[General] Real4test HP HPE7-A06 Dumps PDF Format
103
【General】 Real4test HP HPE7-A06 Dumps PDF Format
Posted at 2/8/2026 12:01:17      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-A06 dumps are available on Google Drive shared by Real4test: https://drive.google.com/open?id=1qUQ64gwRNk17foiIs889P_2d1BReJB_3
With the help of Real4test’s marvelous brain dumps, you make sure your success in HPE7-A06 certification exam with money back guarantee. Real4test serves a huge network of its clientele with the state of the art and exam-oriented short-term study content that requires as little as a two-week time to get ready the entire HPE7-A06 Certification syllabus.
If you are on the bus, you can choose the APP version of HPE7-A06 training engine. On one hand, after being used for the first time in a network environment, you can use it in any environment. The APP version of HPE7-A06 Study Materials can save you traffic. And on the other hand, the APP version of HPE7-A06 exam questions can be applied to all kinds of electronic devices, so that you can practice on the IPAD or phone.
Latest HPE7-A06 Test Answers, HPE7-A06 PDF VCEReal4test makes your HPE7-A06 exam preparation easy with it various quality features. Our HPE7-A06 exam braindumps come with 100% passing and refund guarantee. Real4test is dedicated to your accomplishment, hence assures you successful in HPE7-A06 Certification exam on the first try. If for any reason, a candidate fails in HPE7-A06 exam then he will be refunded his money after the refund process. Also, we offer 1 year free updates to our HPE7-A06 Exam esteemed user, these updates are applicable to your account right from the date of purchase. 24/7 customer support is favorable to candidates who can email us if they find any ambiguity in the HPE7-A06 exam dumps, our support will merely reply to your all HPE7-A06 exam product related queries.
HPE Campus Access Switching Expert Written Exam Sample Questions (Q42-Q47):NEW QUESTION # 42
An OSPF router has learned a path to an external network by both an E1 and E2 advertisement, both routes having the same path cost.
Which path will the router prefer?
  • A. Both routes will be suppressed until the path conflict has been resolved.
  • B. The router will use both paths equally my means of ECMP.
  • C. The router will prefer the E2 path.
  • D. The router will prefer the E1 path.
When both OSPF E1 (External Type 1) and E2 (External Type 2) routes exist to the same destination with equal cost, the router always prefers the E1 path. This is because E1 routes include both the external cost and the internal OSPF cost to reach the ASBR, making them more accurate for path selection.
NEW QUESTION # 43
Ever since a recent firewall change at your WAN/lnternet edge, the 8GP state in your VSX pair has not returned to Established. What should you check to restore BGP functionality at the site?
  • A. Confirm that appropriate TCP ports are still allowed.
  • B. Restart the routing service so thatBGP auto-discovers its neighbors.
  • C. Confirm that BGP Peer AS has not changed.
  • D. Restart NAT service for the BGP interface.
The BGP state on a VSX pair is stuck (not 'Established') after a recent firewall change at the WAN/Internet edge, where the BGP peering likely occurs.
* BGP and Firewalls:BGP establishes sessions usingTCP port 179. Firewalls located between BGP peers must explicitly permit TCP port 179 traffic bidirectionally for the peering to establish and maintain. Firewall changes are a frequent cause of broken BGP sessions.
* Troubleshooting Steps After Firewall Change:The most logical first step is to verify that the firewall change did not inadvertently block TCP port 179 between the configured BGP neighbor IP addresses.
* Analysis of Options:
* A: Restarting routing service is disruptive and not the first step.
* B: Confirming that appropriate TCP ports (specifically 179) are still allowed through the firewall directly addresses the most probable cause related to the firewall change event.
* C: Restarting NAT service is likely irrelevant unless NAT is incorrectly configured for BGP peers.
* D: Confirming the peer AS is a basic configuration check but less likely related to thefirewall changeevent than port blocking.
* Conclusion:Given the problem occurred immediately following a firewall change, verifying that the firewall still permits TCP port 179 between the BGP peers is the most direct and likely troubleshooting step.
References:BGP protocol specifications (RFC 4271), Firewall management principles, Network troubleshooting methodology. This relates to "Routing" (16%), "Security" (10%), and "Troubleshooting" (10%) objectives.
NEW QUESTION # 44
An IT administrator wants to set up an HPE Aruba Networking User Experience Insight (UXI) sensor. During the initiation process, the administrator sees that the color of the LED is orange.
What does the orange LED mean?
  • A. The sensor is still booting
  • B. This is a G6E UXI sensor and does not have enough PoE power
  • C. The sensor cannot connect to the UXI cloud
  • D. The sensor needs multi-rate port but this port is only standard 1G port
On an HPE Aruba Networking UXI sensor, an orange LED indicates that the sensor cannot connect to the UXI cloud. This typically points to network connectivity, DNS, or firewall issues blocking communication between the sensor and the cloud service.
