[General] CCDAK Pass4sure Dumps Pdf | CCDAK Valid Test Book
【General】 CCDAK Pass4sure Dumps Pdf | CCDAK Valid Test Book
Posted at 2/7/2026 18:19:44      View:88 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4King CCDAK dumps now are free: https://drive.google.com/open?id=1kfTlT-C38OerJR8gS5x8_QwbVq1wyYN5
Just as an old saying goes, it is better to gain a skill than to be rich. Contemporarily, competence far outweighs family backgrounds and academic degrees. One of the significant factors to judge whether one is competent or not is his or her CCDAK certificates. Generally speaking, CCDAK certificates function as the fundamental requirement when a company needs to increase manpower in its start-up stage. In this respect, our CCDAK practice materials can satisfy your demands if you are now in preparation for a CCDAK certificate.
Confluent CCDAK (Confluent Certified Developer for Apache Kafka) certification exam is designed for professionals who want to demonstrate their expertise in Apache Kafka. Confluent Certified Developer for Apache Kafka Certification Examination certification is globally recognized and validates one's ability to develop applications that can effectively utilize Kafka's capabilities.
CCDAK Valid Test Book, Exams CCDAK TorrentWe have the CCDAK Questions and answers with high accuracy and timely update. Our professional team checks CCDAK answers and questions carefully with their professional knowledge. We also have the latest information about the exam center, and will update the version according to the new requirements. Pass guarantee and money back guarantee are also our principles, and if you have any questions, you can also consult the service stuff.
Confluent Certified Developer for Apache Kafka Certification Examination Sample Questions (Q13-Q18):NEW QUESTION # 13
What client protocol is supported for the schema registry? (select two)
  • A. SASL
  • B. HTTPS
  • C. JDBC
  • D. HTTP
  • E. Websocket
clients can interact with the schema registry using the HTTP or HTTPS interface
NEW QUESTION # 14
Which is true about topic compaction?
  • A. When a client produces a new event with an existing key, the broker immediately deletes the offset of the existing event.
  • B. When a client produces a new event with an existing key, the old value is overwritten with the new value in the compacted log segment.
  • C. Topic compaction does not remove old events; instead, when clients consume events from a compacted topic, they store events in a hashmap that maintains the latest value.
  • D. Compaction will keep exactly one message per key after compaction of inactive log segments.
Log compactionensures that Kafka retains at least thelatest value per keyin a topic. Compaction happensin the backgroundand removes older records with the same keyin inactive log segments, not immediately.
From theKafka Documentation > Log Compaction:
"Kafka guarantees that thelast message for each keywill be retained in the log after compaction, even if earlier messages with the same key are deleted." So, D is correct. A is incorrect because compaction does not overwrite; it's a background process. B is incorrect-deletion is not immediate. C incorrectly suggests client-side hashmap behavior.
Reference:Apache Kafka Log Compaction Docs
NEW QUESTION # 15
What information isn't stored inside of Zookeeper? (select two)
  • A. Broker registration info
  • B. Controller registration
  • C. Consumer offset
  • D. Schema Registry schemas
  • E. ACL inforomation
Consumer offsets are stored in a Kafka topic __consumer_offsets, and the Schema Registry stored schemas in the _schemas topic.
NEW QUESTION # 16
In Avro, adding an element to an enum without a default is a __ schema evolution
  • A. forward
  • B. full
  • C. backward
  • D. breaking
Since Confluent 5.4.0, Avro 1.9.1 is used. Since default value was added to enum complex type , the schema resolution changed from:
(<1.9.1) if both are enums:** if the writer's symbol is not present in the reader's enum, then an error is signalled. **(>=1.9.1) if both are enums:
if the writer's symbol is not present in the reader's enum and the reader has a default value, then that value is used, otherwise an error is signalled.
NEW QUESTION # 17
You have a consumer group of 12 consumers and when a consumer gets killed by the process management system, rather abruptly, it does not trigger a graceful shutdown of your consumer. Therefore, it takes up to 10 seconds for a rebalance to happen. The business would like to have a 3 seconds rebalance time. What should you do? (select two)
  • A. increase max.poll.interval.ms
  • B. Decrease heartbeat.interval.ms
  • C. decrease max.poll.interval.ms
  • D. Decrease session.timeout.ms
  • E. Increase session.timeout.ms
  • F. Increase heartbeat.interval.ms
session.timeout.ms must be decreased to 3 seconds to allow for a faster rebalance, and the heartbeat thread must be quicker, so we also need to decrease heartbeat.interval.ms
NEW QUESTION # 18
With passing rate up to 98 to 100 percent, the quality and accuracy of our CCDAK training materials are unquestionable. You may wonder their price must be equally steep. While it is not truth. On the contrary everyone can afford them easily. By researching on the frequent-tested points in the real exam, our experts have made both clear outlines and comprehensive questions into our CCDAK Exam Prep. So our CCDAK practice engine is easy for you to understand.
CCDAK Valid Test Book: https://www.prep4king.com/CCDAK-exam-prep-material.html
2026 Latest Prep4King CCDAK PDF Dumps and CCDAK Exam Engine Free Share: https://drive.google.com/open?id=1kfTlT-C38OerJR8gS5x8_QwbVq1wyYN5
Posted at 2/15/2026 03:10:05        Only Author  2#
Die ASQ CMQ-OE Zertifizierungsprüfung ist zur Zeit sehr beliebt bei den IT-Fachleuten. Durch die ASQ CMQ-OE Zertifizierungsprüfung werden Ihre Lebens-und Arbeitsverhältnisse verbessert. Daneben wird Ihre Position in der IT-Branche gefestigt.
