[Hardware] Related CDCP Certifications, CDCP Top Dumps
92
【Hardware】 Related CDCP Certifications, CDCP Top Dumps
Posted at 2/8/2026 21:38:49      View:122 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CDCP dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1ALFsGFmsXTlx95NYRy-KmXAalbBSp0w5
We provide the EXIN CDCP exam questions in a variety of formats, including a web-based practice test, desktop practice exam software, and downloadable PDF files. LatestCram provides proprietary preparation guides for the certification exam offered by the CDCP Exam Dumps. In addition to containing numerous questions similar to the CDCP exam, the Certified Data Centre Professional (CDCP) (CDCP) exam questions are a great way to prepare for the EXIN CDCP exam dumps.
As one of the leading brand in the market, our CDCP practice materials can be obtained on our website within five minutes. That is the expression of their efficiency. Their amazing quality can totally catch eyes of exam candidates with passing rate up to 98 to 100 percent. We have free demos for your information and the demos offer details of real exam contents. All contents of CDCP practice materials contain what need to be mastered.
CDCP Top Dumps - Valid Test CDCP ExperienceWe often regard learning for CDCP exam as a torture. Actually, learning also can become a pleasant process. With the development of technology, learning methods also take place great changes. With our CDCP study materials, all of your study can be completed on your computers because we have developed a kind of software which includes all the knowledge of the exam. The simulated and interactive learning environment of our CDCP Practice Engine will greatly arouse your learning interests.
EXIN CDCP Exam Syllabus Topics:
  • Equipment Racks: It discusses power rail
  • strip options, security considerations, and rack standards, properties and selection criteria.
  • Designing a Scalable Network Infrastructure: It covers ANSI
  • TIA-942 cabling hierarchy, network redundancy, structured Cabling System, and planning considerations.
  • Light: This topic covers light fixture types and placement, emergency lighting, and emergency Power Supply (EPS).
  • Raised Floor
  • Suspended Ceiling: The topic discusses applicable standards, signal reference grid, and disability act and regulations.
Topic 5
  • Cooling Infrastructure: The topic focuses on liquid immersion cooling, supplemental cooling options, sensible and latent heat definitions, and temperature and humidity recommendations.
Topic 6
  • Auxiliary Systems: The topic covers water leak detection systems, data centre monitoring requirements, EMS, BMS and DCIM.
EXIN Certified Data Centre Professional (CDCP) Sample Questions (Q45-Q50):NEW QUESTION # 45
is the degree to which a system or component is operational and accessibility when required for use.
  • A. Availability
  • B. Agility
  • C. Scalability
  • D. Reliability
Availability is the degree to which a system, product or component is operational and accessible when required for use. It is one of the attributes of reliability, which is the ability of a system or component to perform its required functions under stated conditions for a specified period of time. Availability can be calculated as the ratio of the expected value of the uptime (the time when the system is functional) to the total time (uptime plus downtime) of a system or component. Availability can also be influenced by factors such as maintainability, fault tolerance, redundancy, diagnostics, and logistics.
References: EPI Data Centre Professional (CDCP) Preparation Guide, page 8; Availability - Wikipedia; Reliability - ISO 25000.
NEW QUESTION # 46
What should be considered when implementing hot- or cold-aisle containment in an existing computer room?
  • A. It will be more difficult to install power and network cabling in the contained area.
  • B. The delta-T of the equipment will increase too much causing reliability issues.
  • C. It creates potential issues with the existing fire suppression system(s).
  • D. Equipment will get too hot at the rear (back) of the rack potentially resulting in more ICT hardware failures.
Hot- or cold-aisle containment is a strategy to improve the cooling efficiency and reduce the energy consumption of data centers by isolating the hot exhaust air from the cold supply air. However, implementing this strategy in an existing computer room may create potential issues with the existing fire suppression system(s), such as:
*The containment barriers may interfere with the distribution and activation of the fire suppression agents, such as water, gas, or aerosol, and reduce their effectiveness in extinguishing a fire.
*The containment barriers may create pockets of high temperature and pressure that could damage the equipment or the containment structure itself in the event of a fire.
*The containment barriers may obstruct the access and visibility of the fire detection and alarm devices, such as smoke detectors, heat sensors, or manual call points, and delay the response time of the fire suppression system(s).
*The containment barriers may violate the local fire codes and regulations that specify the minimum clearance and ventilation requirements for the data center.
