Quiz Mule-Arch-202 - Valid Salesforce Certified MuleSoft Platform Integration Ar
142
Posted at 2/8/2026 17:55:45      View:73 | Replies:0        Print      Only Author   [Copy Link] 1#
You can increase your competitive force in the job market if you have the certificate. Mule-Arch-202 exam torrent of us will offer an opportunity like this. If you choose us, we will help you pass the exam just one time. Mule-Arch-202 exam torrent of us is high quality and accuracy, and you can use them at ease. Besides, we offer you free demo to have a try before buying, and we have free update for 365 days after purchasing. The update version for Mule-Arch-202 Exam Dumps will be sent to your email automatically.
Holding a Salesforce Certified MuleSoft Platform Integration Architect Mule-Arch-202 Certification in a certain field definitely shows that one have a good command of the Mule-Arch-202 knowledge and professional skills in the related field. However, it is universally accepted that the majority of the candidates for the Salesforce Certified MuleSoft Platform Integration Architect exam are those who do not have enough spare time and are not able to study in the most efficient way.
Mule-Arch-202 Trustworthy Exam Torrent & Valid Mule-Arch-202 Test QuestionTo help you learn with the newest content for the Mule-Arch-202 preparation materials, our experts check the updates status every day, and their diligent works as well as professional attitude bring high quality for our Mule-Arch-202 practice materials. You may doubtful if you are newbie for our Mule-Arch-202 training engine, free demos are provided for your reference. The free demo of Mule-Arch-202 exam questions contains a few of the real practice questions, and you will love it as long as you download and check it.
Salesforce Certified MuleSoft Platform Integration Architect Sample Questions (Q40-Q45):NEW QUESTION # 40
An organization has defined a common object model in Java to mediate the communication between different Mule applications in a consistent way. A Mule application is being built to use this common object model to process responses from a SOAP API and a REST API and then write the processed results to an order management system.
The developers want Anypoint Studio to utilize these common objects to assist in creating mappings for various transformation steps in the Mule application.
What is the most straightforward way to utilize these common objects to map between the inbound and outbound systems in the Mule application?
  • A. Use JAXB (XML) and Jackson (JSON) data bindings
  • B. Use Idempotent Message Validator components
  • C. Use the Java module
  • D. Use the Transform Message component
NEW QUESTION # 41
An external web UI application currently accepts occasional HTTP requests from client web browsers to change (insert, update, or delete) inventory pricing information in an inventory system's database. Each inventory pricing change must be transformed and then synchronized with multiple customer experience systems in near real-time (in under 10 seconds).
New customer experience systems are expected to be added in the future. The database is used heavily and limits the number of SELECT queries that can be made to the database to 10 requests per hour per user.
How can inventory pricing changes synchronize with the various customer experience systems in near real-time using an integration mechanism that is scalable, decoupled, reusable, and maintainable?
  • A. Write a Mule application with a Database On Table Row event source configured for the inventory pricing database, with the ID attribute set to an appropriate database column.
  • B. Replace the external web UI application with a Mule application to accept HTTP requests from client web browsers.
  • C. Write a Mule application with a Database On Table Row event source configured for the inventory pricing database, with the watermark attribute set to an appropriate database column.
  • D. Add a trigger to the inventory-pricing database table so that for each change to the inventory pricing database, a stored procedure is called that makes a REST call to a Mule application.
NEW QUESTION # 42
A developer has been tasked by the integration architect to build a solution based on the Streaming API. The developer has done some research and has found there are different implementations of the events in Salesforce (Push Topic Events, Change Data Capture, Generic Streaming, Platform Events), but is unsure of to proceed with the implementation. The developer asks the system architect for some guidance.
What should the architect consider when making the recommendation?
  • A. Change Data Capture does not have record access support.
  • B. Change Data Capture can be published from Apex.
  • C. Push Topic Event can define a custom payload.
  • D. Apex triggers can subscribe to Generic Events.
NEW QUESTION # 43
An organization is sizing an Anypoint Virtual Private Cloud (VPC) to extend its internal network to CloudHub 1.0. For this sizing calculation, the organization assumes three production-type environments will each support up to 150 Mule application deployments.
Each Mule application deployment is expected to be configured with two CloudHub 1.0 workers and will use the zero-downtime feature in CloudHub 1.0. This is expected to result in, at most, several Mule application deployments per hour.
What is the minimum number of IP addresses that should be configured for this VPC resulting in the smallest usable range of private IP addresses to support the deployment and zero-downtime of these 150 Mule applications (not accounting for any future Mule applications)?
  • A. 10.0.0.0/24 (256 IPs)
  • B. 10.0.0.0/21 (2048 IPs)
  • C. 10.0.0.0/23 (512 IPs)
  • D. 10.0.0.0/22 (1024 IPs)
NEW QUESTION # 44
An internet company is building a new search engine that indexes sites on the internet and ranks them according to various signals. The management team wants various features added to the site. There is a team of software developers eager to start on the functional requirements received from the management team.
Which two traditional architectural requirements should the integration architect ensure are in place to support the new search engine? (Choose two.)
  • A. Relevant search results are returned for a query
  • B. Search results are returned in the language chosen by the user
  • C. Search result listings link to the correct website
  • D. The system can handle increased load as more people utilize the engine
  • E. New features can be added to the system with ease
Answer: D,E
NEW QUESTION # 45
In the case of studying with outdated Salesforce Certified MuleSoft Platform Integration Architect (Mule-Arch-202) practice questions, you will fail and lose your resources. Pass4training made an Mule-Arch-202 Questions for the students so that they don't get confused to prepare for Mule-Arch-202 Certification Exam successfully in a short time. Pass4training has designed the real Mule-Arch-202 exam dumps after consulting many professionals and receiving positive feedback.
Mule-Arch-202 Trustworthy Exam Torrent: https://www.pass4training.com/Mule-Arch-202-pass-exam-training.html
The Salesforce Mule-Arch-202 exam questions are affordable and 365 days free updated, and you can use them without any guidance, Our Mule-Arch-202 exam questions can give you some help, Salesforce Mule-Arch-202 Exam Online We aim to provide excellent products & customer service and then built long-term relationship with buyers, Valid contents of Mule-Arch-202 exam study material.
The answer starts with how our historical Mule-Arch-202 definition of creativity came to be in the first place, Return-Path Noise Sources,The Salesforce Mule-Arch-202 Exam Questions are affordable and 365 days free updated, and you can use them without any guidance.
Verified and Updated Salesforce Mule-Arch-202 Exam Questions & AnswersOur Mule-Arch-202 exam questions can give you some help, We aim to provide excellent products & customer service and then built long-term relationship with buyers, Valid contents of Mule-Arch-202 exam study material.
Our company uses its pioneering spirit to responsibly deliver Mule-Arch-202 exam preparation to the world.
