[General] CTFL-AT Actual Exam Dumps, Latest CTFL-AT Practice Materials
【General】 CTFL-AT Actual Exam Dumps, Latest CTFL-AT Practice Materials
Posted at 2/7/2026 18:35:10      View:96 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4away CTFL-AT dumps now are free: https://drive.google.com/open?id=1KEqRJkTvdhmjnjACSI6L0a7_E4yGYIZC
If you do not quickly begin to improve your own strength, the next one facing the unemployment crisis is you. The time is very tight, and choosing our CTFL-AT study materials can save you a lot of time. And our CTFL-AT Exam Questions can really save you time and efforts. If you study with our CTFL-AT learning guide for 20 to 30 hours, then you will be able to pass the exam and get the certification.
ISQI CTFL-AT exam, also known as the ISTQB Certified Tester - Foundation Level Extension - Agile Tester, is a certification exam designed to test the foundational knowledge of agile testing. CTFL-AT exam is ideal for individuals who have experience in software testing and are looking to expand their knowledge in agile methodologies. The CTFL-AT Certification is recognized globally and is highly valued by employers in the software development industry.
Latest CTFL-AT Practice Materials | Reliable CTFL-AT Exam TestkingIndividuals who pass the ISTQB Certified Tester - Foundation Level Extension - Agile Tester (CTFL-AT) certification exam demonstrate to their employers and clients that they have the knowledge and skills necessary to succeed in the industry. Prep4away is aware that preparing with outdated ISTQB Certified Tester - Foundation Level Extension - Agile Tester (CTFL-AT) study material results in a loss of time and money.
ISQI ISTQB Certified Tester - Foundation Level Extension - Agile Tester Sample Questions (Q74-Q79):NEW QUESTION # 74
Which of the following statements about the differences between testing activities in Agile projects and traditional projects is true?
  • A. In traditional V-model projects there is a system test level that usually involves executing functional tests as well as non-functional tests, while in Agile projects there is never a system test level
  • B. In traditional V-model projects the different test phases are performed sequentially, while in Agile projects these phases are performed parallel to one another within each iteration
  • C. Risk-based testing can be adopted both in Agile projects and traditional projects. In Agile projects, the specific risks for all of the iterations are identified and assessed during release planning
  • D. Because Agile projects tend to adopt test-first approaches, test automation in Agile projects is performed at lower test levels, while test automation in traditional projects is performed at higher test levels
FromCTFL-AT Syllabus v4.0, Section 2.4Testing and Iterations, it states:
"In Agile projects, testing activities are conducted in parallel with development activities within an iteration, unlike traditional models where testing is done after development." Therefore,Option Dis correct - Agile promotesparallel testing, while traditional projects (e.g., V-model) followsequential phases.
* Option Ais incorrect - Agile projectsdo perform system testing, but it's integrated within iterations.
* Option Bis misleading - while Agile emphasizeslower-level test automation, traditional projects also use automation at various levels.
* Option Cis partially correct but oversimplifies the process -risks are reassessed iteratively, not just once during release planning.
Learning Objective (K2) - Compare Agile vs traditional testing activities
NEW QUESTION # 75
Which ONE of the following is an example of a typical "Business-oriented work product"?
  • A. A user manual.
  • B. The released product.
  • C. Usability testing test results.
  • D. Acceptance testing entry criteria.
Business-oriented work products are those that describe what is needed (e.g., requirements specifications) and how to use it (e.g., user documentation). A user manual is an example of a business-oriented work product, as it provides instructions and guidance on how to use the product from the user's perspective. A user manual may also contain information about the product's features, benefits, and limitations. A user manual is typically written by technical writers, who may collaborate with developers, testers, and business analysts to ensure the accuracy and clarity of the content. A user manual may be delivered in various formats, such as printed, online, or interactive. References: ISTQB Foundation Level Agile Tester Syllabus1, Section
1.2.1, page 10; ASTQB Agile Tester Certification Resources2, Section 1.2.1, page 10.
NEW QUESTION # 76
In Agile projects, which of the following approaches would result in the best compromise for preserving independence of testers and for allowing testers to have a good understanding of the product as well as good relationships with other team members?
  • A. Having only Agile teams where testers are integral parts and where they perform many of the testing tasks, without having an independent test team
  • B. Having independent separate test teams where all of the testers work separately from developers without being assigned to Agile teams
  • C. Having independent separate test teams where testers are assigned to Agile teams on-demand during the final days of each iteration
  • D. Having independent separate test teams where testers are assigned to Agile teams on a long-term basis, at the beginning of an Agile project
FromCTFL-AT Syllabus v4.0, Section 2.5Testers and Independence, it states:
"Testers may be assigned to Agile teams on a permanent or rotating basis. While full independence is compromised, this setup allows for better collaboration and understanding of the product, while still maintaining some degree of independence." Thus,Option Bis the most accurate -long-term embedded testerssupport Agile collaboration while preservingpartial independence.
* Option Aleads tolate involvement, which contradicts Agile principles.
* Option Csacrifices independence entirely.
* Option Dis traditional and contrary to Agile values of collaboration.
Learning Objective (K2) - Understand approaches to preserving test independence in Agile
NEW QUESTION # 77
Which agile development approach incorporates the following practices:
* a project is divided into iterations called sprints
* each sprint results in a potentially releasable/shippable product?
  • A. Extreme Programming
  • B. Continuous Integration
  • C. Kanban
  • D. Scrum
NEW QUESTION # 78
Which of the following is an Agile software development approach in which transparency of content and progress of tasks is usually obtained with the visualization of the active tasks and in which iterations are optional?
  • A. Scrum
  • B. Continuous integration
  • C. Kanban
  • D. Slack
FromCTFL-AT Syllabus v4.0, Section 1.2Fundamentals of Agile Software Development, it states:
"Kanban is a lean approach that uses visualization (typically via a task board) to manage work in progress and improve workflow. Unlike Scrum, iterations in Kanban are optional." Thus,Option C (Kanban)is correct. It emphasizesvisualizationand doesnot require fixed-length iterations.
* Option A (Scrum)is iteration-based.
* Option B (Continuous integration)is a practice, not a development approach.
* Option D (Slack)is a communication tool, not a methodology.
Learning Objective (K1) - Recognize Agile development approaches
NEW QUESTION # 79
By choosing a good training site, you can achieve remarkable results. Prep4away has committed to provide all real ISQI CTFL-AT practice tests. Prep4away ISQI CTFL-AT exam dumps authorized by the supplier, with wide coverage can save a lot of time for you. Guarantee your success in the first attempt. If you do not pass the ISQI Business Solutions CTFL-AT Exam on your first attempt we will give you a FULL REFUND of your purchasing fee. Failing an Exam won't damage you financially as we provide 100% refund on claim.
Latest CTFL-AT Practice Materials: https://www.prep4away.com/ISQI-certification/braindumps.CTFL-AT.ete.file.html
BONUS!!! Download part of Prep4away CTFL-AT dumps for free: https://drive.google.com/open?id=1KEqRJkTvdhmjnjACSI6L0a7_E4yGYIZC
Posted at 2/8/2026 23:52:07        Only Author  2#
This article is phenomenal, I’m grateful for your sharing. Sharpen your IT knowledge with free Valid CCDM test materials. Best of luck to you!
