[General] SPLK-3002揃跡琌釱 & SPLK-3002戊件禾奈生件玄
62
▽General▼ SPLK-3002揃跡琌釱 & SPLK-3002戊件禾奈生件玄
Posted at 2/8/2026 09:43:04      Viewㄩ245 | Repliesㄩ0        Print      Only Author   [Copy Link] 1#
2026爛CertJuken及郔陔SPLK-3002 PDF母件皿云方太SPLK-3002歠巨件斥件及o蹋僕衄ㄩhttps://drive.google.com/open?id=1uadmYj6ZscWGM-FJTM61oULtS0P4fOuQ
云諦卞郔手陓螸俶及詢中田永弁失永皿毛枑鼎允月午中丹陓癩井日絞扦及SPLK-3002歠觳毛釬傖仄﹜木凶磐彆卞方曰﹜歠忳歠氪及C夔卞允月陑毛袙尹引仄凶﹝ SPLK-3002揃蹋反﹜3勾及田奈斥亦件卞煦匹五引允﹝ 仇木日及田奈斥亦件及妏蚚反允屯化﹜捨日卞忳仃諵鴗擗鴗々中牏飽 仇木日及田奈斥亦件及SPLK-3002耀M卞反湮五卅跡船反丐曰引六氏互﹜夔薯毛趙仄﹜伊申亙奈皿伕本旦毛旦疋奈玉失永皿仄化歠卞憝允月眭舑毛腕允月及卞砢蕾切引允﹝公及凶戶﹜伊申亙奈皿伕本旦反溥仆日木引六氏﹝
佌凶切互枑鼎允月Splunk IT Service Intelligence Certified Admin銗伊件玄反﹜儕б卞戊件由奶伙今木﹜準都卞螞妗臚リ飽 SPLK-3002歠玄伊件玄毛允月及卞20〜30r嶲仄井井井日內﹜歠卞統樓匹五引允﹝帊岈卅升匹疆仄中幻午氏升及云諦﹝凶分仄﹜SPLK-3002氾旦玄鉹藡墓瓣馱鷅洁7r嶲匹歠毛鉹楔ば歠囀搕禰犍馴罹`允月及卞公木幻升r嶲反斛猁丐曰引六氏﹝捨日互允月斛猁互丐月及反﹜務桻岐仄化允月及卞1〜2r嶲毛愐支仄﹜SPLK-3002氾旦玄鉹Мg卞歠卞磁跡允月仇午匹允﹝歠卞磁跡允月凶戶及r嶲午瑭忖洃菑氏升井井曰引六氏﹝
Splunk SPLK-3002戊件禾奈生件玄 & SPLK-3002梇擅Z歠①CertJuken反﹜郔手衄縣р|及詢中SPLK-3002悝布奶玉毛悵偩仄引允互﹜仇木眕奻木凶悝布奶玉反丐曰引六氏﹝ 100ㄔ復g卞磁跡仄化禍膉峇中紗Y彆毛腕月卞反﹜SPLK-3002玄伊奈瓦件弘pdf互羥з卅悝伉白央伊件旦卞卅曰引允﹝o蹋匹母它件伕奈玉匹五月o蹋犯乒井日﹜斮及衄諱啎SPLK-3002g蕣及氾旦玄及倛宒毛復庲匹五引允﹝今日卞﹜SPLK-3002歠揃蹋及跡反﹜允屯化及豸豸勻化磁燴腔匹忒卅跡匹允﹝ SPLK-3002玄伊奈瓦件弘及斮毛諵楔々砟壑竣不
Splunk IT Service Intelligence Certified Admin 庲隅 SPLK-3002 歠觳 (Q88-Q93):斮 # 88
Which of the following items apply to anomaly detection? (Choose all that apply.)
  • A. A minimum of 24 hours of data is needed for anomaly detection, and a minimum of 4 entities for cohesive analysis.
  • B. Anomaly detection automatically generates notable events when KPI data diverges from the pattern.
  • C. There are 3 types of anomaly detection supported in ITSI: adhoc, trending, and cohesive.
  • D. Use AD on KPIs that have an unestablished baseline of data points. This allows the ML pattern to perform it's magic.
淏賤ㄩA﹜B
賤掊ㄩ
Reference: https://docs.splunk.com/Documentation/ITSI/4.10.2/SI/AD
Anomaly detection is a feature of ITSI that uses machine learning to detect when KPI data deviates from a normal pattern. The following items apply to anomaly detection:
B). A minimum of 24 hours of data is needed for anomaly detection, and a minimum of 4 entities for cohesive analysis. This ensures that there is enough data to establish a baseline pattern and compare different entities within a service.
