[General] Valid Dumps NP-Con-102 Pdf & NP-Con-102 Reliable Study Materials
101
General Valid Dumps NP-Con-102 Pdf & NP-Con-102 Reliable Study Materials
Posted at 2/8/2026 14:08:24      View106 | Replies0        Print      Only Author   [Copy Link] 1#
Studying from an updated practice material is necessary to get success in the Salesforce NP-Con-102 certification test on the first try. If you don't adopt this strategy, you will not be able to clear the Salesforce Certified Nonprofit Cloud Consultant (NPC) (NP-Con-102) examination. Failure in the Salesforce Certified Nonprofit Cloud Consultant (NPC) (NP-Con-102) test will lead to loss of confidence, time, and money. Don't worry because "PassSureExam" is here to save you from these losses with its updated and real Salesforce NP-Con-102 exam questions.
Our Salesforce dumps torrent contains everything you need to pass NP-Con-102 actual test smoothly. We always adhere to the principle that provides our customers best quality NP-Con-102 Exam Prep with most comprehensive service. This is the reason why most people prefer to choose our NP-Con-102 vce dumps as their best preparation materials.
Salesforce - NP-Con-102 - Newest Valid Dumps Salesforce Certified Nonprofit Cloud Consultant (NPC) PdfAccording to the needs of all people, the experts and professors in our company designed three different versions of the NP-Con-102 study materials for all customers. The three versions are very flexible for all customers to operate. According to your actual need, you can choose the version for yourself which is most suitable for you to preparing for the coming exam. All the NP-Con-102 Study Materials of our company can be found in the three versions. It is very flexible for you to use the three versions of the NP-Con-102 study materials to preparing for your coming exam.
Salesforce Certified Nonprofit Cloud Consultant (NPC) Sample Questions (Q118-Q123):NEW QUESTION # 118
A consultant is assisting a nonprofit in its data integration and mapping between two systems. The consultant is unsure when a particular field was added to NPSP. Where can the consultant find the NPSP version number for the field in question?
  • A. Schema Builder
  • B. NPSP Data Dictionary
  • C. NPSP package details
  • D. Custom field definition detail
When performing complex integrations or troubleshooting why a field is missing in an older sandbox, a consultant needs a reliable reference for the NPSP metadata.
The NPSP Data Dictionary:
* Historical Reference: The NPSP Data Dictionary is an official Salesforce resource (usually provided as a spreadsheet or a dedicated help article). It lists every object and field included in the managed package.
* Version Tracking: Crucially, the Data Dictionary includes a column for "Introduced In" or " Package Version." This tells the consultant exactly which release of NPSP (e.g., 3.154) first included that specific field.
* Object Mapping: It also provides the API names, descriptions, and help text for all NPSP-specific fields, making it the primary "source of truth" for mapping projects.
* Custom Field Definition (Option C): In the Salesforce Setup menu, the field detail page will show the
"Installed Package" (Nonprofit Success Pack), but it does not tell you which version of that package introduced the field.
* NPSP Package Details (Option A): This shows you the current version installed in the org, but not the historical release version for individual fields.
* Schema Builder (Option D): This is a visual tool for seeing relationships between objects; it contains no versioning or historical metadata.
NEW QUESTION # 119
A nonprofit wants to convert from Legacy Recurring Donations to Enhanced Recurring Donations. What are two considerations the nonprofit should take into account before making the switch? (Choose 2)
  • A. Reverting to Legacy Recurring Donations is unsupported.
  • B. Enhanced Recurring Donations introduces a new custom object.
  • C. Data Loader is required to revert to Legacy Recurring Donations.
  • D. All existing integrations should be reviewed for compatibility.
The move from Legacy Recurring Donations to Enhanced Recurring Donations (ERD) is a significant architectural upgrade in NPSP. While ERD offers better performance and more flexible scheduling, it changes how data is processed and stored.
Key Considerations:
* Integration Compatibility (A): Enhanced Recurring Donations changes the underlying logic of how installments (Opportunities) are created and managed. If the nonprofit uses third-party apps (like an external payment gateway or a custom web form) that rely on the legacy npe03__Recurring_Donation__c fields or the old "Monthly" vs. "Custom" picklist values, those integrations may break. A consultant must perform a thorough audit of all APIs and managed packages before the conversion.