Therefore, when implementing hot- or cold-aisle containment in an existing computer room, it is important to consider the impact on the existing fire suppression system(s) and take appropriate measures to ensure the safety and compliance of the data center, such as:
*Consulting with the fire authorities and the fire suppression system vendor to assess the compatibility and suitability of the containment solution with the existing fire suppression system(s).
*Modifying or upgrading the existing fire suppression system(s) to accommodate the containment solution, such as relocating or adding fire suppression devices, adjusting the discharge rate and pressure, or installing a secondary fire suppression system within the contained area.
*Installing fire-rated containment barriers that can withstand high temperatures and resist the spread of fire and smoke, and that have self-closing or automatic release mechanisms in case of a fire.
*Installing fire detection and alarm devices within the contained area and ensuring their proper integration and communication with the existing fire suppression system(s).
*Conducting regular testing and maintenance of the fire suppression system(s) and the containment solution to ensure their functionality and reliability.
References: EPI Data Centre Framework, Module 4: Fire Protection, page 10-11. EPI Data Centre Professional (CDCP®) Reference Materials, page 66-67. 1, 2, 3.
NEW QUESTION # 47
What is the minimum clearance space required below water sprinkler heads and nozzles of gas-based fire suppression systems?
  • A. 46 cm / 18 inches
  • B. 120 cm / 47 inches
  • C. 64 cm / 25 inches
  • D. 60 cm / 24 inches
The minimum clearance space required below water sprinkler heads and nozzles of gas-based fire suppression systems is 46 cm / 18 inches, according to the CDCP Preparation Guide1 and OSHA regulation 29 CFR
1910.159  (10)2. This clearance space is necessary to ensure that the sprinkler spray or gas discharge can reach the fire and cover the protected area effectively. Any material or obstruction below this clearance space can interfere with the sprinkler or gas distribution and reduce the fire suppression performance. Therefore, building owners and managers should ensure that all storage and objects in the data centre are kept below this clearance space, and that the clearance space is maintained at all times.
1: CDCP Preparation Guide, page 24, section 2.4.3 2: Clarification of OSHA regulation 29 CFR 1910.159 (10), Sprinkler ...3, page 1, section 1
NEW QUESTION # 48
Which Class of Fires involves cooking appliances?
  • A. Class B
  • B. Class K
  • C. Class A
  • D. Class C
According to the EPI Data Centre Professional (CDCP®) Preparation Guide, Class K fires involve cooking appliances that use combustible cooking media such as vegetable or animal oils and fats (page 28). Class K fires require special extinguishing agents that can suppress the high-temperature flames and prevent re-ignition. Class K fires are different from Class B fires, which involve flammable liquids such as gasoline, oil, or paint.
*EPI Data Centre Professional (CDCP®) Preparation Guide, page 28
*Fire Classes and Extinguishing Agents | The Fire Equipment Manufacturers' Association
NEW QUESTION # 49
Which one of the following does a Physical Infrastructure consists of in a Data Centre?
  • A. Rack
  • B. Server
  • C. Switch
  • D. Hub
A physical infrastructure in a Data Center consists of racks, which are metal frames used to store and organize server and other IT equipment. The racks are usually arranged in rows and columns, and they can be used to hold servers, storage devices, and other pieces of IT equipment. The racks can also be used to organize cables and other components to ensure that the Data Center is kept organized and efficient.
NEW QUESTION # 50
Our company never sets many restrictions to the CDCP exam question. Once you pay for our study materials, our system will automatically send you an email which includes the installation packages. You can conserve the CDCP real exam dumps after you have downloaded on your disk or documents. Whenever it is possible, you can begin your study as long as there has a computer. In addition, all installed CDCP study tool can be used normally. In a sense, our CDCP Real Exam dumps equal a mobile learning device. We are not just thinking about making money. Your convenience and demands also deserve our deep consideration. At the same time, your property rights never expire once you have paid for money. So the CDCP study tool can be reused after you have got the CDCP certificate. You can donate it to your classmates or friends. They will thank you so much.
CDCP Top Dumps: https://www.latestcram.com/CDCP-exam-cram-questions.html
BTW, DOWNLOAD part of LatestCram CDCP dumps from Cloud Storage: https://drive.google.com/open?id=1ALFsGFmsXTlx95NYRy-KmXAalbBSp0w5
