[General] Sure Oracle 1Z0-1042-25 Pass | 1Z0-1042-25 Valid Mock Exam
87
General Sure Oracle 1Z0-1042-25 Pass | 1Z0-1042-25 Valid Mock Exam
Posted at 2/8/2026 08:27:13      View142 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Dumps4PDF 1Z0-1042-25 dumps for free: https://drive.google.com/open?id=122ZDjAIAGmhIjZx7Euf8lLyNM8Ek2MJY
The Oracle 1Z0-1042-25 exam questions are the ideal and recommended study material for quick and easiest Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam dumps preparation. The Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) practice questions are designed and verified by qualified and renowned Oracle Certification Exams trainers. They work closely and check all 1Z0-1042-25 Exam Dumps step by step. They also ensure the best possible answer for all 1Z0-1042-25 exam questions and strive hard to maintain the top standard of Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam dumps all the time.
One way to makes yourself competitive is to pass the 1Z0-1042-25 certification exams. Hence, if you need help to get certified, you are in the right place. Dumps4PDF offers the most comprehensive and updated braindumps for Oracles certifications. To ensure that our products are of the highest quality, we have tapped the services of Oracle experts to review and evaluate our 1Z0-1042-25 Certification test materials. In fact, we continuously provide updates to every customer to ensure that our 1Z0-1042-25 products can cope with the fast changing trends in 1Z0-1042-25 certification programs.
Best Preparation Material For The Oracle 1Z0-1042-25 Exam Dumps from Dumps4PDFThe Oracle modern job market is becoming more and more competitive and challenging and if you are not ready for it then you cannot pursue a rewarding career. Take a smart move right now and enroll in the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) certification exam and strive hard to pass the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) certification exam. The Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) certification exam offers you a unique opportunity to learn new in-demand skills and knowledge.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OICs integration capabilities.
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
Topic 5
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q21-Q26):NEW QUESTION # 21
When creating a new Oracle Integration Cloud (OIC) Connection resource, there are several steps that must be done before it is fully configured and can be used in an integration flow. Which task is NOT required in order to transition a new Connection resource from the draft to the configured state?
  • A. Configure the connection properties.
  • B. Specify the corresponding lookup.
  • C. Configure the security properties.
  • D. Execute a successful test of the connection.
  • E. Specify the connection role.
  • F. Specify an adapter type.
Configuring a connection:
A, B, C, E:Required-adapter type, role (trigger/invoke), security, and properties define the connection.
F:Required-testing validates configuration.
NEW QUESTION # 22
You have an Oracle Integration (OIC) synchronous integration flow that updates external systems with several invocations. However, several of your OIC integration clients are reporting that they are experiencing timeouts waiting for the response confirmation from this processing. Which is a legitimate strategy to mitigate this issue?
  • A. Change the implementation logic to invoke multiple fine-grained external API calls within a single loop.
  • B. Increase the blocking timeout within the OIC integration settings to allow for extended time.
  • C. Change the design implementation strategy to an asynchronous flow that provides a separate notification to clients when the processing is complete.
Timeouts:
B:True-async flow resolves client wait issues.
NEW QUESTION # 23
Which Oracle Integration (OIC) XPath function can be used to retrieve data from an OIC Lookup within the Map Editor?
  • A. get-value-from-lookup
  • B. lookupValue
  • C. get-content-as-string
  • D. getLookup
XPath in Mapper:
D:True-lookupValue retrieves lookup data.
NEW QUESTION # 24
Which statements are TRUE with regard to SOAP and the advantages it provides? Select THREE.
  • A. SOAP typically leverages XML-based payloads to communicate between two client machines across any modern network.
  • B. SOAP commonly serves as a cleaning agent that removes excess data from the transmissionprotocol.
  • C. SOAP clients can easily hold stateful references to remote server-side SOAP objects.
  • D. SOAP over HTTP is typically not blocked by firewalls and proxy servers.
  • E. SOAP provides flexibility for message formatting allowing for loose coupling between a client and a server.
  • F. SOAP is platform independent and programming language independent.
Answer: A,D,F
SOAP advantages:
B, C, F:True-platform independence, XML payloads, HTTP compatibility.
NEW QUESTION # 25
In Oracle Integration Cloud (OIC) Process, you create web forms to interact with end users. As part of creating a web form, you add its controls, configure its data, and define form behavior.
Which statement is true about creating web forms?
  • A. You can assign only one style sheet and one or more presentations to a web form.
  • B. You can assign one or more stylesheets and only one presentation to a web form.
  • C. You can assign only one style sheet and only one presentation to a web form.
  • D. You can assign one or more stylesheets and one or more presentations to a web form.
You can assign multiple stylesheets and presentations to a web form in OIC, allowing for more dynamic customization of both the appearance (stylesheets) and content structure (presentations).
NEW QUESTION # 26
Dumps4PDF offers affordable Oracle Cloud Infrastructure 2025 Application Integration Professional exam preparation material. You dont have to go beyond your budget to buy updated Oracle 1Z0-1042-25 Dumps. Use the coupon code SAVE50 to get a 50% exclusive discount on all Oracle Exam Dumps. To make your 1Z0-1042-25 Exam Preparation material smooth, a bundle pack is also available that includes all the 3 formats of dumps questions.
1Z0-1042-25 Valid Mock Exam: https://www.dumps4pdf.com/1Z0-1042-25-valid-braindumps.html
DOWNLOAD the newest Dumps4PDF 1Z0-1042-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=122ZDjAIAGmhIjZx7Euf8lLyNM8Ek2MJY
Posted at 2/9/2026 10:15:31        Only Author  2#
This article is superb, I appreciate you sharing it. The Valid study D-PSC-DS-01 questions resources are available for freegood luck, everyone!
Posted at 2/16/2026 03:52:05        Only Author  3#
This article is simply awe-inspiring, thank you for sharing it! The Test C-BCWME-2504 fee exam is almost here C wish me luck!
