Reliable Oracle 1z0-1104-25 Test Topics & 1z0-1104-25 Latest Examprep
Posted at 2/8/2026 10:57:44
DOWNLOAD the newest DumpsTorrent 1z0-1104-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19nea9ruYwSMiOhPswWvjMxUw5IBmKUlp
As we all know, if you want to pass the 1z0-1104-25 exam, you need to have the right method of study, plenty of preparation time, and targeted test materials. However, most people do not have one or all of these. That is why I want to introduce our 1z0-1104-25 Original Questions to you. So why not try our Oracle original questions, which will help you maximize your pass rate? Even if you unfortunately fail to pass the exam, we will give you a full refund.
Oracle 1z0-1104-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
| | Topic 2 | - Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
| | Topic 3 | - Implementing Identity and Access Management (IAM): This section of the exam measures skills of OCI Administrators and focuses on identity and access controls. It covers IAM domains, users, groups, and compartments, as well as the use of IAM policies to manage access to resources. Candidates are also tested on configuring dynamic groups, network sources, and tag-based access control, along with managing MFA, sign-on policies, and activity monitoring.
Updated Oracle 1z0-1104-25 Exam Questions in PDF DocumentMany exam candidates feel hampered by the shortage of effective 1z0-1104-25 practice materials, and the thick books and similar materials causing burden for you. Serving as indispensable choices on your way of achieving success especially during this exam, more than 98 percent of candidates pass the exam with our 1z0-1104-25 practice materials and all of former candidates made measurable advance and improvement. All 1z0-1104-25 practice materials fall within the scope of this exam for your information. The content is written promptly and helpfully because we hired the most processional experts in this area to compile the Oracle Cloud Infrastructure 2025 Security Professional practice materials.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q25-Q30):NEW QUESTION # 25
During your investigation of a load balancer issue, you discovered that all back-end servers associated with one of the affected listeners were reported as unhealthy. However, when you checked the back-end servers, they seemed to be working just fine.
What might be causing this issue?
- A. Overloaded back-end servers
- B. Incorrect DNS configuration
- C. Incorrect subnet configuration
- D. Misconfigured security rule
- E. Misconfigured health check
Answer: E
NEW QUESTION # 26
Task 4: Create a Certificate Authority (CA)
Create a certificate authority, where:
CA name: PBT-CERT-CA-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate authority name should be PBT- CERT-CA-01990086771abuser01 Ensure you eliminate special characters from the user name.
Common name: PBT-CERT-OCICA-01
Master Encryption Key: PBT-CERT-MEK-01 (created in the previous task)
See the solution below in Explanation.
Step 1: Access the OCI Vault
* Log in to the OCI Console.
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Certificate Authority
* In the PBI_Vault_SP vault details page, underResources, clickCertificate Authorities.
* ClickCreate Certificate Authority.
* Enter the following details:
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-CA-
0199008677labuser01).
* Common Name: Enter PBT-CERT-OCICA-01.
* Master Encryption Key: Select the PBT-CERT-MEK-01<username> key created in Task 3 (e.
g., PBT-CERT-MEK-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required by your setup.
* Validity Period: Set as needed (e.g., 10 years), or use the default.
* Compartment: Ensure it's set to the root compartment.
* ClickCreate Certificate Authorityand wait for the CA to be provisioned.
Step 3: Verify the Certificate Authority
* After creation, go to theCertificate Authoritiessection under PBI_Vault_SP.
* Confirm the CA PBT-CERT-CA-01<username> (e.g., PBT-CERT-CA-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 27
A company is securing its compute instances (VMs and Bare Metal Machines) in Oracle Cloud infrastructure (OCI) using a network firewall. As shown in the diagram, traffic flows from the internet Gateway (IGW) to the firewall in the Public DMZ Subnet, and then to the compute instances in the Public Subnet.
When configuring security lists and network security groups (NSGs) in this setup, what should they consider?
- A. Add stateful rules to the security list attached to the firewall subnet or include the firewall in an NSG containing stateful rules for better performance.
- B. Ensure that any security list or NSG rules allow the traffic to enter the firewall for appropriate evaluation.
- C. Security list and NSG rules associated with the firewall subnet and VNICs are evaluated after the firewall.
- D. If the policy used with the firewall has no rules specified, the firewall allows all traffic.
NEW QUESTION # 28
"You are part of the security operations of an organization with thousands of users accessing Oracle Cloud Infrastructure (OCI). It is reported that an unknown user action was executed resulting in configuration errors.
You are tasked with identifying the details of all users who were active in the last six hours along with any REST API calls that were executed.
Which OCI feature should you use?
- A. Object Collection Rule
- B. Management Agent Log Ingestion
- C. Service Connector Hub"
- D. Audit Analysis Dashboard
NEW QUESTION # 29
You're managing an Oracle Cloud Infrastructure (OCI) environment where a public website hosts downloadable assets stored in Object Storage buckets. These buckets need to be publicly accessible for website visitors, but Cloud Guard keeps flagging them as security risks.
