Salesforce Integration-Architect Questions [2026]
Posted at 2/8/2026 17:25:28
DOWNLOAD the newest Lead2PassExam Integration-Architect PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1TFdGD_FPxcfvvzm0ED2kTPDE8BI5fSvr
Most of the candidates who plan to take the Integration-Architect certification exam lack updated practice questions to ace it on the first attempt. Due to this, they fail the Salesforce Certified Integration Architect (Integration-Architect) test, losing money and time. And in some cases, applicants fail on the second attempt as well because they don't prepare with Integration-Architect Actual Exam questions. This results in not only the loss of resources but also the motivation of the candidate.
Salesforce Integration-Architect certification is ideal for professionals who work in IT or consulting roles and are responsible for designing and implementing complex integration solutions. Salesforce Certified Integration Architect certification is also suitable for professionals who are looking to enhance their career prospects by gaining expertise in integrating Salesforce with other systems. The Integration-Architect Certification is recognized as a mark of excellence in the Salesforce community and is highly valued by employers who are looking for professionals with advanced integration skills.
Integration-Architect Exam Materials and Integration-Architect Test Braindumps - Integration-Architect Dumps Torrent - Lead2PassExamIt has similar specifications to the Salesforce Integration-Architect desktop-based practice exam software, but it requires an internet connection. Our Salesforce Integration-Architect practice exam highlights mistakes at the end of each attempt, allowing you to overcome them before it's too late. This kind of approach is great for complete and flawless Salesforce Integration-Architect Test Preparation.
Salesforce Certified Integration Architect Sample Questions (Q48-Q53):NEW QUESTION # 48
An Architect has received a request to prevent employees that leavethe company from accessing data in Salesforce after they are deactivated in the company's HR system.
What should an Architect determine before recommending a solution?
- A. Determine data volume requirements, then identify the loading schedule.
- B. Determine inbound integration requirements, then identify frequency.
- C. Determine data access prevention requirements, then identify system constraints.
- D. Determinedata access prevention requirements, then identify frequency.
The Architect should determine the data access prevention requirements and then identify the system constraints before recommending a solution. The data access prevention requirements are the business rules and policies that define how to prevent deactivated employees from accessing Salesforce data. For example, the Architect should determine whether the HR system can send a notification to Salesforce when an employee is deactivated, or whether Salesforce needs to query the HR system periodically to check the employee status. Thesystem constraints are the technical limitations and challenges that may affect the integration solution. For example, the Architect should determine whether the HR system supports outbound or inbound integration, what are the security and authenticationprotocols, what are the data formats and protocols, and what are the performance and scalability requirements. The frequency of the integration is not as important as the requirements and constraints, as it can be adjusted based on the business needs and technical feasibility. The data volume requirements and loading schedule are not relevant for this scenario, as they are more applicable for data migration or replication scenarios.
NEW QUESTION # 49
Universal Containers (UC) is a leading provider of managementtraining globally, UC requested students course registration data generated from the Salesforce student community to be synced with the learning management system (LMS). Any update to the course registration data needs to be reflected in the LMS.
Which integration mechanism should be used to meet the requirement?
- A. Outbound Message
- B. Platform Event
- C. Change Data Capture (CDC)
- D. Streaming API
Change Data Capture (CDC) is the best option to meet the requirement. CDC is a type of streaming event that notifies subscribers of changes to Salesforce records, such as creation, update, delete, and undelete operations.
By subscribing to CDC events for the course registration data, the LMS can receive real-time updates and sync with Salesforce. Streaming API is another type of streaming event that notifies subscribers of changes to Salesforce records that match a SOQL query. However, Streaming API has some limitations, such as not supporting all SOQL features and not capturing delete and undelete operations. Platform Event is a type of streaming event that delivers custom notifications within the Salesforce platform or from external sources.
