[General] Training Fortinet NSE8_812 Materials & Pdf NSE8_812 Dumps
115
【General】 Training Fortinet NSE8_812 Materials & Pdf NSE8_812 Dumps
Posted at 2/8/2026 14:36:34      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4SureQuiz NSE8_812 dumps from Cloud Storage: https://drive.google.com/open?id=1dG34l1Hf7Zj1rHH36_yjcVnKkNABVw18
The Fortinet NSE8_812 certification is one of the hottest career advancement credentials in the modern Fortinet world. The NSE8_812 certification can help you to demonstrate your expertise and knowledge level. With only one badge of NSE8_812 certification, successful candidates can advance their careers and increase their earning potential. The Fortinet NSE8_812 Certification Exam also enables you to stay updated and competitive in the market which will help you to gain more career opportunities.
If you prefer to Practice NSE8_812 Exam dumps on paper, you can try the exam dumps of us. NSE8_812 PDF version is printable, and you can take some notes on it and can practice them anytime. Besides through using NSE8_812 e questions and answers of us, you can pass the exam and get a certificate successfully. We offer you pass guarantee and money back guarantee if you fail to pass the exam. Once you have made your decision, just add them into your cart and pay for it, we will send the downloading link in ten minutes.
Pdf NSE8_812 Dumps - NSE8_812 Practice GuideIf you purchasing our NSE8_812 simulating questions, you will get a comfortable package services afforded by our considerate after-sales services. We respect your needs toward the useful NSE8_812practice materials by recommending our NSE8_812 Guide preparations for you. And we give you kind and professional supports by 24/7, as long as you can have problems on our NSE8_812 study guide, then you can contact with us.
Fortinet NSE 8 - Written Exam (NSE8_812) Sample Questions (Q65-Q70):NEW QUESTION # 65
You are responsible for recommending an adapter type for NICs on a FortiGate VM that will run on an ESXi Hypervisor. Your recommendation must consider performance as the main concern, cost is not a factor. Which adapter type for the NICs will you recommend?
  • A. Physical Function (PF) PCI Passthrough
  • B. Virtual Function (VF) PCI Passthrough
  • C. Native ESXi Networking with VMXNET3
  • D. Native ESXi Networking with E1000
The FortiGate VM is a virtual firewall appliance that can run on various hypervisors, such as ESXi, Hyper-V, KVM, etc. The adapter type for NICs on a FortiGate VM determines the performance and compatibility of the network interface cards with the hypervisor and the physical network. There are different adapter types available for NICs on a FortiGate VM, such as E1000, VMXNET3, SR-IOV, etc. If performance is the main concern and cost is not a factor, one option is to use native ESXi networking with VMXNET3 adapter type for NICs on a FortiGate VM that will run on an ESXi hypervisor. VMXNET3 is a paravirtualized network interface card that is optimized for performance in virtual machines and supports features such as multiqueue support, Receive Side Scaling (RSS), Large Receive Offload (LRO), IPv6 offloads, and MSI/MSI-X interrupt delivery. Native ESXi networking means that the FortiGate VM uses the standard virtual switch (vSwitch) or distributed virtual switch (dvSwitch) provided by the ESXi hypervisor to connect to the physical network. This option can provide high performance and compatibility for NICs on a FortiGate VM without requiring additional hardware or software components. Reference: https://docs.fortinet.com/docume ... e-vm-on-vmware-esxi https://docs.fortinet.com/docume ... xi/19662/networking
NEW QUESTION # 66
Review the Application Control log.
Which configuration caused the IPS engine to generate this log?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 67
A customer's cybersecurity department needs to implement security for the traffic between two VPCs in AWS, but these belong to different departments within the company. The company uses a single region for all their VPCs.
Which two actions will achieve this requirement while keeping separate management of each department's VPC? (Choose two.)
  • A. Migrate all the instances to the same VPC and create 1AM accounts for each department, then implement a new subnet for a FortiGate auto-scaling group and use routing tables to force the traffic through the FortiGate cluster.
  • B. Create an 1AM account for the cybersecurity department to manage both existing VPC, create a FortiGate HA Cluster on each VPC and IPSEC VPN to force traffic between the VPCs through the FortiGate clusters
  • C. Create a VPC with a FortiGate auto-scaling group with a Transit Gateway attached to the three VPC to force routing through the FortiGate cluster
  • D. Create a transit VPC with a FortiGate HA cluster, connect to the other two using VPC peering, and use routing tables to force traffic through the FortiGate cluster.
To implement security for the traffic between two VPCs in AWS, while keeping separate management of each department's VPC, two possible actions are:
Create a transit VPC with a FortiGate HA cluster, connect to the other two using VPC peering, and use routing tables to force traffic through the FortiGate cluster. This option allows the cybersecurity department to manage the transit VPC and apply security policies on the FortiGate cluster, while the other departments can manage their own VPCs and instances. The VPC peering connections enable direct communication between the VPCs without using public IPs or gateways. The routing tables can be configured to direct all inter-VPC traffic to the transit VPC.
