FSCP최신시험기출문제최1
Posted at 2/8/2026 11:48:19
View195
Replies2
그리고 ExamPassdump FSCP 시험 문제집의 전체 버전을 클라우드 저장소에서 다운로드할 수 있습니다: https://drive.google.com/open?id=1HdPWc5f6F4pHAPqAFq2aTtLgMoHNbzEw
Forescout인증 FSCP시험을 어떻게 패스할가 고민그만하고ExamPassdump의Forescout 인증FSCP시험대비 덤프를 데려가 주세요.가격이 착한데 비해 너무나 훌륭한 덤프품질과 높은 적중율, ExamPassdump가 아닌 다른곳에서 찾아볼수 없는 혜택입니다.
Forescout FSCP 시험요강:| 주제 | 소개 | | 주제 1 | - Advanced Product Topics Licenses, Extended Modules and Redundancy: This section of the exam measures skills of product deployment leads and solution engineers, and covers topics such as licensing models, optional modules or extensions, high availability or redundancy configurations, and how those affect architecture and operational readiness.
| | 주제 2 | - Plugin Tuning User Directory: This section of the exam measures skills of directory services integrators and identity engineers, and covers tuning plugins that integrate with user directories: configuration, mapping of directory attributes to platform policies, performance considerations, and security implications.
| | 주제 3 | - Plugin Tuning HPS: This section of the exam measures skills of plugin developers and endpoint integration engineers, and covers tuning the Host Property Scanner (HPS) plugin: how to profile endpoints, refine scanning logic, handle exceptions, and ensure accurate host attribute collection for enforcement.
| | 주제 4 | - Notifications: This section of the exam measures skills of monitoring and incident response professionals and system administrators, and covers how notifications are configured, triggered, routed, and managed so that alerts and reports tie into incident workflows and stakeholder communication.
| | 주제 5 | - Customized Policy Examples: This section of the exam measures skills of security architects and solution delivery engineers, and covers scenario based policy design and implementation: you will need to understand business case requirements, craft tailored policy frameworks, adjust for exceptional devices or workflows, and document or validate those customizations in context.
FSCP완벽한 덤프공부자료, FSCP최신 업데이트버전 덤프문제공부Forescout인증FSCP시험에 도전해보려고 없는 시간도 짜내고 거금을 들여 학원을 선택하셨나요? 사실 IT인증시험은 보다 간단한 공부방식으로 준비하시면 시간도 돈도 정력도 적게 들일수 있습니다. 그 방법은 바로ExamPassdump의Forescout인증FSCP시험준비덤프자료를 구매하여 공부하는 것입니다. 문항수도 적고 시험예상문제만 톡톡 집어 정리된 덤프라 시험합격이 한결 쉬워집니다.
최신 Forescout Certified Professional FSCP 무료샘플문제 (Q43-Q48):질문 # 43
What is the default recheck timer for a NAC policy?
- A. 2 hours
- B. 4 hours
- C. 8 hours
- D. 24 hours
- E. 12 hours
정답C
설명
Comprehensive and Detailed Explanation From Exact Extract of Forescout Platform Administration and Deployment:
According to the Forescout Administration Guide - Policy Main Rule Advanced Options, the default recheck timer for a NAC policy is 8 hours.
Default Policy Recheck Timer:
According to the official documentation:
"By default, both matched endpoints and unmatched endpoints are rechecked every eight hours, and on any admission event." This 8-hour default ensures that all endpoints are periodically re-evaluated against policy conditions, regardless of whether they currently match the policy.
Recheck Configuration:
According to the documentation:
When you configure a policy's main rule advanced options:
* Default Recheck Interval: 8 hours
* Customizable Range: Can be configured from 1 hour to infinite (no recheck)
* Applies to: All endpoints in the policy scope
Recheck Triggers:
According to the administration guide:
Policies recheck when:
* Recheck Timer Expires - Every 8 hours by default
* Admission Event - When specific network events occur
* SecureConnector Event - When SC status changes
Referenced Documentation:
* Forescout Platform Policy Main Rule Advanced Options
* Main Rule Advanced Options
질문 # 44
In a multi-site Distributed deployment, what needs to be done so that switch management traffic does not cross the WAN?
- A. Configure Switch Auto Discovery so that a discovered switch is automatically assigned to the correct appliance.
- B. Change the connecting appliance by going to Option > Appliance > IP Assignment and change the segment the switch is on to the desired appliance.
- C. Change the switch settings by going to Options > Switch and select the switch and change the Connecting Appliance option.
- D. Configure the Failover Clustering functionality so the switches get transferred automatically to the correct appliance that has better availability and capacity.
- E. Change the switch settings by going to the switch configuration and make sure the CLI user name and password are configured on the switch plugin so that it can be managed automatically by the right appliance.
