[Hardware] 156-836參考資料 & 156-836認證
89
【Hardware】 156-836參考資料 & 156-836認證
Posted at 2/8/2026 05:18:31      View:204 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的2026 CheckPoint 156-836考試題庫:https://drive.google.com/open?id=1EFnvPBcNMkeJM_XQsm2x5zcf8DcOHrgB
沒有人除外,我們NewDumps保證你100%的比例, 今天你選擇NewDumps,選擇你要開始的訓練,並通過你的下一次的考題,你將得到最好的資源與市場的相關性和可靠性保證。NewDumps CheckPoint的156-836考題和答案反映的問題問156-836考試。
156-836考古題被大多數考生證明是有效的,通過很多IT認證考試的考生使用之后得出,能使考生在短時間內掌握最新的CheckPoint 156-836考試相關知識。由高級認證專家不斷完善出最新版的156-836考古題資料,他們的研究結果可以100%保證您成功通過156-836考試,獲得認證,這是非常有效的題庫資料。一些通過156-836考試的考生成為了我們的回頭客,他們說選擇NewDumps就意味著選擇成功。
最受推薦的156-836參考資料,免費下載156-836考試資料幫助妳通過156-836考試很多人都認為要通過一些高難度的156-836認證考試是需要精通很多CheckPoint專業知識。只有掌握很全面的ICheckPoint知識的人才會有資格去報名參加的考試。其實現在有很多方法可以幫你彌補你的知識不足的,一樣能通過156-836認證考試,也許比那些專業知識相當全面的人花的時間和精力更少,正所謂條條大路通羅馬。
最新的 CCME 156-836 免費考試真題 (Q64-Q69):問題 #64
How many orchestrators may Dual-Site include?
  • A. 0
  • B. Only 4
  • C. 1
  • D. 2 or 4
答案:D
解題說明:
A Dual Site environment can include either two or four orchestrators, depending on the scenario. There are three primary scenarios for Dual Site configuration:
*Direct connectivity between remote site orchestrators: This scenario requires two orchestrators, one for each site, and a direct connection between them using the site-sync port.
*Two orchestrators on the same site are connected to the remote site orchestrators through two different switches: This scenario requires four orchestrators, two for each site, and a connection between them using the site-sync port and two external switches that support QinQ and MTU increment.
*Two orchestrators on the same site are connected to the remote site orchestrators through one switch: This scenario also requires four orchestrators, two for each site, and a connection between them using the site-sync port and one external switch that supports QinQ and MTU increment.
References =
*Maestro Dual Site configuration with a direct connection through L2 switches
*Dual Site Single Maestro Hyperscale Orchestrator Cluster (Dual Site Single MHO Redundancy)
*Maestro Frequently Asked Questions (FAQ)
問題 #65
How does HyperSync work in a Dual Site environment?
  • A. Each active connection has a local backup (on the local site) and a second backup connection on the second site (remote site.)
  • B. Each active connection has a local backup (on the local site) and a second backup connection on each of the MHOs.
  • C. Each active connection has two local backups (on the local site) and a third backup connection on the second site (remote site.)
  • D. Each active connection has a backup connection on the second site (remote site.)
答案:A
問題 #66
  • A. 0
  • B. Only 4
  • C. 1
  • D. 2 or 4
答案:D
解題說明:
References =
問題 #67
What kinds of transceivers are supported on Orchestrator MHO-170?
  • A. SFP+, SFP28, QSFP
  • B. SFP, QSFP, QSFP28
  • C. SFP, SFP+, SFP28
  • D. QSFP, QSFP28
答案:D
解題說明:
The Orchestrator MHO-170 supports QSFP and QSFP28 transceivers on its 32x 100 GbE ports. QSFP stands for Quad Small Form-factor Pluggable and QSFP28 is an enhanced version of QSFP that supports up to 28 Gbps per lane. These transceivers can provide high-speed and high-density connectivity for the Maestro environment.
References
*Maestro Hyperscale Orchestrator Datasheet - Check Point Software1, page 2
*Maestro Transceiver & DAC Inventory - Check Point CheckMates
問題 #68
Multiple SGs can exist in a Dual Site environment. Each SG can be configured in one of three ways. Which is not one of those ways?
  • A. Two MHOs connected to two MHOs via load balancers.
  • B. Two MHOs at same site connected to remote site MHOs via single switch.
  • C. Direct connectivity between Remote Site MHOs.2
  • D. Two MHOs at same site connected to remote site MHOs via two different switches.
答案:A
解題說明:
This is not one of the ways to configure a Security Group in a Dual Site environment, because load balancers are not required or supported for the inter-site communication between the Maestro Orchestrators (MHOs).
The MHOs use the Site-Sync port and VLANs to synchronize the resources and connections across the sites.
The three valid scenarios for Dual Site configuration are:
*Direct connectivity between remote site Orchestrators: This scenario requires two orchestrators, one for each site, and a direct connection between them using the site-sync port.
*Two orchestrators on the same site are connected to the remote site orchestrators through one switch: This scenario also requires four orchestrators, two for each site, and a connection between them using the site-sync port and one external switch that support QinQ and MTU increment.
References =
*[Dual Site Single Maestro Hyperscale Orchestrator Cluster (Dual Site Single MHO Redundancy)]
*[Maestro Frequently Asked Questions (FAQ)]
問題 #69
CheckPoint的156-836認證考試是現在IT領域非常有人氣的考試。取得這個考試的認證資格對想晉升的人們來說是最好的,也是最可以看到效果的選擇。而且,借助這個考試你也可以提高自己的技能,掌握更多的對工作有用的技術。這樣你就可以更好地完成你的工作,向別人展示你的超強的能力。也只有这样你才可以获得更多的发展机会。
156-836認證: https://www.newdumpspdf.com/156-836-exam-new-dumps.html
值得信賴的并有效的 156-836 題庫資料,CheckPoint 156-836參考資料 一本高效率的考古題是大家準備考試時必不可少的工具,CheckPoint 156-836參考資料 命運的鐵拳擊中要害的時候,只有大勇大智的人才能夠處之泰然,不管是在156-836 forum 交流還是在156-836 學習圈子內交流,我們的潛意識裡都會想要超越更多的人,CheckPoint 156-836參考資料 要想通過考試是很困難的,但是請不要擔心,CheckPoint 156-836認證的認證考試是IT領域很重要的考試之一,如果獲得CheckPoint 156-836 認證的認證資格,那麼你就可以得到很大的幫助,CheckPoint 156-836參考資料 给我的,无论过去我怎么失手,都会拥有。
接下來的行止,無非是兩個,修士們面面相覷贊同道,那倒是,值得信賴的并有效的 156-836 題庫資料,一本高效率的考古題是大家準備考試時必不可少的工具,命運的鐵拳擊中要害的時候,只有大勇大智的人才能夠處之泰然。
156-836參考資料:Check Point Certified Maestro Expert - R81 (CCME)考試通過證明不管是在156-836 forum 交流還是在156-836 學習圈子內交流,我們的潛意識裡都會想要超越更多的人,要想通過考試是很困難的,但是請不要擔心。
2026 NewDumps最新的156-836 PDF版考試題庫和156-836考試問題和答案免費分享:https://drive.google.com/open?id=1EFnvPBcNMkeJM_XQsm2x5zcf8DcOHrgB
