaded anytime on your mobile, laptop, or MacBook.
ISTQB CT-AI Exam Syllabus Topics:
  • Using AI for Testing: In this section, the exam topics cover categorizing the AI technologies used in software testing.
  • Testing AI-Specific Quality Characteristics: In this section, the topics covered are about the challenges in testing created by the self-learning of AI-based systems.
  • Test Environments for AI-Based Systems: This section is about factors that differentiate the test environments for AI-based
  • Quality Characteristics for AI-Based Systems: This section covers topics covered how to explain the importance of flexibility and adaptability as characteristics of AI-based systems and describes the vitality of managing evolution for AI-based systems. It also covers how to recall the characteristics that make it difficult to use AI-based systems in safety-related applications.
Topic 5
  • ML Functional Performance Metrics: In this section, the topics covered include how to calculate the ML functional performance metrics from a given set of confusion matrices.
Topic 6
  • Introduction to AI: This exam section covers topics such as the AI effect and how it influences the definition of AI. It covers how to distinguish between narrow AI, general AI, and super AI; moreover, the topics covered include describing how standards apply to AI-based systems.
Topic 7
  • Machine Learning ML: This section includes the classification and regression as part of supervised learning, explaining the factors involved in the selection of ML algorithms, and demonstrating underfitting and overfitting.
Topic 8
  • Methods and Techniques for the Testing of AI-Based Systems: In this section, the focus is on explaining how the testing of ML systems can help prevent adversarial attacks and data poisoning.
Topic 9
  • Testing AI-Based Systems Overview: In this section, focus is given to how system specifications for AI-based systems can create challenges in testing and explain automation bias and how this affects testing.
Topic 10
  • Neural Networks and Testing: This section of the exam covers defining the structure and function of a neural network including a DNN and the different coverage measures for neural networks.
Topic 11
  • ML: Data: This section of the exam covers explaining the activities and challenges related to data preparation. It also covers how to test datasets create an ML model and recognize how poor data quality can cause problems with the resultant ML model.
High-quality ISTQB Reliable CT-AI Exam Simulations & Authorized TorrentExam - Leader in Certification Exam MaterialsIt is universally accepted that in this competitive society in order to get a good job we have no choice but to improve our own capacity and explore our potential constantly, and try our best to get the related CT-AI certification is the best way to show our professional ability, however, the CT-AI Exam is hard nut to crack but our CT-AI preparation questions are closely related to the exam, it is designed for you to systematize all of the key points needed for the CT-AI exam.
ISTQB Certified Tester AI Testing Exam Sample Questions (Q34-Q39):NEW QUESTION # 34
Which statement regarding pairwise testing in an AI-based automotive lane-keeping assist system is correct?
Choose ONE option (1 out of 4)
  • A. Pairwise testing is usually insufficient because most defects arise only from interactions of many parameters.
  • B. Pairwise testing only uses parameters directly influenced by the driver, otherwise the number of test cases becomes too large.
  • C. Pairwise testing reduces the test suite so much that it is typically feasible within the available time.
  • D. Pairwise testing can reduce testing efforts otherwise very high due to the large number of parameters.
The ISTQB CT-AI syllabus (Section4.3 - Test Design for AI-Based Systems) highlights pairwise testing as an effectivetest-case reduction techniquefor systems with many input parameters. Lane-keeping assist systems typically include environmental, sensor, and vehicle-dynamic parameters, making exhaustive testing infeasible. Pairwise testing significantly reduces the number of test cases while still capturingall 2-way interactions, which are responsible for a large proportion of software defects.
OptionBaligns with this syllabus description: pairwise testing reduces otherwise extremely large parameter combinations, making test effort manageable.
Option A overstates feasibility guarantees; the syllabus never claims pairwise testing always makes testing
"typically feasible." Option C is unsupported and incorrect because pairwise testing doesnotrestrict parameters to driver-controlled ones. Option D is incorrect because, although some defects arise from higher- order interactions, pairwise testing captures many relevant defects and is widely recognized as a pragmatic compromise.
Thus,Option Bis the correct statement.
NEW QUESTION # 35
Which ONE of the following hardware is MOST suitable for implementing Al when using ML?
SELECT ONE OPTION
  • A. 64-bit CPUs.
  • B. Hardware supporting high precision floating point operations.
  • C. Hardware supporting fast matrix multiplication.
  • D. High powered CPUs.
A . 64-bit CPUs.
While 64-bit CPUs are essential for handling large amounts of memory and performing complex computations, they are not specifically optimized for the types of operations commonly used in machine learning.
B . Hardware supporting fast matrix multiplication.
Matrix multiplication is a fundamental operation in many machine learning algorithms, especially in neural networks and deep learning. Hardware optimized for fast matrix multiplication, such as GPUs (Graphics Processing Units), is most suitable for implementing AI and ML because it can handle the parallel processing required for these operations efficiently.
