[Hardware] Study Plat-101 Dumps | Plat-101 Valid Dumps Ebook
92
【Hardware】 Study Plat-101 Dumps | Plat-101 Valid Dumps Ebook
Posted at 2/8/2026 21:06:48      View:197 | Replies:2        Print      Only Author   [Copy Link] 1#
Are you ready to gain all these Salesforce Plat-101 certification benefits? Looking for a simple, smart, and quick way to pass the challenging Salesforce Certified Platform Foundations exam? If your answer is yes then you need to enroll in the Plat-101 exam and prepare well to crack this Plat-101 Exam with good scores. In this career advancement journey, you can get help from Exams-boost. The Exams-boost will provide you with real, updated, and error-free Plat-101 Exam Dumps that will enable you to pass the final Salesforce Certified Platform Foundations exam easily.
Plat-101 certification can demonstrate your mastery of certain areas of knowledge, which is internationally recognized and accepted by the general public as a certification. Plat-101certification is so high that it is not easy to obtain it. It requires you to invest time and energy. If you are not sure whether you can strictly request yourself, our Plat-101 test materials can help you. With high pass rate of our Plat-101 exam questons as more than 98%, you will find that the Plat-101 exam is easy to pass.
Salesforce Plat-101 Valid Dumps Ebook | New Braindumps Plat-101 BookSometimes choice is greater than important. Good choice may do more with less. If you still worry about your exam, our Plat-101 braindump materials will be your right choice. Our exam braindumps materials have high pass rate. Most candidates purchase our products and will pass exam certainly. If you want to fail exam and feel depressed, our Plat-101 braindump materials can help you pass exam one-shot. Exams-boost sells high passing-rate preparation products before the real test for candidates.
Salesforce Plat-101 Exam Syllabus Topics:
  • Data Model: This section of the exam measures skills of Marketing Cloud Administrators and covers Salesforce’s data model. It involves understanding the relationship between core standard objects such as Accounts, Contacts, Leads, Opportunities, and Cases. The section also evaluates knowledge of ensuring data visibility through features and maintaining data integrity using the right tools in different business scenarios.
  • Reports & Dashboards: This section of the exam measures skills of Marketing Specialists and covers reporting and visualization in Salesforce. It includes describing how reports are built, how dashboards present insights, and how these tools help organizations monitor performance and make informed marketing decisions.
  • Navigation: This section of the exam measures the skills of Marketing Specialists and covers how users navigate Salesforce. It tests the ability to locate and access necessary information in given scenarios and to identify where different types of Salesforce customizations take place. The emphasis is on practical system navigation that supports marketing operations.
  • Salesforce Ecosystem: This section of the exam measures skills of Marketing Cloud Administrators and covers the overall Salesforce ecosystem. It focuses on understanding the different resources available for learning and skill development, recognizing how Salesforce Customer 360 products can be applied in real business use cases, and explaining how organizations make use of Salesforce in daily operations. It also highlights awareness of job roles and career opportunities within the Salesforce ecosystem.
Salesforce Certified Platform Foundations Sample Questions (Q67-Q72):NEW QUESTION # 67
A salesforce associate wants to retrieve a record for a business but only remembers a portion of the business name.
Using the fewest clicks, how should the associate search the account records for the desired business?
  • A. A report of all accounts
  • B. A list view of all accounts
  • C. The global Search box
Using the global search box is the best way to search the account records for the desired business using the fewest clicks. The global search box is a feature that allows the user to search for records across multiple objects and fields using keywords or phrases. The global search box also supports wildcards, operators, and filters to refine the search results. For example, the user could enter "Get*" in the global search box to find all account records that start with "Get". Using a list view of all accounts would not work, because a list view is a filtered set of records that display data in a tabular format. A list view does not support wildcards or operators, and it requires more clicks to apply filters and sort the records. Using a report of all accounts would not work, because a report is a tool that displays data from one or more objects in a tabular or graphical format. A report does not support wildcards or operators, and it requires more clicks to create, run, and filter the report.
NEW QUESTION # 68
A Salesforce associate wants to refresh a report and email it to an executive team each week.
Which functionality of Salesforce Reports should the associate use?