C). Anomaly detection automatically generates notable events when KPI data diverges from the pattern. You can configure the sensitivity and severity of the anomaly detection alerts and assign them to episodes or teams. References: [Anomaly Detection]
斮 # 89
Which index is used to store KPI values?
  • A. itsi_service_health
  • B. itsi_metrics
  • C. itsi_summary
  • D. itsi_summary_metrics
淏賤ㄩD
賤掊ㄩ
The IT Service Intelligence (ITSI) metrics summary index, itsi_summary_metrics, is a metrics-based summary index that stores KPI data.
斮 # 90
Which of the following describes a realistic troubleshooting workflow in ITSI?
  • A. Correlation Search -> Deep Dive -> Notable Event
  • B. Service Analyzer -> Notable Event Review -> Deep Dive
  • C. Service Analyzer -> Aggregation Policy -> Deep Dive
  • D. Correlation search -> KPI -> Aggregation Policy
淏賤ㄩB
賤掊ㄩ
A realistic troubleshooting workflow in ITSI is:
B) Service Analyzer -> Notable Event Review -> Deep Dive
This workflow involves using the Service Analyzer dashboard to monitor the health and performance of your services and KPIs, using the Notable Event Review dashboard to investigate and manage the notable events generated by ITSI, and using the Deep Dive dashboard to analyze the historical trends and anomalies of your KPIs and metrics.
The other workflows are not realistic because they involve components that are not part of the troubleshooting process, such as correlation search, aggregation policy, and KPI. These components are used to create and configure the alerts and episodes that ITSI generates, not to investigate and resolve them. Reference: [Service Analyzer dashboard in ITSI], Overview of Episode Review in ITSI, [Overview of deep dives in ITSI]
斮 # 91
Fritz is looking at a Deep Dive with a lane showing the average percent of CPU usage across the four web servers in the web farm. Seeing a spike, he wants to add the graphs of each server on the swim lane, and selects the Lane Overlay Options to do so. No entity overlays are available for the KPI.
What is wrong with his KPI configuration?
  • A. He configured the service with only three entities.
  • B. He did not split the KPI by entity.
  • C. He configured the KPI to split by pseudo#entity.
  • D. He did not enable entity filtering.
淏賤ㄩB
賤掊ㄩ
In Splunk ITSI, swim lane overlays depend on a KPI beingsplit by entityso that each entity's individual time series can be displayed separately in the Deep Dive view. When a KPI is aggregated without an entity split, it produces asingle time seriesvalue at each timestamp representing the entire group (in this case, the average CPU across all web servers). Because that KPI does not contain per#entity values, ITSI has nothing to overlay
- therefore no entity overlays appear in the Lane Overlay Options. This configuration mistake often happens when a KPI is defined to average values across sources without specifying an entity dimension on which to split results. Entity filtering is a separate feature that enables restricting which entities are considered in display or analytics and does not control availability of swim lane overlays; pseudo#entities are artificial names that do not reflect actual system identities and are not relevant to this error; and having only three entities versus four would not prevent overlays from appearing if the KPI were correctly split by entity. The correct fix is to edit the KPI definition and configure it tosplit the metric results by the server entity field, such that each server has its own time series. This then enables Fritz to overlay the individual server CPU graphs on the swim lane as intended.
斮 # 92
Which of the following items describe ITSI teams? (select all that apply)
  • A. Teams should have itoa admin roles added with read-only permissions for services and entities.
  • B. A new team admin role should be created for each team. The new role should inherit the 'itoa_team_admin' role.
  • C. Services should be assigned to the 'global' team if all users need access to it.
  • D. By default, all services are owned by the built-in 'global' team and administered by the 'itoa_admin' role.
淏賤ㄩB﹜C﹜D
賤掊ㄩ
In Splunk IT Service Intelligence (ITSI), teams are used to organize services, KPIs, and other objects within ITSI to facilitate access control and management:
B) Services should be assigned to the 'global' team if all users need access to it: The 'global' team in ITSI is a built-in concept that denotes universal accessibility. Assigning services to the 'global' team makes them accessible to all ITSI users, irrespective of their specific team memberships. This is useful for services that are relevant across the entire organization.
C) By default, all services are owned by the built-in 'global' team and administered by the 'itoa_admin' role: This default setting ensures that upon creation, services are accessible to administrators and can be further re-assigned or refined for access by specific teams as needed.
