[General] CCM Reliable Exam Materials, CCM Latest Exam Vce
109
General CCM Reliable Exam Materials, CCM Latest Exam Vce
Posted at 2/8/2026 12:02:24      View118 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CCM dumps are available on Google Drive shared by ActualtestPDF: https://drive.google.com/open?id=1MqYoQDkIqUL_HDgj57i-zjmUwbyJ4q_R
Life is beset with all different obstacles that are not easily overcome. For instance, CCM exams may be insurmountable barriers for the majority of population. However, with the help of our exam test, exams are no longer problems for you. The reason why our CCM Training Materials outweigh other study prep can be attributed to three aspects, namely free renewal in one year, immediate download after payment and simulation for the software version.
You don't need to worry about wasting your precious time but failing to get the CCM certification. Many people have used our CCM study materials and the pass rate of the exam is 99%. This means as long as you learn with our CCM Practice Guide, you will pass the exam without doubt. And we will give you one year's free update of the exam study materials you purchase and 24/7 online service. Now just make up your mind and get your CCM exam dumps!
CCM Latest Exam Vce, CCM Test Simulator FeeIn order to cater to different needs of our customers, we have three versions for CCM exam materials. Each version has its own feature, and you can choose the most suitable one according to your own needs. CCM PDF version supports print, if you like hard one, you can choose this version and take notes on it. CCM Online Test engine supports all electronic devices and you can also practice offline. CCM Soft test engine can stimulate the real exam environment, and you can install this version in more than 200 computers. Just have a look, there is always a version is for you.
Medical Professional Certified Case Manager Certification Exam (CCM) Sample Questions (Q19-Q24):NEW QUESTION # 19
Applying FIDIC Silver Book (edition 1999), which one of the following elements shallnotform part of the time Programme/revised programme?
  • A. The remedial work (if any) instructed under Sub-Clause 7.6.
  • B. Review periods under Sub-Clause 5.2.
  • C. The intended order of the works.
  • D. The sequence and timing of inspections and tests.
According to the FIDIC Silver Book, 1999 Edition (The Conditions of Contract for EPC/Turnkey Projects), the Contractor is required under Sub-Clause 8.3 ("Programme") to submit a time programme that illustrates the sequence and timing of the works, including milestones and key events. The intended order of the works (Option A), sequence and timing of inspections and tests (Option B), and review periods (Option D) related to contract management processes such as approval of design or submissions (Sub-Clause 5.2) are integral to effective scheduling and coordination.
However,remedial work instructed under Sub-Clause 7.6, which concerns remedying defects or damage, is generally not part of the initial or revised programme. Instead, remedial works are typically handled as separate tasks or incorporated into specific defect liability or rectification schedules after the main programme has been executed. Such remedial works arise from defects liability obligations and do not belong to the original or revised time programme used to plan the main construction phases.
This distinction is important because the programme reflects planned works execution, whereas remedial work is reactive and may be scheduled separately under defects liability clauses or final project close-out arrangements.
FIDIC Silver Book 1999 Edition, Clause 8.3 - Programme
FIDIC Silver Book 1999 Edition, Clause 7.6 - Remedial Work
FIDIC Contract Manager Study Guide, Module on Time and Delay Management
NEW QUESTION # 20
Which of the following statements are relevant to continuing effect claims? [FIDIC 2017 Edition] (2 correct answers apply)
  • A. In case the Contractor is the Claiming Party, when he/she misses to submit even just a single interim claim, then his/her entitlement is lost.
  • B. In general, a fully detailed Claim has to be submitted within 84 days after becoming aware of the event giving rise to the claim.
  • C. Continuing effect claims shall be noticed in the same way as "normal" claims, within 28 days after the Claiming Party became aware of the event or circumstance.
  • D. In case the Employer is the Claiming Party, then he/she is not obliged to submit interim claims.
Option A is correct: Continuing effect claims (claims where the event's impact continues over time) require notices like other claims, typically within 28 days of awareness.
Option D is correct: The fully detailed claim submission generally must be within 84 days of becoming aware of the event, allowing the Claiming Party to elaborate on the claim.
Option B is incorrect; Employer claims also require timely notification.
Option C is incorrect; missing a single interim claim does not necessarily result in losing entitlement if the contract allows for correction or continued claims.
FIDIC Red, Yellow, and Silver Books 2017 Edition, Sub-Clause 20.1 - Claims and Notices FIDIC Contract Manager Study Guide, Module on Claims and Continuing Effects
NEW QUESTION # 21
Regarding the FIDIC Red Book (edition 1999), which two statements are true?
  • A. A notice is to be signed by the Engineer, Contractor's Representative or Employer's Authorised Representative.
  • B. A notice and other communications may be delivered by hand, courier and mail. In each case with proof of receipt is required to qualify as legally valid.
  • C. Notices and other communications may be sent in hand written, type written, in print or through an electronic original transmission system.
  • D. In emergency situations notices can also be submitted verbally (rather than (also) in writing).
Option A is true: In emergencies, verbal notices are permitted with the requirement to follow up in writing.
Option D is true: Notices and communications may be sent in various formats including handwritten, typed, printed, or electronic systems.
Option B is incorrect; a notice does not necessarily have to be signed by all these representatives; it depends on the party issuing the notice.
Option C is incorrect; proof of receipt is ideal but not always strictly required for legal validity depending on contract provisions.
