[General] PEGACPRSA22V1 PDF Questions [2026]-Right Preparation Material
98
General PEGACPRSA22V1 PDF Questions [2026]-Right Preparation Material
Posted at 2/8/2026 18:54:03      View182 | Replies4        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ValidBraindumps PEGACPRSA22V1 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1qiUwkUaMjCerccHOnBLTPChIlNNdAjx_
We all know that Certified Pega Robotics System Architect 22 (PEGACPRSA22V1) exam dumps are an important section of the PEGACPRSA22V1 exam that is purely based on your skills, expertise, and knowledge. So, we must find quality PEGACPRSA22V1 Questions that are drafted by industry experts who have complete knowledge regarding the PEGACPRSA22V1 Certification Exam and can share the same with those who want to clear the PEGACPRSA22V1 exam. The best approach to finding Certified Pega Robotics System Architect 22 (PEGACPRSA22V1) exam dumps is to check the ValidBraindumps that is offering the PEGACPRSA22V1 practice questions.
The Certified Pega Robotics System Architect 22 exam is designed to validate a candidate's knowledge and skills in using Pega Robotics Studio and understanding the concepts of Pega Robotics technology. Candidates will be tested on various topics, including designing a robotics solution, creating and debugging automations, and deploying automations.
New Pegasystems PEGACPRSA22V1 Exam Papers & PEGACPRSA22V1 Practice TestValidBraindumps field is leaping up day by day and more people are pursuing it as a career than ever. Due to these reasons, candidates find it difficult to land their dream job and often face difficulty in finding the right career opportunities. But to overcome this issue, the PEGACPRSA22V1 Exam is introduced by Pegasystems that provides candidates with a sustainable platform to examine their true capabilities and surf through their desired opportunities.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q54-Q59):NEW QUESTION # 54
A project requirement is to run the solution in multiple environments: Development and Production.
Which two items can be added to the two Project Configuration files? (Choose two.)
  • A. Adapter Text MatchRules
  • B. Citrix Context properties
  • C. Project properties
  • D. Variable values
NEW QUESTION # 55
During application discovery of a Clarify application, you determine that the user accesses more than one customer case concurrently within the application, which creates multiple windows of the same type. This requires you to enable the UseKeys property on an application's object.
Based on the image that shows the application and the matched controls in the Object Explorer, which control' s UseKeys property must be set to True?
  • A. MdiClient
  • B. ClarifyCRM
  • C. Control
  • D. _Case_1
NEW QUESTION # 56
Automation you are working on creates a data collection, so you have extracted a Data Table proxy. What action occurs when you drag the DataTableProxy from the Globals section of the Palette to the automation surface?
  • A. A This property is added to the automation surface.
  • B. A proxy design block is added to the automation surface.
  • C. A Select Action dialog box opens.
  • D. A Quick Add dialog box opens.
  • E. A GetTable method is added to the automation surface.
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
In Pega Robot Studio, the DataTableProxy component acts as an intermediary between automations and a Data Table, allowing the automation to read, manipulate, and update tabular data stored in the project.
When you drag an element such as a DataTableProxy from the Globals section of the Palette onto the automation design surface, Pega Robot Studio presents the user with available actions (methods, properties, or events) that can be executed using that component. This is done through a Select Action dialog box, which lists all available methods associated with the DataTableProxy (e.g., GetTable, AddRow, RemoveRow, Find, Update, etc.).
From the Pega Robotics System Design and Implementation Guide (Data Table Proxy and Data Handling section):
"When a component such as a DataTableProxy or connector object is dragged from the Palette onto the automation design surface, the system opens the Select Action dialog box.
This dialog lists all available methods and properties of the selected object, allowing the developer to select the action to instantiate on the automation surface.
The dialog ensures developers can directly add the desired operation (such as GetTable or UpdateRow) without manually searching through the object's members." Detailed Reasoning:
* The DataTableProxy represents a data-handling object; it does not directly add a "property" or
"method" by default when dragged.
* Instead, Robot Studio prompts you with a Select Action dialog box, allowing you to choose which specific method (like GetTable, FindRow, or AddRow) you want to include in your automation.
* After the selection is made, the chosen method (for example, GetTable) is then displayed on the automation surface.
Option Analysis:
* A. Incorrect - A property is not automatically added; you must choose an action first.
* B. Incorrect - The Quick Add dialog is used for linking variables and not for proxy components.
* C. Incorrect - A "proxy design block" is not automatically added without specifying a method.
* D. Correct - The Select Action dialog box opens to let you choose the method or property to add.
* E. Incorrect - GetTable may be one of the options available, but it is not added automatically.
Hence, the correct answer is D - dragging a DataTableProxy from the Globals section triggers the Select Action dialog box to open, allowing the developer to choose which action to use.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, DataTableProxy Configuration and Action Selection section (Pega Robotics 19.1 and later).
NEW QUESTION # 57
Deploying a robotic project to Pega Robot Manager requires configuring the Pega server and credentials.
The server connectivity settings can be set up or adjusted in several ways.
Which three of the following options are methods to set up or adjust the Pega Server settings? (Choose Three)
  • A. Configure the server settings during the initial installation of Pega Robot Studio.
  • B. Manually edit the PegaStudioConfig.xml file from the Tools menu in Pega Robot Studio.
  • C. Edit the Server Connectivity settings in the Tools menu in Pega Robot Studio.
  • D. Edit the Change Server fields during the deployment process.
  • E. Rerun the Pega Robot Studio installation and configure the server settings.
