Why Do You Need to Trust Nutanix NCM-MCI-6.10 Exam Questions?
Posted at 2/8/2026 13:55:57
View106
Replies1
We are so sincere to provide a free trial version of our NCM-MCI-6.10 exam questions for you, just want you to find the best product for your own. We hope that you are making a choice based on understanding our NCM-MCI-6.10 study braindumps. And you will find that our NCM-MCI-6.10 training materials are so popular for their special advantages. Not only the content is always the latest, but also the displays are design carefully to cater to all kinds of study conditions. We will respect your decision. And our NCM-MCI-6.10 learning guide really wants to be your long-term partner.
The Nutanix NCM-MCI-6.10 dumps pdf formats are specially created for candidates having less time and a vast syllabus to cover. It has various crucial features that you will find necessary for your Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) exam preparation. Each NCM-MCI-6.10 practice test questions format supports a different kind of study tempo and you will find each NCM-MCI-6.10 exam dumps format useful in various ways.
NCM-MCI-6.10 New Exam Materials & Valid NCM-MCI-6.10 Practice MaterialsLearning at electronic devices does go against touching the actual study. Although our NCM-MCI-6.10 exam dumps have been known as one of the worlds leading providers of exam materials, you may be still suspicious of the content. For your convenience, we especially provide several demos for future reference and we promise not to charge you of any fee for those downloading. Therefore, we welcome you to download to try our NCM-MCI-6.10 Exam for a small part. Then you will know whether it is suitable for you to use our NCM-MCI-6.10 test questions. There are answers and questions provided to give an explicit explanation. We are sure to be at your service if you have any downloading problems.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q17-Q22):NEW QUESTION # 17
An administrator is experiencing an unidentified issue which is causing inode exhaustion on CVMs in Cluster
1. The time between receiving alerts and exhaustion is too short; the administrator needs to lower the alert thresholds to allow more time to clean up inodes until the issue has been identified and resolution implemented.
From Prism Element, modify the appropriate alert policy setting critical threshold for Cluster 1 to 60% and warning threshold to 45%. Ensure the check runs every minute and is not resolved without administrator action.
See the Explanation below for detailed answer.
Here is the step-by-step solution to modify the alert policy from the Prism Element (PE) interface for Cluster 1.
1. Access Cluster 1 Prism Element
* From the main Prism Central dashboard, navigate to Hardware > Clusters.
* Find Cluster 1 in the list and click its name. This will open the specific Prism Element login page for that cluster.
* Log in to Cluster 1's Prism Element interface.
2. Modify the Alert Policy
* In the Cluster 1 PE interface, click the gear icon (Settings) in the top-right corner.
* From the left-hand menu, select Alert Policies.
* In the search bar, type inode to find the correct policy.
* Select the checkbox for the policy named cvm_inode_usage_high.
* Click the Update button.
* In the "Update Alert Policy" dialog, configure the following settings:
* Warning Threshold (%): Change the value to 45.
* Critical Threshold (%): Change the value to 60.
* Check Interval (Secs): Change the value to 60 (to run the check every minute).
* Auto Resolve: Uncheck this box (to ensure the alert is not resolved without administrator action).
* Click Save.
NEW QUESTION # 18
Task 7
An administrator has been informed that a new workload requires a logically segmented network to meet security requirements.
Network configuration:
VLAN: 667
Network: 192.168.0.0
Subnet Mask: 255.255.255.0
DNS server: 34.82.231.220
Default Gateway: 192.168.0.1
Domain: cyberdyne.net
IP Pool: 192.168.9.100-200
DHCP Server IP: 192.168.0.2
Configure the cluster to meet the requirements for the new workload if new objects are required, start the name with 667.
See the Explanation for step by step solution.
To configure the cluster to meet the requirements for the new workload, you need to do the following steps:
Create a new VLAN with ID 667 on the cluster. You can do this by logging in to Prism Element and going to Network Configuration > VLANs > Create VLAN. Enter 667 as the VLAN ID and a name for the VLAN, such as 667_VLAN.
Create a new network segment with the network details provided. You can do this by logging in to Prism Central and going to Network > Network Segments > Create Network Segment. Enter a name for the network segment, such as 667_Network_Segment, and select 667_VLAN as the VLAN. Enter 192.168.0.0 as the Network Address and 255.255.255.0 as the Subnet Mask. Enter 192.168.0.1 as the Default Gateway and
34.82.231.220 as the DNS Server. Enter cyberdyne.net as the Domain Name.
