Latest NCA-6.10 Study Plan - NCA-6.10 Reliable Exam Simulations
Posted at 2/7/2026 22:30:18
View114
Replies1
P.S. Free & New NCA-6.10 dumps are available on Google Drive shared by VCETorrent: https://drive.google.com/open?id=1TOLZgYFbFXZtkwuE8Y1sDhl6ZHS5MTFt
We will free provide you part of the exercises of Nutanix Certification NCA-6.10 Exam on the Internet to let you try to test our product's quality. After your trail you will find VCETorrent's exercises is the most comprehensive one and is what you want to.
As the saying goes, to develop study interest requires to giving learner a good key for study, this is promoting learner active development of internal factors. The most function of our NCA-6.10 question torrent is to help our customers develop a good study habits, cultivate interest in learning and make them pass their exam easily and get their NCA-6.10 Certification. All workers of our company are working together, in order to produce a high-quality product for candidates. I believe that our NCA-6.10 exam torrent will be very useful for your future.
NCA-6.10 Reliable Exam Simulations | NCA-6.10 Actual Test AnswersWe find methods to be success, and never find excuse to be failure. In order to provide the most authoritative and effective NCA-6.10 exam software, the IT elite of our VCETorrent study NCA-6.10 exam questions carefully and collect the most reasonable answer analysis. The NCA-6.10 Exam Certification is an important evidence of your IT skills, which plays an important role in your IT career.
Nutanix Certified Associate v6.10 Sample Questions (Q24-Q29):NEW QUESTION # 24
Which Nutanix Disaster Recovery component or feature provides the best Recovery Time Objective (RTO)?
- A. Async
- B. Availability Zone
- C. NearSync
- D. Metro Availability
NEW QUESTION # 25
When is deduplication recommended?
- A. Cold data
- B. Full clone VMs
- C. Linked Clone VMs
- D. Server workloads
NEW QUESTION # 26
What minimum number of clusters must be registered to Prism Central to open a support case from the UI?
The correct answer isB. 1
Nutanix Prism Central provides the ability to create and manage support casesdirectly from the UI, but this functionality requiresat least one clusterto be registered to Prism Central. The Support option becomes active onceone or more clustersare managed.
Important distinctions:
* Zero clusters(Option A): With no clusters registered, Prism Central is effectively disconnected from any environment and thus cannot associate logs or telemetry with a support case.
* One cluster(Option B): Enables access to support features, including log bundle generation and direct case submission.
* Options C and D (2 or 3 clusters) are incorrect; they arenot a requirementfor enabling support case functionality.
Prism Central UI Navigation Path:
Settings (gear icon) > Support > Create Support Case
Official Reference:
* Nutanix Prism Central Guide - Support Integration Section
* Excerpt: "To open a support case through Prism Central, ensure at least one cluster is registered.
Support features become available once a cluster is connected."
Conclusion:Only one cluster is required to activate the support case workflow in Prism Central.
NEW QUESTION # 27
An administrator is considering a data protection strategy between two sites. There is a 10ms round trip latency between the two clusters. Which data protection solution can the administrator implement that minimizes data loss in the event of a disaster?
- A. Metro Availability
- B. Async DR
- C. Synchronous Replication
- D. NearSync Replication
The correct answer isA. NearSync Replication.
Key Concepts from Official Nutanix Documentation:
Nutanix supports various types of data replication methods depending on the Recovery Point Objective (RPO), Recovery Time Objective (RTO), and the latency between the sites.
* Metro Availabilityrequires a maximum latency of<5ms RTTand is used forzero RPO synchronous replication. Since the given latency is 10ms,Metro Availability is not supportedin this case.
Reference: Nutanix Bible - Metro Availability Section
Prism UI Navigation: Protection Domains > Metro Availability
Synchronous Replicationis often synonymous withMetro Availabilityin Nutanix's implementation. Thus, it is similarly bound by the <5ms RTT requirement.
Async DR (Asynchronous Disaster Recovery)allows for more relaxed RPOs, typically1 hour or more, which doesnot minimize data lossin the event of a disaster.
NearSync Replicationsupports anRPO as low as 1 minuteand issuitable for up to 20ms RTT latency. It utilizeslightweight snapshotsandschedule-based replicationto deliverlow-RPO protectioneven over relatively long distances and moderate latencies.
Reference: Nutanix Data Protection Guide - NearSync Overview
Prism UI Navigation: Data Protection > Protection Domains > Schedule (with 1-minute RPO option) Detailed Source References:
Nutanix Data Protection and DR Guide - v5.x and later:"NearSync replication enables you to achieve RPOs as low as 1 minute and is designed to work with round-trip latencies of up to 20ms." Prism Central UI:Navigate toProtection > Data Protection > Protection Domains > Create Schedule# Set schedule type to "NearSync" and observe the 1-minute RPO options.
Hence, since 10ms RTTexceeds Metro Availability requirementsbut iswell within NearSync's acceptable latency, the best choice thatminimizes data lossis:
NEW QUESTION # 28
An administrator needs to configure a solution that ensures VMs automatically power on in a specific order at the DR site in the event of a disaster.
Which feature will achieve this?
- A. Protection Policy
- B. Category
- C. Resource Scheduling
- D. Recovery Plan
The feature that ensures VMs automatically power on in a specific order at the DR site during a disaster is a Recovery Plan. Recovery Plans are part of Nutanix's DR functionality and allow administrators to define startup sequences, dependencies, and priorities for VMs during failover scenarios.
Steps:
* Create a Recovery Plan in Prism Central under the DR section.
* Configure the VM power-on sequence and dependency rules.
* Test the Recovery Plan to ensure it operates as intended.
Nutanix Disaster Recovery Guide - Recovery Plan Configuration.
Nutanix Prism Central Documentation - DR Features.