  • A. Notifications
  • B. Refresh
  • C. Subscriptions
The functionality of Salesforce Reports that the associate should use to refresh a report and email it to an executive team each week is subscriptions. Subscriptions let you schedule reports to run at regular intervals and send notifications to you or other recipients by email or Chatter5. You can also set conditions for when the notifications are sent, such as when the report returns no results or the results change.
NEW QUESTION # 69
Refer to the image below:
A Salesforce associate reviews a report that shows more information than they need. The associated see individual records but only wants to see the Record Count.
Which switches should the associated toggle to only show the Record Count?
  • A. Row Counts and Grand Total
  • B. Subtotals and Detail Rows
  • C. Grand Total and Subtotals
The switches that the associate should toggle to only show the Record Count are Row Counts and Grand Total. Row Counts is a switch that shows the number of rows in the report, which is the same as the number of records. Grand Total is a switch that shows the sum, average, minimum, maximum, or other aggregate functions of a numeric field in the report. By toggling these two switches on and the other two switches off, the associate can see the Record Count and the Grand Total of the report, without seeing the individual records or the subtotals. Subtotals and Detail Rows are switches that show the breakdown and the details of the records in the report, which are not needed for the Record Count.
NEW QUESTION # 70
An online retail company uses Sales Cloud and Marketing Cloud. The company's Salesforce associate needs help while working in Marketing Cloud and wants to hear other Salesforce professionals' opinions. They would like to post a question that anyone around the globe who is familiar with Salesforce can answer.
Which resource should they use?
  • A. Salesforce Help
  • B. Trailblazer Community
  • C. Trailhead Academy
The Trailblazer Community is the resource that the Salesforce associate should use to post a question that anyone around the globe who is familiar with Salesforce can answer. The Trailblazer Community is an online platform where Salesforce users, partners, employees, and experts can connect, collaborate, and learn from each other. The Trailblazer Community allows the user to ask questions, join groups, share ideas, access resources, and earn badges. Trailhead Academy is a resource that provides training courses, certifications, and learning paths for Salesforce users who want to enhance their skills and knowledge. Salesforce Help is a resource that provides documentation, guides, videos, and support for Salesforce users who need assistance with using or troubleshooting Salesforce products and features.
NEW QUESTION # 71
An organization wants to implement Salesforce into its business model. The requirements include:
* Operations management
* Program management
* Grantmaking
* Fundraising
* Marketing
* Engagement
Which cloud is preconfigured to handle all of these requirements7
  • A. Analytics
  • B. Nonprofit
  • C. Experience
The Nonprofit Cloud is the cloud that is preconfigured to handle all of the requirements listed. The Nonprofit Cloud is a set of products and solutions designed specifically for nonprofit organizations, such as operations management, program management, grantmaking, fundraising, marketing, and engagement. The Nonprofit Cloud includes the Nonprofit Success Pack (NPSP), which is a managed package that adds pre-built objects, fields, workflows, and reports to the standard Salesforce platform. The Analytics Cloud is a cloud that provides business intelligence and data visualization tools, such as Einstein Analytics and Tableau. The Experience Cloud is a cloud that allows the creation of digital experiences, such as websites, portals, and mobile apps, for customers, partners, and employees.
NEW QUESTION # 72
We provide the update freely of Plat-101 Exam Questions within one year and 50% discount benefits if buyers want to extend service warranty after one year. The old client enjoys some certain discount when buying other exam materials. We update the Plat-101 guide torrent frequently and provide you the latest study materials which reflect the latest trend in the theory and the practice. So you can master the Salesforce Certified Platform Foundations test guide well and pass the exam successfully. While you enjoy the benefits we bring you can pass the exam.
Plat-101 Valid Dumps Ebook: https://www.exams-boost.com/Plat-101-valid-materials.html
Posted at 3/7/2026 21:55:59        Only Author  2#
This article is nothing short of spectacular, thank you for sharing. Using the CRT-450 exam topics pdf, I achieved a promotion and salary raise. It’s now free to everyone. Wishing you all success in your career journey!
Posted at 4/20/2026 03:46:47        Only Author  3#
After reading this article, I have a more thorough understanding of the related topics. Best of luck! Here are the Generative-AI-Leader reliable real test resources, free for everyone!