* No Revert Path (D): This is a "one-way door." Salesforce documentation explicitly states that reverting to Legacy Recurring Donations is unsupported once the upgrade process has been completed. The conversion process modifies the database schema and migrates records in a way that cannot be easily undone. Therefore, testing in a full sandbox is a non-negotiable prerequisite.
Clarifying Other Points:
* New Custom Object (Option B): This is incorrect. Enhanced Recurring Donations actually uses the same custom object as the legacy version (npe03__Recurring_Donation__c), but it utilizes new fields, new page layouts, and a completely different set of Apex triggers and batch jobs.
* Data Loader (Option C): Since the process is unsupported, Data Loader is not a viable or recommended way to "revert" the complex architectural changes.
NEW QUESTION # 120
What are two benefits of using Agile project management?
  • A. A linear sequence of steps and carefully controlled change
  • B. All risks defined early in the project and the result is a single deliverable
  • C. Iterative planning and hands-on stakeholder involvement
In the context of a Nonprofit Cloud implementation, the Agile methodology is often preferred over traditional methods because it accounts for the evolving needs of mission-driven organizations. Unlike a rigid framework, Agile focuses on delivering value in small, manageable increments called "Sprints." Two of the most significant benefits of this approach are:
* Iterative Planning: Rather than trying to document every single requirement for a complex feature like
"Outcome Management" at the very start, Agile allows for continuous planning. The consultant and the nonprofit stakeholders prioritize a "Backlog" of work. At the start of each sprint, the team plans only the work for that cycle. This allows the organization to pivot if, for example, a new grant requirement is announced mid-project that changes how they need to track benefits.
* Hands-on Stakeholder Involvement: Agile requires constant collaboration. Stakeholders (such as Program Managers or Gift Officers) are involved in "Sprint Reviews" where they see live demonstrations of the work completed. This "fail-fast" or "learn-early" model ensures that if a consultant builds a Gift Entry flow that doesn't quite match the staff's physical workflow, it is caught and corrected within weeks rather than months.
* Option A: Defining all risks early and producing a "single deliverable" is a hallmark of the Waterfall method. In Agile, risks are identified continuously, and deliverables are produced incrementally.
* Option C: A "linear sequence" and "carefully controlled change" describes a rigid Waterfall environment. In contrast, Agile is non-linear and embraces change as a way to improve the final product's relevance to the nonprofit's mission.
NEW QUESTION # 121
A nonprofit wants to send an event cancellation notice to 150 Salesforce contacts without a separate email service provider. It wants to manage bounces, resend the notice as needed, and view the send history on the Contact record. Which option should a consultant recommend to meet the requirements?
  • A. Account Engagement
  • B. Send List Email
  • C. Elevate
  • D. Email-to-Case
For a small volume of contacts (150) and a simple one-off requirement like an event cancellation, standard Salesforce functionality is the most cost-effective and efficient choice. Send List Email is a native Lightning Experience feature that meets all the organization's criteria without the complexity of a third-party marketing tool.
How Send List Email Meets the Requirements:
* Direct Send: Users can select up to 2,000 contacts from a list view or a campaign and click Send List Email. This uses Salesforce's internal mail servers (or the organization's connected Office 365/Gmail account).
* Send History: Every list email sent is automatically recorded in the Activity History (specifically the
"HTML Email Status" or "Emails" related list) on the Contact record. This satisfies the requirement to
"view the send history."
* Manage Bounces: Salesforce has a native "Email Bounce Management" feature. If an email address is invalid, a warning icon appears next to the email address on the Contact record, and the staff can see the
"Bounce Reason."
* Resending: Because the send history is logged as an activity, staff can easily identify who didn't receive the message and trigger a follow-up email manually or by creating a filtered list of "bounced" contacts.
* Elevate (Option A): This is a payment processing platform for fundraising and has no native bulk email capabilities for event management.
* Email-to-Case (Option B): This is a support tool for receiving incoming emails and turning them into tickets; it is not for proactive event outreach.
