[General] 高質量的F5CAB1通過考試,最有效的學習資料幫助妳快速通過F5CAB1考試
115
【General】 高質量的F5CAB1通過考試,最有效的學習資料幫助妳快速通過F5CAB1考試
Posted at 2/8/2026 14:48:54      View:103 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. PDFExamDumps在Google Drive上分享了免費的2026 F5 F5CAB1考試題庫:https://drive.google.com/open?id=1QmnXkVGP9YR9Buz8Ki3HgKGc1EL_SaoM
在當今這個社會,人才到處都是。在IT領域更是這樣。隨著電腦的普及,已經幾乎沒有不會使用電腦的人了。同樣在IT行業工作的你難道沒有感覺到壓力嗎?不管你的學歷有多高都不能代表你的實力。學歷只是一個敲門磚,真正能保住你地位的是你的實力。作為IT職員,你是怎麼培養自己的實力的呢?參加IT認證考試是一個不錯的選擇。既可以掌握更多的技能,又可以取得可以證明自己能力的認證資格。最近F5的F5CAB1認證考試很受歡迎,想參加嗎?
F5 F5CAB1 考試大綱:
主題簡介
主題 1
  • BIG IP Administration Install Initial Configuration and Upgrade: This section of the exam measures skills of System Administrators and covers the lifecycle tasks for deploying and maintaining a BIG IP system. It includes installing the platform, performing initial setup, applying licenses, configuring basic networking, and planning and executing software upgrades and hotfixes.
主題 2
  • BIG IP Administration Data Plane Concepts: This section of the exam measures skills of Network Administrators and covers how BIG IP handles application traffic on the data plane. It includes understanding flow of traffic, key data path components, basic concepts of load balancing, and how security and performance features affect user traffic.
主題 3
  • BIG IP Administration Data Plane Configuration: This section of the exam measures skills of System Administrators and covers configuring BIG IP objects that control data plane behavior. It focuses on setting up virtual servers, pools, nodes, monitors, and profiles so that applications are delivered reliably and efficiently according to design requirements.
主題 4
  • BIG IP Administration Support and Troubleshooting: This section of the exam measures skills of Network Administrators and covers identifying and resolving common issues that affect BIG IP operation. It focuses on using logs, statistics, diagnostic tools, and basic troubleshooting methods to restore normal traffic flow and maintain stable application delivery.
主題 5
  • BIG IP Administration Control Plane Administration: This section of the exam measures skills of System Administrators and covers managing the control plane where BIG IP is configured and administered. It includes working with user accounts, roles, device settings, configuration management, and using the graphical interface and command line for daily administrative tasks.
F5 F5CAB1考古題分享,F5CAB1套裝選擇參加F5 F5CAB1 認證考試是一個明智的選擇,因為有了F5 F5CAB1認證證書後,你的工資和職位都會有所提升,生活水準就會相應的提供。但是通過F5 F5CAB1 認證考試不是很容易的,需要花很多時間和精力掌握好相關專業知識。PDFExamDumps是一個制訂F5 F5CAB1 認證考試培訓方案的專業IT培訓網站。你可以先在我們的網站上免費下載部分部分關於F5 F5CAB1 認證考試的練習題和答案作為免費嘗試,以便你可以檢驗我們的可靠性。一般,試用PDFExamDumps的產品後,你會對我們的產品很有信心的。
最新的 F5-CA F5CAB1 免費考試真題 (Q34-Q39):問題 #34
What traffic will be permitted to reach the BIG-IP?
  • A. FTP
  • B. SSH
  • C. Telnet
答案:B
解題說明:
The exhibit shows the configuration of aSelf IPwith:
* Port Lockdown: Allow Custom
* ACustom Listthat includes the following TCP ports:
* 443
* 22
Meaning of these ports:
* TCP 443# HTTPS (TMUI - web-based management)
* TCP 22# SSH (command-line remote access)
No other TCP, UDP, or protocol entries are listed; therefore, only these two services are allowed to reach the BIG-IP via this Self IP.
Evaluating the answer choices:
Option
Service
Port
Allowed?
FTP
TCP 21
Not listed
#Not allowed
SSH
TCP 22
Listed
#Allowed
Telnet
TCP 23
Not listed
#Not allowed
Thus,SSHis the only traffic permitted through this Self IP configuration.
問題 #35
The BIG-IP Administrator needs to update access to the Configuration Utility to include the172.28.31.0/24and
172.28.65.0/24networks.
From the TMOS Shell (tmsh), which command should the BIG-IP Administrator use to complete this task?
  • A. modify /sys httpd allow add { 172.28.31.0 172.28.65.0 }
  • B. modify /sys httpd permit add { 172.28.31.0/255.255.255.0 172.28.65.0/255.255.255.0 }
  • C. modify /sys httpd allow add { 172.28.31.0/255.255.255.0 172.28.65.0/255.255.255.0 }
答案:C
解題說明:
Access to the BIG-IP Configuration Utility (TMUI) is controlled through the/sys httpd allowlist.
This list defines which IP addresses or subnets are allowed to connect to the management web interface.
To allow two new subnets-172.28.31.0/24and172.28.65.0/24-the administrator mustaddboth subnets to the existing list without removing current entries.