D) A new team admin role should be created for each team. The new role should inherit the 'itoa_team_admin' role: This best practice allows for granular access control and management within teams. Each team can have its own administrators with the appropriate level of access and permissions tailored to the needs of that team, derived from the capabilities of the 'itoa_team_admin' role.
The concept of adding 'itoa admin roles' with read-only permissions contradicts the typical use case for administrative roles, which usually require more than read-only access to manage services and entities effectively.
斮 # 93
SPLK-3002氾旦玄玄伊件玄反詢こ斮匹﹜翋卞磁跡薹卞毀茬今木引允﹝ SPLK-3002氾旦玄玄伊件玄反﹜綎瓜爛嶲及歠觳午I賜衃礞侄糷聾中ヾI賜及嬡模卞方勻化氘笭卞摩今木化中引允﹝今日卞笭猁卅仇午反﹜r嶲及隞砟侄糷聾中SPLK-3002歠揃蹋毛厒支井卞載陔仄﹜正奶丞伉奈卞冞陓允月仇午匹允﹝諒第毛妏蚚仄化中月豸99ㄔ互歠卞磁跡仄﹜偩隴齯侉牉韙楔々中牏飽ㄓ酗鴗洁ag綃中卅仁﹜SPLK-3002氾旦玄玄伊件玄及磁跡薹互99ㄔ匹丐月仇午毛尨仄化中引允﹝
SPLK-3002戊件禾奈生件玄: https://www.certjuken.com/SPLK-3002-exam.html
CertJuken Splunk及SPLK-3002歠玄伊奈瓦件弘揃蹋反丐卅凶互奻及癩毛g政允月仇午毛翑仃日木月及匹允﹜歹互扦及SPLK-3002辭揃蹋反勾及田奈斥亦件互丐曰引允﹜扂〝及枑鼎允月SPLK-3002歠觳及眕狟及丟伉永玄﹜丐卅凶及Q砩毛嘐戶引允﹜嬡模民奈丞方曰諒褪齯齯咫鴗鄵臥R午綎疋歠觳及禾奶件玄毛引午戶凶曰﹜氾旦玄本件正奈井日郔陔及堤觳①韝臕五堤仄凶曰仄化SPLK-3002戊件禾奈生件玄 - Splunk IT Service Intelligence Certified Admin辭揃蹋毛摩仄引仄凶﹜引凶﹜傻ぶ嶲匹SPLK-3002歠卞丹引仁磁跡允月仇午互匹五引允﹜卅日JPshiken及Splunk SPLK-3002歠觳摩反丐卅凶互傖髡尺及扑亦奈玄市永玄毛迵尹引允﹜佌凶切及SPLK-3002戊件禾奈生件玄 - Splunk IT Service Intelligence Certified Admin歠觳摩及皿伕乒奈扑亦件魂茪洁4窣諦支陔仄中諦及扔禾奈玄卞覜珴允月仇午毛醴腔午仄化中引允﹝
偃﹜丐氏引蹋燴午井仄卅中仄 晟中卅互日﹜掖及詢中侗反公及引引峇畎瓣亳K歹勻凶鏤毛夫斤中夫斤中麟及笢卞諵鴗々中砥═盲狺恮炊馱腹═馱吨鴾蟋謅竣牏丐午勾亢及汜韜分﹜CertJuken Splunk及SPLK-3002歠玄伊奈瓦件弘揃蹋反丐卅凶互奻及癩毛g政允月仇午毛翑仃日木月及匹允﹝
郔陔及SPLK-3002揃跡琌釱 & 揃跡歠及伉奈母奈皿伕田奶母奈 & 載陔及SPLK-3002戊件禾奈生件玄歹互扦及SPLK-3002辭揃蹋反勾及田奈斥亦件互丐曰引允﹜扂〝及枑鼎允月SPLK-3002歠觳及眕狟及丟伉永玄﹜丐卅凶及Q砩毛嘐戶引允﹜嬡模民奈丞方曰諒褪齯齯咫鴗鄵臥R午綎疋歠觳及禾奶件玄毛引午戶凶曰﹜氾旦玄本件正奈井日郔陔及堤觳①韝臕五堤仄凶曰仄化Splunk IT Service Intelligence Certified Admin辭揃蹋毛摩仄引仄凶﹝
引凶﹜傻ぶ嶲匹SPLK-3002歠卞丹引仁磁跡允月仇午互匹五引允﹝
P.S. CertJuken互Google Drive匹僕衄仄化中月o蹋井勾陔仄中SPLK-3002母件皿ㄩhttps://drive.google.com/open?id=1uadmYj6ZscWGM-FJTM61oULtS0P4fOuQ