Platform Event is not suitable for this requirement because it is not tied to Salesforce records and requires custom logic to publish and subscribe. Outbound Message is a workflow action that sends SOAP messages with field values to designated endpoints. Outbound Message is not suitable for this requirement because it does not support complex data types, such as sObjects or collections.
NEW QUESTION # 50
An integration architect needs to build a solution that will be using the Streaming API, but the data loss should be minimized, even when the client re-connects every couple of days.
Which two types of Streaming API events should be considered?
Choose 2 answers
- A. PushTopic Events
- B. High Volume Platform Events
- C. Generic Events
- D. Change Data Capture Events
NEW QUESTION # 51
An enterprise customer with more than 10 million customers has the following systems and conditions in its landscape:
* Enterprise Billing System (EBS) - All customers' monthly billing is generated by this system.
* Enterprise Document Management System (DMS) - Bills mailed to customers are maintained in the Document Management system.
* Salesforce CRM (CRM) - Customer information, sales, and support information is maintained in the CRM.
Only authorized users are allowed access to the EBS and the Enterprise DMS. Customers call Customer Support when they need clarification on their bills. Customer Support needs seamless access to customer billing information from the EBS and to view generated bills from the DMS. Which authorization and authentication need should an integration consultant consider while integrating the DMS and EBS with Salesforce?
- A. Identify options to maintain DMS and EBS authentication and authorization details in Salesforce.
- B. Consider Enterprise security needs for access to DMS and EBS.
When integrating high-security back-office systems like an Enterprise Billing System (EBS) and a Document Management System (DMS) with Salesforce, the primary concern for an Integration Architect is maintaining the integrity of the organization's existing security perimeter. In an enterprise landscape with over
10 million customers, these systems are typically governed by strict regulatory and compliance standards (such as PCI-DSS or GDPR) that dictate who can view financial records.
The consultant must consider Enterprise security needs for access to these systems rather than simply attempting to synchronize credentials. This involves evaluating an Identity Federation strategy using protocols like SAML 2.0 or OpenID Connect. Instead of maintaining a separate silo of authentication details within Salesforce (which creates a security risk and administrative overhead), Salesforce should act as a Service Provider (SP) that trusts a central Identity Provider (IdP).1234 Furthermore, the "seamle5ss access" requirement implies that once a support agent is authenticated into Salesforce, their identity should be propagated to the EBS and DMS to authorize the specific 6view of a7 customer's bill. This is often achieved through Single Sign-On (SSO) and Token-Based Authentication8.
By prioritizing the enterprise security framewo9rk, the architect ensures that access is auditable, centralized, and compliant with corporate policies, while providing th10e "360-degree" view required by support agents without forcing them to log in to multiple disconnected systems. Migrating such massive systems (Option A) into Salesforce is technically and financially unfeasible for most enterprises due to data volume and specialized processing logic.
NEW QUESTION # 52
An Enterprise Customer is planning to implement Salesforce to support case management. Below, is their current system landscape diagram.
Considering Salesforce capabilities, what should the Integration Architect evaluate when integrating Salesforce with the current system landscape?
- A. Integrating Salesforce with Order Management System, Data Warehouse and Case Management System.
- B. Integrating Salesforce with Order Management System, Email Management System and Case Management System.
- C. Integrating Salesforce with Data Warehouse, Order Management and Email Management System.
- D. Integrating Salesforce with Email Management System, Order Management System and Case Management System.
NEW QUESTION # 53
If you fail in Integration-Architect exam test with Lead2PassExam Integration-Architect exam dumps, we promise to give you full refund! You only need to scan your Integration-Architect test score report to us together with your receipt ID. After our confirmation, we will give you full refund in time. Or you can choose to charge another exam Q&AS instead of Integration-Architect Exam Dumps. Useful Salesforce certifications exam dumps are assured with us. If our Integration-Architect exam dumps can’t help you pass Integration-Architect exam, details will be sent before we send the exam to you. We don't waste our customers' time and money! Trusting Lead2PassExam is your best choice!