Create a new IP pool with the IP range provided. You can do this by logging in to Prism Central and going to Network > IP Pools > Create IP Pool. Enter a name for the IP pool, such as 667_IP_Pool, and select
667_Network_Segment as the Network Segment. Enter 192.168.9.100 as the Starting IP Address and
192.168.9.200 as the Ending IP Address.
Configure the DHCP server with the IP address provided. You can do this by logging in to Prism Central and going to Network > DHCP Servers > Create DHCP Server. Enter a name for the DHCP server, such as
667_DHCP_Server, and select 667_Network_Segment as the Network Segment. Enter 192.168.0.2 as the IP Address and select 667_IP_Pool as the IP Pool.
NEW QUESTION # 19
TASK 1
A newly created Windows VM "SQL02" is experiencing poor storage performance when compared to
"SQL01" running within the same cluster, on the same storage container.
The cluster is in a healthy state.
Create a new session named Monitor SQL02 with meaningful metrics. Right click on the session page and click Select All then paste this into Notepad and save it as Task 1.txt on the desktop.
Also, save the analysis as a report named MonitorSQL02 and send the report as a PDF on a daily basis to perf_group@ACME.org. Reports should not be retained. If any new objects need to be created, use monitovm2 in the name.
Finally, correct the issue within "SQL02".
Notes:
* Do not power on the VMs.
* While you will be creating a session, you will need to examine the VM configurations to determine the issue.
* Do not delete the VM to resolve the issue, any other destructive change is acceptable.
Here is the step-by-step solution to all three tasks, performed within the Nutanix Prism interface.
Task 1: Create Monitoring Session & Save Metrics
* From the Prism Central dashboard, navigate to Operations > Analysis.
* Click the + New Session button.
* Name the session Monitor SQL02.
* In the "Entities" search box, type SQL01 and select VM: SQL01.
* In the "Entities" search box, type SQL02 and select VM: SQL02.
* Click Add Charts > New Chart.
* Title: Storage IOPS
* Metric: Storage Controller IOPS
* Click Add.
* Title: Storage Latency
* Metric: Storage Controller Latency
* Click Add.
* Title: Storage Bandwidth
* Metric: Storage Controller Bandwidth
* Click Add.
* Click Save Session.
* With the "Monitor SQL02" session open, right-click anywhere on the page and click Select All.
* Right-click again and select Copy.
* Open Notepad, paste the content, and save the file to the desktop as Task 1.txt.
(The content pasted into Task 1.txt would be the session's chart configurations, showing metrics for SQL01 and SQL02.)
Task 2: Create and Schedule the Report
* While still in the "Monitor SQL02" analysis session, click the Save as Report button (it looks like a bookmark icon).
* Name the report MonitorSQL02 and click Save.
* Navigate to Operations > Reports.
* Find the MonitorSQL02 report in the list. Select its checkbox.
* Click the Actions dropdown and select Schedule.
* Configure the schedule with the following settings:
* Schedule Name: monitovm2_daily_report
* Recurrence: Daily
* Start Time: (Set to a time, e.g., 8:00 AM)
* Repeat every: 1 day(s)
* Retention Policy: Uncheck the "Retain a copy of the report" box. (This ensures reports are not retained).
* Email Report: Check this box.
* Format: PDF
* Recipients: perf_group@ACME.org
* Click Save.
Task 3: Identify and Correct the Performance Issue
This task is performed without powering on the VMs, indicating a configuration error.
Investigation
* Navigate to VMs > Table view.
* Click on the SQL01 (the good VM) and select the Configuration tab.
* Expand the Disks section. Observe that the primary disk is attached to a SCSI bus (e.g., scsi.0). This is the high-performance standard.
* Return to the VM list and click on SQL02 (the problem VM).
Root Cause
You discover that the primary disk for SQL02 is attached to an IDE bus. The IDE bus has significant performance limitations and is not suitable for a database server, causing the poor storage performance.
Correction
* With the SQL02 VM selected, click the Update button.
* In the "Update VM" dialog, scroll down to the Disks section.
* Find the disk attached to the IDE bus. Click the Edit (pencil) icon for that disk.