C . High powered CPUs.
High powered CPUs are beneficial for general-purpose computing tasks and some aspects of ML, but they are not as efficient as specialized hardware like GPUs for matrix multiplication and other ML-specific tasks.
D . Hardware supporting high precision floating point operations.
High precision floating point operations are important for scientific computing and some specific AI tasks, but for many ML applications, fast matrix multiplication is more critical than high precision alone.
Therefore, the correct answer is B because hardware supporting fast matrix multiplication, such as GPUs, is most suitable for the parallel processing requirements of machine learning.
NEW QUESTION # 36
Which of the following aspects is a challenge when handling test data for an AI-based system?
  • A. Output data or intermediate data
  • B. Personal data or confidential data
  • C. Video frame speed or aspect ratio
  • D. Data frameworks or machine learning frameworks
The syllabus explicitly mentions challenges of handling personal data and ensuring privacy when testing AI- based systems:
"The management of personal data and sensitive data is often a concern during testing, as testing typically requires realistic data and it is difficult to fully anonymize data." (Reference: ISTQB CT-AI Syllabus v1.0, Section 7.3, page 52 of 99)
NEW QUESTION # 37
Which of the following descriptions of quality aspects of a data set is correct?
  • A. The quality aspect "Unbalanced data" describes the fact that the data used should be as up-to-date as possible.
  • B. The quality aspect "Irrelevant data" describes the fact that irrelevant data does not affect the ML model.
  • C. The quality aspect "Incomplete data" describes the fact that data is missing, e.g., for a certain time interval.
  • D. The quality aspect "Data not preprocessed" describes the fact that the collected data was recorded incorrectly.
The ISTQB CT-AI syllabus describes severaldata quality aspectsthat affect ML performance. In Section2.2
- Data Preparation, it explains that datasets may suffer from issues such asincomplete data,irrelevant data, incorrect data,unbalanced data, or data lacking preprocessing. "Incomplete data" means thatportions of the required data are missing, often because some time periods, records, or sources were not captured. This aligns exactly with Option A, which correctly identifies missing intervals as incomplete data.
Option B is incorrect: "data not preprocessed" refers to data that has not undergone normalization, cleaning, or transformation-not data recorded incorrectly. Option C is wrong because irrelevant datadoesnegatively affect ML models by introducing noise and unnecessary features. The syllabus explicitly states that including irrelevant features can degrade model learning. Option D is incorrect: "unbalanced data" relates to disproportionate class distribution, not recency or freshness of data.
Thus, OptionAis the only statement that correctly matches the syllabus definition of this data quality aspect.
NEW QUESTION # 38
Which of the following statements regarding experience-based testing for AI-based systems is correct?
  • A. Intuitive test case design for AI-based systems involves interactive, hypothesis-driven examination of data for correlations or developmental trends.
  • B. In checklist-based testing of AI-based systems, the existing test cases are dynamically adapted, for example based on metamorphic testing.
  • C. Tour refers to intuitive test case design for AI-based systems based on multiple, sequential test cases using systematically biased training data.
  • D. Exploratory testing is often used for AI-based systems because there are often insufficient specifications or problems with the test oracle for AI-based systems.
The ISTQB CT-AI syllabus explains inSection 4.4 - Experience-Based Testing for AI Systemsthat AI- based systems frequently suffer frominsufficient specifications, unpredictable model behavior, andtest oracle problems, especially when outputs depend on probabilistic or learned patterns. The syllabus explicitly states thatexploratory testingis especially valuable in such contexts because it allows testers to investigate the system interactively, observe unexpected behavior, and evaluate system responses that cannot be fully predicted beforehand. Thus, OptionCaccurately reflects the role and justification of exploratory testing for AI systems.
Option A describes data analysis rather than intuitive test design. Option B is incorrect because checklist- based testing does not dynamically adapt test cases; instead, it follows predetermined checklists. Option D incorrectly defines "tour-based testing"; tours refer to structured exploratory approaches, not biased datasets.
Therefore,Option Cis the syllabus-aligned correct statement.
NEW QUESTION # 39
In this fast-changing world, the requirements for jobs and talents are higher, and if people want to find a job with high salary they must boost varied skills which not only include the good health but also the working abilities. But if you get the CT-AI certification, your working abilities will be proved and you will find an ideal job. We provide you with CT-AI Exam Materials of high quality which can help you pass the CT-AI exam easily. It also saves your much time and energy that you only need little time to learn and prepare for CT-AI exam.
Latest CT-AI Test Cram: https://www.torrentexam.com/CT-AI-exam-latest-torrent.html
P.S. Free 2026 ISTQB CT-AI dumps are available on Google Drive shared by TorrentExam: https://drive.google.com/open?id=1aiBDRfeiLkwlnkelhsJb1ODRx9LMKYMm