Answer: A,C,D
Pega Robot Studio provides multiple ways to configure or modify Pega Server connectivity settings used for Robot Manager deployment. These settings define the server URL, operator credentials, and authentication method.
According to the Pega Robotics System Design and Implementation Guide, section "Configuring Pega Server Connectivity":
"Server connectivity settings can be specified in multiple ways within Pega Robot Studio:
* During the initial installation process, when prompted to enter Robot Manager URL and credentials.
* By navigating to the Tools # Options # Server Connectivity menu to edit or test server details.
* By adjusting the Change Server fields that appear during the deployment process to override existing configurations.Manual editing of XML files is not recommended for changing server connectivity settings." Detailed Reasoning:
* A. Edit the Change Server fields during the deployment process - Correct. The deployment wizard allows adjusting or overriding existing server settings.
* B. Configure the server settings during the initial installation of Pega Robot Studio - Correct. The installation wizard prompts for server setup.
* C. Rerun the Pega Robot Studio installation and configure the server settings - Not necessary unless reinstallation is required.
* D. Manually edit the PegaStudioConfig.xml file - Not recommended or supported for changing connectivity.
* E. Edit the Server Connectivity settings in the Tools menu in Pega Robot Studio - Correct. This is the standard interface to modify or test connection settings.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Server Connectivity and Deployment Configuration section (Pega Robotics 19.1 and later).
NEW QUESTION # 58
Unattended automations, when run. follow a basic process flow. Arrange the following steps in the order in which unattended automation topic processes a case.
Retrieves the assignment from the queue.
Obtains the case data that is associated with the assignment.
Performs the specified automation task.
Sends the updated data, the assignment, and confirmation back to the case.
Retrieves the next assignment from the queue.
Unattended automations (also known as Robotic Process Automation (RPA)) are designed to work without human intervention. These automations process assignments or cases that are queued by Pega Platform and retrieved by robots through the Pega Robot Manager service.
According to the Pega Robotics System Design and Implementation Guide, in the section "Unattended Automation Workflow and Queue Processing", the following sequence defines how an unattended robot processes a work item:
"1. The robot retrieves an assignment from the work queue managed by Pega Robot Manager.
2. The robot then requests the case data associated with the assignment, which contains the necessary contextual information.
3. The robot performs the defined automation tasks within the target applications using the case data as input.
4. Upon completion, the robot updates the case, returns the assignment results, and confirms the completion to Pega Platform.
5. The robot then retrieves the next available assignment from the queue to continue processing." Detailed Step Reasoning:
* Retrieves the assignment from the queue - The robot begins by pulling a new assignment from the Pega Platform work queue through the Robot Manager interface.
* Obtains the case data that is associated with the assignment - After assignment retrieval, the robot obtains the case data (for example, customer details or transaction info) from the platform.
* Performs the specified automation task - The robot executes the defined automation using the fetched data, interacting with the necessary enterprise applications.
* Sends the updated data, the assignment, and confirmation back to the case - Once the task is complete, the robot posts the results and completion confirmation back to Pega Platform.
* Retrieves the next assignment from the queue - The cycle repeats as the robot moves to the next queued case or assignment.
This structured loop ensures consistent, unattended case handling by robotic workers, maintaining synchronization between Pega Platform and the robotic runtime environment.
Final Correct Order:
* Retrieves the assignment from the queue.
* Obtains the case data that is associated with the assignment.
* Performs the specified automation task.
* Sends the updated data, the assignment, and confirmation back to the case.
* Retrieves the next assignment from the queue.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Unattended Automations - Queue Processing and Workflow Lifecycle section (Pega Robotics 19.1 and later).
NEW QUESTION # 59
We can send you a link within 5 to 10 minutes after your payment. You can click on the link immediately to download our PEGACPRSA22V1 real exam, never delaying your valuable learning time. If you want time - saving and efficient learning, our PEGACPRSA22V1 Exam Questions are definitely your best choice. And if you buy our PEGACPRSA22V1 learning braindumps, you will be bound to pass for our PEGACPRSA22V1 study materials own the high pass rate as 98% to 100%.
New PEGACPRSA22V1 Exam Papers: https://www.validbraindumps.com/PEGACPRSA22V1-exam-prep.html
P.S. Free & New PEGACPRSA22V1 dumps are available on Google Drive shared by ValidBraindumps: https://drive.google.com/open?id=1qiUwkUaMjCerccHOnBLTPChIlNNdAjx_
Posted at 2/9/2026 03:53:29        Only Author  2#
Your article was truly enlightening and refreshing, thank you! The Reliable test dbt-Analytics-Engineering collection pdf material is top-notch, and I hope it assists you, with no cost involved.
Posted at 2/9/2026 14:34:03        Only Author  3#
Im truly inspired by what I read, thanks for sharing! Testing C_P2W12_2311 center gives you rich content for free, hoping it supports your learning journey.
Posted at 2/11/2026 23:46:16        Only Author  4#
Your article really opened my eyes, Im so grateful for it. Preparing for the F5CAB5 test labs exam. Wish me luck!
Posted at 3/6/2026 19:31:44        Only Author  5#
ҡPalo Alto NetworksXDR-AnalystԇY˜ʂ䤹뤪͘ˤXDR-Analyst}`ӥṩǤϲǤޤʤXDR-Analyst}֤ᡢҡXDR-Analyst}һgΟoϸ¤ṩޤҡΌTҤϥ`ˆ}¤Ƥޤһgǡ⤷¤顢¤XDR-Analyst}ԄӵĤˤʤΥ`륢ɥ쥹͸ޤʤΜȤϡҡФƤѥ`Ǥ