정답C
설명
According to the Forescout Administration Guide and Switch Plugin documentation, in a multi-site Distributed deployment, to ensure switch management traffic does not cross the WAN, you should "Change the switch settings by going to Options > Switch and select the switch and change the Connecting Appliance option".
Switch Management Traffic in Distributed Deployments:
In a multi-site deployment:
* Local Appliance - Should manage switches at the same site (LAN)
* Remote Appliance - Should NOT manage switches across WAN links
* Traffic Optimization - Management traffic stays local to reduce WAN usage Connecting Appliance Configuration:
When a switch is discovered or needs to be managed by a specific appliance:
* Navigate to Tools > Options > Switch
* Select the switch from the list
* Change the "Connecting Appliance" option
* Select the local appliance that should manage this switch
* Apply the configuration
This ensures management traffic stays local to the site where both the appliance and switch reside.
Why Other Options Are Incorrect:
* A. Configure Switch Auto Discovery - Auto-discovery may assign switches incorrectly across WAN; manual assignment is needed for multi-site
* B. Configure CLI username and password - While credentials are needed for management, this doesn't control which appliance connects to the switch
* C. Configure Failover Clustering - Failover clustering is for appliance redundancy, not for controlling switch management traffic paths
* D. Change via Option > Appliance > IP Assignment - This path manages appliance segment assignments, not individual switch connections Best Practice for Multi-Site Deployments:
text
Site A Site B
## Appliance A ## Appliance B
## Switch A-1 ## Switch B-1
# ## Managed by A## ## Managed by B#
## Switch A-2 ## Switch B-2
## Managed by A### Managed by B#
NOT:
Appliance A managing Switch B-1 across WAN#
Connecting Appliance Option Details:
According to the switch configuration documentation:
The "Connecting Appliance" setting:
* Specifies which CounterACT appliance will manage the switch
* Should be set to the appliance closest to the switch
* Minimizes WAN traffic for switch management protocols (SNMP, SSH, Telnet)
* Applies immediately without requiring appliance restart
* ForeScout CounterACT Administration Guide - Switch Configuration
Congratulations! You have now completed all 63 questions from the comprehensive FSCP exam preparation series with verified answers from official Forescout platform administration and deployment documentation.
This comprehensive study guide covers all major topics required for the Forescout Certified Professional certification.
질문 # 45
Based on ForeScout's recommended troubleshooting approach, where should you start the troubleshooting process?
- A. Examine the GUI Logs
- B. Look at dependencies
- C. Review command line logs
- D. Run fstool tech-support
- E. Check that requirements are met
정답E
설명
According to the Forescout troubleshooting methodology, the recommended starting point for the troubleshooting process is to "Check that requirements are met". This foundational step must come before any detailed investigation.
Forescout Troubleshooting Approach:
The basic troubleshooting workflow consists of:
text
Step 1: CHECK THAT REQUIREMENTS ARE MET (START HERE)
## System requirements
## Software versions
## Network connectivity
## Licensing
Step 2: Look at Dependencies
## Network dependencies
## Service dependencies
## Appliance dependencies
Step 3: Gather Information from CounterACT
## GUI logs
## Properties
## Policies
Step 4: Gather Information from Command Line
## CLI logs
## Network diagnostics
Step 5: Form Hypothesis and Diagnose
## Analyze findings
## Determine root cause
Why Checking Requirements is the First Step:
According to the troubleshooting best practices:
* Foundation - Verifying requirements prevents wasting time on invalid configurations
* System Integrity - Ensures all prerequisites are met before investigating issues
* Efficiency - Many issues stem from unmet requirements; fixing these resolves the problem immediately
* Logical Flow - Without meeting requirements, no further troubleshooting will be effective Why Other Options Are Incorrect:
* A. Run fstool tech-support - This is an advanced diagnostic tool, not the starting point
* C. Look at dependencies - Dependencies are examined AFTER confirming requirements are met
* D. Examine the GUI Logs - Logs are reviewed AFTER requirements and dependencies are checked
* E. Review command line logs - CLI logs are examined later in the process, not first Requirements Verification Includes:
According to the methodology:
* System Requirements
* Supported OS versions
* Memory and storage requirements
* CPU specifications
* Software Versions
* Forescout platform version
* Plugin/module compatibility
* Browser versions for Console
* Network Connectivity
* IP address configuration
* Network interfaces
* Firewall rules
* Licensing
* Valid licenses
* License not expired
* License for required modules
* Basic troubleshooting approach methodology
질문 # 46
Which of the following is a switch plugin property that can be used to identify endpoint connection location?