In tmsh, subnet entries must be specified innetwork/netmask format, for example:
The correct tmsh command to append these networks is:
modify /sys httpd allow add { 172.28.31.0/255.255.255.0 172.28.65.0/255.255.255.0 } Why the other options are incorrect:
Option B:
* IPs are listed without masks, which is invalid for subnet-based access control.
* The system requiresnetwork/netmaskformat.
Option C:
* The command uses permit instead of allow, which is not a valid attribute of /sys httpd.
* The correct keyword must beallow.
Thus, onlyOption Acorrectly adds both permitted subnets in the proper tmsh format.
問題 #36
What are the two options for securing a BIG-IP's management interface?
(Choose two.)
  • A. Use the BIG-IP's Self-IP addresses for administrative access rather than the management interface.
  • B. Limiting network access through the management interface to a trusted/secured network VLAN.
  • C. Block all management-interface administrative HTTPS and SSH service ports to prevent access.
  • D. Restrict administrative HTTPS and SSH access to specific IP addresses or IP ranges.
答案:B,D
解題說明:
Securing the BIG-IP management interface is a fundamental administrative responsibility. F5 best practices emphasize restricting who can reach the management port and ensuring that only authorized systems are allowed access.
A). Limiting management access to trusted network segments
F5 recommends placing the management interface on adedicated, isolated, and secured management network or VLAN, rather than exposing it to production or untrusted networks.
This reduces the attack surface by ensuring only trusted segments have visibility to administrative interfaces.
D). Restricting management access by IP or subnet
F5 BIG-IP uses the/sys httpd allowlist (for HTTPS) and configuration options insshd(for SSH) to control which IP addresses or subnets can access the device.
By specifying only known administrative IPs or ranges, unauthorized users cannot reach the login services.
B). Blocking all management HTTPS/SSH ports
* This would prevent any administrative access and is not a viable security practice.
C). Using Self-IP addresses for administrative access
* F5 explicitly warns against using Self-IPs for management access unless strictly necessary.
* Self-IPs are exposed to the data plane and should not be used as the primary administrative interface.
問題 #37
A BIG-IP Administrator needs to verify the state of equipment in the data center.
A BIG-IP appliance has asolid yellow indicatoron the status LED.
How should the administrator interpret this LED indicator?
  • A. Appliance is halted or in End-User Diagnostic (EUD) mode
  • B. Appliance is a standby member in a device group
  • C. A warning-level alarm condition is present
  • D. A power supply is NOT operating properly
答案:C
解題說明:
BIG-IP hardware platforms use chassis LEDs to indicate system health states.
Asolid yellow status LEDtypically indicates awarning condition, such as:
* A non-critical hardware alert
* A temperature threshold nearing limit
* A minor fan or sensor irregularity
* Other non-fatal environmental or system conditions
This state reflects awarning-level alarm, meaning the unit is operational but requires investigation.
A). Halted or EUD mode
* This is associated with different LED patterns (usually flashing conditions or specific color codes), not a solid yellow status LED.
B). Standby in device group
* HA state is not indicated by the chassis status LED.
* Standby status is alogicaldevice state, not a hardware LED state.
D). Power supply failure
* Power supply indicators use separate LEDs located on each power module (usually flashing amber/red), not the system status LED.
Thus, asolid yellow status indicatorsignifies awarning-level alarm.
問題 #38
An F5 BIG-IP Administrator is asked to report which modules areprovisionedon the BIG-IP.
In which two ways can this be done?
(Choose two.)
  • A. Via TMSH withlist /sys provision
  • B. Via TMSH withshow /sys provision
  • C. Via the GUI atSystem # Resource Provisioning # Module Allocation
  • D. Via the GUI atStatistics # Module Statistics # System
答案:A,C
解題說明:
Provisioning determines:
* Which BIG-IP modules are enabled (LTM, ASM, APM, AFM, DNS, etc.)
* Their provisioning levels (None, Minimal, Nominal, Dedicated)
Two accurate ways to view provisioning settings are:
A). GUI - System # Resource Provisioning # Module Allocation
This is the primary GUI screen showing:
* All modules
* System resource distribution impact
Administrators commonly use this page to confirm or change module provisioning.
D). TMSH - list /sys provision
This tmsh command displays each module and its provisioning level:
sys provision ltm { level nominal }
sys provision asm { level none }
This is the authoritative CLI method for checking module provisioning configurations.
B). show /sys provision
* Showsruntimeinformation butnot the actual configuration levels.
* list is the correct command for configuration details.
C). Statistics # Module Statistics
* Shows performance statistics, NOT provisioning status.
Therefore, the correct responses areAandD.
問題 #39
每個IT人士都在努力,不是為了升職就是為了加薪,這也是現代社會所形成的壓力的一種體現。這樣討得上司的喜歡,還不如用實力說話。大家來通過F5的F5CAB1考試認證吧,其實這個考試也沒有想像的那麼苦難,只需要你選擇合適的培訓資料就足夠,PDFExamDumps F5的F5CAB1考試培訓資料將是最好的培訓資料,選擇了它你就是選擇你最想要的,為了現實,趕緊行動吧。
F5CAB1考古題分享: https://www.pdfexamdumps.com/F5CAB1_valid-braindumps.html
2026 PDFExamDumps最新的F5CAB1 PDF版考試題庫和F5CAB1考試問題和答案免費分享:https://drive.google.com/open?id=1QmnXkVGP9YR9Buz8Ki3HgKGc1EL_SaoM
