[General] Questions for the Salesforce Analytics-Con-201 Exam 2026 - Ensure Your Success
111
【General】 Questions for the Salesforce Analytics-Con-201 Exam 2026 - Ensure Your Success
Posted at 2/8/2026 01:18:39      View:138 | Replies:2        Print      Only Author   [Copy Link] 1#
Our Analytics-Con-201 preparation torrent can keep pace with the digitized world by providing timely application. There are versions of Software and APP online, they can simulate the real exam environment. If you take good advantage of this Analytics-Con-201 practice materials character, you will not feel nervous when you deal with the Analytics-Con-201 Real Exam. Furthermore, they can be downloaded to all electronic devices so that you can have a rather modern study experience conveniently. Why not have a try on our Analytics-Con-201 exam questions?
The proper answer to your questions is ValidDumps. When studying for the Salesforce Certified CRM Analytics and Einstein Discovery Consultant (Analytics-Con-201) certification exam, ValidDumps is one of the most helpful resources. ValidDumps guarantees success on the first try by providing you with actual Salesforce Certified CRM Analytics and Einstein Discovery Consultant (Analytics-Con-201) exam questions in PDF, desktop practice exam software, and a web-based practice exam.
Most Effective Way to Get Salesforce Analytics-Con-201 CertificationThe ValidDumps Analytics-Con-201 exam questions are checked and verified by experienced and qualified Salesforce Certified CRM Analytics and Einstein Discovery Consultant exam trainers. So you can trust on the validity and top standard of ValidDumps Analytics-Con-201 exam practice test questions. With the ValidDumps Analytics-Con-201 exam questions you will get everything that you need to prepare and pass the challenging Salesforce Analytics-Con-201 Exam with good scores. The ValidDumps Analytics-Con-201 exam questions will give you an idea about the final Analytics-Con-201 exam format and you will get experience about Analytics-Con-201 exam format before the final exam.
Salesforce Certified CRM Analytics and Einstein Discovery Consultant Sample Questions (Q26-Q31):NEW QUESTION # 26
A new picklist value was added for the Category field on the Account object. This field is already added as part of the Account object data sync and the respective recipe that uses this field.
The CRM Analytics team reports that when they start the recipe it runs successfully with no errors or warnings, but theyare unable to See this new valueson their existing dashboards.
What is the oridi4 of this issue?
  • A. The user who runs the dataflow/recipe does not have access to the field.
  • B. There are no records in Salesforce with this new plicklist value.
  • C. The Integration User profile does not have access to the field.
NEW QUESTION # 27
A consultant is preparing a dataset to predict customer lifetime value and is collecting data from a questionnaire that asks for demographic information. A very small number of respondents fill in the Income box, but the consultant thinks that it is an informative column even though it only represents 1% of respondents.
What should the consultant do?
  • A. Apply the predict missing values transformation in recipe nodes.
  • B. Drop the field as it will be difficult to get future respondents.
  • C. Fill in the missing data with an average of all incomes.
NEW QUESTION # 28
An CRM Analytics consultant creates a model to maximize the satisfaction of cases. They want to deploy the mode! and further use the model and predictions in an existing automated business process powered by Salesforce Flow.
What is the most efficient way to accomplish this?
  • A. Use the Einstein Discovery flow action to make a prediction with the flow.
  • B. Write an Apex class with Einstein Discovery Predictions and append them to process.
  • C. Create a trigger on Case objectand use REST APIs to append the predictions intothe business process.
NEW QUESTION # 29
Acompany wants to create a timeline chart to visualize the evolution of its Closed Won opportunities.
What are the required parameters to build a lens that displays output similar to the image shown?
  • A. 1 measure, 0 groupings if trellis Is disabled, or 0-2 groupings If trellis is enabled
  • B. 1 measure, 1 grouping by a date field, and either 0-1 groupings groupings by a dimensionif trellis is disabled, or 0-2groupings if trellis is enabled
  • C. 1 measure, 1-2 groupings if trellis is disabled, or 1-4 groupings if trellis is enabled
To create a timeline chart similar to the one shown, the following parameters are typically required:
* 1 Measure: This could be the count of Closed Won opportunities or any other relevant metric that needs to be tracked over time.
