[General] Salesforce Plat-Dev-210 Pdf Questions - Outstanding Practice To your Salesforce
109
General Salesforce Plat-Dev-210 Pdf Questions - Outstanding Practice To your Salesforce
Posted at 2/8/2026 12:09:29      View130 | Replies1        Print      Only Author   [Copy Link] 1#
We are a team of the exam questions providers of Salesforce braindumps in the IT industry that ensure you to pass actual test 100%. We have experienced and professional IT experts to create the latest Plat-Dev-210 Exam Questions And Answers which are approach to the real Plat-Dev-210 practice test. Try download the free dumps demo.
We have created a number of reports and learning functions for evaluating your proficiency for the Plat-Dev-210 exam dumps. In preparation, you can optimize Salesforce Plat-Dev-210 practice exam time and question type by utilizing our Salesforce Plat-Dev-210 Practice Test software. iPassleader makes it easy to download Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam questions immediately after purchase.
By Achieving the Salesforce Plat-Dev-210 Certification You will Get the JobThe up-to-date Salesforce Plat-Dev-210 exam answers will save you from wasting much time and energy in the exam preparation. The content of our Salesforce Plat-Dev-210 Dumps Torrent covers the key points of exam, which will improve your ability to solve the difficulties of Salesforce Plat-Dev-210 real questions.
Salesforce Plat-Dev-210 Exam Syllabus Topics:
  • Omniscripts: This portion of the exam measures the skills of a Business Analyst and focuses on the use of OmniScripts to create dynamic, guided user experiences. It includes comparing and contrasting various OmniScript elements and their configurations to fulfill given use cases. The section also examines the candidate's understanding of the JSON structure that supports OmniScripts, as well as the ability to select appropriate elements and properties to address functional requirements effectively.
  • Flexcards: This section of the exam measures the skills of a Solution Architect and covers the ability to design and configure FlexCards based on specific business requirements. It evaluates the candidate's knowledge in selecting appropriate card styles, defining data sources and fields, and implementing user actions across different card states. Additionally, this domain tests the understanding of constructing the underlying JSON data structure that powers the FlexCards framework, ensuring that the configured cards meet both functional and technical specifications.
  • Expression Sets & Decision Matrices: This section measures the skills of a Logic Designer and covers the configuration and application of Expression Sets and Decision Matrices within Omnistudio tools. It requires demonstrating an understanding of how Expression Sets evaluate conditions and how Decision Matrices use rule-based logic to determine outcomes. This knowledge is essential for automating decisions and streamlining complex business processes.
  • Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
Salesforce Certified Omnistudio Developer Sample Questions (Q45-Q50):NEW QUESTION # 45
In an Integration Procedure, a developer needs to perform a multi-step calculation on every element of an array.
Based on best practices, what two methods are recommended?
Choose 2 answers
  • A. Use a Matrix Action to call a Calculation Matrix.
  • B. Use a Set Values Element inside a Loop Block.
  • C. Use a List Action to merge the array elements together.
  • D. Use a Calculation Action to call a Calculation Procedure.
According to the Integration Procedure Actions page, a Calculation Action can be used to "call a Calculation Procedure that performs calculations on input data" and a Matrix Action can be used to "call a Calculation Matrix that performs calculations on input data".
NEW QUESTION # 46
Refer to the following row-versioned calculation matrix.
The developer needs to delete the row that contains the Code CA-SF.
If the developer deletes that row in Version 3, whatis the result?
  • A. The row is deleted only in Version 3.
  • B. The row is deleted In Versions 2 and 3 but will remain in Version 1.
  • C. The row is deleted in all versions
  • D. The row is deleted in Version 3 and Version 1.
Deleting a row in Version 3 will only affect that version, not any previous or future versions. The row that contains the Code CA-SF will remain in Versions 1 and 2, as well as any versions created after Version 3. The other options are incorrect because they imply that deleting a row in one version will affect other versions as well.
NEW QUESTION # 47
A developer has a requirement to create a child FlexCard that contains all of its parent FlexCard's records In a Datable How should the developer configure the parent FlexCard's Node?
  • A. {Records}
  • B. {Records Plat-Dev-210}
  • C. {Recorded}
  • D. {Params, records}
The Node field for the parent FlexCard should be set to {Records}, which is an array of all the records retrieved by the parent FlexCard data source. This will allow the child FlexCard to access the records and display them in a DataTable.
NEW QUESTION # 48
A developer needs to build a DataRaptor Transform to send current weather to both an OmniScript Card Layout. Which of these samples would be valid for the Expected Output JSON?
  • A.
  • B.
  • C.
  • D.
According to the Transform External Data Unit, the Expected Output JSON should match the Output Path of the DataRaptor Transform. In option D, the Output Path is Current:CityState, which matches the Expected Output JSON. The other options have different Output Paths that do not match the Expected Output JSON.
Therefore, the correct answer is D.
NEW QUESTION # 49
A developer needs to retrieve data from an external system that stores policy data. The external system supports REST APIs to access and update the policies. Due to the volume of the policy data and peak hours of hours of business, calls to the REST APIs sometimes take longer than expected to response.
The developer creates an Integration Procedure to retrieve the policy data for use in an OmniScript.
Given the external system's known performance issues, which configuration should be used to implement the call to the external system?
Choose 2 answers
  • A. Configure a Remote action with timeout settings of 120000
  • B. Check the Chainable checkbox on the integration procedure Action in the OmniScript
  • C. Check the Chain on Step Check on the HTTP Action in the Integration Procedure
  • D. Set the Timeout property on the HTTP Action in the Integration Procedure
Setting the Timeout property on the HTTP Action in the Integration Procedure allows the developer to specify how long to wait for a response from the external system before timing out. Checking the Chain on Step Check on the HTTP Action in the Integration Procedure allows the developer to chain multiple HTTP Actions together and execute them sequentially. Configuring a Remote action with timeout settings of 120000 is not necessary, as it is already done by default in OmniStudio. Checking the Chainable checkbox on the integration procedure Action in the OmniScript has no effect on calling an external system.
NEW QUESTION # 50
To upgrade skills, hundreds of candidates attempt the Salesforce Certified Omnistudio Developer (Plat-Dev-210) certification exam and try to be smart and more efficient than the rest. In that case, they are now finding ways by which they can get help to crack the Salesforce Certified Omnistudio Developer (Plat-Dev-210) certification exams. Let's discuss the sources that can prove to be a major help if you are planning to take the exam.
Study Plat-Dev-210 Test: https://www.ipassleader.com/Salesforce/Plat-Dev-210-practice-exam-dumps.html
Posted at 3/7/2026 00:42:21        Only Author  2#
Right away, hitting the like buttonthis is amazing. Unlock your promotion with free Valid test C-BCFIN-2502 experience exam materialscareer growth is waiting!
