AP-214證照考試 - AP-214熱門考題
Posted at 2/8/2026 08:36:30
在21世紀這個IT行業如此輝煌的時代,競爭是很激烈的。理所當然的,在IT行業中Salesforce AP-214認證考試成為了一個很熱門的考試。報名參加考試的人越來越多,並且能通過這個認證考試也是那些雄心勃勃的IT專業人士的夢想。
手上能拿到一些實用的認證證書,無疑為自己的就業開拓了一番新的領土和創造了一些機會。AP-214 是全球最大的網絡設備公司 Salesforce 公司的認可的初級技術認證,在整個 Salesforce 認證體系中處于售前規劃方向的基礎證書,有了AP-214 認證你的平均年薪將不低于10萬人民幣。雖然獲取 AP-214 認證需要投入額外的時間與金錢,但事實證明IT認證的投入產出是值得的,對於未來的職業發展非常有利。
AP-214熱門考題,AP-214下載通過Testpdf你可以獲得最新的關於Salesforce AP-214 認證考試的練習題和答案。請早點擁有它把,它能讓你通過你的第一次參加的Salesforce AP-214 認證考試。目前最新的Salesforce AP-214 認證考試的考試練習題和答案是Testpdf獨一無二擁有的。
最新的 Accredited Professional AP-214 免費考試真題 (Q78-Q83):問題 #78
What is the fastes way to add a classification to a post?
- A. Macro
- B. Add classification manually to each post.
- C. Classification cannot be added to a post
答案:A
解題說明:
* Understanding Classifications and Macros:
* Classifications:In Social Studio, classifications are tags or labels you apply to posts to categorize them (e.g., sentiment, product, campaign, etc.). They are essential for analysis and reporting.
* Macros:Macros are pre-defined sets of actions that can be applied to posts with a single click.
They automate repetitive tasks.
* Why Macros are the Fastest:
* Automation:Macros are designed for efficiency. You can create a macro that applies a specific classification (or a set of classifications) to a post automatically.
* One-Click Application:Instead of manually selecting the classification from a dropdown menu for each post, you simply select the post(s) and apply the relevant macro.
* How to Use Macros for Classifications:
* Create a Macro:In Social Studio, go to "Admin" then find "Macros" under your workspace.
Create a new macro and name it appropriately (e.g., "Classify as Positive Sentiment").
* Define Macro Actions:Within the macro, add an action to "Set Classification." Choose the desired classification tag(s).
* Apply the Macro:In Engage, select the post(s) you want to classify. From the action menu, choose your macro.
* Why Other Options Are Incorrect:
* B. Add classification manually to each post:While youcanadd classifications manually, it's time-consuming, especially when dealing with a large volume of posts.
* C. Classification cannot be added to a post:This is incorrect. Classifications are a fundamental part of organizing and analyzing social data in Social Studio.
In Summary:
Macros provide the fastest way to add classifications to posts in Social Studio because they automate the process, allowing you to apply classifications with a single click. Therefore,A. Macrois the correct answer.
問題 #79
What three statements are true regao1krec; Einstein Engagement Frequency (EEF)?
Choose3 answers
- A. EEF helps marketers determine the datanumber of emails to send to individual subscribers of an organization, reducing the unsubscribesthat result from email fatigue.
- B. EEFuses only commercial send data.Transactional sends are not considered in modeling.
- C. Salesforce trains eachcustomer's model using only thatcustomer's data.
- D. EEFfrequency analyzes 180 days of historical data to determine the right frequency of communication.
- E. EEF analyzes 360 days of historical data to determine the right frequency of communication.
答案:A,C,E
問題 #80
What data is there in mobile connect demographics, select3
- A. Region
- B. channel
- C. First name
- D. City
- E. Email
答案:A,C,D
解題說明:
MobileConnect Demographics:
* MobileConnect Demographics is a data extension in Marketing Cloud that stores information about your MobileConnect contacts (people you can send SMS messages to).
Available Data Fields (Standard):
* A. City:The city associated with the contact's mobile number or address.
* B. Region:The region (state, province, etc.) associated with the contact.
* D. First Name:The contact's first name (if captured during opt-in or data import).
* Other standard fields also include last name, country, postal code, mobile number, carrier, source object ID, status, and opt-in-related fields. You can also add custom attributes to this data extension.
* C. Email:Email addresses are typically stored in a separate data extension (like All Subscribers or a custom data extension) and linked to MobileConnect through a subscriber key or contact ID.
* E. Channel:While "Channel" might be a custom field you could add, it's not a standard field in the MobileConnect Demographics data extension.
問題 #81
Events and journeys have a close relationship. When a contact takes action with a marketing message or system, Marketing Cloud creates an event instance with associated properties.
Which are three methods in which Entry Events initiate journeys in Journey Builder?
- A. Changes to a contact's attributes
- B. Contact actions in response to marketing messages
- C. Data-modifications to a contact's profile information
- D. Status change through contact deletion operation
- E. Data retention policies
答案:A,B,E
問題 #82
Which two use cases are best suited for the new MC Transactional Messaging API?
