[General] VMware新版2V0-16.25考古題是行業領先材料&新版2V0-16.25考古題: VMware vSphere Foundation 9.0 Admini
93
【General】 VMware新版2V0-16.25考古題是行業領先材料&新版2V0-16.25考古題: VMware vSphere Foundation 9.0 Admini
Posted at 2/7/2026 21:50:54      View:149 | Replies:2        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的PDFExamDumps 2V0-16.25 PDF版考試題庫:https://drive.google.com/open?id=1qBLCLozezItCYf3GVUCZHNwlewD7SXw3
不管你參加2V0-16.25認證的哪個考試,PDFExamDumps的參考資料都可以給你很大的幫助。因為PDFExamDumps的考試考古題包含實際考試中可能出現的所有問題,並且可以給你詳細的解析讓你很好地理解2V0-16.25考試試題。只要你認真學習了PDFExamDumps的考古題,你就可以輕鬆地通過你想要參加的考試。
VMware 2V0-16.25 考試大綱:
主題簡介
主題 1
  • Troubleshoot and Optimize the VMware Solution: This section of the exam measures the ability of Systems Engineers to troubleshoot and optimize VMware-based environments. While no explicit testable objectives are listed, candidates are expected to apply their problem-solving skills to diagnose, resolve, and enhance VMware solutions for improved reliability and performance.
主題 2
  • Deploy, Configure, and Operate VMware vSphere Foundation (VVF): This section of the exam measures the expertise of Data Center Administrators and emphasizes hands-on skills in deploying and configuring VMware vSphere Foundation environments. Candidates must understand the components of a VVF deployment, configure Supervisors within clusters, and manage identity, access control, licensing, and certificate management. The objectives also extend to lifecycle management within the vSphere Foundation. Furthermore, it explores operational tasks including monitoring and analyzing logs, configuring alerting, managing dashboards, and integrating with VMware Cloud Foundation (VCF) Operations. Candidates will also be tested on cost and pricing configuration, compliance monitoring, and security hardening practices. Finally, automation skills are validated through deploying services with Supervisors, running Kubernetes workloads, using VM services, and integrating VCF Operations Orchestrator to support enterprise automation.
主題 3
  • VMware vSphere Foundation Fundamentals: This section of the exam measures the skills of Virtualization Engineers and focuses on the essentials of virtualization technology. It introduces the principles of virtualization, explores use cases, and highlights the value it brings to businesses. Candidates are expected to demonstrate knowledge of VMware compute components such as vCenter and ESX, cluster configuration, and lifecycle management of virtual machines. It also covers secure workload operations, encryption, and managing resources with content libraries. In addition, storage fundamentals are examined through configuring vSphere storage, deploying VMware vSAN clusters, defining storage policies, and ensuring data availability. Networking fundamentals are also introduced, requiring the ability to differentiate between VMware vSphere networking components.
主題 4
  • Plan and Design the VMware by Broadcom Solution: This section of the exam measures the ability of VMware Solution Architects to plan and design solutions. While there are no specific testable objectives included, the focus is on preparing professionals to design VMware-based solutions that align with organizational goals and best practices.
主題 5
  • IT Architectures, Technologies, Standards: This section of the exam measures the understanding of IT Infrastructure Architects and covers foundational concepts of architectures, emerging technologies, and industry standards. Although no testable objectives are listed here, it establishes the baseline knowledge needed to interpret and design VMware-related environments effectively.
值得信賴的新版2V0-16.25考古題 |第一次嘗試輕鬆學習並通過考試並且有效的2V0-16.25:VMware vSphere Foundation 9.0 Administrator還在為不知道怎麼通過的2V0-16.25認證考試而煩惱嗎?現在終於不用擔心這個問題啦。PDFExamDumps多年致力於2V0-16.25認證考試的研究,有著豐富的經驗,強大的考古題,幫助你高效率的通過考試。能否成功通過一項考試,並不在於你看了多少東西,而在於你是否找對了方法,PDFExamDumps就是你通過2V0-16.25認證考試的正確方法!
