[General] New MB-820 Test Testking - Certification MB-820 Training
127
【General】 New MB-820 Test Testking - Certification MB-820 Training
Posted at 2/9/2026 00:30:40      View:127 | Replies:4        Print      Only Author   [Copy Link] 1#
2026 Latest DumpTorrent MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1UrJ-K9tJwgEmhZtqBIwGo4VekIhTvwvt
Our to-the-point and trustworthy Microsoft MB-820 Exam Questions in three formats for the Microsoft MB-820 certification exam will surely assist you to qualify for Microsoft Dynamics 365 Business Central Developer certification. Do not underestimate the value of our Microsoft MB-820 Exam Dumps because it is the make-or-break point of your career.
Microsoft MB-820 Exam Syllabus Topics:
  • Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic.  It also explains implementation of APIs.
  • Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
  • Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
Pass Guaranteed Quiz Microsoft MB-820 - Marvelous New Microsoft Dynamics 365 Business Central Developer Test TestkingReal Microsoft MB-820 test questions provide the necessary knowledge and skills to clear the test in a short time. When applicants don't prepare with the latest Microsoft Dynamics 365 Business Central Developer (MB-820) exam questions they fail and lose money. DumpTorrent provides valid MB-820 practice test material for applicants who want to pass the MB-820 exam quickly.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q16-Q21):NEW QUESTION # 16
You need to create the Install codeunit that is requited in the extension used for installing or updating the Housekeeping app.
Which data type or declaration should you use? To answer, select the appropriate options in the answer area.
NOTE; Each correct selection is worth one point.
For the Install codeunit required for the extension used for installing or updating the Housekeeping app, you should use the following data type and declaration:
* Data type for information: ModuleInfo
* Start of the declaration of the method or procedure to perform the tasks: local procedure In AL language, which is used for developing extensions in Business Central, an Install codeunit is a special type of codeunit that is used to handle installation or upgrade logic for an extension.
* ModuleInfo is a data type that contains information about the current extension, such as its version. It is typically used within the OnInstallAppPerCompany or OnUpgradePerCompany triggers of an Install codeunit to determine if the app is being installed for the first time or upgraded.
* A local procedure within an Install codeunit is a method that is only accessible within the codeunit itself. It is not visible to other objects or extensions. This is suitable for tasks that are internal to the installation process and should not be exposed globally.
These selections align with the requirements of handling installation and update procedures in a controlled and encapsulated manner within Business Central extensions.
Topic 1, Case Study Alpine Ski House
Alpine Ski House is a company that owns and operates hotels, restaurants, and stores. Currently, the company uses the following software and interlace:
* Property management software (PMS) to manage hotel rooms
* On-premises accounting software to generate sales invoices and create purchase orders
* An API that allows restaurants and stores to obtain necessary information Restaurants and stores use standalone software for point of sale (POS) devices. Each day, the POS terminals generate a text file of sales data and save the files in a serval folder. An account assistant must manually import the files to the current software tables to be processed by the system.
The general manager receives several reports monthly from department managers. The reports take too much time to prepare.
The company is moving from a different system to Business Central online to manage the whole company.
The company plans to increase efficiency in every department by using APIs to obtain or share information between the different systems.
Each department involved in purchasing must be able to make purchase requests automatically and easily.
The departments do not need access to the full ERP management system.
Alpine Ski House requires the development of several extensions for the planned improvements. Business Central design patterns must be used to develop all extensions.
Alpine Ski House must develop the following pages:
* Pages that provide multiple configurations in a multistep dialog, like a wizard, to provide required information when the extensions are first installed
* Department-specific Role Center pages to show relevant information and pages with additional information The IT department plans to use Power 61 to analyze departmental information. The database must be configured to provide optimal performance.
The housekeeping department requires the following to increase efficiency and help avoid data entry errors:
* A Housekeeping Role Center to minimize navigation to relevant areas In Business Central online and to show relevant information in it
* Pages to embed into a new Room page to show additional information about the Room entity
* A table named Room Incident for the housekeeping team to enter room issue information
* A Housekeeping canvas app that connects to an extension
The department requires the development of an extension with a new API page named RoomsAPI.
* The housekeeping team will use RoomsAPI to publish room details, update when work is complete, or provide repair notifications from the canvas app.
* This custom API page must expose a custom table named Rooms and have an ID 50000. The table must be able to update from the PMS. The PMS team must know the end to connect to the custom API.
* A developer provides the following details for the API page:
APIPublisher = 'alpine';
APIGroup - 'integration';
APIVersion - 'v2.6';
fntityName # 'room';
EntitySetName = 'rooms';
* The extension must be published in Business Central online and include a list page named Room List that includes all hotel rooms.
* Installation or updates to this extension must meet the following requirements:
o Some web services must be published automatically.
o The version of the specified application's metadata must be obtained in AL language.
o The code required to perform tasks cannot be accessible from other parts of the application.
The Room Incident table information must include the following fields:
* Incident entry: An incremental number
* Room No.: A room from the Room table
* Incident Date: The work date
o The table definition in the Room Incident table must autofill the Incident Date when the housekeeping team inserts a new record, o The value for Incident Date must be the work date configured in the Business Central online client.
