Real Exam Experience with the Microsoft AI-102 Practice Test
81
Posted at 2/8/2026 16:11:40      View94 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of CramPDF AI-102 dumps for free: https://drive.google.com/open?id=1iZc2gD_v6H_ajADLhtDBR6XsAOl9ri2U
In this cut-throat competitive world of Microsoft, the Microsoft AI-102 certification is the most desired one. But what creates an obstacle in the way of the aspirants of the Microsoft AI-102 certificate is their failure to find up-to-date, unique, and reliable Designing and Implementing a Microsoft Azure AI Solution (AI-102) practice material to succeed in passing the Microsoft AI-102 Certification Exam. If you are one of such frustrated candidates, don't get panic. CramPDF declares its services in providing the real AI-102 PDF Questions. It ensures that you would qualify for the Designing and Implementing a Microsoft Azure AI Solution (AI-102) certification exam on the maiden strive with brilliant grades.
To avail of all these Microsoft AI-102 certification exam benefits you need to enroll in Microsoft AI-102 certification exam and pass it with good scores. Are you ready for this? If your answer is right then you do not need to go anywhere. Just download Microsoft AI-102 Dumps questions and start preparing today.
Testking Microsoft AI-102 Learning Materials & Questions AI-102 PdfOur experts offer help by diligently working on the content of AI-102 learning questions more and more accurate. Being an exam candidate in this area, we believe after passing the exam by the help of our AI-102 practice materials, you will only learn a lot from this AI-102 Exam but can handle many problems emerging in a long run. You can much more benefited form our AI-102 study guide. Don't hesitate, it is worthy to purchase!
The AI-102 Certification Exam covers a wide range of topics, including Azure Cognitive Services, Natural Language Processing (NLP), and Computer Vision. You will be tested on your ability to develop and implement AI solutions using various Azure services and tools.
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q300-Q305):NEW QUESTION # 300
You are developing an internet-based training solution for remote learners.
Your company identifies that during the training, some learners leave their desk for long periods or become distracted.
You need to use a video and audio feed from each learner's computer to detect whether the learner is present and paying attention. The solution must minimize development effort and identify each learner.
Which Azure Cognitive Services service should you use for each requirement? To answer, select the appropriate options in the answer area.
Graphical user interface, text, application, email Description automatically generated
https://docs.microsoft.com/en-us ... -cognitive-services
NEW QUESTION # 301
You are building an app by using the Speech SDK. The app will translate speech from French to German by using natural language processing.
You need to define the source language and the output language.
How should you complete the code? To answer, select the appropriate options in the answer area.
NEW QUESTION # 302
You have an Azure subscription that contains an Azure Al Content Safety resource named resource1.
You need to add a custom category to resource1.
How should you complete the cURL statement? To answer, select the appropriate options in the answer area.
Use "definition" for the first field and "sampleBlobUrl" for the second field When creating a custom text category in Azure AI Content Safety, you call the PUT /contentsafety/text
/categories/{categoryName} endpoint and provide a JSON body that includes:
* categoryName: the identifier of your category.
* definition: a natural-language description of what the category covers (e.g., "text prompts about learning advice while preparing for an exam").
* sampleBlobUrl: a pointer to labeled sample data (typically a JSONL file in Azure Storage) used to help the service understand the category.
Keys like prompt or text are used when analyzing content (for example, text:detect), not when defining a category. Likewise, blocklistName applies to blocklist operations, and outputType is not part of the category- creation schema. Therefore, the correct payload fields to complete the cURL are definition and sampleBlobUrl.
Microsoft Azure AI References (titles only)
* Azure AI Content Safety - Create or update custom text categories (REST)
* Azure AI Content Safety - Custom categories concepts and training data (JSONL in blob storage)
* Azure AI Content Safety - Text analysis vs. category management endpoints
NEW QUESTION # 303
You are training a Language Understanding model for a user support system.
You create the first intent named GetContactDetails and add 200 examples.
You need to decrease the likelihood of a false positive.
What should you do?
  • A. Add a machine learned entity.
  • B. Add examples to the None intent.
  • C. Enable active learning.
  • D. Add additional examples to the GetContactDetails intent.
Active learning is a technique of machine learning in which the machine learned model is used to identify informative new examples to label. In LUIS, active learning refers to adding utterances from the endpoint traffic whose current predictions are unclear to improve your model.
https://docs.microsoft.com/en-us ... /luis/luis-glossary
NEW QUESTION # 304
You are building a customer support chatbot.
You need to configure the bot to identify the following:
* Code names for internal product development
* Messages that include credit card numbers
The solution must minimize development effort.
Which Azure Cognitive Service for Language feature should you use for each requirement? To answer, drag the appropriate features to the correct requirements. Each feature may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content NOTE: Each correct selection is worth one point.
NEW QUESTION # 305
Microsoft certification exams become more and more popular. The certification exams are widely recognized by international community, so increasing numbers of people choose to take Microsoft certification test. Among Microsoft certification exams, AI-102 is one of the most important exams. So, in order to pass AI-102 test successfully, how do you going to prepare for your exam? Will you choose to study hard examinations-related knowledge, or choose to use high efficient study materials?
Testking AI-102 Learning Materials: https://www.crampdf.com/AI-102-exam-prep-dumps.html
P.S. Free & New AI-102 dumps are available on Google Drive shared by CramPDF: https://drive.google.com/open?id=1iZc2gD_v6H_ajADLhtDBR6XsAOl9ri2U