* Change the Bus Type dropdown from IDE to SCSI.
* The Device Index will automatically populate (e.g., scsi.0).
* Click Save in the "Update Disk" dialog.
* (Note: A "VirtIO SCSI Controller" will be automatically added to the VM configuration if one was not already present.)
* Click Save in the "Update VM" dialog.
The VM SQL02 is now configured to use the high-performance VirtIO-SCSI controller, which will resolve the storage performance discrepancy once the VM is powered on.
NEW QUESTION # 20
Create a VM template on Cluster 1 named Small Template that matches the small VM Configuration in NVD-2031 (see the FilesDocumentation 6.10 folder) however, you will use default storage container.
Configure SMTP Alerting and NCC reports per NVD-2031 for Cluster 1.
Settings:
* SMTP: Use Cluster 2 IP address
* Cluster email: cluster1@ACME.org
* Alert emails: primaryalerts@ACME.org, secondaryalerts@ACME.org
Here is the step-by-step solution to complete both tasks on Cluster 1.
This solution requires you to first find the IP of Cluster 2 (for the SMTP server) and then perform all configurations within the Prism Element interface for Cluster 1.
Prerequisite: Find Cluster 2 IP
* In Prism Central, navigate to Hardware > Clusters.
* Find Cluster 2 in the list and note its IP Address. You will use this in the steps below.
Task 1: Create the VM Template
* Log in to the Prism Element (PE) interface for Cluster 1. (From PC, go to Hardware > Clusters > click the name "Cluster 1").
* Navigate to the VM view from the main dashboard.
* Click the + Create VM button.
* Fill in the VM details based on the NVD-2031 "Small VM" configuration (e.g., 2 vCPUs, 1 Core per vCPU, 4 GB RAM).
* Name: Small Template
* Compute Details:
* vCPUs: 2
* Number of Cores per vCPU: 1
* Memory: 4 GB
* Scroll down to Storage and click + Add New Disk.
* Operation: Select Clone from Image Service.
* Image: Select any available guest OS image (e.g., a Windows or CentOS image).
* Storage Container: Ensure the default container is selected (as required by the task).
* Click Add.
* Scroll down to Network Adapters (NIC) and click + Add NIC.
* Select any available VLAN/Subnet (e.g., Primary).
* Click Add.
* Click Save. The VM will be created (and remain powered off).
* Find the new Small Template VM in the list. Select its checkbox.
* Click the Actions dropdown and select Convert to Template.
* Confirm the action by clicking OK.
Task 2: Configure SMTP and NCC Reports
* While still in the Cluster 1 Prism Element interface, click the gear icon (Settings) in the top-right corner.
* Select SMTP Server from the left-hand menu.
* Click the Configure button.
* In the "Server Settings" tab, fill in the following:
* Server Address: Enter the Cluster 2 IP Address (which you found in the prerequisite step).
* Port: 25 (leave as default).
* From Email Address: cluster1@ACME.org
* Click Next.
* In the "Email Recipients" tab, click + Add Email Recipient.
* Address: primaryalerts@ACME.org
* Ensure all severities (Critical, Warning, Info) are checked.
* Click Save.
* Click + Add Email Recipient again.
* Address: secondaryalerts@ACME.org
* Ensure all severities are checked.
* Click Save.
* Click Done. A test email will be sent.
* In the main Settings menu, select Alerts and Notifications.
* Scroll to the NCC Health Checks section.
* Check the box labeled Email Nutanix Cluster Check reports to recipients. (This will use the SMTP settings and recipients you just configured).
* Click Save.
NEW QUESTION # 21
A company who offers Infrastructure as a Service needs to onboard a new customer. The new customer requires a dedicated cloud plan which tolerates two host failures.
The customer is planning to move current workloads in three waves, with three months between waves starting today:
* Wave One: 100 VMs
* Wave Two: 50 VMs
* Wave Three: 20 VMs
Workload profile is:
* vCPU: 4
* vRAM: 16 GB
* Storage: 200 GB
The service provider company needs to estimate required resources upfront, to accommodate customer requirements, considering also that:
* limit the number of total nodes
* selected system vendor HPE
* selected model DX365-10-G11-NVMe
* full-flash node (including NVMe + SSD)
* 12 months runway
Create and save the scenario as IaaS and export to the desktop, name the file IaaS-requirement.pdf Note: You must export the PDF to the desktop as IaaS-requirement.pdf to receive any credit.