- A. Switch IP/FQDN and Port Name
- B. Switch Location
- C. Wireless SSID
- D. Switch Port Action
- E. Switch Port Alias
정답A
설명
According to the Forescout Switch Plugin Configuration Guide Version 8.12 and the Switch Properties documentation, the Switch IP/FQDN and Port Name property is used to identify an endpoint's connection location. The documentation explicitly states:
"The Switch IP/FQDN and Port Name property contains either the IP address or the fully qualified domain name of the switch and the port name (the physical connection point on that switch) to which the endpoint is connected." Switch IP/FQDN and Port Name Property:
This property is fundamental for identifying where an endpoint is physically connected on the network.
Purpose: Provides the exact physical location of an endpoint on the network by identifying:
* Switch IP Address or FQDN - Which switch the endpoint is connected to
* Port Name - Which specific port on that switch the endpoint uses
Example: A property value might look like:
* 10.10.1.50 ort Fa0/15 (IP address and port name)
* core-switch.example.com:GigabitEthernet0/1/1 (FQDN and port name)
Use Cases for Location Identification:
According to the Switch Plugin Configuration Guide:
* Physical Topology Mapping - Administrators can see exactly where each endpoint connects to the network
* Port-Based Policies - Create policies that apply actions based on specific switch ports
* Troubleshooting - Quickly locate endpoints by their switch port connection
* Inventory Tracking - Maintain accurate records of device locations and connections Switch Location vs. Switch IP/FQDN and Port Name:
Property
Purpose
Switch Location
The switch location based on the switch MIB (Management Information Base) - geographic location of the switch itself Switch IP/FQDN and Port Name The specific switch and port where an endpoint is connected - physical connection point Switch Port Alias The alias/description of the port (if configured on the switch) The key difference: Switch Location identifies where the switch itself is located, while Switch IP/FQDN and Port Name identifies the specific connection point where the endpoint is attached.
* A. Switch Location - Identifies the location of the switch device itself (from MIB), not the endpoint's connection point
* B. Switch Port Alias - This is an alternate name for a port (like "Conference Room Port"), not the connection location information
* D. Switch Port Action - This indicates what action was performed on a port, not where the endpoint is located
* E. Wireless SSID - This is a Wireless Plugin property, not a Switch Plugin property; identifies wireless network name, not switch connection location Switch Properties for Endpoint Location:
According to the complete Switch Properties documentation:
The Switch Plugin provides these location-related properties:
* Switch IP/FQDN - The switch to which the endpoint connects
* Switch IP/FQDN and Port Name - The complete location (switch and port)
* Switch Port Name - The specific port on the switch
* Switch Port Alias - Alternate port name
Only Switch IP/FQDN and Port Name provides the complete endpoint connection location information in a single property.
* Forescout CounterACT Switch Plugin Configuration Guide Version 8.12
* Switch Properties documentation
* Viewing Switch Information in the All Hosts Pane
* About the Switch Plugin
질문 # 47
Which of the following plugins assists in classification for computer endpoints? (Choose two)
- A. Advanced Tools
- B. Switch
- C. HPS Inspection Engine
- D. DNS Client
- E. Linux Plugin
정답A,C
설명
According to the Forescout Administration Guide and Base Modules documentation, the plugins that assist in classification for computer endpoints are HPS Inspection Engine (B) and Advanced Tools (D).
HPS Inspection Engine Classification:
According to the HPS Inspection Engine Configuration Guide:
"The HPS Inspection Engine powers CounterACT tools used for classifying endpoints. These tools include the classification engine that is part of HPS Inspection Engine, the Primary Classification, Asset Classification and Mobile Classification templates, the Classify actions, and Classification/Classification (Advanced) properties." The HPS Inspection Engine provides:
* Classification Engine - Determines the Network Function property
* Primary Classification Template - Classifies endpoints into categories
* Asset Classification Template - For asset-level classification
* Mobile Classification Template - For mobile device classification
* Multiple Classification Methods - Including NMAP, HTTP banner scanning, SMB analysis, passive TCP/IP fingerprinting Advanced Tools Plugin Classification:
According to the Advanced Tools Plugin documentation:
"The Advanced Tools Plugin is used to classify endpoints based on characteristics such as operating system, hardware vendor, and application software." The Advanced Tools Plugin provides:
* Endpoint Classification - Based on OS, vendor, and applications
* Device Property Resolution - Resolves device characteristics
* Fingerprinting - Identifies endpoints based on behavioral patterns
* A. Switch - The Switch Plugin manages network devices (switches) and provides VLAN/access control, not endpoint classification
* C. Linux Plugin - The Linux Plugin is a platform-specific module for managing Linux endpoints, not a general classification tool
* E. DNS Client - The DNS Client Plugin resolves DNS queries but does not assist with endpoint classification Classification Workflow:
When classifying computer endpoints, Forescout uses:
* HPS Inspection Engine - Primary classification tool analyzing:
* HTTP banners from web services
* SMB protocol information
* NMAP scans and service detection
* Passive TCP/IP fingerprinting
* Domain credentials analysis
* Advanced Tools Plugin - Secondary classification providing:
* Vendor/model information
* Application detection
* Operating system identification
* Hardware characteristics
Together, these plugins provide comprehensive endpoint classification for computer systems.