NEW QUESTION # 29
Nowadays, so many internet professionals agree that Nutanix exam certificate is a stepping stone to the peak of our life. NCA-6.10 exam is an exam concerned by lots of internet professionals. Close to 100% passing rate is the best gift that our customers give us. We also hope our NCA-6.10 exam materials can help more and more ambitious people pass the NCA-6.10 exam. Our professional team checks the update of exam materials every day, so please rest assured that the NCA-6.10 Exam software you are using must contain the latest and most information. We are a team of the exam questions providers NCA-6.10 exam in internet that ensured you can pass actual test 100%. We have experienced and professional experts to create the latest NCA-6.10 exam questions and answers many times which are approach to the NCA-6.10 exam.
NCA-6.10 Reliable Exam Simulations: https://www.vcetorrent.com/NCA-6.10-valid-vce-torrent.html
Nutanix Latest NCA-6.10 Study Plan We are welcome to your questions 24 hours, And as long as you try our NCA-6.10 practice questions, you will love it, Nutanix Latest NCA-6.10 Study Plan Luckily, our study guide can reduce your pressure, The modern Nutanix NCA-6.10 Reliable Exam Simulations world is changing its dynamics at a fast pace, Nutanix Latest NCA-6.10 Study Plan Well, what is the good tool?
Press writes on CircleID.com that connections NCA-6.10 to India, for example, are likely to serve community organizations, clinics, schools, and businesses, Being honest about expectations, objectives, NCA-6.10 Reliable Exam Simulations and restrictions is one of the most crucial elements of successful communication.
Updated Latest NCA-6.10 Study Plan - Easy and Guaranteed NCA-6.10 Exam SuccessWe are welcome to your questions 24 hours, And as long as you try our NCA-6.10 Practice Questions, you will love it, Luckily, our study guide can reduce your pressure.
The modern Nutanix world is changing NCA-6.10 Reliable Exam Simulations its dynamics at a fast pace, Well, what is the good tool?
- NCA-6.10 Exam Paper Pdf 🛢 Pass4sure NCA-6.10 Pass Guide 🕺 Valid NCA-6.10 Study Materials 😏 Enter [ [url]www.practicevce.com ] and search for NCA-6.10 to download for free 🐎New NCA-6.10 Exam Bootcamp[/url]
- NCA-6.10 Training Pdf 💏 NCA-6.10 Exam Engine 😷 Updated NCA-6.10 Testkings 🐖 Go to website ➤ [url]www.pdfvce.com ⮘ open and search for ➡ NCA-6.10 ️⬅️ to download for free 🥣NCA-6.10 Latest Test Sample[/url]
- NCA-6.10 Reliable Test Camp 📖 NCA-6.10 Training Pdf 🏊 Pass4sure NCA-6.10 Pass Guide 🪕 Open website ➡ [url]www.examcollectionpass.com ️⬅️ and search for NCA-6.10 for free download ❤NCA-6.10 New Study Materials[/url]
- Newest Latest NCA-6.10 Study Plan Provide Prefect Assistance in NCA-6.10 Preparation 🧄 Download ⮆ NCA-6.10 ⮄ for free by simply entering [url]www.pdfvce.com website 🐖Valid NCA-6.10 Study Materials[/url]
- Updated NCA-6.10 Testkings 💑 Updated NCA-6.10 Testkings 📚 Pass4sure NCA-6.10 Pass Guide 🏯 Download ⮆ NCA-6.10 ⮄ for free by simply entering ▶ [url]www.torrentvce.com ◀ website 🛬NCA-6.10 Reliable Test Camp[/url]
- Test NCA-6.10 Lab Questions 🐊 NCA-6.10 Latest Test Sample 📼 NCA-6.10 Exam Engine 🃏 Open website ☀ [url]www.pdfvce.com ️☀️ and search for ▶ NCA-6.10 ◀ for free download 😡NCA-6.10 Latest Test Sample[/url]
- NCA-6.10 Test Question 🍫 Training NCA-6.10 Tools 🗽 NCA-6.10 Exam Vce Format 😕 Immediately open ➤ [url]www.examcollectionpass.com ⮘ and search for ➡ NCA-6.10 ️⬅️ to obtain a free download 🍩Valid NCA-6.10 Exam Tutorial[/url]
- Updated NCA-6.10 Testkings 👿 Updated NCA-6.10 Testkings 🥩 Reliable NCA-6.10 Exam Materials 🤦 Easily obtain free download of ▷ NCA-6.10 ◁ by searching on ☀ [url]www.pdfvce.com ️☀️ 📊NCA-6.10 Latest Test Sample[/url]
- Quiz Nutanix - NCA-6.10 - Nutanix Certified Associate v6.10 CThe Best Latest Study Plan ⏏ Search for ✔ NCA-6.10 ️✔️ and easily obtain a free download on ➽ [url]www.torrentvce.com 🢪 ☘Reliable NCA-6.10 Exam Materials[/url]
- Updated NCA-6.10 Testkings 🔩 Sample NCA-6.10 Questions Answers 🐘 Test NCA-6.10 Lab Questions 🐵 Open [url]www.pdfvce.com enter ▷ NCA-6.10 ◁ and obtain a free download ↔NCA-6.10 New Study Materials[/url]
- NCA-6.10 Exam Questions - NCA-6.10 Pdf Training - NCA-6.10 Latest Vce 🌏 Search for NCA-6.10 and easily obtain a free download on ⮆ [url]www.prepawayexam.com ⮄ 👍NCA-6.10 Practice Exam Questions[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, anonup.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Nutanix NCA-6.10 dumps are available on Google Drive shared by VCETorrent: https://drive.google.com/open?id=1TOLZgYFbFXZtkwuE8Y1sDhl6ZHS5MTFt