* Status: Includes the following options lo identify the status of the incident:
o Open: When the Room Incident is created
o In Progress: When someone starts repair work
o Closed: When the incident is solved
* Incident Closing Date: Auto-updating field (when the status passes to Closed, the field will update with the work date)
* Incident Description: Text
* Image. Media data type
o The stored picture must be downloadable from a menu action.
o A Room Incident page must be developed to contain the download action.
To increase efficiency, the new system must manage the generated data from the restaurants and stores directly by using the API on the POS terminals.
* The company requires a code unit called from a job queue to read the information from the POS terminal APIs.
* The POS terminal information must be stored in a table named POS Information, have an ID 50100. and be editable on a page.
* The account manager requires an option on the menu of the page to run the process manually.
To analyze the information received from the POS terminals, the company requires:
* A custom API named ticketAPI to export the information to Power BI
* Use of the Read Scale-Out feature to improve database performance
The purchasing department requites a new entity in Business Central online to log non-conformities of goods received from vendors. The entity must be set up as follows:
* The non-conformity entity must have two tables:
o a header with common information
o one or more lines with the detailed received items that are non-conforming
* The entity requires a page named Non-conformity and a subpage named Non-Conformity Lines to store the information.
When a purchase order with incorrect quantity 01 quality issues is received, the entity must create a non- conformity document in the system. The following information must be nick the document:
* Non-conformity Number: must use the No. Series table from Business Central online to manage this field and use these features:
o Alphanumeric values
o Number format that includes "NO and the year as part of the number: for example, NC24-001
* Non-conformity Date: stores only the creation date
* Vendor No.: stores the number of the vendor that sent the items; only vendors from the company must be included
* Owner: code of an employee defined in the company
* Receipt No.: must meet the following conditions:
o Be an existing receipt No.
o Be received from the vendor indicated in the Vendor No. field
* Comments: can include comments with rich text and pictures to illustrate quality problems
* Status: includes nonconformity statuses, such as:
o Open
o Notified
o Closed
* Lines must contain the following details:
o Item No.: item received (for existing inventory items only)
o Description: item description
0 Quantity: non-conforming quantity
0 Non-conformity Type:
# Quality
# Quantity
# Delivery date
The serial numbers of the non-conformities and the period in which they can be created must be in a configuration table and its corresponding page to allow them to be modified for the users.
NEW QUESTION # 17
A company plans to import and export data with Business Central
You must configure an XMLport that provides the following implementation;
* Specifies import 01 export on the Request page at run time
* Formats the data in a non-fixed length CSV format
You need to create the XMLport.
How should you complete the code segment' To answer, select the appropriate options in the answer area.
NEW QUESTION # 18
A company is setting up a sandbox environment.
You observe the following issues in Visual Studio Code:
* When you open the User Settings window, no AL command is available
* In the Problems tab. the error 'The target page Customer List for the extension object is not found' is displayed.
You need to identify a solution for each issue.
Which solutions should you use? To answer, select the appropriate options in the answer area.
No AL command in User Settings:The correct solution is to Install the AL Language extension.
* This issue arises when the AL Language extension is not installed in Visual Studio Code, which is required to work with AL projects in Business Central.
Error in the Problems tab:The correct solution is to Download Symbols.
* This error typically occurs when the symbols (metadata for pages, tables, etc.) are not downloaded, and Visual Studio Code cannot resolve the reference to the Customer List page. Downloading symbols should fix the problem.
NEW QUESTION # 19
You create the following Vendor table and Item table in Business Central.
You require the following data set to assign vendors to items.
You need to create a query to assign the vendors.
Which three code blocks should you use to develop the solution? To answer, move the appropriate code blocks from the list of code blocks to the answer area and arrange them in the correct order.
NOTE: More than one order of answer choices is correct. You will receive credit for any of the correct orders you select.
dataitem(Item; Item)
SqlJoinType = InnerJoin;
DataItemLink = "Vendor No." = Vendor.Vendor_No;
NEW QUESTION # 20
You need to create the Fabrikam Vendor API for the accounting department.
How should you complete the code segment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 21
Our MB-820 practice materials are suitable for exam candidates of different degrees, which are compatible whichever level of knowledge you are in this area. These MB-820 training materials win honor for our company, and we treat MB-820 test engine as our utmost privilege to help you achieve your goal. Meanwhile, you cannot divorce theory from practice, but do not worry about it, we have stimulation MB-820 Test Questions for you, and you can both learn and practice at the same time.
Certification MB-820 Training: https://www.dumptorrent.com/MB-820-braindumps-torrent.html
BONUS!!! Download part of DumpTorrent MB-820 dumps for free: https://drive.google.com/open?id=1UrJ-K9tJwgEmhZtqBIwGo4VekIhTvwvt
Posted at 2/9/2026 13:44:33        Only Author  2#
I’m very grateful for your article, it really caught my attention. Free D-ECS-DY-23 reliable braindumps files available for boosting your IT skills. Wishing you success!
Posted at 2/14/2026 15:02:47        Only Author  3#
Liking this content without any hesitation. Wishing you success! Here are the free High CDCS quality resources for you!
Posted at 3/5/2026 21:17:58        Only Author  4#
I really appreciate your article, it left a strong impression. Here’s the SSM test book exam that was part of my promotion and pay raise—now shared with you for free today. Wishing you all success in your career paths!
Posted at 3/7/2026 03:45:40        Only Author  5#
Your article is brilliant, thank you for sharing! I owe my promotion and raise to the Exam LEED-Green-Associate collection pdf questions, and today I’m sharing them for free with all of you!