Create a VPC with a FortiGate auto-scaling group with a Transit Gateway attached to the three VPCs to force routing through the FortiGate cluster. This option also allows the cybersecurity department to manage the security VPC and apply security policies on the FortiGate cluster, while the other departments can manage their own VPCs and instances. The Transit Gateway acts as a network hub that connects multiple VPCs and on-premises networks. The routing tables can be configured to direct all inter-VPC traffic to the security VPC. Reference: https://docs.fortinet.com/docume ... e-to-an-aws-vpc-vpn https://docs.fortinet.com/docume ... d-wan-configuration
NEW QUESTION # 68
SD-WAN is configured on a FortiGate. You notice that when one of the internet links has high latency the time to resolve names using DNS from FortiGate is very high.
You must ensure that the FortiGate DNS resolution times are as low as possible with the least amount of work.
What should you configure?
  • A. Configure two DNS servers and use DNS servers recommended by the two internet providers.
  • B. Configure an SD-WAN rule to the DNS server and use the FortiGate interface IPs in the source address.
  • C. Configure local out traffic to use the outgoing interface based on SD-WAN rules with the interface IP and configure an SD-WAN rule to the DNS server.
  • D. Configure local out traffic to use the outgoing interface based on SD-WAN rules with a manual defined IP associated to a loopback interface and configure an SD-WAN rule from the loopback to the DNS server.
SD-WAN is a feature that allows users to optimize network performance and reliability by using multiple WAN links and applying rules based on various criteria, such as latency, jitter, packet loss, etc. One way to ensure that the FortiGate DNS resolution times are as low as possible with the least amount of work is to configure local out traffic to use the outgoing interface based on SD-WAN rules with the interface IP and configure an SD-WAN rule to the DNS server. This means that the FortiGate will use the best WAN link available to send DNS queries to the DNS server according to the SD-WAN rule, and use its own interface IP as the source address. This avoids NAT issues and ensures optimal DNS performance. References: https://docs.fortinet.com/docume ... sd-wan/19662/sd-wan
NEW QUESTION # 69
Refer to the exhibit showing a firewall policy configuration.
To prevent unauthorized access of their cloud assets, an administrator wants to enforce authentication on firewall policy ID 1.
What change does the administrator need to make?
  • A. Option B
  • B. Option A
  • C. Option D
  • D. Option C
https://docs.fortinet.com/docume ... n-policy-extensions
NEW QUESTION # 70
In the past few years, NSE8_812 study materials have helped countless candidates pass the NSE8_812 exam. After having a NSE8_812 certification, some of them encountered better opportunities for development, some went to great companies, and some became professionals in the field. NSE8_812 study materials have stood the test of time and market and received countless praises. Through the good reputation of word of mouth, more and more people choose to use NSE8_812 Study Materials to prepare for the NSE8_812 exam, which makes us very gratified. Please be assured that we will stand firmly by every warrior who will pass the exam. NSE8_812 study materials have the following characteristics:
Pdf NSE8_812 Dumps: https://www.pass4surequiz.com/NSE8_812-exam-quiz.html
Try our NSE8_812 Fortinet NSE 8 - Written Exam (NSE8_812) study guides that are composed to deepen your knowledge on all topics covered under the NSE8_812 certification’s syllabus in the form of NSE8_812 questions and answers, Fortinet Training NSE8_812 Materials As the saying goes, time is life so spend it wisely, Our NSE8_812 real dumps has received popular acceptance worldwide with tens of thousands of regular exam candidates who trust our proficiency, Our service team will update the NSE8_812 certification file periodically and provide one-year free update.
How to debug across different devices, We ensure your 100% success in NSE8_812 Exam with the help of our provided material, Try our NSE8_812 Fortinet NSE 8 - Written Exam (NSE8_812) study guides that are composed to deepen your knowledge on all topics covered under the NSE8_812 certification’s syllabus in the form of NSE8_812 questions and answers.
Fortinet NSE 8 - Written Exam (NSE8_812) exam certification & NSE8_812 exam reviewsAs the saying goes, time is life so spend it wisely, Our NSE8_812 real dumps has received popular acceptance worldwide with tens of thousands of regular exam candidates who trust our proficiency.
Our service team will update the NSE8_812 certification file periodically and provide one-year free update, In fact, there are techniques that can help.
2026 Latest Pass4SureQuiz NSE8_812 PDF Dumps and NSE8_812 Exam Engine Free Share: https://drive.google.com/open?id=1dG34l1Hf7Zj1rHH36_yjcVnKkNABVw18