- A. Password Resets
- B. Subscription reminders
- C. Flash Sales
- D. Order confirmations
答案:A,D
問題 #83
Testpdf為Salesforce AP-214 認證考試準備的培訓包括Salesforce AP-214認證考試的模擬測試題和當前考試題。在互聯網上你也可以看到幾個也提供相關的培訓的網站,但是你比較之後,你就會發現Testpdf的關於Salesforce AP-214 認證考試的培訓比較有針對性,不僅品質是最高的,而且內容是最全面的。
AP-214熱門考題: https://www.testpdf.net/AP-214.html
Accredited Professional認證技術員 AP-214認證驗證的能力,執行基本的故障排除和桌面型電腦和可擕式Macintosh系統,如iMac電腦和MacBook Pro維修,Testpdf將是您獲得認證的最好選擇,我們保證您100%可以通過AP-214認證考試,我們Salesforce AP-214考古題是考試原題的完美組合,答案由多位專業資深講師原版破解得出,正確率100%,我們Testpdf有龐大的IT精英團隊,會準確的迅速的為您提供Salesforce AP-214认证考試材料,也會及時的為Salesforce AP-214認證考試相關考試練習題和答案提供更新及裝訂,而且我們Testpdf也在很多認證行業中得到了很高的聲譽,因為再沒有像 Salesforce 的 AP-214 這樣的優秀的題庫資料,既是最好的題庫資料保證您通過 AP-214 考試,又給您最優質的服務,讓客戶百分之百的滿意。
水本就是萬物之源,天然擁有凈化之力,好啊,我倒想看看妳有沒有那個本事,Accredited Professional認證技術員 AP-214認證驗證的能力,執行基本的故障排除和桌面型電腦和可擕式Macintosh系統,如iMac電腦和MacBook Pro維修,Testpdf將是您獲得認證的最好選擇,我們保證您100%可以通過AP-214認證考試。
使用真實的Salesforce AP-214證照考試準備您的Salesforce AP-214考試,輕松通過我們Salesforce AP-214考古題是考試原題的完美組合,答案由多位專業資深講師原版破解得出,正確率100%,我們Testpdf有龐大的IT精英團隊,會準確的迅速的為您提供Salesforce AP-214认证考試材料,也會及時的為Salesforce AP-214認證考試相關考試練習題和答案提供更新及裝訂,而且我們Testpdf也在很多認證行業中得到了很高的聲譽。
- AP-214證照考試: Marketing Cloud Advanced Cross Channel Accredited Professional,最快的通過考試方式是選擇我們 😒 在➤ [url]www.newdumpspdf.com ⮘網站下載免費“ AP-214 ”題庫收集免費下載AP-214考題[/url]
- AP-214最新考古題 🍘 AP-214最新考古題 🦟 AP-214 PDF 🙉 到⮆ [url]www.newdumpspdf.com ⮄搜索➡ AP-214 ️⬅️輕鬆取得免費下載最新AP-214題庫[/url]
- AP-214真題材料 👍 AP-214 PDF 😃 AP-214考試心得 ℹ 到➡ [url]www.pdfexamdumps.com ️⬅️搜尋➠ AP-214 🠰以獲取免費下載考試資料AP-214最新考古題[/url]
- 全面覆蓋的AP-214證照考試 |第一次嘗試輕鬆學習和通過考試和優質的AP-214:Marketing Cloud Advanced Cross Channel Accredited Professional 💦 ☀ [url]www.newdumpspdf.com ️☀️提供免費▶ AP-214 ◀問題收集AP-214真題材料[/url]
- AP-214熱門考古題 🏡 AP-214證照指南 🐽 AP-214題庫最新資訊 🏊 立即打開➡ tw.fast2test.com ️⬅️並搜索▶ AP-214 ◀以獲取免費下載AP-214熱門考古題
- AP-214 PDF 🦈 AP-214題庫最新資訊 🎳 AP-214認證題庫 🌔 在➽ [url]www.newdumpspdf.com 🢪網站上免費搜索☀ AP-214 ️☀️題庫AP-214證照指南[/url]
- 專業的AP-214證照考試,高質量的考試指南幫助妳壹次性通過AP-214考試 🤙 ▷ [url]www.vcesoft.com ◁是獲取➽ AP-214 🢪免費下載的最佳網站AP-214最新題庫資源[/url]
- [url=https://zilvetiluis.com/?s=AP-214%e7%9c%9f%e9%a1%8c%e6%9d%90%e6%96%99%20%f0%9f%8d%8f%20AP-214%e6%9c%80%e6%96%b0%e9%a1%8c%e5%ba%ab%e8%b3%87%e6%ba%90%20%f0%9f%8c%b8%20AP-214%e8%80%83%e5%8f%a4%e9%a1%8c%e4%bb%8b%e7%b4%b9%20%f0%9f%85%b1%20%e5%9c%a8%e3%80%90%20www.newdumpspdf.com%20%e3%80%91%e7%b6%b2%e7%ab%99%e4%b8%8a%e5%85%8d%e8%b2%bb%e6%90%9c%e7%b4%a2[%20AP-214%20]%e9%a1%8c%e5%ba%abAP-214%20PDF]AP-214真題材料 🍏 AP-214最新題庫資源 🌸 AP-214考古題介紹 🅱 在【 www.newdumpspdf.com 】網站上免費搜索[ AP-214 ]題庫AP-214 PDF[/url]
- 最新版的AP-214證照考試,Salesforce Accredited Professional認證AP-214考試題庫提供免費下載 👶 ➤ [url]www.newdumpspdf.com ⮘是獲取➽ AP-214 🢪免費下載的最佳網站AP-214套裝[/url]
- AP-214認證題庫 🟥 AP-214真題材料 ✴ AP-214認證題庫 🙌 在➤ [url]www.newdumpspdf.com ⮘網站下載免費▛ AP-214 ▟題庫收集AP-214指南[/url]
- AP-214考試內容 🕓 AP-214認證資料 🐈 AP-214指南 🏦 立即打開{ [url]www.newdumpspdf.com }並搜索⮆ AP-214 ⮄以獲取免費下載AP-214最新題庫資源[/url]
- www.flirtic.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.fuxinwang.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, gettr.com, Disposable vapes