Here is the step-by-step solution to create and export the capacity planning scenario. This task is performed within Prism Central.
1. Navigate to the Planning Dashboard
* From the Prism Central main menu (hamburger icon), navigate to Operations > Planning.
2. Create and Define the Scenario
* Click the + Create Scenario button.
* In the dialog box:
* Scenario Name: IaaS
* Scenario Type: Select New Workload
* Click Create. This will open the scenario editor.
3. Configure Cluster and Runway Settings
* In the "IaaS" scenario editor, find the Runway setting (top left) and set it to 12 Months.
* Find the Cluster configuration tile and click Edit.
* Set Number of Host Failures to Tolerate to 2.
* Click Save.
4. Define the Workload Profile
* In the Workloads section, click the + Add Workload button.
* Select Create a new workload profile.
* Fill in the VM specifications:
* Workload Name: Customer-VM (or similar)
* vCPU per VM: 4
* Memory per VM: 16 GB
* Storage per VM: 200 GB
* Click Add.
5. Set the Workload Growth Plan (Waves)
* You will be returned to the main scenario editor. In the timeline section ("Workload Plan"), add the VMs:
* Wave One (Today):
* Click + Add under the "Today" column.
* Select the Customer-VM profile.
* Enter 100 VMs.
* Click Add.
* Wave Two (3 Months):
* Click the + icon on the timeline itself.
* Set the date to 3 Months from today.
* Click + Add under this new "3 Months" column.
* Enter 50 VMs.
* Click Add.
* Wave Three (6 Months):
* Click the + icon on the timeline.
* Set the date to 6 Months from today.
* Click + Add under this new "6 Months" column.
* Enter 20 VMs.
* Click Add.
6. Select the Hardware
* In the Hardware configuration tile, click Change Hardware.
* In the "Select Hardware" pane:
* Vendor: Select HPE.
* Model: Search for and select DX365-10-G11-NVMe.
* Note: This model is full-flash by definition, satisfying the requirement.
* Click Done. The planner will recalculate the required nodes.
7. Save and Export the Scenario
* Click the Save icon (floppy disk) in the top-right corner to save the IaaS scenario.
* Click the Export icon (arrow pointing down) in the top-right corner.
* Select PDF from the dropdown menu.
* A "Save As" dialog will appear.
* Navigate to the Desktop.
* Set the file name to IaaS-requirement.pdf.
* Click Save.
NEW QUESTION # 22
Nowadays everyone is interested in the field of Nutanix because it is growing rapidly day by day. The Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) credential is designed to validate the expertise of candidates. But most of the students are confused about the right preparation material for NCM-MCI-6.10 Exam Dumps and they couldn't find real NCM-MCI-6.10 exam questions so that they can pass Nutanix NCM-MCI-6.10 certification exam in a short time with good grades.
NCM-MCI-6.10 New Exam Materials: https://www.testsdumps.com/NCM-MCI-6.10_real-exam-dumps.html
Nutanix NCM-MCI-6.10 Valid Exam Voucher 24/7 Get Free Advice, TestsDumps NCM-MCI-6.10 exam PDF and exam VCE simulators are very easy to use and install, If you pass NCM-MCI-6.10 test dump you will have a good reputation and considerable salary and make friends with different successful men in the bright future, It would waste a lot of time, energy and money on Nutanix NCM-MCI-6.10 exams.
The Shells Responsibilities, After studying from the NCM-MCI-6.10 dumps, I am pretty sure that I will pass, 24/7 Get Free Advice, TestsDumps NCM-MCI-6.10 exam PDF and exam VCE simulators are very easy to use and install.
Free PDF Quiz 2026 Nutanix Reliable NCM-MCI-6.10 Valid Exam VoucherIf you Pass NCM-MCI-6.10 Test dump you will have a good reputation and considerable salary and make friends with different successful men in the bright future, It would waste a lot of time, energy and money on Nutanix NCM-MCI-6.10 exams.
Learn the importance of self-evident, and the stand or fall of learning outcome NCM-MCI-6.10 measure, in reality of hiring process, for the most part through your grades of high and low, as well as you acquire the qualification of how much remains.