最新的 VCP-VVF Admin 2V0-16.25 免費考試真題 (Q38-Q43):問題 #38
An administrator is tasked with importing a vSphere Lifecycle Manager image and applying it to a cluster containing six hosts, with two of the hosts in maintenance mode. The administrator uses the vSphere Client, navigates to the cluster, and edits the remediation settings to enable Parallel Remediation and clicks the Remediate All button to execute the remediation process.
What is the expected result of this remediation process?
  • A. The image is remediated on the four hosts not in maintenance mode, in parallel. The hosts in maintenance mode are not remediated.
  • B. The image is remediated on the hosts in maintenance mode in parallel. The hosts not in maintenance mode are not remediated.
  • C. The image is remediated on the hosts in maintenance mode in parallel, and when completed the hosts not in maintenance mode are remediated in parallel.
  • D. The image is remediated on the four hosts not in maintenance mode, in sequence. The hosts in maintenance mode are not remediated.
答案:B
解題說明:
When usingvSphere Lifecycle Manager (vLCM)withParallel Remediationenabled, the following rules apply:
* Parallel remediation only applies to ESXi hosts that are already in Maintenance Mode.
* vLCM doesnotput hosts into Maintenance Mode automatically in this mode.
* Similarly, it does not exit Maintenance Mode automatically after remediation.
* Hosts not in Maintenance Mode are skipped.
* If Parallel Remediation is activated, vLCM remediates only those hosts that are already in Maintenance Mode.
* Any hosts that are not in Maintenance Mode remain untouched.
* Remediation happens in parallel for all eligible hosts.
* In this case, two of the six hosts are in Maintenance Mode. Those two hosts will be remediated in parallel.
* The remaining four hosts (not in Maintenance Mode) willnotbe remediated at all.
* A. Four hosts not in maintenance mode are remediated in parallel##Incorrect. Hosts must already be in Maintenance Mode to be remediated.
* B. Hosts in maintenance mode first, then non-maintenance hosts##Incorrect. Non-maintenance mode hosts are skipped, not remediated after.
* C. Four hosts remediated sequentially, others skipped##Incorrect. Parallel Remediation does not touch non-maintenance mode hosts.
* D. Hosts in maintenance mode remediated in parallel; others skipped##Correct and matches VMware documentation.
VMware vSphere 9.0 Documentation -Parallel Remediation for Lifecycle Manager Images VMware vSphere 9.0 Documentation -Parallel remediation applies only to ESX hosts already in maintenance mode
問題 #39
The operations team is tasked with the preparation of a weekly health status overview of a VMware vSphere Foundation (VVF) environment to senior management with the following requirements:
* It should be sent every Monday morning.
* It must include KPIs related to cluster health, storage usage, and virtual machine (VM) growth trends.
* Operational overhead should be minimized.
Which two actions must the administrator perform to satisfy these requirements? (Choose two.)
  • A. Export the built-in Cluster Summary report via FTP.
  • B. Export the desired metrics from the Metrics Explorer to CSV.
  • C. Configure the scheduler to send the report via e-mail weekly.
  • D. Create a custom dashboard with the required KPIs.
  • E. Create a custom View with the KPIs and add it to a new Report Template.
答案:C,E
解題說明:
VMware vSphere Foundation (VVF) integrates VMware Aria Operations (vRealize Operations) for intelligent operations management, enabling automated reporting to minimize operational overhead. To meet the requirements for a weekly health status overview including cluster health, storage usage, and VM growth trends, an administrator must first create a custom View in Aria Operations to define the specific KPIs (e.g., cluster availability, datastore capacity, and VM count trends over time). This View is then added to a new Report Template, which compiles the data into a structured report format like PDF or CSV. Next, the scheduler in Aria Operations is configured to generate and email the report every Monday morning, ensuring delivery without manual intervention. This approach leverages built-in automation for recurring tasks, reducing effort compared to ad-hoc exports or manual configurations.
Other options do not fully satisfy the requirements: Option A creates a dashboard for interactive visualization but not a scheduled report; Option C uses a built-in report with limited customization and no direct FTP export or scheduling; Option E involves manual CSV exports from Metrics Explorer, increasing overhead and lacking automation.
問題 #40
In VMware Cloud Foundation (VCF) Operations for Logs, where does an administrator visualize the value range of a field?
