[Hardware] Latest CRT-450 Test Blueprint - 2026 Salesforce First-grade CRT-450 Cost Effecti
96
【Hardware】 Latest CRT-450 Test Blueprint - 2026 Salesforce First-grade CRT-450 Cost Effecti
Posted at 2/7/2026 20:24:29      View:118 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest FreeDumps CRT-450 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1vm3PmkzIsAubdWFAV1Bsped2jpfFA3Nr
Firstly, we can give you 100% pass rate guarantee on the CRT-450 exam. Our CRT-450 practice quiz is equipped with a simulated examination system with timing function, allowing you to examine your learning results at any time, keep checking for defects, and improve your strength. Secondly, during the period of using CRT-450 learning guide, we also provide you with 24 hours of free online services, which help to solve any problem for you on the CRT-450 exam questions at any time and sometimes mean a lot to our customers.
The Salesforce CRT-450 exam consists of 60 multiple-choice questions that must be completed within 105 minutes. The questions are designed to test the candidate's knowledge and understanding of the Salesforce platform, including Apex programming language, Visualforce framework, and the Salesforce development process. CRT-450 Exam also covers the use of the Salesforce development tools, such as Developer Console and Force.com IDE.
CRT-450 Cost Effective Dumps, CRT-450 Valid Test PatternWith the CRT-450 certification exam you can climb up the corporate ladder faster and achieve your professional career objectives. Do you plan to enroll in the Salesforce CRT-450 certification exam? Looking for a simple and quick way to crack the CRT-450 test? If your answer is yes then you need to start Salesforce CRT-450 Test Preparation with Salesforce CRT-450 PDF Questions and practice tests. With the FreeDumps Salesforce Certified Platform Developer I CRT-450 practice test questions you can prepare yourself shortly for the final Salesforce CRT-450 exam.
Salesforce Certified Platform Developer I Sample Questions (Q218-Q223):NEW QUESTION # 218
Which three operations affect the number of times a trigger can fire?
Choose 3 answers
  • A. Criteria-based Sharing calculations
  • B. Workflow Rules
  • C. Process Flows
  • D. Email messages
  • E. Roll-Up Summary fields
Answer: B,C,E
NEW QUESTION # 219
If apex code executes inside the execute() method of an Apex class when implementing the Batchable interface, which statement are true regarding governor limits? Choose 2 answers
  • A. The Apex governor limits cannot be exceeded due to the asynchronous nature of the transaction,
  • B. The Apex governor limits are relaxed while calling the constructor of the Apex class.
  • C. The Apex governor limits might be higher due to the asynchronous nature of the transaction.
  • D. The apex governor limits are reset for each iteration of the execute() method.
NEW QUESTION # 220
What are three ways for 2 developer to execute tests in an org? Choose 3 answers
  • A. Metadata APT
  • B. SalesforceDX
  • C. Tooling API
  • D. Bulk API
  • E. Setup Menu
Answer: B,C,E
A developer can execute tests in an org using the following methods:
* Setup Menu: By browsing to setup->Apex Test Execution, the developer can select and run tests from the user interface1.
* SalesforceDX: By using the Salesforce CLI on the command line, the developer can run tests in an org using the force:apex:test:run command2. This command can also be used from Salesforce Extensions for VS Code or from within third-party continuous integration tools, such as Jenkins or CircleCI2.
* Tooling API: The developer can also run tests using the Tooling REST API. Use the /runTestsAsynchronous/ and /runTestsSynchronous/ endpoints to run tests asynchronously or synchronously3.
* 1: Get a Refresh on Testing Unit | Salesforce Trailhead
* 2: Run Apex Tests | Salesforce DX Developer Guide | Salesforce Developers
* 3: What are three ways for a developer to execute tests in an Org?
NEW QUESTION # 221
Which code block returns the ListView of an Account object usingthe following debug statement?
system.debug(controller.getListViewOptions() );
  • A. ApexPages.StandardController controller = new ApexPages.StandardController( Database.getQueryLocator( 'SELECT Id FROM Account LIMIT 1'));
  • B. ApexPages.StandardSetController controller = new ApexPages.StandardSetController( Database.getQueryLocator( 'SELECT Id FROM Account LIMIT 1'));
  • C. ApexPages.StandardControllercontroller = new ApexPages.StandardController( [SELECT Id FROM Account LIMIT 1]);
  • D. ApexPages.StandardController controller = new ApexPages.StandardController( [SELECT Id FROM Account LIMIT 1]);
NEW QUESTION # 222
Refer to the component code 9fd requirements below:
Requirements
* For mobile devices. the information should display in three rows.
* For desktops and tablets, the information should display in a single row.
Requirement 2 is not displaying as desired.
Which option has the correct component code to meet the requirements for desktops end and tablets?
  • A.
  • B.
To meet the requirements:
For mobile devices, the content should display inthree rows.
For desktops and tablets, the content should display ina single row.
Explanation of Correct Option (B):The code useslightning:layoutItemwith appropriate sizing formediumDeviceSize="4", which ensures:
Mobile devices: Each layout item will occupy the full width (size="12"), resulting in three rows.
Tablets and desktops: Each layout item will occupy one-third of the row (mediumDeviceSize="4"), displaying in a single row.
Example Code from Option B:
<lightning:layoutmultipleRows="true">
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.Name}</lightning:layoutItem>
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.AccountNumber}</lightning:
layoutItem>
<lightning:layoutItemsize="12"mediumDeviceSize="4">{!v.account.Industry}</lightning:layoutItem>
</lightning:layout>
Option Aoes not account for mediumDeviceSize and will not adjust for tablets/desktops.
Option C:Uses incorrect sizing formediumDeviceSize, which may not display correctly for tablets/desktops.
Referenceightning Design System Grid
NEW QUESTION # 223
Candidates for the CRT-450 exam can rely on our practice material because it is of the greatest quality and will assist them in preparing for the Salesforce certification test successfully on the first try. FreeDumps's main goal is to offer 100% actual CRT-450 Exam Questions in order to help applicants clear the CRT-450 test in a short time. We are confident that our updated CRT-450 practice questions will help you pass the Salesforce Certified Platform Developer I (CRT-450) certification exam on the first attempt.
CRT-450 Cost Effective Dumps: https://www.freedumps.top/CRT-450-real-exam.html
P.S. Free & New CRT-450 dumps are available on Google Drive shared by FreeDumps: https://drive.google.com/open?id=1vm3PmkzIsAubdWFAV1Bsped2jpfFA3Nr
Posted at 2/23/2026 05:01:00        Only Author  2#
I appreciate your article deeply, it left a strong impression on me. Enhance your IT knowledge with free Dumps JN0-253 discount. Good luck and best wishes!