NEW QUESTION # 45
AnOSPF router has teamed a path to an external network oy both an El and an E2 advertisement, both routes having the same path cost. Which path -will the router prefer?
  • B. The router will use both paths equally by means ofECMP
The question involves an OSPF router receiving both an E1 (External Type 1) and an E2 (External Type 2) advertisement for an external network with the same path cost. The task is to determine which path the router will prefer.
* Option A (ECMP):Equal-Cost Multi-Path (ECMP) is used when multiple paths have the same total cost, but E1 and E2 routes have different metric calculations, so ECMP does not apply here.
* Option B (Prefer E2):Incorrect, as E2 routes are preferred only when E1 routes are not present or have a higher total cost.
* Option C (Suppressed):OSPF does not suppress routes due to path conflicts; it selects the best path based on metrics.
* Option D (Prefer E1):Correct. OSPF prefers E1 routes over E2 routes because E1 routes include the internal cost to the ASBR (Autonomous System Boundary Router) plus the external cost, providing a more accurate total cost.
* Why Option D is Correct:In OSPF, external routes are advertised as E1 or E2. E1 routes include both the external cost (advertised by the ASBR) and the internal cost to reach the ASBR, making them more precise for path selection. E2 routes only consider the external cost and are the default for redistributed routes unless explicitly configured as E1. When an OSPF router receives both E1 and E2 routes with the same external cost, it prefers the E1 route because it accounts for the total path cost, including internal network topology. This is per OSPF standards (RFC 2328).
* Relevance to Certification Objectives:
* Routing (16%):Involves designing and troubleshooting OSPF routing topologies, including external route types (E1 vs. E2).
* Troubleshooting (10%):Includes analyzing OSPF path selection to resolve routing issues.
HPE Aruba Networking AOS-CX Configuration Guide: OSPF Configuration, detailing E1 and E2 route types.
HPE7-A06Study Guide: Covers OSPF external route selection and path preference.
RFC 2328: OSPF Version 2, explaining E1 and E2 route metrics and preference.
NEW QUESTION # 46
A client would like to use the HPE Aruba Networking Switch MultiEdit Software function in HPE Aruba Networking Central.
Which option is available?
  • A. Use templates and apply them to selected switches.
  • B. Use CLI scripts and apply them to selected switches.
  • C. Run the same NAE scripts for selected switches.
  • D. Apply a configuration to an interface range for selected switches.
The MultiEdit function in HPE Aruba Networking Central allows administrators to push CLI scripts and apply them to selected switches in bulk. This provides flexibility to make consistent configuration changes across multiple devices simultaneously.
NEW QUESTION # 47
HP is obliged to give you 12 months of free update checks to ensure the validity and accuracy of the HP HPE7-A06 exam dumps. We also offer you a 100% money-back guarantee, in the very rare case of failure or unsatisfactory results. This puts your mind at ease when you are HP HPE7-A06 Exam preparing with us.
Latest HPE7-A06 Test Answers: https://www.real4test.com/HPE7-A06_real-exam.html
Our HPE7-A06 exam questions will help you get what you want in a short time, We are helping you pass the HPE7-A06 exam successfully has been given priority to our agenda, HP Valid HPE7-A06 Exam Prep During one's formative process, we all experienced some unforgettable exams in which we gain desirable outcomes, For another thing, the content inside our Aruba Certified Professional - Campus Access HPE7-A06 exam study pdf consistently matches the real HPE7-A06 exam test, which grasps of the core knowledge and key point of it.
Book Review: The New Geography of Jobs The New Geography of HPE7-A06 Jobs, written by UC Berkeley economics professor Enrico Moretti, was released last spring, Ten Deadly Marketing Sins;
Our HPE7-A06 Exam Questions will help you get what you want in a short time, We are helping you pass the HPE7-A06 exam successfully has been given priority to our agenda.
Experience The Real Environment With The Help Of HP HPE7-A06 Exam QuestionsDuring one's formative process, we all experienced Valid HPE7-A06 Exam Prep some unforgettable exams in which we gain desirable outcomes, For another thing, the content inside our Aruba Certified Professional - Campus Access HPE7-A06 exam study pdf consistently matches the real HPE7-A06 exam test, which grasps of the core knowledge and key point of it.
Our operation system will send the HPE7-A06 best questions to the e-mail address you used for payment, and all you need to do is just waiting for a while then check your mailbox.
DOWNLOAD the newest Real4test HPE7-A06 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1qUQ64gwRNk17foiIs889P_2d1BReJB_3
