[General] Pass Oracle 1z0-076 Exam in First Attempt Guaranteed!
98
General Pass Oracle 1z0-076 Exam in First Attempt Guaranteed!
Posted at 2/8/2026 18:58:25      View129 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of VCE4Dumps 1z0-076 dumps for free: https://drive.google.com/open?id=1eQLNVqoFtEunTudarUsbPqVmgHAEE7p5
This is where your 1z0-076 exam prep really takes off, in the testing your knowledge and ability to quickly come up with answers in the 1z0-076 online tests. Using 1z0-076 practice exams is an excellent way to increase response time and queue certain answers to common issues. Get 1z0-076 ebooks from VCE4Dumps which contain real 1z0-076 exam questions and answers. You will pass your 1z0-076 exam on the first attempt using only VCE4Dumps's 1z0-076 excellent preparation tools and tutorials
Oracle 1z0-076 Exam Syllabus Topics:
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
  • Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
  • Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
Topic 5
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
Topic 6
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Topic 7
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Topic 8
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
Valid Test 1z0-076 Tutorial | Exam 1z0-076 ObjectivesIf you are preparing for the practice exam, we can make sure that the 1z0-076 study materials from our company will be the best choice for you, and you cannot find the better study materials than our company. There are a lot of advantages of our 1z0-076 Study Materials, and then, I am going to introduce the special functions of our 1z0-076 study materials in detail to you. We are hopeful that you will like our products.
Oracle Database 19c: Data Guard Administration Sample Questions (Q59-Q64):NEW QUESTION # 59
Your current Data Guard environment consists of:
A primary database containing no abstract data types used for user tables.
Two separate remote physical standby databases used for reporting.
Examine these requirements for adding a new standby database to this Data Guard environment:
The new standby database must provide a disaster recovery solution.
There must be minimal additional performance overheads on the primary database.
The new standby database may require additional indexes and materialized views not present in the primary.
New tables or schemas may be required in the standby database that are not present in the primary.
What would you recommend to fulfill these requirements?
  • A. A physical standby database with asynchronous redo transport and Real-Time Query enabled.
  • B. A physical standby database with synchronous redo transport and Real-Time Query enabled.
  • C. A logical standby database with asynchronous redo transport and SQL apply on.
  • D. A logical standby database with synchronous redo transport and redo apply on.
  • E. A logical standby database with synchronous redo transport and SQL apply on.
NEW QUESTION # 60
Which two statements are true regarding asynchronous redo transport in a Data Guard
  • A. This transport mode satisfies the minimum requirements for Maximum Availability data protection mode.
  • B. Real-time query performance on a physical standby database improves for current read requests when using this transport mode.
  • C. This transport mode satisfies the minimum requirements for Maximum Performance data protection mode.
  • D. The performance of SQL apply on a logical standby database always improves when using this transport mode.
  • E. A transaction can commit without waiting for redo to be sent to any standby database in the data guard configuration.
Answer: C,E
Asynchronous redo transport is a method where the primary database does not wait for an acknowledgment from the standby database before committing transactions, which helps in minimizing the impact on the primary database's performance (B). This transport mode is associated with the Maximum Performance data protection mode, which prioritizes performance over synchronicity of data between the primary and standby databases (C). While it provides a level of data protection, there could be some data loss in the event of a primary database failure because redo data may not have been transmitted to the standby database at the time of the failure.
References:Oracle Data Guard Concepts and Administration documentation provides detailed explanations of different redo transport modes and their implications on data protection and performance. Asynchronous transport mode's behavior and association with Maximum Performance mode are outlined explicitly.
NEW QUESTION # 61
Which THREE statements are true about snapshot standby databases?
  • A. A snapshot standby database can have Real-Time apply enabled.
  • B. A snapshot standby database may be opened read-only.
  • C. FLASHBACK DATABASE is enabled automatically on a physical standby database as part of the conversion into a snapshot standby database, if not already enabled.
  • D. FLASHBACK DATABASE must be manually enabled on a physical standby database before converting it into a snapshot standby database.
  • E. FLASHBACK DATABASE is enabled automatically on a snapshot standby database after converting it from a physical standby database if not already enabled.
  • F. A snapshot standby database may be opened read-write.
Answer: C,E,F
Snapshot standby databases are a feature of Oracle Data Guard that allows a physical standby database to be temporarily converted into a read-write database for testing or other purposes. The true statements about snapshot standby databases are:
FLASHBACK DATABASE is enabled automatically on a snapshot standby database after converting it from a physical standby database if not already enabled (B): When a physical standby is converted to a snapshot standby, FLASHBACK DATABASE is automatically enabled to allow the database to be easily reverted back to its original state.
FLASHBACK DATABASE is enabled automatically on a physical standby database as part of the conversion into a snapshot standby database, if not already enabled (C): As part of the conversion process, FLASHBACK DATABASE is turned on to ensure that changes made while the database is in snapshot standby mode can be undone.
A snapshot standby database may be opened read-write (E): Once a physical standby is converted to a snapshot standby, it can be opened for read-write operations, allowing for testing and other tasks that require a writable database.
Oracle Database Backup and Recovery User's Guide
NEW QUESTION # 62
Which three are true regarding prerequisites for a logical standby database as a disaster recovery solution?
  • A. Ensure that flashback is enabled on the primary database.
  • B. Do not perform any nologging operations on the primary.
  • C. Ensure that no ROWID data types are contained in the primary database.
  • D. Ensure that no BFILE LOB data types are contained in the primary database.
  • E. Ensure that supplemental logging is enabled on the primary database.
Answer: B,D,E
NEW QUESTION # 63
Examine the procedure that you plan to execute on your logical standby:
SQL> EXECUTE DBMS_LOGSTDBY.SKIP(stmt => 'DML', schema_name => 'HR', object_name => 'EMPLOYEE'); What is a prerequisite for execution of this procedure?
  • A. Stop redo transport to the logical standby database.
  • B. Stop SQL Apply on the logical standby database.
  • C. Change the redo transport mode if necessary to ASYNC.
  • D. Execute the DBMS_LOGSTDBY.APPLY_SET procedure to record errors that might cause SQL Apply to stop.
NEW QUESTION # 64
With the number of people who take the exam increasing, the 1z0-076 exam has become more and more difficult for many people. A growing number of people have had difficulty in preparing for the 1z0-076 exam, and they have a tendency to turn to the study materials. However, a lot of people do not know how to choose the suitable study materials. We are willing to recommend the 1z0-076 Exam Questions from our company to you. We can make a promise to you that our study materials will be the best 1z0-076 study guide for you to prepare for your exam.
Valid Test 1z0-076 Tutorial: https://www.vce4dumps.com/1z0-076-valid-torrent.html
P.S. Free & New 1z0-076 dumps are available on Google Drive shared by VCE4Dumps: https://drive.google.com/open?id=1eQLNVqoFtEunTudarUsbPqVmgHAEE7p5
Posted at 3/8/2026 04:27:09        Only Author  2#
ExamPassdump 의 IT전문가들이 자신만의 경험과 끊임없는 노력으로 최고의  Salesforce EX-Con-101학습자료를 작성해 여러분들이Salesforce EX-Con-101시험에서 패스하도록 최선을 다하고 있습니다. 덤프는 최신 시험문제를 커버하고 있어 시험패스율이 높습니다. Salesforce EX-Con-101시험을 보기로 결심한 분은 가장 안전하고 가장 최신인 적중율 100%에 달하는Salesforce EX-Con-101시험대비덤프를 ExamPassdump에서 받을 수 있습니다.