Classification Properties Resolved:
According to the Base Modules documentation:
The HPS Inspection Engine and Advanced Tools plugins resolve:
* Function (Workstation, Printer, Server, Router, etc.)
* Operating System (Windows, Linux, macOS, etc.)
* Vendor and Model information
* Network Function (specific device role)
* Application information
* CounterACT Endpoint Module HPS Inspection Engine Configuration Guide v10.8
* Forescout Platform Base Modules
* About the Forescout Advanced Tools Plugin
질문 # 48
지금 같은 세대에 많은 분들이 IT업계에 관심을 가지고 있습니다. 이렇게 인재가 많은 사회에서 IT관련인사들은 아직도 적은 편입니다. 면접 시에도 IT인증 자격증유무를 많이들 봅니다. 때문에 IT자격증이 많은 인기를 누리고 있습니다.이런 살아가기 힘든 사회에서 이런 자격증들 또한 취득하기가 넘 어렵습니다.Forescout FSCP인증시험 또한 아주 어려운 시험입니다. 많은 분들이 응시하지만 통과하는 분들은 아주 적습니다.
FSCP완벽한 덤프공부자료: https://www.exampassdump.com/FSCP_valid-braindumps.html
- FSCP최신 시험기출문제 인증시험 대비자료 🙏 무료로 쉽게 다운로드하려면 [url]www.dumptop.com 에서▷ FSCP ◁를 검색하세요FSCP최신 인증시험 대비자료[/url]
- 최신 FSCP최신 시험기출문제 인증시험 덤프문제 ☝ 무료로 쉽게 다운로드하려면 [url]www.itdumpskr.com 에서➠ FSCP 🠰를 검색하세요FSCP최신 인증시험 대비자료[/url]
- FSCP높은 통과율 공부문제 🍲 FSCP높은 통과율 시험공부자료 ‼ FSCP시험대비 덤프데모 🏏 지금➡ [url]www.dumptop.com ️⬅️을(를) 열고 무료 다운로드를 위해▶ FSCP ◀를 검색하십시오FSCP시험덤프자료[/url]
- 최신 FSCP최신 시험기출문제 덤프자료 🏜 FSCP 를 무료로 다운로드하려면➠ [url]www.itdumpskr.com 🠰웹사이트를 입력하세요FSCP적중율 높은 인증덤프공부[/url]
- 최신 FSCP최신 시험기출문제 인증시험 덤프문제 🧳 [url]www.exampassdump.com 을(를) 열고➡ FSCP ️⬅️를 입력하고 무료 다운로드를 받으십시오FSCP높은 통과율 공부문제[/url]
- FSCP최신 시험기출문제 최신 업데이트된 덤프 😏 ➡ [url]www.itdumpskr.com ️⬅️에서 FSCP 를 검색하고 무료로 다운로드하세요FSCP높은 통과율 시험자료[/url]
- FSCP적중율 높은 인증덤프공부 📋 FSCP시험패스 📅 FSCP퍼펙트 최신버전 공부자료 💦 ▛ FSCP ▟를 무료로 다운로드하려면▶ [url]www.dumptop.com ◀웹사이트를 입력하세요FSCP적중율 높은 인증덤프공부[/url]
- FSCP시험대비 덤프데모 🛩 FSCP시험대비 덤프데모 🦛 FSCP퍼펙트 최신버전 공부자료 🚐 지금⮆ [url]www.itdumpskr.com ⮄에서▶ FSCP ◀를 검색하고 무료로 다운로드하세요FSCP높은 통과율 공부문제[/url]
- 시험준비에 가장 좋은 FSCP최신 시험기출문제 최신 공부자료 🌏 지금➥ [url]www.exampassdump.com 🡄을(를) 열고 무료 다운로드를 위해 FSCP 를 검색하십시오FSCP최신 인증시험 대비자료[/url]
- 시험준비에 가장 좋은 FSCP최신 시험기출문제 덤프자료 🏠 무료 다운로드를 위해 지금⏩ [url]www.itdumpskr.com ⏪에서⮆ FSCP ⮄검색FSCP높은 통과율 시험자료[/url]
- 적중율 좋은 FSCP최신 시험기출문제 시험기출자료 🥬 ➥ [url]www.exampassdump.com 🡄에서[ FSCP ]를 검색하고 무료로 다운로드하세요FSCP높은 통과율 시험자료[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mahademy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mylearningstudio.site, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! ExamPassdump FSCP 시험 문제집 전체 버전을 무료로 다운로드하세요: https://drive.google.com/open?id=1HdPWc5f6F4pHAPqAFq2aTtLgMoHNbzEw
