[General] Sample Plat-Dev-210 Questions Answers & Latest Plat-Dev-210 Exam Dumps
103
【General】 Sample Plat-Dev-210 Questions Answers & Latest Plat-Dev-210 Exam Dumps
Posted at 2/8/2026 11:54:10      View:121 | Replies:1        Print      Only Author   [Copy Link] 1#
The Salesforce Certified Omnistudio Developer (Plat-Dev-210) certification exam is one of the top-rated career advancement certifications in the market. This Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam dumps have been inspiring beginners and experienced professionals since its beginning. There are several personal and professional benefits that you can gain after passing the Salesforce Plat-Dev-210 Exam. The validation of expertise, more career opportunities, salary enhancement, instant promotion, and membership of Salesforce certified professional community.
Salesforce Plat-Dev-210 Exam Syllabus Topics:
  • Expression Sets & Decision Matrices: This section measures the skills of a Logic Designer and covers the configuration and application of Expression Sets and Decision Matrices within Omnistudio tools. It requires demonstrating an understanding of how Expression Sets evaluate conditions and how Decision Matrices use rule-based logic to determine outcomes. This knowledge is essential for automating decisions and streamlining complex business processes.
  • Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
  • Omniscripts: This portion of the exam measures the skills of a Business Analyst and focuses on the use of OmniScripts to create dynamic, guided user experiences. It includes comparing and contrasting various OmniScript elements and their configurations to fulfill given use cases. The section also examines the candidate's understanding of the JSON structure that supports OmniScripts, as well as the ability to select appropriate elements and properties to address functional requirements effectively.
Latest Salesforce Plat-Dev-210 Exam Dumps, Pass4sure Plat-Dev-210 Pass GuideAs is known to us, our company is professional brand established for compiling the Plat-Dev-210 study materials for all candidates. The Plat-Dev-210 study materials from our company are designed by a lot of experts and professors of our company in the field. We can promise that the Plat-Dev-210 study materials of our company have the absolute authority in the study materials market. We believe that the study materials designed by our company will be the most suitable choice for you. You can totally depend on the Plat-Dev-210 Study Materials of our company when you are preparing for the exam.
Salesforce Certified Omnistudio Developer Sample Questions (Q82-Q87):NEW QUESTION # 82
A developer writes an OmniScript that includes a DataRaptor that updates the Account statue based on information provided from the OmniScript. The information must be updated only if the Account record already exists. Otherwise, a new account must be created.
How should the developer accomplish this task?
  • A. Check Overwrite Target for all Null input checkbox on the Account id field
  • B. Populate the Lookup object and Lookup fields
  • C. Check the Upset key and is required for Upsert checkboxes on the Account id field
  • D. Check the Upsert key checkbox on the Account Status field
According to the OmniStudio Developer Guide, "To upsert a record, select the Upsert Key checkbox for the field that contains the unique identifier for the record. If you want to create a new record when no match is found, select Is Required for Upsert." Therefore, the correct answer is B.
NEW QUESTION # 83
An integration Procedure uses an HTTP action to makea REST API call. The response from the REST API must be converted into a specific XML structure before sending it as an input to another external wen service.
How should the developer configure the Integration Procedure to meet this requirement?
  • A. Use a DataRaptor Transform to convert JSON to XML
  • B. Use a DataRaptor Extract and check the XML checkbox on the Output JSON Path.
  • C. Use a Remote Action that calls the XMLStreamWriter class
  • D. Use a Remote Action that calls the XMLStreamReader class
According to the OmniStudio Developer Guide, "DataRaptor Transform actions can convert JSON to XML and vice versa." Therefore, the correct answer is C.
NEW QUESTION # 84
A developer creates a DataRaptor Extract to retrieve data to pass to an external service. The external service expects the field value to be an integer. However, the DataRaptor is sending it as a string.
Which action can the developer take to fix this?
  • A. In the DataRaptor Output tab, enter the default value as 0 on the field.
  • B. In the DataRaptor Extract tab, set the Input Data Type field to Integer.
  • C. In the DataRaptor Output tab, select the Output Data Type of that field to Integer.
  • D. In the DataRaptor Formula tab, define a formula using the function TOINTEGER and use the formula as output.
The DataRaptor Formula tab allows the developer to define formulas using functions and operators to manipulate data. The TOINTEGER function converts a string value to an integer value. The developer can use this function to output the field value as an integer and use the formula as output
NEW QUESTION # 85
A developer has a requirement to create a child FlexCard that contain all of its parent FlexCard's records in a Datatable.
  • A. {Records[0]}
  • B. {recordId}
  • C. {Records}
  • D. {Params records}
The correct syntax for passing all of the parent FlexCard's records to a child FlexCard is {Records}, which represents an array of records. The other options are incorrect because they either use an invalid syntax or refer to a single record instead of an array of records.
NEW QUESTION # 86
A developer needs to display read-only contact information in a OmniScript. The developer will format the information as a table, using merge codes to dynamically include first name, last name, street address, state, postal, code, and country from the data JSON.
Which OmniScript element should the developer use to meet this requirement?
  • A. Text Block
  • B. Rich text Area
  • C. Text area
  • D. Edit Block
A Text Block element allows the developer to display read-only text in a table format, using merge codes to dynamically include data from the data JSON. A Rich Text Area element is used to display formatted text with images and links. A Text Area element is used to display editable text in a single line or multiple lines.
An Edit Block element is used to display editable fields in a form layout.
NEW QUESTION # 87
To cope with the fast growing market, we will always keep advancing and offer our clients the most refined technical expertise and excellent services about our Plat-Dev-210 exam questions. In the meantime, all your legal rights will be guaranteed after buying our Plat-Dev-210 Study Materials. For many years, we have always put our customers in top priority. Not only we offer the best Plat-Dev-210 training prep, but also our sincere and considerate attitude is praised by numerous of our customers.
Latest Plat-Dev-210 Exam Dumps: https://www.vcedumps.com/Plat-Dev-210-examcollection.html
Posted at 2/14/2026 19:32:14        Only Author  2#
クライアントがC-ARP2P-2508ガイドトレントの支払いに成功すると、5〜10分でシステムから送信されたメールを受信します。その後、彼らはメールを流してログインし、ソフトウェアを使用してすぐに学習することができます。その時間は学習者にとって非常に重要であり、誰もが効率的な学習ができることを望んでいます。クライアントがすぐにC-ARP2P-2508テストトレントを使用できるのは、C-ARP2P-2508試験問題の大きなメリットです。使用を開始すると、試験のシミュレーションやタイミング機能の向上など、C-ARP2P-2508実践ガイドのさまざまな機能と利点をお楽しみいただけます。