Integration-Architect Valid Vce Dumps: https://www.lead2passexam.com/Salesforce/valid-Integration-Architect-exam-dumps.html
- Salesforce Practice Integration-Architect Exam Pdf: Salesforce Certified Integration Architect - [url]www.testkingpass.com High-quality Products for you ⏲ Open { www.testkingpass.com } enter 【 Integration-Architect 】 and obtain a free download 🍶Standard Integration-Architect Answers[/url]
- Salesforce certification Integration-Architect the latest exam questions and answers 💃 Open website “ [url]www.pdfvce.com ” and search for ⏩ Integration-Architect ⏪ for free download 🐀Integration-Architect Valid Test Tutorial[/url]
- Free PDF 2026 Salesforce Newest Integration-Architect: Practice Salesforce Certified Integration Architect Exam Pdf 📝 Search for ▷ Integration-Architect ◁ and easily obtain a free download on ➽ [url]www.validtorrent.com 🢪 👩Integration-Architect Reliable Braindumps Free[/url]
- Integration-Architect Reliable Braindumps Free 😓 Latest Integration-Architect Test Answers 🤜 Integration-Architect Test Lab Questions 👞 Easily obtain ➥ Integration-Architect 🡄 for free download through ➠ [url]www.pdfvce.com 🠰 ⚖Integration-Architect Instant Download[/url]
- Integration-Architect Reliable Test Sims 🍜 Latest Integration-Architect Test Answers 🐪 Integration-Architect Valid Test Tutorial 🏘 Download ▷ Integration-Architect ◁ for free by simply searching on { [url]www.vceengine.com } 🌂Valid Real Integration-Architect Exam[/url]
- Free PDF Quiz 2026 Salesforce Integration-Architect: The Best Practice Salesforce Certified Integration Architect Exam Pdf 🏛 Copy URL ➠ [url]www.pdfvce.com 🠰 open and search for 「 Integration-Architect 」 to download for free 🕕Latest Integration-Architect Test Answers[/url]
- Free PDF Quiz 2026 Salesforce Integration-Architect: The Best Practice Salesforce Certified Integration Architect Exam Pdf 📓 Immediately open ➡ [url]www.vce4dumps.com ️⬅️ and search for “ Integration-Architect ” to obtain a free download 🧕Exam Integration-Architect Experience[/url]
- Integration-Architect Valid Test Tutorial 🥐 Standard Integration-Architect Answers 🥾 Integration-Architect Valid Test Prep 🥬 ➥ [url]www.pdfvce.com 🡄 is best website to obtain ➥ Integration-Architect 🡄 for free download 🥘Integration-Architect Instant Download[/url]
- Integration-Architect Valid Practice Questions 🦼 Integration-Architect Practice Test Engine 🥮 Exam Integration-Architect Experience ⛴ Search for ▛ Integration-Architect ▟ and download exam materials for free through ⮆ [url]www.exam4labs.com ⮄ 🍗Integration-Architect Reliable Braindumps Free[/url]
- Pass Guaranteed Fantastic Salesforce - Integration-Architect - Practice Salesforce Certified Integration Architect Exam Pdf 🐟 Simply search for ➠ Integration-Architect 🠰 for free download on 《 [url]www.pdfvce.com 》 🏗Integration-Architect Latest Braindumps Pdf[/url]
- Salesforce Practice Integration-Architect Exam Pdf: Salesforce Certified Integration Architect - [url]www.dumpsquestion.com High-quality Products for you 🐡 Immediately open [ www.dumpsquestion.com ] and search for ▛ Integration-Architect ▟ to obtain a free download 🍈Integration-Architect Reliable Test Sims[/url]
- mahademy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, notefolio.net, soocareer.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, trakeef.com, Disposable vapes
What's more, part of that Lead2PassExam Integration-Architect dumps now are free: https://drive.google.com/open?id=1TFdGD_FPxcfvvzm0ED2kTPDE8BI5fSvr