* 1 Grouping by a Date Field: This is essential to plot the timeline effectively. The date field would typically be the close date of the opportunities.
* Additional Groupings: Depending on the complexity and the detail needed, additional groupings can be added. For example, grouping by region or product line can provide more insights into the timeline. If trellis is used, it allows for the creation of multiple smaller charts within the main chart, each representing a slice of data based on the additional groupings.
This setup helps visualize the evolution of Closed Won opportunities over time, making it easy to spot trends, seasonal patterns, or other relevant insights.
NEW QUESTION # 30
A CRM Analytics consultant is asked to make changes to the current sales dashboard at Cloud Kicks. The dashboard is crucial to track the daily sales performance of the company and needs to be available for other users while the consultant works on the changes.
How should the consultant proceed to update the dashboard?
  • A. Clone the dashboard to a new one, apply the changes, share the new dashboard with the users, and delete the old one.
  • B. Self assign as a dashboard publisher and make the changes to the dashboard in draft mode while maintaining a previous version live.
  • C. Wait for a period of least usability or the dashboard to edit it.
NEW QUESTION # 31
We recommend you use Salesforce Analytics-Con-201 practice material to prepare for your Analytics-Con-201 certification exam. ValidDumps provides the most accurate and real Salesforce Analytics-Con-201 Exam Questions. These Salesforce Analytics-Con-201 practice test questions will assist you in better preparing for the final Salesforce Analytics-Con-201 exam.
Analytics-Con-201 Test Pass4sure: https://www.validdumps.top/Analytics-Con-201-exam-torrent.html
Those who do not study with real Salesforce Certified CRM Analytics and Einstein Discovery Consultant (Analytics-Con-201) dumps often fail the test and waste their valuable resources, If you decide to buy and use the Analytics-Con-201 Test Questions Salesforce Consultant training materials from our company with dedication on and enthusiasm step and step, it will be very easy for you to pass the exam without doubt, Download latest Analytics-Con-201 Exam Dumps for the Salesforce Certified CRM Analytics and Einstein Discovery Consultant exam in PDF file format.
Support for tax and shipping tables is built in seamlessly, For a floating New Analytics-Con-201 Test Preparation window, click in the window, and then drag the layers you want to reclaim from the Layers panel into the original document window.
2026 Excellent Analytics-Con-201 New Learning Materials Help You Pass Analytics-Con-201 EasilyThose who do not study with real Salesforce Certified CRM Analytics and Einstein Discovery Consultant (Analytics-Con-201) dumps often fail the test and waste their valuable resources, If you decide to buy and use the Analytics-Con-201 TestQuestions Salesforce Consultant training materials from our company Analytics-Con-201 with dedication on and enthusiasm step and step, it will be very easy for you to pass the exam without doubt.
Download latest Analytics-Con-201 Exam Dumps for the Salesforce Certified CRM Analytics and Einstein Discovery Consultant exam in PDF file format, Analytics-Con-201 learning material always regards helping students to pass the exam as it is own mission.
If you want to remove all the Analytics-Con-201 New Learning Materials complications of the updated Salesforce Salesforce Certified CRM Analytics and Einstein Discovery Consultant.
Posted at 2/9/2026 06:26:21        Only Author  2#
I sincerely appreciate your article; it really left a deep impression on me! Free Valid Advanced-Administrator test preparation questions to help you prepare. Wishing you all success!
Posted at 2/20/2026 05:00:16        Only Author  3#
Pass4Testにあるソフトウェアバージョンは、C-TS422-2504実際の試験の3つのバージョンの1つであり、当社の専門家によって設計されています。 ソフトウェアバージョンの機能は非常に特殊です。 たとえば、ソフトウェアバージョンは実際の試験環境をシミュレートできます。 C-TS422-2504試験問題を購入すると、同様の実際の試験環境を楽しむことができます。 また、教材のソフトウェアバージョンは、コンピューターの数に限定されません。 C-TS422-2504準備試験をためらわずに購入してください。多くのメリットが得られ、C-TS422-2504試験に確実に合格します。