How can Cloud Guard be configured to ignore problems specific to public buckets while still ensuring security checks are applied to other resources that require them?
- A. Fix the baseline by configuring the Conditional groups for the detector.
- B. Resolve or remediate the problems by making the buckets private.
- C. A public bucket is a security risk, so Cloud Guard will keep detecting it.
- D. Dismiss problems associated with those resources.
NEW QUESTION # 30
Remember to fill in the correct mail address in order that it is easier for us to send our 1z0-1104-25 study guide to you, therefore, this personal message is particularly important. We are selling virtual products, and the order of our 1z0-1104-25 exam materials will be immediately automatically sent to each purchaser's mailbox according to our system. In the future, if the system updates, we will still automatically send the latest version of our 1z0-1104-25 learning questions to the buyer's mailbox.
1z0-1104-25 Latest Examprep: https://www.dumpstorrent.com/1z0-1104-25-exam-dumps-torrent.html
- Reliable 1z0-1104-25 Test Topics | Pass-Sure Oracle Cloud Infrastructure 2025 Security Professional 100% Free Latest Examprep ⏳ Search for ➡ 1z0-1104-25 ️⬅️ and download it for free immediately on ▛ [url]www.dumpsmaterials.com ▟ 👏1z0-1104-25 Reliable Test Experience[/url]
- Exam Discount 1z0-1104-25 Voucher 🌆 1z0-1104-25 Exam Simulations 🍻 1z0-1104-25 Lead2pass 🦐 Immediately open ➥ [url]www.pdfvce.com 🡄 and search for ⮆ 1z0-1104-25 ⮄ to obtain a free download 🙃1z0-1104-25 Reliable Test Experience[/url]
- Pass Guaranteed Quiz Oracle - 1z0-1104-25 –High-quality Reliable Test Topics 🩺 Search for ⮆ 1z0-1104-25 ⮄ and download it for free immediately on ▶ [url]www.testkingpass.com ◀ 🍮1z0-1104-25 Test Result[/url]
- 1z0-1104-25:Oracle Cloud Infrastructure 2025 Security Professional collect - ExamCollection 1z0-1104-25 bootcamp 😦 Go to website ✔ [url]www.pdfvce.com ️✔️ open and search for ➡ 1z0-1104-25 ️⬅️ to download for free ℹ
df 1z0-1104-25 Braindumps[/url] - Use 1z0-1104-25 Exam Questions [2026]-Forget About Failure 🤖 Search for ✔ 1z0-1104-25 ️✔️ and download exam materials for free through ⇛ [url]www.troytecdumps.com ⇚ 🎷1z0-1104-25 Reliable Test Experience[/url]
- 1z0-1104-25 Best Practice 🕎 Updated 1z0-1104-25 Test Cram ⏪ Test 1z0-1104-25 Book 🐋 Download ➠ 1z0-1104-25 🠰 for free by simply entering 《 [url]www.pdfvce.com 》 website 🥉
df 1z0-1104-25 Braindumps[/url] - Test 1z0-1104-25 Simulator Online 🏂 1z0-1104-25 Reliable Test Experience ✅ 1z0-1104-25 Test Result 🦽 Go to website ( [url]www.prepawayexam.com ) open and search for ⮆ 1z0-1104-25 ⮄ to download for free 🆘1z0-1104-25 Exam Simulations[/url]
- Reliable 1z0-1104-25 Test Topics | Pass-Sure Oracle Cloud Infrastructure 2025 Security Professional 100% Free Latest Examprep 🍏 Open ⮆ [url]www.pdfvce.com ⮄ enter 「 1z0-1104-25 」 and obtain a free download 🐛Test 1z0-1104-25 Book[/url]
- Latest 1z0-1104-25 Exam Papers 😅 1z0-1104-25 New Dumps Ppt 🐸 Latest 1z0-1104-25 Exam Papers 🙄 Open { [url]www.exam4labs.com } enter [ 1z0-1104-25 ] and obtain a free download 🧷1z0-1104-25 Test Duration[/url]
- Test 1z0-1104-25 Simulator Online ⏯ Exam Discount 1z0-1104-25 Voucher 📦 1z0-1104-25 Lead2pass 👣 Search for ▶ 1z0-1104-25 ◀ on 《 [url]www.pdfvce.com 》 immediately to obtain a free download 📥Study 1z0-1104-25 Plan[/url]
- Use 1z0-1104-25 Exam Questions [2026]-Forget About Failure 🏛 Open 《 [url]www.troytecdumps.com 》 enter ▛ 1z0-1104-25 ▟ and obtain a free download ⚫Test 1z0-1104-25 Book[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, connect.garmin.com, Disposable vapes
What's more, part of that DumpsTorrent 1z0-1104-25 dumps now are free: https://drive.google.com/open?id=19nea9ruYwSMiOhPswWvjMxUw5IBmKUlp
