[Hardware] SAP C-THR96-2505 Exam Questions are Available in 3 Easy-to-Understand Formats
103
【Hardware】 SAP C-THR96-2505 Exam Questions are Available in 3 Easy-to-Understand Formats
Posted at 2/8/2026 22:09:24      View:125 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 SAP C-THR96-2505 dumps are available on Google Drive shared by BraindumpQuiz: https://drive.google.com/open?id=1wePKGLeFaXOfXS1VQIIdTo3ZRvLiKVuZ
Quality first, service second! We put much attention and resources on our products quality of C-THR96-2505 real questions so that our pass rate of the C-THR96-2505 training braindump is reaching as higher as 99.37%. As for service we introduce that "Pass Guaranteed". We believe one customer feel satisfied; the second customer will come soon for our C-THR96-2505 Study Guide. If you want to have a look at our C-THR96-2505 practice questions before your paymnet, you can just free download the demo to have a check on the web.
SAP C-THR96-2505 Exam Syllabus Topics:
  • Process Data and Hierarchies: This section of the exam measures skills of HR Data Specialists and focuses on the processes involved in validating and organizing data through hierarchies for clean and structured workforce analysis.
  • Metrics Pack Fundamentals: This section of the exam evaluates the ability of Analytics Consultants to work with pre-delivered metrics packs, focusing on their role in enabling standard KPI definitions and reporting frameworks in Workforce Analytics.
  • Metadata Framework (MDF) Fundamentals: This section of the exam measures skills of Analytics Consultants and covers the foundational understanding of Metadata Framework elements, including object definitions and the relationship between MDF and analytics structures.
  • SAP SuccessFactors Employee Central Fundamentals: This section of the exam assesses the knowledge of HR Data Specialists in understanding how Employee Central structures and employee data relate to and impact the setup of Workforce Analytics.
Topic 5
  • Build Validation and Data Validation: This section of the exam evaluates the ability of Analytics Consultants to implement build validations and data checks to ensure integrity, accuracy, and consistency of analytical outputs before go-live.
Topic 6
  • BI Fundamentals and Build Fact Tables: This section of the exam evaluates the ability of Analytics Consultants to apply business intelligence concepts when constructing fact tables, which serve as the basis for metric reporting in WFA.
Topic 7
  • This section of the exam measures skills of HR Data Specialists and covers the preconditions for a successful WFA on HANA implementation, including system readiness, integration points, and methodology phases.
Topic 8
  • Create Lookups and Events: This section of the exam measures skills of HR Data Specialists and includes configuring lookup tables and event types used to enrich data calculations and contextual reporting in the analytics solution.
Topic 9
  • SAP SuccessFactors Workforce Analytics on SAP HANA – Prerequisites and Implementation Methodology
Pass-Sure SAP - C-THR96-2505 - New SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Workforce Analytics Exam CramIf you buy C-THR96-2505 exam torrent online, you may have the concern of safety of your money, if you do have the concern like this, we will put your mind at rest. Since we apply the international recognition third party for C-THR96-2505 exam materials payment, and they are very safe. Your money and account will be very safe if you choose us. What’s more, we also pass guarantee and money back guarantee if you fail to pass the exam, and the money will be refunded to your payment account. If you have any questions about the C-THR96-2505 Exam Torrent, just contact us.
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Workforce Analytics Sample Questions (Q71-Q76):NEW QUESTION # 71
Which table requires values for the columns Event and Event Reason Icode?
  • A. Emp Job Info T
  • B. Emp Personal Info T
  • C. Emp Employment Info
  • D. Emp Paycomp Recurring T
NEW QUESTION # 72
What prerequisites must be met for a user to implement SAP SuccessFactors Workforce Analytics on SAP HANA? Note: There are 3 correct answe rs to this question.
  • A. The user has permission to access WFA on HANA Data Factory.
  • B. Single-sign on has been enabled in the instance.
  • C. SAP SuccessFactors Employee Central has been enabled in the instance.
  • D. The user has permission to upload SAP HANA templates.
  • E. Advanced Reporting has been enabled in the instance.
Answer: C,D,E
NEW QUESTION # 73
How do you validate the value of a local salary that has been converted to the unified target currency for the Annual Salary calculated column? Note: There are 3 correct answe rs to this question.
  • A. Temporarily disable Role-Based Permissions for the data required to build the base input measure.
  • B. Create two calculated columns: one for local salary figure, the other for local currency type, and add them into Drill to Detail.
  • C. Add all fields used in the Annual Salary calculation syntax into Drill to Detail.
  • D. Use Drill to Detail to compare source and target salary figures and currencies.
  • E. Create two calculated columns: one for converted target salary figure, the other for target currency type, and add them into Drill to Detail.
Answer: B,D,E
NEW QUESTION # 74
What are Derived Input Measures?
  • A. Calculations of Base Input Measures and Derived Input Measures combined in formulas
  • B. Breakdowns of measure values across administrative and geographic structures
  • C. Input of Derived or Result Measures that are NOT displayed in the Measures tab of the Workforce Analytics portal
  • D. Base Input Measures filtered by Dimensions
NEW QUESTION # 75
Consider the following scenario: EOP headcount has Age, Disability, EEO Job Category, Employment Level, and Employment Status dimensions turned on. SOP headcount has Age and EEO Job Category dimensions turned on. Average headcount has Gender and Future Leader dimensions turned on. Hires has Age, Disability, EEO Job Category, Employment Level, and Employment Status dimensions turned on. Terminations has Age, Disability, EEO Job Category, Employment Level, and Employment Status dimensions turned on. You are required to perform the following task: Turn on Age, Disability, EEO Job Category, Employment Level, Employment Status and Gender dimensions on for EOP Headcount, SOP Headcount, and Average Headcount. How would you complete this task? Note: There are 2 correct answe rs to this question.
  • A. Select each measure listed above and turn on the missing dimensions respectively.
  • B. Select each required dimension listed above and turn on the missing measures respectively.
  • C. Select EOP Headcount, SOP Headcount, and Average Headcount at the same time, then turn on the above dimensions in bulk.
  • D. Select EOP Headcount and turn on the missing dimensions. Use the Mirror Dimension function to replicate dimensions to both SOP Headcount and Average Headcount.
NEW QUESTION # 76
Exam candidates grow as the coming of the exam. Most of them have little ideas about how to deal with it. Or think of it as a time-consuming, tiring and challenging task to cope with C-THR96-2505 exam questions. So this challenge terrifies many people. Perplexed by the issue right now like others? Actually, your anxiety is natural, to ease your natural fear of the C-THR96-2505 Exam, we provide you our C-THR96-2505 study materials an opportunity to integrate your knowledge and skills to fix this problem.
C-THR96-2505 Paper: https://www.braindumpquiz.com/C-THR96-2505-exam-material.html
What's more, part of that BraindumpQuiz C-THR96-2505 dumps now are free: https://drive.google.com/open?id=1wePKGLeFaXOfXS1VQIIdTo3ZRvLiKVuZ
Posted at 2/23/2026 19:44:20        Only Author  2#
It was an article full of wisdom and insights. Construction-Manager latest braindumps files helped me achieve a promotion and salary boost. Get it for free today!