- NCM-MCI-6.10 Exam Assessment 🛃 NCM-MCI-6.10 Free Download 🃏 Real NCM-MCI-6.10 Exam Questions 💘 Open ▶ [url]www.dumpsmaterials.com ◀ and search for ▶ NCM-MCI-6.10 ◀ to download exam materials for free 🐳Real NCM-MCI-6.10 Exam Questions[/url]
- Real NCM-MCI-6.10 Exam Questions ❤️ NCM-MCI-6.10 Cert ⏫ NCM-MCI-6.10 Valid Test Syllabus 🏣 ⮆ [url]www.pdfvce.com ⮄ is best website to obtain ⇛ NCM-MCI-6.10 ⇚ for free download 🙇NCM-MCI-6.10 Valid Exam Tutorial[/url]
- First-grade NCM-MCI-6.10 Valid Exam Voucher C Find Shortcut to Pass NCM-MCI-6.10 Exam 🐆 Enter ➠ [url]www.prepawaypdf.com 🠰 and search for NCM-MCI-6.10 to download for free 🎌NCM-MCI-6.10 Authentic Exam Hub[/url]
- Certification NCM-MCI-6.10 Exam Cost 🥑 NCM-MCI-6.10 Free Download 🔮 New NCM-MCI-6.10 Test Discount 🥏 The page for free download of ➡ NCM-MCI-6.10 ️⬅️ on ➠ [url]www.pdfvce.com 🠰 will open immediately 😜NCM-MCI-6.10 Valid Test Syllabus[/url]
- NCM-MCI-6.10 Latest Exam Answers 🆚 NCM-MCI-6.10 Valid Exam Tutorial 🧀 Regualer NCM-MCI-6.10 Update 🐁 Search on [url]www.vce4dumps.com for NCM-MCI-6.10 to obtain exam materials for free download 💨NCM-MCI-6.10 Reliable Exam Pattern[/url]
- Printable NCM-MCI-6.10 PDF 😸 Latest Braindumps NCM-MCI-6.10 Ppt 📼 Valid NCM-MCI-6.10 Exam Pass4sure 🥪 Search on ⮆ [url]www.pdfvce.com ⮄ for ⮆ NCM-MCI-6.10 ⮄ to obtain exam materials for free download 🐘Latest Braindumps NCM-MCI-6.10 Ppt[/url]
- Top NCM-MCI-6.10 Valid Exam Voucher | Easy To Study and Pass Exam at first attempt - Latest updated NCM-MCI-6.10: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) 🧳 Enter ⏩ [url]www.prep4away.com ⏪ and search for ✔ NCM-MCI-6.10 ️✔️ to download for free ⏸Valid Exam NCM-MCI-6.10 Blueprint[/url]
- Top NCM-MCI-6.10 Valid Exam Voucher | Easy To Study and Pass Exam at first attempt - Latest updated NCM-MCI-6.10: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) 🚙 Open ▷ [url]www.pdfvce.com ◁ and search for NCM-MCI-6.10 to download exam materials for free 🛶Real NCM-MCI-6.10 Exam Questions[/url]
- Fast Download NCM-MCI-6.10 Valid Exam Voucher | Verified NCM-MCI-6.10 New Exam Materials: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) 🍝 Search for ☀ NCM-MCI-6.10 ️☀️ and obtain a free download on ➡ [url]www.exam4labs.com ️⬅️ 🧷Latest NCM-MCI-6.10 Test Online[/url]
- First-grade NCM-MCI-6.10 Valid Exam Voucher C Find Shortcut to Pass NCM-MCI-6.10 Exam 🎦 Easily obtain free download of NCM-MCI-6.10 by searching on { [url]www.pdfvce.com } 🧷Valid Exam NCM-MCI-6.10 Blueprint[/url]
- Valid NCM-MCI-6.10 Test Duration 🌑 Regualer NCM-MCI-6.10 Update 🛌 NCM-MCI-6.10 Cert 🍋 Search for ▷ NCM-MCI-6.10 ◁ and obtain a free download on ➡ [url]www.examcollectionpass.com ️⬅️ ℹ
rintable NCM-MCI-6.10 PDF[/url] - pathshala.digitalproductszones.com, www.stes.tyc.edu.tw, vietnamfranchise.vn, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