* Account Engagement (Option D): Formerly known as Pardot, this is a robust marketing automation platform. While it could do this, it is considered "overkill" for a one-off 150-person email and requires a separate, significant license and technical setup.
NEW QUESTION # 122
A nonprofit wants to be in full compliance with Salesforce best practices for data security and has asked its consultant for an evaluation. Which tool should the consultant use to provide this assessment?
  • A. Salesforce Health Check
  • B. Shield Platform Encryption
  • C. NPSP Health Check
  • D. Salesforce Optimizer
To provide a comprehensive assessment of data security best practices, the consultant should use the native Salesforce Health Check.
What Salesforce Health Check provides:
* Security Baseline: It compares the organization's current security settings against the Salesforce Recommended Baseline.
* Scoring: It provides an overall "Health Score" (0-100%).
* Specific Evaluations: It analyzes critical security settings, including:
* Password Policies: Complexity, expiration, and lockout settings.
* Session Settings: Timeout values and whether "secure cookies" are required.
* Network Security: IP ranges and multi-factor authentication requirements.
* File Settings: Restrictions on file types and downloads.
* Actionable Advice: For every setting that does not meet the baseline, it provides a "Fix It" link or instructions on how to bring the setting into compliance.
* Salesforce Optimizer (Option C): This is a general "maintenance" tool. It checks for unused fields, limits, and technical debt. While it has some security checks, it is not a dedicated security assessment tool.
* NPSP Health Check (Option D): This is specifically for data integrity within NPSP (e.g., checking if rollups are working or if households have addresses). It does not evaluate the underlying Salesforce platform security settings.
* Shield (Option B): This is a product (a set of security features) you can buy, not an assessment tool to evaluate current compliance.
NEW QUESTION # 123
PassSureExam's study material is available in three different formats. The reason we have introduced three formats of the Salesforce Certified Nonprofit Cloud Consultant (NPC) (NP-Con-102) practice material is to meet the learning needs of every student. Some candidates prefer NP-Con-102 practice exams and some want Real NP-Con-102 Questions due to a shortage of time. At PassSureExam, we meet the needs of both types of aspirants. We have Salesforce NP-Con-102 PDF format, a web-based practice exam, and Salesforce Certified Nonprofit Cloud Consultant (NPC) (NP-Con-102) desktop practice test software.
NP-Con-102 Reliable Study Materials: https://www.passsureexam.com/NP-Con-102-pass4sure-exam-dumps.html
It can match your office software and as well as help you spare time practicing the NP-Con-102 exam, We are considered the best ally to our customers who want to pass their NP-Con-102 exam by their first attempt and achieve the certification successfully, With our NP-Con-102 learning materials for 20 to 30 hours, we can claim that you will be confident to go to write your NP-Con-102 exam and pass it, Up-to-date & Valid NP-Con-102 Reliable Study Materials - Salesforce Certified Nonprofit Cloud Consultant (NPC) Dumps NP-Con-102 Reliable Study Materials - Salesforce Certified Nonprofit Cloud Consultant (NPC) Dumps at PassSureExam NP-Con-102 Reliable Study Materials are always kept up to date.
According to an analysis by Intuit of its early borrowers: percent of QuickBooks NP-Con-102 Capital customers had never applied for a loan before, It not only can improve your cultural knowledge, but also improve your operation level.
Pass Guaranteed Quiz Salesforce - NP-Con-102 CValid Valid Dumps PdfIt can match your office software and as well as help you spare time practicing the NP-Con-102 Exam, We are considered the best ally to our customers who want to pass their NP-Con-102 exam by their first attempt and achieve the certification successfully!
With our NP-Con-102 learning materials for 20 to 30 hours, we can claim that you will be confident to go to write your NP-Con-102 exam and pass it, Up-to-date & Valid Valid Dumps NP-Con-102 Pdf Salesforce Certified Nonprofit Cloud Consultant (NPC) Dumps Salesforce Certified Nonprofit Cloud Consultant (NPC) Dumps at PassSureExam are always kept up to date.
Salesforce Certified Nonprofit Cloud Consultant (NPC) VCE dumps for simulated practice.