  • A. Click on the field in the Events table.
  • B. Click the pencil in the Manage Fields pane.
  • C. Click on the field in Manage Fields.
  • D. Click on the field in the Field Table.
答案:A
解題說明:
InVCF Operations for Logs, administrators can analyze logs using queries, fields, and charts. A key feature is the ability toview the value range of a specific field.
* When a log query is executed, results appear in theEvents table.
* Each field shown in the Events table is interactive.
* Byclicking on a field in the Events table, administrators can drill down into the data tovisualize its value distribution (range), typically in the form of a histogram or grouped data set.
This provides insight intowhat values are present and how frequently they occur, which is useful for troubleshooting, anomaly detection, and refining queries.
Why not the other options?
* A. Click the pencil in the Manage Fields pane# Used toedit or extract fields, not visualize ranges.
* C. Click on the field in Manage Fields# Displays field definitions and settings, not real-time value ranges.
* D. Click on the field in the Field Table# The Field Table lists defined fields but does not provide value range visualization.
VMware Cloud Foundation 9.0.3 -Smart fields and field value histogram from Events table VMware Cloud Foundation 9.0.3 -Analyze logs, queries, and fields in the Events table
問題 #41
An administrator is tasked to deploy a new eight-node VMware vSAN Express Storage Architecture (ESA) cluster.
What are three minimum requirements to accomplish this? (Choose three.)
  • A. PCIe flash device (NVMe)
  • B. SAS solid-state disk (SSD)
  • C. 256GB Memory
  • D. 10GbE network interfaces
  • E. 128GB Memory
  • F. 25GbE network interfaces
答案:A,E,F
解題說明:
ForvSAN ESA (Express Storage Architecture), minimum requirements differ from OSA:
* 25GbE NICsare required to handle high-performance traffic. (C)
* NVMe PCIe flash devicesmust be used for storage. (D)
* 128GB Memory minimumper host is required. (F)
Other options:
* A. 10GbE# Only supported in vSAN OSA, not ESA.
* B. 256GB Memory# Recommended for large workloads, not minimum.
* E. SAS SSDs# Not supported in ESA; NVMe required.
VMware Cloud Foundation 9.0 -vSAN ESA Hardware Requirements
VMware Docs: vSAN ESA Deployment Requirements
問題 #42
Which scenario demonstrates the benefit of server consolidation using VMware server virtualization?
  • A. Running multiple independent machines on a single physical host.
  • B. Providing protection against ransomware attacks.
  • C. Performing load balancing between web servers.
  • D. Automating the deployment of application clusters.
答案:A
解題說明:
Thecore benefit of server consolidation using VMware server virtualizationis the ability to runmultiple independent virtual machines (VMs)on asingle physical host.
* This increases hardware utilization, reduces physical server sprawl, and cuts operational costs.
* A. Load balancing# Achieved through features like DRS, not basic server consolidation.
* C. Ransomware protection# Achieved through security features and backups, not consolidation.
* D. Automating application clusters# A benefit of orchestration tools, not consolidation.
VMware vSphere 9.0 -Server Consolidation Benefits
VMware Docs: VMware Virtualization Fundamentals
問題 #43
如果你使用了我們的VMware的2V0-16.25學習資料資源,一定會減少考試的時間成本和經濟成本,有助於你順利通過考試,在你決定購買我們VMware的2V0-16.25之前,你可以下載我們的部門免費試題,其中有PDF版本和軟體版本,如果需要軟體版本請及時與我們客服人員索取。
2V0-16.25考古題分享: https://www.pdfexamdumps.com/2V0-16.25_valid-braindumps.html
2026 PDFExamDumps最新的2V0-16.25 PDF版考試題庫和2V0-16.25考試問題和答案免費分享:https://drive.google.com/open?id=1qBLCLozezItCYf3GVUCZHNwlewD7SXw3
Posted at 2/22/2026 14:39:46        Only Author  2#
Thank you for sharing such a powerful article! Here are the Study C-ARCIG-2508 center materials, free of charge—best of luck!
Posted at 2/23/2026 13:57:02        Only Author  3#
This article is truly one worth keeping and referring to. Wishing you success! Here are the free 712-50 valid exam collection free test materials.