FIDIC Red Book 1999 Edition, Sub-Clause 1.3 - Communications and Notices FIDIC Contract Manager Study Guide, Module on Contract Communication
NEW QUESTION # 22
You are the Contract Manager of the Engineer in a condominium project under FIDIC Yellow Book (edition
2017), with Time for Completion of 5 months.
The Contractor received a Letter of Acceptance on 1 May 2022. The Contract Agreement was signed on 1 June 2022. The Contract Agreement states that the Commencement Date shall be notified by the Engineer, but it shall be no later than 14 days after the signing of the Contract Agreement, subject to the issuance of the construction permit.
1 July 2022 is the first day the Engineer was at Site. On the same day, the Engineer issued a Notice to the Contractor that the Commencement Date shall be 15 July 2022. However, the construction permit was issued only on 1 August 2022.
The Project was completed on 1 December 2022. After completion, the Employer submitted a claim for Delay Damages. Following consultations, the Parties could not reach agreement on the Commencement Date.
What is the correct Commencement Date?
  • A. 12 June 2022
  • B. 15 June 2022
  • C. 1 August 2022
  • D. 15 July 2022
According to the FIDIC Yellow Book 2017, the Commencement Date is the date notified by the Engineer as the date on which the Contractor shall start the execution of the Works (Sub-Clause 8.1). In this case, although the Engineer notified 15 July 2022 as the Commencement Date, it was subject to the issuance of the construction permit. Since the construction permit was only obtained on 1 August 2022, work could not legally commence before that date.
FIDIC recognizes that the Contractor cannot be expected to start before all necessary permissions are granted.
Hence, the effective Commencement Date must be the earliest date on which the Contractor can legally commence work, i.e., the date when the permit was issued (1 August 2022). The contract's requirement that the Commencement Date notification occur no later than 14 days after signing is subject to actual readiness conditions (permit availability).
Therefore, for purposes of delay and completion, the Commencement Date is 1 August 2022. This affects the calculation of the Time for Completion and any delay claims accordingly.
FIDIC Yellow Book 2017 Edition, Sub-Clause 8.1 - Commencement of Works
FIDIC Yellow Book 2017 Edition, Sub-Clause 2.1 - Right of Access to Site and Permits FIDIC Contract Manager Study Guide, Module on Contract Formation and Execution
NEW QUESTION # 23
Which one of the following statements best describes the requirements of Time for Completion?
  • A. This is the Contractor's fundamental time-related obligation, namely the completion of most of the Works (except minor outstanding works), within the Time for Completion calculated from the Commencement Date.
  • B. This is the Contractor's fundamental time-related obligation, namely completion the whole of the Works within the Time for Completion calculated from the Commencement Date.
  • C. This is one of the Contractor's obligations, namely the completion of most of the Works (except minor outstanding works), within the Time for Completion calculated from the Commencement Date.
  • D. This is one of the Contractor's obligations, namely the completion of most of the Works (except minor outstanding works), within the Time for Completion calculated from the Effective Date.
Option A best describes the Time for Completion as the Contractor's fundamental obligation to complete the entire Works within the contractual Time for Completion, calculated from the Commencement Date.
Options B, C, and D incorrectly limit the scope to "most" of the Works or confuse the reference date.
The Time for Completion sets the critical timeline for contract performance and triggering of delay damages or extensions.
FIDIC Red and Yellow Books 1999 & 2017 Editions, Sub-Clause 8.1 - Time for Completion FIDIC Contract Manager Study Guide, Module on Time and Delay Management
NEW QUESTION # 24
For one thing, the most advanced operation system in our company which can assure you the fastest delivery speed on our CCM exam questions, and your personal information will be encrypted automatically by our operation system. For another thing, with our CCM actual exam, you can just feel free to practice the questions in our training materials on all kinds of electronic devices. In addition, under the help of our CCM Exam Questions, the pass rate among our customers has reached as high as 98% to 100%. We are look forward to become your learning partner in the near future.
CCM Latest Exam Vce: https://www.actualtestpdf.com/Medical-Professional/CCM-practice-exam-dumps.html
Medical Professional CCM Reliable Exam Materials It will assess if you are able to solve the math questions correctly and quickly, Medical Professional CCM Reliable Exam Materials Up to now, no one has ever challenged our leading position of this area, If you are preparing for the practice exam, we can make sure that the CCM test practice files from our company will be the best choice for you, and you cannot find the better study materials than our company, Medical Professional CCM Reliable Exam Materials When you have trade online, your worry about the personal information leakage will generate.
Flexibility of the design, Directories and databases complement one CCM Test Simulator Fee another, even though they serve different purposes, It will assess if you are able to solve the math questions correctly and quickly.
High Pass-Rate CCM Reliable Exam Materials - Trustworthy CCM Exam Tool Guarantee Purchasing SafetyUp to now, no one has ever challenged our leading CCM position of this area, If you are preparing for the practice exam, we can make sure that the CCM test practice files from our company will CCM Latest Exam Vce be the best choice for you, and you cannot find the better study materials than our company.
When you have trade online, your worry about the personal information leakage will generate, At the same time, we always keep updating the CCM training guide to the most accurate and the latest.
2026 Latest ActualtestPDF CCM PDF Dumps and CCM Exam Engine Free Share: https://drive.google.com/open?id=1MqYoQDkIqUL_HDgj57i-zjmUwbyJ4q_R
